TP2301-TR
TP2301-TR
    3PEAK(思瑞浦)
    SOT23-5
    运算放大器 SOT23-5
TP2301-TR 数据手册
3PEAK TP2301/TP2302 /TP2304 20MHz Bandwidth, Low Noise High Precision Op-amps Features Description ◼ Gain-bandwidth Product: 20MHz ◼ Offset Voltage: 50 μV (max) ◼ Low Noise: 7.3nV/√Hz(f= 1kHz) ◼ Slew Rate: 25 V/μs ◼ Low THD+N: 0.0005% ◼ Supply Range: 2.2V to 5.5V ◼ Supply Current: 3.5 mA/ch The TP2301 series products are very high precision amplifiers featuring very low noise, low offset voltage, high bandwidth, low input bias current and low temperature drift making them the ideal choice for applications requiring both high DC accuracy and AC performance. The combination of precision, low noise, and high bandwidth provides the user with outstanding value and flexibility relative to similar competitive parts. ◼ Low Input Bias Current: 0.3pA Typical ◼ Rail-to-Rail I/O ◼ High Output Current: 70mA (1.0V Drop) ◼ –40°C to 125°C Operation Range Applications for these amplifiers include precision active filters, medical and analytical instrumentation, precision power supply controls, and industrial controls requiring high gains. Featuring low THD+N, the TP2301 series is also excellent for consumer audio applications, particularly for single-supply systems. The TP2301 is single channel version available in 8-pin SOIC and 5-pin SOT23 packages. The TP2302 is dual channel version available in 8-pin SOIC and MSOP packages. The TP2304 is quad channel version available in 14-pin SOP and TSSOP packages. Applications ⚫ Sensor Signal Conditioning ⚫ Consumer Audio ⚫ Multi-Pole Active Filters ⚫ Control-Loop Amplifiers ⚫ Communications ⚫ Security ⚫ Scanners 3PEAK and the 3PEAK logo are registered trademarks of 3PEAK INCORPORATED. All other trademarks are the property of their respective owners. Pin Configuration (Top View) Positive Output Swing vs. Load Current TP2302 8-Pin SOIC/MSOP (-S Suffix) (-S and -V Suffixes) NC 1 8 NC Out A 1 ﹣In 2 7 ﹢Vs ﹣In A 2 ﹢In 3 6 Out ﹢In A 3 ﹣Vs 4 5 NC ﹣Vs 4 +In 7 Out B 6 ﹣In B 5 ﹢In B (-T Suffix) (-S and -T Suffixes) 2 ﹣In A 2 3 ﹢In A 3 ﹢Vs 4 ﹢In B 5 ﹣Vs ﹢Vs TP2304 14-Pin SOIC/TSSOP 1 1 B 8 TP2301 5-Pin SOT23 Out A Out A 5 ﹢Vs A 4 -In B www.3peak.com 6 T=-40℃ 5 T=25℃ T=130℃ 4 Vdrop(V) TP2301 8-Pin SOIC 3 2 14 Out D 13 ﹣In D 12 ﹢In D 11 ﹣Vs 10 ﹢In C D 1 0 0 0.05 0.1 0.15 0.2 I source(A) C ﹣In B 6 9 ﹣In C Out B 7 8 Out C Rev. A.5 1 TP2301 / TP2302 / TP2304 20MHz Bandwidth, Low Noise High Precision Op-amps Order Information Order Number Package MSL Transport Media, Quantity Marking Information TP2301-TR 5-Pin SOT23 MSL3 Tape and Reel, 3,000 301 TP2302-SR 8-Pin SOIC MSL3 Tape and Reel, 4,000 TP2302 TP2302-VR 8-Pin MSOP MSL3 Tape and Reel, 3,000 TP2302 TP2304-SRNote 1 14-Pin SOIC MSL3 Tape and Reel, 2,500 TP2304 14-Pin TSSOP MSL3 Tape and Reel, 3,000 TP2304 TP2304-TR Note 1: Future product, contact 3PEAK factory for more information and sample. Absolute Maximum Ratings Note 1 Supply Voltage: V+ – V– Note 2..............................7.0V Output Short-Circuit Duration Note 4…….......... Infinite Voltage on Input Pin…………… V– – 0.3 to V+ + 0.3 Operating Temperature Range........–40°C to 125°C Voltage on Output Pin…………. Maximum Junction Temperature................... 150°C V– – 0.3 to V+ + 0.3 Differential Input Voltage............ V– – V+ to V+ – V– Storage Temperature Range.......... –65°C to 150°C Input Current: +IN, –IN Note 3.......................... ±20mA Lead Temperature (Soldering, 10 sec) ......... 