US3AB THRU US3MB
Reverse Voltage - 50 to 1000 Volts
Forward Current - 3.0 Ampere
SURFACE MOUNT ULTRA FAST RECTIFIER
Features
DO-214AA/SMB
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
0.155(3.94)
0.130(3.30)
0.086 (2.20)
0.071 (1.80)
Ultra fast switching for high efficiency
Low reverse leakage
Built-in strain relief,ideal for automated placement
0.185(4.70)
0.160(4.06)
High forward surge current capability
0.012(0.305)
0.006(0.152)
High temperature soldering guaranteed
250 °C/10 seconds at terminals
0.096(2.44)
0.084(2.13)
0.060(1.52)
0.030(0.76)
Mechanical Data
0.008(0.203)MAX.
0.220(5.59)
0.200(5.08)
Case : JEDEC DO-214AA/SMB Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.003 ounce, 0.095grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
VRRM
VRMS
VDC
MDD
MDD
MDD
MDD
MDD
MDD
MDD
US3AB US3BB US3DB US3GB US3JB US3KB US3MB
50
35
50
100
70
100
200
140
200
400
280
400
600
420
600
800
560
800
UNITS
1000
700
1000
V
V
V
Maximum average forward rectified current
I(AV)
3
A
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
IFSM
90
A
Maximum instantaneous forward voltage at 3A
VF
Maximum DC reverse current
at rated DCblocking voltage
IR
Maximum reverse recovery time
TA=25℃
TA=125℃
(NOTE 1)
Typical junction capacitance (NOTE 2)
Typical thermal resistance (NOTE 3)
Operating junction and storage temperature range
1.3
1
5
100
trr
50
CJ
75
RθJA
RθJC
TJ,TSTG
45
15
V
1.68
μA
75
ns
50
pF
℃/W
-55 to +150
Note:1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A
2.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
3.P.C.B. mounted with 2.0”x2.0”(5.0x5.0cm) copper pad areas
https://www.microdiode.com
Rev:2024A2
Page :1
US3AB THRU US3MB
Ratings And Characteristic Curves
Fig.2 Typical Reverse Characteristics
Fig.1 Maximum Average Forward Current Rating
4.0
3.5
Average Forward Current (A)
3.0
2.5
2.0
1.5
1.0
0.5
Single phase half-wave 60 Hz resistive
or inductive load
0.0
25
50
75
100
125
150
175
Instaneous Reverse Current(μ A)
100
TJ=125°C
10
1.0
TJ=25°C
0.1
00
Case Temperature (°C)
40
60
80
100
120
140
percent of Rated Peak Reverse Voltage (%)
Fig.4 Maximum Non-Repetitive Peak
Forward Surage Current
Fig.3 Typical Forward Characteristics
10
TJ=25°C
Peak Forward Surage Current (A)
100
Instaneous Forward Current (A)
1.0
US3AB~US3DB
US3GB
0.1
US3JB~US3MB
0.01
0.001
1.0
1.5
2.0
Instaneous Forward Voltage (V)
2.5
80
60
40
8.3 ms Single Half Sine Wave (JEDEC
Method)
1
10
100
Number of Cycles
The curve above is for reference only.
Rev:2024A2
Page :2
US3AB THRU US3MB
Packing information
P0
P1
d
unit:mm
E
F
B
A
Item
W
D2
D1
C
W1
D
Tolerance
SMB
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
3.81
5.41
2.42
1 5.0
330.00
50.00
13.00
1.75
5.55
8.00
4.00
2.00
0.30
12.00
12.30
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
P
T
Symbol
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(mm)
BOX
(pcs)
INNER
BOX
(mm)
REEL
DIA,
(mm)
SMB
13"
3,000
4.0
6,000
190*190*41
330
CARTON
SIZE
(mm)
365*365*360
CARTON
(pcs)
48,000
APPROX.
GROSS WEIGHT
(kg)
14.0
Suggested Pad Layout
Symbol
A
B
C
D
E
Unit (mm)
2.8
2.4
Unit (inch)
0.110
4.6
0.094
0.181
2.2
7.0
0.086
0.276
Rev:2024A2
Page :3
很抱歉,暂时无法提供与“US3JB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.57800
- 100+0.34480
- 800+0.24140
- 3000+0.17240
- 6000+0.16380
- 30000+0.15170
- 国内价格
- 10+0.29085
- 100+0.23123
- 300+0.20142
- 3000+0.17280
- 6000+0.15498
- 9000+0.14602
