ES2A THRU ES2J
Reverse Voltage - 50 to 600 Volts
Forward Current - 2.0 Ampere
SURFACE MOUNT SUPER FAST RECOVERY RECTIFIER
Features
DO-214AC/SMA
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Low reverse leakage
Built-in strain relief,ideal for automated
placement High forward surge current capability
High temperature soldering guaranteed:
0.110(2.80)
0.094(2.40)
0.067 (1.70)
0.051 (1.30)
0.177(4.50)
0.157(3.99)
0.012(0.305)
0.006(0.152)
250°C/10 seconds at terminals
Glass passivated chip junction
0.096(2.42)
0.078(1.98)
Mechanical Data
0.060(1.52)
0.030(0.76)
0.008(0.203)MAX.
0.208(5.30)
0.188(4.80)
Case : JEDEC DO-214AC/SMA Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.0019 ounce, 0.055grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unlss otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
VRRM
VRMS
VDC
MDD
ES2A
MDD
ES2B
MDD
ES2C
MDD
ES2D
MDD
ES2E
MDD
ES2G
MDD
ES2J
UNITS
50
35
50
100
70
100
150
105
150
200
140
200
300
210
300
400
280
400
600
420
600
V
V
V
Maximum average forward rectified current
at Tc=125℃
I(AV)
2.0
A
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
IFSM
50
A
Maximum instantaneous forward voltage at 2.0A
VF
Maximum DC reverse current
at rated DCblocking voltage
TA=25℃
1
1.25
1.68
V
5.0
100.0
uA
CJ
35
40.0
pF
Typical thermal resistance (NOTE 3)
RJA
60.0
℃/W
Operating junction and storage temperature range
TJ,TSTG
TA=125℃
Maximum reverse recovery time
(NOTE 1)
Typical junction capacitance (NOTE 2)
IR
trr
-55to+150
ns
Note:1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A
2.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
3.Pulse test: Pulse width 200 sec, Duty cycle 2%
4..P.C.B. mounted with 1.0 X 1.0" (2.54 X 2.54 cm) copper pad areas.
http://www.microdiode.com
Rev:2024A2
Page :1
ES2A THRU ES2J
Ratings And Characteristic Curves
Fig.1 Reverse Recovery Time Characteristic And Test Circuit Diagram
50 ohm
Noninductive
trr
10 ohm
Noninductive
+0.5
D.U.T
PULSE
GENERATOR
Note 2
25Vdc
approx
1 ohm
NonInductive
OSCILLOSCOPE
Note 1
-1.0
Note:1.Rise Time = 7ns, max.
Input Impedance = 1megohm,22pF.
2. Ries Time =10ns, max.
Source Impedance = 50 ohms.
10ns/div
Set time Base for 10ns/div
Fig.3 Typical Reverse Characteristics
3.0
300
2.5
I R - Reverse Current (μA)
Average Forward Current (A)
Fig.2 Maximum Average Forward Current Rating
2.0
1.5
1.0
0.5
Single phase half-wave 60 Hz resistive
or inductive load
100
TJ=125°C
10
TJ=75°C
1.0
TJ=25°C
0.1
0.0
25
50
75
100
125
150
175
Case Temperature (°C)
60
80
100
Fig.5 Typical Junction Capacitance
10
Junction Capacitance (pF)
Instaneous Forward Current (A)
Fig.4 Typical Forward Characteristics
TJ=25°C
1.0
ES2A~ES2D
ES2E/ES2G
0.1
40
% of PIV.VOLTS
ES2J
0.01
TJ=25°C
100
10
TJ=25°C
f = 1.0MHz
Vsig = 50mVp-p
1
0.001
1.0
1.5
2.0
2.5
0.1
1.0
10
100
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
Fig.6 Maximum Non-Repetitive Peak
60
50
40
30
8.3 ms Single Half Sine Wave (JEDEC
Method)
00
1
10
100
Number of Cycles
The curve above is for reference only.
Rev:2024A2
Page :2
ES2A THRU ES2J
Packing information
unit:mm
P0
P1
d
Item
Symbol
Tolerance
SMA
A
B
C
d
D
D1
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
2.80
5.33
2.36
1.50
330.00
50.00
178.00
62.00
13.00
1.75
5.50
4.00
4.00
2.00
0.28
12.00
18.00
E
F
B
A
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
W
P
D2
T
D1
C
W1
D
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
SMA
REEL SIZE
7"
APPROX.
GROSS WEIGHT
(kg)
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
2,000
4.0
4,000
183*155*183
178
382*356*392
80,000
10,000
290*290*38
330
310*310*360
80,000
11.0
15,000
335*335*38
330
350*330*360
120,000
14.5
SMA
11"
5,000
4.0
SMA
13"
7,500
4.0
CARTON
SIZE
(m/m)
CARTON
(pcs)
16.0
Suggested Pad Layout
Symbol
Unit (mm)
A
1.68
0.066
B
1.52
0.060
C
3.93
0.154
D
2.41
0.095
E
5.45
0.215
Unit (inch)
Rev:2024A2
Page :3
很抱歉,暂时无法提供与“ES2G”相匹配的价格&库存,您可以联系我们找货