260°C Note 1: Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. Exposure to any Absolute Maximum Rating condition for extended periods may affect device reliability and lifetime. Note 2: The op amp supplies must be established simultaneously, with, or before, the application of any input signals. Note 3: The inputs are protected by ESD protection diodes to each power supply. If the input extends more than 500mV beyond the power supply, the input current should be limited to less than 10mA. Note 4: A heat sink may be required to keep the junction temperature below the absolute maximum. This depends on the power supply voltage and how many amplifiers are shorted. Thermal resistance varies with the amount of PC board metal connected to the package. The specified values are for short traces connected to the leads. ESD, Electrostatic Discharge Protection Symbol Parameter Condition HBM Human Body Model ESD ANSI/ESDA/JEDEC JS-001 4 kV CDM Charged Device Model ESD ANSI/ESDA/JEDEC JS-002 1.5 kV Thermal Resistance 2 Package Type θJA θJC Unit 5-Pin SOT23 250 81 ° C/W 8-Pin SOIC 158 43 ° C/W 8-Pin MSOP 210 45 ° C/W 14-Pin SOIC 120 36 ° C/W 14-Pin TSSOP 180 35 ° C/W Rev.A.5 www.3peakic.com.cn Minimum Level Unit TP2301/TP2302 / TP2304 20MHz Bandwidth, Low Noise High Precision Op-amps Electrical Characteristics The specifications are at TA = 27° C. VS = +2.2 V to +5.5 V, or ± 1.1 V to ± 2.75 V, RL = 2kΩ, CL =100pF.Unless otherwise noted. SYMBOL VOS VOS TC IB PARAMETER Input Offset Voltage Input Offset Voltage Drift Input Bias Current CONDITIONS MIN TYP MAX UNITS VCM = VDD/2, TP2301 and TP2302 -50 -100 +50 +100 μV VCM = VDD/2, TP2304 ±7 ± 15 1 2 μV/° C -40° C to 125° C μV TA = 27 ° C 0.3 pA TA = 85 ° C 150 pA TA = 125 ° C 300 pA 0.001 pA IOS Input Offset Current Vn Input Voltage Noise f = 0.1Hz to 10Hz 2.0 μVPP en in RIN Input Voltage Noise Density Input Current Noise Input impedance f = 1kHz f = 1kHz 7.3 nV/√Hz fA/√Hz Ω CIN Input Capacitance CMRR PSRR Common Mode Rejection Ratio Common-mode Input Voltage Range Power Supply Rejection Ratio AVOL VCM Differential Common Mode VCM = 2V to 3V 80 2 1012 7.76 6.87 100 (V–) - 0.3 pF dB (V+) + 0.3 V VCM = 2.5V, VS = 4V to 5V 80 100 dB Open-Loop Large Signal Gain RLOAD = 2kΩ 100 130 dB VOL, VOH Output Swing from Supply Rail RLOAD = 2kΩ ROUT Closed-Loop Output Impedance G = 1, f =1MHz, IOUT = 0 RO Open-Loop Output Impedance f = 1kHz, IOUT = 0 ISC Output Short-Circuit Current Sink or source current VDD Supply Voltage IQ Quiescent Current per Amplifier 20 100 50 mV 0.043 Ω 125 Ω 130 200 mA 5.5 V 5 9 mA TP2302/TP2304, VDD = 5V 3.5 5 mA 2.2 TP2301, VDD = 5V PM Phase Margin RLOAD = 1kΩ, CLOAD = 60pF 60 ° GM Gain Margin RLOAD = 1kΩ, CLOAD = 60pF 11 dB Gain-Bandwidth Product f = 1kHz AV = 1, VOUT = 1.5V to 3.5V, CLOAD = 60pF, RLOAD = 1kΩ 20 MHz 25 V/μs 5.21 0.29 0.45 MHz 123 dB 110 dB GBWP SR FPBW tS THD+N Xtalk Slew Rate Full Power Bandwidth Note 1 Settling Time, 0.1% Settling Time, 0.01% Total Harmonic Distortion and Noise Channel Separation AV = –1, 1V Step f = 1kHz, AV =1, RL = 2kΩ, VOUT = 1Vp-p f = 1kHz, RL = 2kΩ 15 μs Note 1: Full power bandwidth is calculated from the slew rate FPBW = SR/π • VP-P www.3peak.com Rev. A.5 3 TP2301 / TP2302 / TP2304 20MHz Bandwidth, Low Noise High Precision Op-amps Typical Performance Characteristics VS = ±2.5V, VCM = 0V, RL = Open, unless otherwise specified. Offset Voltage Production Distribution CMRR vs. Temperature 160 4000 Number = 55343 pcs 140 3000 