MMBF2202PT1G
www.VBsemi.com
P-Channel 20 V (D-S) MOSFET
FEATURES
PRODUCT SUMMARY
VDS (V)
- 20
RDS(on) ()
ID (A)c
0.080 at VGS = - 4.5 V
- 3.1
0.100 at VGS = - 2.5 V
- 2.3
• Halogen-free According to IEC 61249-2-21
Definition
• TrenchFET® Power MOSFET
• 100 % Rg Tested
• Compliant to RoHS Directive 2002/95/EC
Qg (Typ.)
4.3 nC
APPLICATIONS
• Load Switch
• DC/DC Converters
S
SOT-323
SC-70
G
1
G
3
S
D
2
D
Top View
P-Channel MOSFET
ABSOLUTE MAXIMUM RATINGS (TA = 25 °C, unless otherwise noted)
Parameter
Symbol
Limit
Drain-Source Voltage
VDS
- 20
Gate-Source Voltage
VGS
± 12
Continuous Drain Current (TJ = 150 °C)
TC = 25 °C
- 3.1
TC = 70 °C
- 2.1
TA = 25 °C
ID
IDM
Pulsed Drain Current
Continuous Source-Drain Diode Current
TC = 25 °C
TA = 25 °C
IS
TC = 25 °C
Maximum Power Dissipation
TC = 70 °C
TA = 25 °C
Soldering Recommendations (Peak Temperature)
A
-6
- 0.4
- 0.3
0.5
PD
0.3
0.4a, b
W
0.3a, b
TA = 70 °C
Operating Junction and Storage Temperature Range
V
- 1.4a, b
- 1.1a, b
TA = 70 °C
Unit
TJ, Tstg
- 50 to 150
260
°C
Notes:
a. Surface mounted on 1" x 1" FR4 board.
b. t = 10 s.
c. Based on TC = 25 °C.
服务热线:400-655-8788
1
MMBF2202PT1G
www.VBsemi.com
THERMAL RESISTANCE RATINGS
Parameter
Maximum Junction-to-Ambienta, b
Maximum Junction-to-Foot (Drain)
Notes:
b. Maximum under steady state conditions is 360 °C/W.
Symbol
Typical
Maximum
t 10 s
RthJA
250
300
Steady State
RthJF
225
270
Unit
°C/W
SPECIFICATIONS (TJ = 25 °C, unless otherwise noted)
Parameter
Static
Drain-Source Breakdown Voltage
Test Conditions
Min.
VDS
VGS = 0 V, ID = - 250 µA
- 20
VDS/TJ
VDS Temperature Coefficient
VGS(th) Temperature Coefficient
Gate-Source Threshold Voltage
Symbol
VGS(th)/TJ
ID = - 250 µA
VGS(th)
VDS = VGS, ID = - 250 µA
Gate-Source Leakage
IGSS
VDS = 0 V, VGS = ± 8 V
Zero Gate Voltage Drain Current
IDSS
a
On-State Drain Current
Drain-Source On-State Resistancea
ID(on)
RDS(on)
Forward Transconductancea
Dynamicb
gfs
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Gate Resistance
Rg
Turn-On Delay Time
Rise Time
Turn-Off DelayTime
Fall Time
Turn-On Delay Time
Rise Time
Turn-Off DelayTime
Fall Time
Drain-Source Body Diode Characteristics
tr
Max.
mV/°C
2.4
- 0.45
- 1.5
V
± 100
nA
VDS = - 20 V, VGS = 0 V
-1
- 10
VDS - 5 V, VGS = - 4.5 V
-2
0.080
VGS = - 2.5 V, ID = - 1.2 A
0.120
VGS = - 1.8 V, ID = - 0.3 A
0.140
VDS = - 5 V, ID = - 1.4 A
5
S
272
VDS = - 10 V, VGS = 0 V, f = 1 MHz
55
pF
44
VDS = - 10 V, VGS = - 4.5 V, ID = - 1.4 A
VDS = - 10 V, VGS = - 2.5 V, ID = - 1.4 A
4.3
6.5
2.7
4.1
0.7
VDD = - 10 V, RL = 9.1
ID - 1.1 A, VGEN = - 4.5 V, Rg = 1
1.4
7
14
12
35
9
18
td(on)
5
10
10
ID - 1.1 A, VGEN = - 8 V, Rg = 1
tf
IS
Pulse Diode Forward Currenta
ISM
Body Diode Voltage
VSD
Body Diode Reverse Recovery Time
trr
Body Diode Reverse Recovery Charge
Qrr
Reverse Recovery Fall Time
ta
Reverse Recovery Rise Time
tb
Notes:
a. Pulse test; pulse width 300 µs, duty cycle 2 %.
b. Guaranteed by design, not subject to production testing.
nC
1.0
f = 1 MHz
tf
tr
µA
A
23
td(off)
Unit
V
- 14
VDS = - 20 V, VGS = 0 V, TJ = 55 °C
td(on)
td(off)
Typ.
18
27
7
14
- 2.4
TC = 25 °C
-6
IF = - 0.7 A
IF = - 0.7 A, dI/dt = 100 A/µs, TJ = 25 °C
ns
A
- 0.8
- 1.2
V
18
27
ns
7
14
nC
7
11
ns
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation
of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum
rating conditions for extended periods may affect device reliability.
