P6KE Series
Breakdown Voltage: 6.8 to 600 V
Peak Pulse Power: 600 W
Axial Lead
Transient Voltage Suppressors
Features
DO-15
Glass passivated chip
600 W peak pulse power capability with a
10/1000 μs waveform, repetitive rate (duty
cycle):0.01 %
Low leakage
Uni and Bidirectional unit
Excellent clamping capability
Very fast response time
RoHS compliant
0.300 7.63
0.230 5.85
Mechanical Data
DIA.
0.033 0.84
0.028 0.71
1.000 [25.40]
MIN
Case: Molded plastic
Epoxy: UL 94V-0 rate flame retardant
Lead: Solderable per MIL-STD-202, method
208 guranteed
Polarity: Color band denotes cathode end
except Bipolar
Mounting position: Any
DIA.
0.142 3.61
0.102 2.60
1.000 [25.40]
MIN
Dimensions :
inch [ mm ]
Maximum Ratings(TA=25℃ unless otherwise noted)
Parameter
Peak power dissipation with a 10/1000μs waveform(1)
Peak pulse current with a 10/1000μs waveform(1)
Power dissipation on infinite heatsink at TL = 75 °C
Peak forward surge current, 8.3 ms single half sine-wave
unidirectional only(2)
Maximum instantaneous forward voltage at 50 A for
unidirectional only(3)
Operating junction and storage temperature range
Symbol
PPP
Value
600
Unit
W
IPP
See Next Table
A
PD
5.0
W
IFSM
100
A
VF
3.5/5.0
V
TJ, TSTG
- 55 to +150
°C
Note:
(1)Non-repetitive current pulse per Fig.5 and derated above TA= 25 °C per Fig.1
(2)Measured on 8.3 ms single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minute maximum
(3)VF
很抱歉,暂时无法提供与“P6KE62CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.38500
- 50+0.22770
- 2000+0.20350
- 国内价格
- 10+0.42920
- 100+0.33848
- 300+0.29312
- 2000+0.26298
- 4000+0.23577
- 10000+0.22216