120 2500 100 CMRR(dB) Population 3500 2000 1500 80 60 1000 40 500 20 0 0 -50 -40 -30 -20 -10 0 10 20 30 40 -40 50 -20 0 20 40 60 80 100 120 Temperature(℃) Offset Voltage(uV) Open-Loop Gain and Phase 150 Input Voltage Noise Spectral Density 250 1000 200 150 100 0 -50 -100 0 -150 Phase (°) Gain(dB) 50 50 Noise(nV/√Hz) 100 100 10 -200 -50 -250 -300 -100 0.1 10 1k 100k 10M Frequency (Hz) 4 Rev.A.5 www.3peakic.com.cn -350 1000M 1 1 10 100 1k 10k Frequency(Hz) 100k 1M TP2301/TP2302 / TP2304 20MHz Bandwidth, Low Noise High Precision Op-amps Typical Performance Characteristics VS = ±2.5V, VCM = 0V, RL = Open, unless otherwise specified. (Continued) CMRR vs. Frequency 140 140 120 120 100 100 CMRR(dB) CMRR(dB) Common Mode Rejection Ratio 80 60 80 60 40 40 20 20 0 0 0 1 2 3 4 5 1 100 Common-mode voltage(V) 10k Quiescent Current vs. Temperature Short Circuit Current vs. Temperature 5 120 ISINK 4.5 100 4 3.5 Ishort(mA) Supply Current(mA) 1M Frequency(Hz) 3 2.5 2 ISOURCE 80 60 40 1.5 1 20 0.5 0 0 -40 -20 0 20 40 60 80 100 120 -40 0 20 40 60 80 100 120 Temperature(℃) Temperature(℃) Power-Supply Rejection Ratio Quiescent Current vs. Supply Voltage 5 140 4.5 120 Supply Current(mA) PSRR+ 100 PSRR(dB) -20 80 60 PSRR- 40 20 0 4 3.5 3 2.5 2 1.5 1 0.5 0 -20 1 100 10k Frequency(Hz) www.3peak.com 1M 2 2.5 3 3.5 4 4.5 5 Supply Voltage(V) Rev. A.5 5 TP2301 / TP2302 / TP2304 20MHz Bandwidth, Low Noise High Precision Op-amps Typical Performance Characteristics VS = ±2.5V, VCM = 0V, RL = Open, unless otherwise specified. (Continued) CMRR vs. Temperature 160 160 140 140 120 120 100 100 CMRR(dB) PSRR(dB) Power-Supply Rejection Ratio vs. Temperature 80 60 80 60 40 40 20 20 0 0 -40 -20 0 20 40 60 80 100 120 -40 -20 0 Temperature(℃) 20 40 60 80 100 120 Temperature(℃) EMIRR IN+ vs. Frequency Large-Scale Step Response IN 2V/div 140 100 80 Gain= +1 RL= 10kΩ 60 OUT 2V/div EMIRR IN+(dB) 120 40 20 0 1 10 100 1000 Frequency(MHz) Time (20µs/div) Negative Over-Voltage Recovery Positive Over-Voltage Recovery 2V/div 2V/div Time (1µs/div) 6 Gain= +10 ±V= ±2.5V 1V/div 1V/div Gain= +10 ±V= ±2.5V Rev.A.5 www.3peakic.com.cn Time (500ns/div) TP2301/TP2302 / TP2304 20MHz Bandwidth, Low Noise High Precision Op-amps Typical Performance Characteristics VS = ±2.5V, VCM = 0V, RL = Open, unless otherwise specified. (Continued) Negative Output Swing vs. Load Current Offset Voltage vs Common-Mode Voltage 1 6 T=-40℃ 5 Offset Voltage(V) T=130℃ 4 Vdrop(V) 0.5 T=25℃ 3 2 1 0 -0.5 -1 -1.5 -2 -2.5 -3 0 0 0.05 0.1 0.15 0.2 0 1 2 3 4 5 Common-mode Voltage(V) I sink (A) Positive Output Swing vs. Load Current 6 T=-40℃ 5 T=25℃ T=130℃ Vdrop(V) 4 3 2 1 0 0 0.05 0.1 0.15 0.2 I source(A) www.3peak.com Rev. A.5 7 TP2301 / TP2302 / TP2304 20MHz Bandwidth, Low Noise High Precision Op-amps Tape and Reel Information Order Number Package D1 W1 A0 B0 K0 P0 W0 Pin1 Quadrant TP2301-TR SOT23-5 179.0 12.0 3.3 3.25 1.4 4.0 8.0 Q3 TP2302-SR SOP8 330.0 17.6 6.5 5.4 2.0 8.0 12.0 Q1 TP2302-VR MSOP8 330.0 17.6 5.2 3.3 1.5 8.0 12.0 Q1 TP2304-SR SOP14 330.0 21.6 6.5 9.1 1.9 8.0 16.0 Q1 TP2304-TR TSSOP14 330.0 17.6 6.8 5.5 1.7 8.0 12.0 Q1 8 Rev.A.5 www.3peakic.com.cn TP2301/TP2302 / TP2304 20MHz Bandwidth, Low Noise High Precision Op-amps Package Outline Dimensions SOT23-5 www.3peak.com Rev. A.5 9 TP2301 / TP2302 / TP2304 20MHz Bandwidth, Low Noise High Precision Op-amps SOP8 10 Rev.A.5 www.3peakic.com.cn TP2301/TP2302 / TP2304 20MHz Bandwidth, Low Noise High Precision Op-amps TSSOP8 www.3peak.com