P6KE520CA
P6KE520CA
    SURGING(绍鑫)
    DO-15(DO-204AC)
P6KE520CA 数据手册
Transient Voltage Suppressor 瞬态抑制二极管 P6KE Series http://www.szshaoxin.com/ 绍 鑫 实 业 Transient Voltage Suppressors - P6KE Series 1. FEATURES Plastic package Glass passivated chip junction in DO-15 Package 600W peak pulse power capability on 10/1000us waveform Excellent clamping capability Low zener impedance Fast response time:typically less than 1.0ps from 0 Volts to BV min Typical IR less than 1uA above 12V 2. MECHANICAL DESIGN Bi-directional Case:JEDEC DO-15 Molded Plastic Terminals:Axial leads,solderable per MIL-STD-750,Method 2026 Polarity:Color band denoted cathode except bidirectional Mounting Position:Any Cathode Anode Uni-directional Schematic Symbol 3. MAXIMUMRATINGS (TA=25°C ) Symbol Parameter Value Unit PPPM Peak Pulse Power Dissipation on 10/1000us waveform (Note1,Note2) 600 Watts IPPM Peak Pulse Current of on 10/1000us waveform(Note1) See Table Amps 5.0 Watts 3.5/5.0 Volts 100 Amps PM(AV) VF IFSM Steady State Power Dissipation at TA =50℃ (Note2) Maximum lnstantaneous Forward Voltage at 50A for Unidirectonal Only( Note4) Peak Forward Surge Current,8.3ms Single Half Sine-Wave Superimposed on Rated Load, (JEDEC Method) (Note 3) TJ Operating Junction Temperature -55 to +150 ℃ TS Storage Temperature Range -55 to +150 ℃ 75 ℃/W RθJA Junction to Ambient on printed circuit Notes: 1. Non-repetitive current pulse, TA = 25℃ 2. Mounted on 8.0mm x 8.0mm (0.03mm thick) Copper Pads to each terminal 3. 8.3ms single half sine-wave, or equivalent square wave for unidirectional device only, Duty cycle=4 pulses per minutes maximum 4.VF<3.5V for VBR≤200V and VF<5.0V for VBR≥201V http://www.szshaoxin.com/ 绍 鑫 实 业 Transient Voltage Suppressors - P6KE Series 4. ELECTRICAL CHARACTERISTICS (TA=25℃) Part Number Marking Code Reverse Stand-off Voltage Breakdown Breakdown Voltage Voltage Min. @IT Max. @IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Maximum Reverse Leakage @VRWM UNI BI UNI BI VR(V) VB(V) VB(V) IT(mA) VC(V) IPP(A) IR(uA) P6KE6.8A P6KE6.8CA P6KE6.8A P6KE6.8CA 5.8 6.45 7.14 10.0 10.5 58.1 1000.0 P6KE7.5A P6KE7.5CA P6KE7.5A P6KE7.5CA 6.4 7.13 7.88 10.0 11.3 54.0 500.0 P6KE8.2A P6KE8.2CA P6KE8.2A P6KE8.2CA 7.02 7.79 8.61 10.0 12.1 50.4 200.0 P6KE9.1A P6KE9.1CA P6KE9.1A P6KE9.1CA 7.78 8.65 9.55 1.0 13.4 45.5 50.0 P6KE10A P6KE10CA P6KE10A P6KE10CA 8.55 9.5 10.5 1.0 14.5 42.1 10.0 P6KE11A P6KE11CA P6KE11A P6KE11CA 9.4 10.5 11.6 1.0 15.6 39.1 5.0 P6KE12A P6KE12CA P6KE12A P6KE12CA 10.2 11.4 12.6 1.0 16.7 36.5 5.0 P6KE13A P6KE13CA P6KE13A P6KE13CA 11.1 12.4 13.7 1.0 18.2 33.5 1.0 P6KE15A P6KE15CA P6KE15A P6KE15CA 12.8 14.3 15.8 1.0 21.2 28.8 1.0 P6KE16A P6KE16CA P6KE16A P6KE16CA 13.6 15.2 16.8 1.0 22.5 27.1 1.0 P6KE18A P6KE18CA P6KE18A P6KE18CA 15.3 17.1 18.9 1.0 25.5 24.2 1.0 P6KE20A P6KE20CA P6KE20A P6KE20CA 17.1 19.0 21.0 1.0 27.7 22.0 1.0 P6KE22A P6KE22CA P6KE22A P6KE22CA 18.8 20.9 23.1 1.0 30.6 19.9 1.0 P6KE24A P6KE24CA P6KE24A P6KE24CA 20.5 22.8 25.2 1.0 33.2 18.4 1.0 P6KE27A P6KE27CA P6KE27A P6KE27CA 23.1 25.7 28.4 1.0 37.5 16.3 1.0 P6KE30A P6KE30CA P6KE30A P6KE30CA 25.6 28.5 31.5 