CA1918L-802P02515-1310
    BRH(宝仁弘)
    插件
    共模电感 插件 300mΩ 8mH 26.00mm 23.50 x 14.00mm
CA1918L-802P02515-1310 数据手册
EMI、EMC對策用元件 THIS SPECIFICATION IS APPLIED TO WIRE WOUND INDUCTOR CA1918L-802P02515-1310 Product standard of spec sheet 寶仁弘電子有限公司 Prosperity Electronic Co., Limited EML:brh@baorenhong.com Web:www.baorenhong.com TEL:0755-29687188 FAX:0755-29688152 深圳市寶安區福永鎮立新二路天佑創客產業園 TEL:0512-36878535 FAX:0512-36878435 江蘇省昆山市花橋鎮綠地大道 1325號 CA1918L-802P02515-1310 PRODUCT OVERVIEW ◎Shape&Dimensions 形狀與尺寸: UNIT:mm ◎Electrical Diagram 電性圖: Electrical Diagram Winding Sequence 1 4 2 3 NO:CA20240508A1171 -BA01 Web Site:http://www.baorenhong.com CA1918L-802P02515-1310 TEST DATAS FOR SAMPLES ◎Winding 产品绕制要求: WINDING MATERIAL START--FINISH TURNS REMARK N1 0.25*1.5mm 扁平线 1-2 41Ts REF. 密绕 N2 0.25*1.5mm 扁平线 4-3 41Ts REF. 密绕 Test condition ◎Electrical Characteristics 電氣特性: NO Item Spec Test Equipment 1 L(1-2)(4-3) 8.0mH MIN TH2816A/TH2832/ CHENHWA UC2906 2 DC Resistance (1-2)(4-3) 0.3Ω MAX CHENHWA 502A 3 Difference/Inductanc e/ L(1-2)-L(4-3) 0.3mH MAX TH2816A/TH2832/ CHENHWA UC2906 4 Rated Current(A) Input 220V 5.0A MAX 5 HI-POT TEST AC 50Hz 6 Insulation Resistance.DC 500V 1KHz/0.25V/25℃/ 内阻30Ω 1.5KV/3mA 60s COIL TO COIL E-SUN 19053 100M OHM MIN In case of doubt: Test the samples after putting it in the room temperature of 25℃~40℃ for 5~6 hours Web Site:http://www.baorenhong.com CA1918L-802P02515-1310 TEST DATAS FOR SAMPLES ◎Material 產品材料: ITEM MATERIAL CALSS SUPPLTER UL NO. BOBBIN PHENOLIC T375HF 150℃ CHANG CHUN PLASTICS CO., LTD E59481 CORE 1918 M12K COPPER WIRE SFT-UEWH 180℃ ZHUHAI SUNTEK WIRE CO., LTD E234867 VARNISH E59 130℃ ZHUHAI CHANGXIAN INDUSTRIAL CO., LTD E335405 HENGRUI MATERIAL CO., LTD Web Site:http://www.baorenhong.com CA1918L-802P02515-1310 TEST DATAS FOR SAMPLES ◎Test Datas For Samples 樣品測試數據: MEAS.Item 8mH MIN Suggest 1-2 4-3 1 10.95 10.93 2 11.63 11.62 3 10.42 10.45 4 11.69 11.71 5 11.78 11.77 6 11.25 11.31 7 10.38 10.39 8 10.87 10.83 9 11.07 11.05 10 10.74 10.75 X 11.08 11.08 R 1.40 1.38 Product Diagram The test data above is only for reference,actual results may differ due to different production batches. Web Site:http://www.baorenhong.com CA1918L-802P02515-1310 TEST DATAS FOR SAMPLES ◎Test Datas For Samples 樣品測試數據: MEAS. Item DC Resistance 0.3Ω MAX Product Diagram Suggest 1-2 4-3 1 0.053 0.054 2 0.054 0.055 3 0.053 0.053 4 0.055 0.055 5 0.048 0.051 6 0.052 0.053 7 0.053 0.052 8 0.055 0.053 