Rev. A.5 11 TP2301 / TP2302 / TP2304 20MHz Bandwidth, Low Noise High Precision Op-amps MSOP8 12 Rev.A.5 www.3peakic.com.cn TP2301/TP2302 / TP2304 20MHz Bandwidth, Low Noise High Precision Op-amps SOP14 www.3peak.com Rev. A.5 13 TP2301 / TP2302 / TP2304 20MHz Bandwidth, Low Noise High Precision Op-amps TSSOP14 14 Rev.A.5 www.3peakic.com.cn TP2301/TP2302 / TP2304 20MHz Bandwidth, Low Noise High Precision Op-amps Revision History Date Revision Notes 2022/4/29 A.4 2023/5/29 A.5 Update order information. Update EC table: VOL/VOH: typ 13mV -> 20mV; max 20mV -> 50mV Iq of TP2301(1ch): typ 5mA, max 9mA Slew Rate: min 18 -> 15 The following updates are all about the new datasheet formats or typo, the actual product remains unchanged. Updated to new format of package dimensions and tape and reel information. Updated Absolute Maximum Ratings, added differential input voltage. Updated address of web site. Updated the HBM value from 6kV to 4kV, CDM value from 2kV to 1.5kV due to new test standard. www.3peak.com Rev. A.5 15 TP2301 / TP2302 / TP2304 20MHz Bandwidth, Low Noise High Precision Op-amps IMPORTANT NOTICE AND DISCLAIMER Copyright© 3PEAK 2012-2023. All rights reserved. Trademarks. Any of the 思瑞浦 or 3PEAK trade names, trademarks, graphic marks, and domain names contained in this document /material are the property of 3PEAK. You may NOT reproduce, modify, publish, transmit or distribute any Trademark without the prior written consent of 3PEAK. Performance Information. Performance tests or performance range contained in this document/material are either results of design simulation or actual tests conducted under designated testing environment. Any variation in testing environment or simulation environment, including but not limited to testing method, testing process or testing temperature, may affect actual performance of the product. Disclaimer. 3PEAK provides technical and reliability data (including data sheets), design resources (including reference designs), application or other design recommendations, networking tools, security information and other resources "As Is". 3PEAK makes no warranty as to the absence of defects, and makes no warranties of any kind, express or implied, including without limitation, implied warranties as to merchantability, fitness for a particular purpose or non-infringement of any third-party’s intellectual property rights. Unless otherwise specified in writing, products supplied by 3PEAK are not designed to be used in any life-threatening scenarios, including critical medical applications, automotive safety-critical systems, aviation, aerospace, or any situations where failure could result in bodily harm, loss of life, or significant property damage. 3PEAK disclaims all liability for any such unauthorized use. 16 Rev.A.5 www.3peakic.com.cn
TP2301-TR 价格&库存
很抱歉,暂时无法提供与“TP2301-TR”相匹配的价格&库存,您可以联系我们找货
TP2301-TR
    • 3000+1.15610
    库存:6000
    TP2301-TR
      • 1+4.27280
      • 10+3.38100
      • 30+2.93020
      库存:227
      TP2301-TR
        • 1+1.78800
        • 100+1.42800
        • 750+1.27200
        • 1500+1.20000
        • 3000+1.14000
        库存:3720
        TP2301-TR
        • 3000+6.512053000+0.84011
        • 6000+6.270866000+0.80900
        库存:2909
        TP2301-TR
        • 1+13.443721+1.73435
        • 10+9.8266410+1.26772
        • 25+8.9222725+1.15105
        • 100+7.92367100+1.02222
        • 250+7.44806250+0.96086
        • 500+7.35501500+0.94886
        库存:2909