服务热线:400-655-8788
2
MMBF2202PT1G
www.VBsemi.com
TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted)
6.0
1.0
V GS = 5 V th r u 3 V
V GS = 2 . 5 V
0.8
ID - Drain Current (A)
4.5
V GS = 2V
3.0
V GS = 1.5 V
0.6
0.4
T C = 25 °C
1.5
0.2
T C = 125 °C
V GS = 1 V
0.0
0.0
0.5
1.0
1.5
2.0
0.3
0.6
0.9
1.2
VDS - Drain-to-Source Voltage (V)
VGS - Gate-to-Source Voltage (V)
Output Characteristics
Transfer Characteristics
0.15
1.5
600
0.13
V GS = 1.8 V
450
C - Capacitance (pF)
RDS(on) - On-Resistance (Ω)
T C = - 55 °C
0.0
0.0
0.11
V GS = 2.5 V
0.09
V GS = 4.5 V
Ciss
300
150
0.07
Coss
Crss
0.05
1.5
3.0
4.5
5
15
Capacitance
On-Resistance vs. Drain Current
1.5
4.5
ID = 1.4 A
1.4
ID = 1.4 A
V GS = 2.5 V
3.6
V DS = 10 V
2.7
V DS = 5 V
V DS = 16 V
1.8
1.3
(Normalized)
10
V GS = 4.5 V
1.2
1.1
1.0
0.9
0.9
0.8
0.0
2
3
4
5
0.7
- 50
- 25
50
75
100
125
Qg - Total Gate Charge (nC)
TJ - Junction Temperature (°C)
Gate Charge
On-Resistance vs. Junction Temperature
150
服务热线:400-655-8788
3
MMBF2202PT1G
www.VBsemi.com
0.32
ID = 1.4 A
T J = 150 °C
IS - Source Current (A)
10
T J = 25 °C
1
0.24
T J = 125 °C
0.16
T J = 25 °C
0.08
0.00
0.1
0.3
0.0
0.6
0.9
1.2
1
1.5
2
4
3
5
VSD - Source-to-Drain Voltage (V)
Source-Drain Diode Forward Voltage
On-Resistance vs. Gate-to-Source Voltage
0.75
10
0.65
8
0.55
Power (W)
VGS(th) (V)
ID = 250 μA
0.45
0.35
0.25
- 50
6
4
2
- 25
50
75
100
125
150
0.01
0.1
1
10
100
Time (s)
TJ - Temperature (°C)
Single Pulse Power, Junction-to-Ambient
Threshold Voltage
10
Limited by RDS(on)*
100 μs
1
1 ms
10 ms
0.1
TA = 25 °C
Single Pulse
100 ms
BVDSS Limited
0.01
0.1
1s
10 s, DC
100
1
10
* VGS > minimum VGS at which RDS(on) is specified
Safe Operating Area, Junction-to-Ambient
服务热线:400-655-8788
4
MMBF2202PT1G
www.VBsemi.com
1.6
1.2
0.8
0.4
0.0
25
75
100
125
150
TC - Case Temperature (°C)
Current Derating*
0.6
0.45
0.5
0.36
Power (W)
Power (W)
0.4
0.3
0.27
0.18
0.2
0.09
0.1
0.0
0.00
50
75
100
125
150
50
75
100
125
TA - Ambient Temperature (°C)
Power, Junction-to-Case
150
* The power dissipation PD is based on TJ(max) = 150 °C, using junction-to-case thermal resistance, and is more useful in settling the upper
dissipation limit for cases where additional heatsinking is used. It is used to determine the current rating, when this rating falls below the package
limit.
服务热线:400-655-8788
5
MMBF2202PT1G
www.VBsemi.com
1
Normalized Effective Transient
Thermal Impedance
Duty Cycle = 0.5
0.2
0.1
Notes:
0.05
PDM
0.1
t1
0.02
t2
1. Duty Cycle, D =
t1
t2
2. Per Unit Base = R thJA = 360 °C/W
3. T JM - T A = PDMZthJA(t)
Single Pulse
0.01
10 -4
4. Surface Mounted
10 -3
10 -2
10 -1
1
100
10
1000
Square Wave Pulse Duration (s)
Normalized Thermal Transient Impedance, Junction-to-Ambient
1
Thermal Impedance
Duty Cycle = 0.5
0.2
0.1
0.1
0.05
0.02
Single Pulse
0.01
10 -4
10 -3
10 -2
10 -1
1
10
Normalized Thermal Transient Impedance, Junction-to-Foot
服务热线:400-655-8788
6
MMBF2202PT1G
SCĆ70:
www.VBsemi.com
3ĆLEADS
MILLIMETERS
3
E1 E
1
2
e
b
e1
D
c
A2
A
L
0.08
c
A1
Dim
A
A1
A2
b
c
D
E
E1
e
e1
L
INCHES
Min
Nom
Max
Min
Nom
Max
0.90
1.10
0.035
0.043
0.10
0.004
0.80
1.00
0.031
0.039
0.25
0.40
0.010
0.016
0.10
0.25
0.004
0.010
1.80
2.00
2.20
0.071
0.079
0.087
1.80
2.10
2.40
0.071
0.083
0.094
1.15
1.25
1.35
0.045
0.049
0.053
0.65BSC
0.026BSC
1.20
1.30
1.40
0.047
0.051
0.055
0.10
0.20
0.30
0.004
0.008
0.012
7_Nom
7_Nom
ECN: S-03946—Rev. C, 09-Jul-01
DWG: 5549
服务热线:400-655-8788
7
MMBF2202PT1G
www.VBsemi.com
0.045
(1.143)
(0.648)
0.022
(0.559)
0.026
0.025
(0.622)
(2.438)
0.096
RECOMMENDED MINIMUM PADS FOR SC-70: 3-Lead
0.027
(0.686)
0.071
(1.803)
Recommended Minimum Pads
Dimensions in Inches/(mm)
服务热线:400-655-8788
8
MMBF2202PT1G
www.VBsemi.com
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to the
product.(www.VBsemi.com)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability,
including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
RoHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
