TL431
ADJUSTABLE ACCURATE REFERENCE SOURCE
FEATURES
The effective temperature compensation in the working range of full temperature
The typical value of the equivalent temperature factor in the whole
temperature scope is 50 ppm/°C
The output voltage can be adjusted to 36V
Low dynamic output impedance, its typical value is 0.2Ω
Trapping current capability is 1 to 100mA
Low output noise voltage
Fast on-state response
Surface Mount device
SOT-89
APPLICATION
Shunt Regulator
High-Current Shunt Regulator
Precision Current Limiter
MECHANICAL DATA
Case: SOT-89
Case Material: Molded Plastic. UL flammability
Classification Rating: 94V-0
Weight: 0.055 grams (approximate)
MAXIMUM RATINGS (Operating temperature range applies unless otherwise specified)
Parameter
Symbol
Value
Unit
Cathode Voltage
VKA
36
V
Cathode Current Range (Continuous)
IKA
-100~+150
mA
Reference Input Current Range
Iref
0.05~+10
mA
Power Dissipation
PD
500
mW
Thermal Resistance from Junction to Ambient
RθJA
250
°C/W
Operating Temperature
Topr
-20~+85
°C
Junction Temperature
TJ
150
°C
Storage Temperature Range
TSTG
-55 ~+150
°C
© SHENZHEN HOTTECH ELECTRONICS CO.,LTD
E-mail:hkt@heketai.com
1/6
TL431
ELECTRICAL CHARACTERISTICS (TA = 25°C unless otherwise specified)
Parameter
Symbol
Min
Typ
Max
Unit
Vref
2.475
2.5
2.525
V
VKA=VREF,IKA=10mA
4.5
17
mV
VKA=VREF,IKA=10mA
-25°C≤TA≤+85°C
Ratio of change in reference
input voltage to the change in ΔVref /ΔVKA
cathode voltage
-1.0
-2.7
mV/V
IKA=10mA,ΔVKA=10V-VREF
-0.5
-2.0
mV/V
IKA=10mA,ΔVKA=36V-10V
Reference input current
1.5
4
µA
IKA=10mA,R1=10KΩ,R2=∞
ΔIref /ΔT
0.4
1.2
µA
Emitter cut-off current
IKA(min)
0.45
1.0
mA
VKA=VREF
Off-state Cathode Current
IKA(OFF)
0.05
1.0
µA
VKA=36V,VREF=0
ZKA
0.15
0.5
Ω
VKA=VREF,IKA=1~10mA,f≤1.0kHz
Reference Input Voltage
Deviation of reference input
voltage over temperature
ΔVref /ΔT
current Over full temperature
range
Dynamic Impedance
Iref
Conditions
IKA=10mA,R1=10KΩ,R2=∞,
-25°C≤TA≤+85°C
CLASSIFICATION OF Vref
Rank
0.5%
1%
2%
Range
2.487-2.513
2.475-2.525
2.450-2.550
2/6
TL431
Typical Characteristics
0" &"6
1
1
1
9:;9+0
;1ć
9:
9
0"
7
0" &"6
8
1
8-92
4
+0
9:;9+0
;1ć
1
1
1
1
9:
9
7HVW&LUFXLWIRU9.$ 9UHI
3/6
TL431
0 6 2 ! 3
&"6 7
0" &"6
ƸVref, REFERENCE INPUT VOLTAGE
(mV)
IK=10mA
Ta=25ć
-4
-8
-12
-16
-20
10
15
VKA, CATHODE VOLTAGE
(nA)
35
40
Test Circuit for VKA=Vref(1+R1/R2)+R1*Iref
! 3
7
92 93
700
Iref, REFERENCE INPUT CURRENT
30
(V)
600
500
400
300
200
100
IK=10mA
R1=10K
-20
60
Ta, AMBIENT TEMPERATURE
80
100
Test Circuit for Iref
(ć)
0"
7 92 93
(nA)
45
Ioff, OFF-STATE CATHODE CURRENT
50
40
35
30
25
10
VKA=36V
5
Vref=0V
-20
60
80
100
Test Circuit for Ioff
(ć)
4/6
TL431
SOT-89 Package Outline Dimensions
Symbol
Dimensions In Millimeters
Dimensions In Inches
Min.
Max.
Min.
Max.
A
1.400
1.600
0.055
0.063
b
0.320
0.520
0.013
0.020
b1
0.400
0.580
0.016
0.023
c
0.350
0.440
0.014
0.017
D
4.400
4.600
0.173
0.181
D1
1.550REF
0.061REF
E
2.300
2.600
0.091
0.102
E1
3.940
4.250
0.155
0.167
e
1.500TYP
0.060TYP
e1
3.000TYP
0.118TYP
L
0.900
1.200
0.035
0.047
SOT-89 Suggested Pad Layout
Note:
1.Controlling dimension: in millimeters
2.General tolerance: ±0.05mm
3.The pad layout is for reference purposes only
5/6
TL431
SOT-89 Tape and Reel
SOT-89 Embossed Carrier Tape
DIMENSIONS ARE IN MILLIMETER
TYPE
A
B
C
d
E
F
P0
P
P1
W
SOT-89
4.85
4.45
1.85
Ø1.50
1.75
5.50
4.00
8.00
2.00
12.00
TOLERANCE
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
SOT-89 Tape Leader and Trailer
SOT-89 Reel
REEL OPTION
7’’ DIA
TOLERANCE
D
D1
D2
G
H
I
W1
W2
Ø178
54.40
13.00
R78
R25.60
R6.50
13.20
16.50
±2
±1
±1
±1
±1
±1
±1
±1
6/6
很抱歉,暂时无法提供与“TL431”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.34761
- 100+0.28535
- 200+0.28107
- 400+0.25337
- 1000+0.24957
- 国内价格
- 10+0.31672
- 100+0.25384
- 300+0.22233
- 1000+0.16745
- 5000+0.14857
- 10000+0.13903
