TP9001-18S5
TP9001-18S5
    TECHPUBLIC(台舟)
    SOT23-5
    1.8V 500MA 7V
TP9001-18S5 数据手册
TP90 0 1 Series 500 0 mA H igt PSRR Voltage Reaulators www.sot23.com.tw The TP9001 is available in 5pin SOT23-5 Package .the The TP9001 is a high-performance, 500mA LDO regulator, offering extremely high PSRR and ultra-low dropout. Ideal for portable RF and wireless applications with demanding performance and space requirements. output standards of 1.2V 1.5V 1.8V 2.5V 2.8V 3.0V 3.3V Quiescent Current: 60uA  CDM/GSM mobile phone  PSRR:75dB@1KHz  PDAs /MP3  < 1uA current at shutdown mode  Audio/Video equipment  Output voltage accuracy: tolerance ±2%  Output current:500mA(Typ.)  SOT23 -5 package BL PU Ordering Information IC  S5:SOT23-5 Package TE CH TP900 0 1-12S5  Output voltage: 33=3.3V 28=2.8V 30=3.0V 18=1.8V 12=1.2V XX=X.XV 1 . TP90 0 1 Series 500 0 mA H igt PSRR Voltage Reaulators www.sot23.com.tw CH PU BL IC BLOCK DIAGRAM TE PIN CONFIGURATION VOUT CE SOT23-5 2 Pin Name Function VIN Supply power GND Ground CE Enable pin NC NC VOUT Voltage output TP90 0 1 Series 500 0 mA H igt PSRR Voltage Reaulators www.sot23.com.tw Absolute Maximum Rating ( TA=25°C Parameter unless otherwise noted) Symbol Input Voltage VIN Output Voltage VOUT Output Current Iout Maximum Rating 7 mA 600 SOT-23-5 250 Operating Ambient Temperature Topr -40~+85 Storage Temperature Tstg -40~+125 Electrical Characteristics V VSS-0.3~VIN+0.3 PD Power Dissipation Unit mW °C ( T =25°C unless otherwise noted) O (Vin=Vout+1V,Cin=Cout=1uF,Ta=25 C) CONDITIONS Output Voltage VOUT(E) (Note 2) IOUT=40mA, VIN=Vout+1V Input Voltage VIN Supply Current Standby Current X 0.98 VOUT (T) (Note 1) MAX UNITS X 1.02 V 7.0 V 500 mA VCE VIN=Vout+1V 1.1 V ∆VOUT VIN=Vout+1V, 1mA≤IOUT≤100mA IOUT =100mA IOUT =200mA 50 mV 100 300 mV mV Vdif1 Vdif2 PU VIN=Vout+1V ISS VIN=Vout+1V 60 μA ICEL Vce=0V 1 μA IOUT =40mA Vout+1V ≤VIN≤8V 0.03 %/V 50 uVrms 70 dB ∆VOUT ∆VIN • VOUT Output Noise en TE Line Regulation Ripple Rejection Rate TYP IOUTmax CH Max. Output Current CE Enable Voltage Load Regulation Dropout Voltage (Note 3) MIN IC SYMBOL BL PARAMETER PSRR IOUT =40mA, 300Hz~50kHz Vin= [Vout+1]V +1Vp-pAC IOUT =40mA,f=1kHz 3 TP90 0 1 Series 500 0 mA H igt PSRR Voltage Reaulators www.sot23.com.tw TYPICAL APPLICATION VIN VOUT VIN CIN 1uF VOUT COUT 1uF TE CH PU BL GND IC CE 4 TP90 0 1 Series 500 0 mA H igt PSRR Voltage Reaulators www.sot23.com.tw Package informantion TE CH PU BL IC SOT23-5 5
TP9001-18S5 价格&库存
很抱歉,暂时无法提供与“TP9001-18S5”相匹配的价格&库存,您可以联系我们找货