9 0.051 0.055 10 0.053 0.054 X 0.053 0.054 R 0.007 0.004 The test data above is only for reference,actual results may differ due to different production batches. Web Site:http://www.baorenhong.com CA1918L-802P02515-1310 TEST DATAS FOR SAMPLES ◎Test Datas For Samples 樣品測試數據: MEAS. Item 23.5 MAX 26.0 MAX 14.0 MAX 3.50±1.0 0.8±0.1 1 22.86 24.95 13.38 3.97 0.77 2 22.79 25.02 13.42 3.98 0.79 3 22.83 24.87 13.35 3.95 0.81 4 22.84 25.33 13.41 3.87 0.78 5 22.78 25.08 13.43 3.87 0.79 6 22.84 25.15 13.44 3.85 0.82 7 22.87 24.98 13.39 3.88 0.81 8 22.85 24.95 13.36 3.82 0.79 9 22.83 25.07 13.42 3.89 0.78 10 22.85 25.01 13.41 3.89 0.71 X 22.83 25.04 13.40 3.90 0.79 R 0.09 0.46 0.09 0.16 0.11 The test data above is only for reference,actual results may differ due to different production batches. Web Site:http://www.baorenhong.com CA1918L-802P02515-1310 PACKING ◎Packing 包裝: A. Quantilty per box :According to customer’s request. B. With PE tapes. C. Package Dimensions (mm): L(mm) W(mm) H(mm) 350 MAX 350 MAX 170 MAX D. Lable Items: * Customer * Quantity * Part. Number * Lot. Number * PROSPERITY ELECTRONICS CO.,LTD E. Storage: * Please be sure to store the package at no more than 35℃and 70%RH , keep the package in the atmosphere free of sulphur and chlorine. Web Site:http://www.baorenhong.com CA1918L-802P02515-1310 RELIABILITY TEST ◎Reliability Test 可靠性測試: STORAGE TEMPERATURE -25℃~85℃ OPERATING TEMPERATURE RANGE : -25℃~+85℃(CONTAIN HEATING COIL) EXTERNAL APPEARANCE NO EXTERNAL DEFECTS CAN BE FOUND IN THE VISUAL INSPECTION. TERMINAL STRENGTH FIXED INDUCTORS,ONE END OF THE ELECTRODE WITH 0.45KG PULLING FORCE,GUIDED THE NEEDLE DOES NOT FALL OFF. INSULATING RESISTANCE THE INSULATION RESISTANCE SHOULD BE OVER 1000MΩ WHEN D.C.100V IS APPLIED TO THE WINDING –CORE. MEANWHILE NO STRUCTURE AND ELECTRIC DEFECTS SHOULD BE FOUND FOR 1 MINUTE. HUMIDITY TEST INDUCTANCE DEVIATION IS WITHIN ±10.0% AND NO STRUCTURE AND ELECTRIC DEFECTS CAN BE FOUND AFTER 96±2hours TEST UNDER THE CONDITIONOF RELATIVE HUMIDITY OF 90~95% AND TEMPERATURE OF 40±5℃. AND 1 HOUR STORAGE UNDER ROOM AMBIENT CONDITIONS AFTER THE DEVICE IS WIPED WITH DRY CLOTH. VIBRATION TEST INDUCTANCE DEVIATION IS WITHIN ±10.0% AFTER 1 HOUR SWEEPING VIBRATION IN EACH THREE DIRECTIONS. NAMELY, FREQUENCY IS10~55Hz ANDTHE AMPLITUDE OF 1MINUTE CYCLE IS 1.5mm . Web Site:http://www.baorenhong.com
CA1918L-802P02515-1310 价格&库存
很抱歉,暂时无法提供与“CA1918L-802P02515-1310”相匹配的价格&库存,您可以联系我们找货