1.0 41.4 14.7 1.0 P6KE33A P6KE33CA P6KE33A P6KE33CA 28.2 31.4 34.7 1.0 45.7 13.3 1.0 P6KE36A P6KE36CA P6KE36A P6KE36CA 30.8 34.2 37.8 1.0 49.9 12.2 1.0 P6KE39A P6KE39CA P6KE39A P6KE39CA 33.3 37.1 41.0 1.0 53.9 11.3 1.0 P6KE43A P6KE43CA P6KE43A P6KE43CA 36.8 40.9 45.2 1.0 59.3 10.3 1.0 P6KE47A P6KE47CA P6KE47A P6KE47CA 40.2 44.7 49.4 1.0 64.8 9.4 1.0 P6KE51A P6KE51CA P6KE51A P6KE51CA 43.6 48.5 53.6 1.0 70.1 8.7 1.0 P6KE56A P6KE56CA P6KE56A P6KE56CA 47.8 53.2 58.8 1.0 77.0 7.9 1.0 P6KE62A P6KE62CA P6KE62A P6KE62CA 53.0 58.9 65.1 1.0 85.0 7.2 1.0 P6KE68A P6KE68CA P6KE68A P6KE68CA 58.1 64.6 71.4 1.0 92.0 6.6 1.0 P6KE75A P6KE75CA P6KE75A P6KE75CA 64.1 71.3 78.8 1.0 103.0 5.9 1.0 P6KE82A P6KE82CA P6KE82A P6KE82CA 70.1 77.9 86.1 1.0 113.0 5.4 1.0 P6KE91A P6KE91CA P6KE91A P6KE91CA 77.8 86.5 95.5 1.0 125.0 4.9 1.0 P6KE100A P6KE100CA P6KE100A P6KE100CA 85.5 95.0 105.0 1.0 137.0 4.5 1.0 P6KE110A P6KE110CA P6KE110A P6KE110CA 94.0 105.0 116.0 1.0 152.0 4.0 1.0 P6KE120A P6KE120CA P6KE120A P6KE120CA 102.0 114.0 126.0 1.0 165.0 3.7 1.0 http://www.szshaoxin.com/ 绍 鑫 实 业 Transient Voltage Suppressors - P6KE Series Part Number Marking Code Reverse Stand-off Voltage Breakdown Breakdown Voltage Voltage Min. @IT Max. @IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Maximum Reverse Leakage @VRWM UNI BI UNI BI VR(V) VB(V) VB(V) IT(mA) VC(V) IPP(A) IR(uA) P6KE130A P6KE130CA P6KE130A P6KE130CA 111.0 124.0 137.0 1.0 179.0 3.4 1.0 P6KE150A P6KE150CA P6KE150A P6KE150CA 128.0 143.0 158.0 1.0 207.0 2.9 1.0 P6KE160A P6KE160CA P6KE160A P6KE160CA 136.0 152.0 168.0 1.0 219.0 2.8 1.0 P6KE170A P6KE170CA P6KE170A P6KE170CA 145.0 162.0 179.0 1.0 234.0 2.6 1.0 P6KE180A P6KE180CA P6KE180A P6KE180CA 154.0 171.0 189.0 1.0 246.0 2.5 1.0 P6KE200A P6KE200CA P6KE200A P6KE200CA 171.0 190.0 210.0 1.0 274.0 2.2 1.0 P6KE220A P6KE220CA P6KE220A P6KE220CA 185.0 209.0 231.0 1.0 328.0 1.9 1.0 P6KE250A P6KE250CA P6KE250A P6KE250CA 214.0 237.0 263.0 1.0 344.0 1.8 1.0 P6KE300A P6KE300CA P6KE300A P6KE300CA 256.0 285.0 315.0 1.0 414.0 1.5 1.0 P6KE350A P6KE350CA P6KE350A P6KE350CA 300.0 332.0 368.0 1.0 482.0 1.3 1.0 P6KE400A P6KE400CA P6KE400A P6KE400CA 342.0 380.0 420.0 1.0 548.0 1.1 1.0 P6KE440A P6KE440CA P6KE440A P6KE440CA 376.0 418.0 462.0 1.0 602.0 1.0 1.0 P6KE480A P6KE480CA P6KE480A P6KE480CA 408.0 456.0 504.0 1.0 658.0 0.9 1.0 P6KE510A P6KE510CA P6KE510A P6KE510CA 434.0 485.0 535.0 1.0 698.0 0.9 1.0 P6KE520A P6KE520CA P6KE520A P6KE520CA 442.0 494.0 546.0 1.0 698.0 0.9 1.0 P6KE530A P6KE530CA P6KE530A P6KE530CA 451.0 503.5 557.0 1.0 725.0 0.8 1.0 P6KE540A P6KE540CA P6KE540A P6KE540CA 459.0 513.0 567.0 1.0 740.0 0.8 1.0 P6KE550A P6KE550CA P6KE550A P6KE550CA 467.0 522.5 578.0 1.0 760.0 0.8 1.0 P6KE600A P6KE600CA P6KE600A P6KE600CA 510.0 570.0 630.0 1.0 828.0 0.75 1.0 http://www.szshaoxin.com/ 绍 鑫 实 业 Transient Voltage Suppressors - P6KE Series 5. CHARACTERISTIC CURVES Voltage Transients Voltage or Current Voltage Across TVS Current Through TVS Time Figure 2. Peak Pulse Power Rang Curve I PPM - Peak Pulse Current, %I RSM 150 tr=10uS Peak Pulse Power (P PP ) or Current (I PP ) Dera ng in Percentage % Figure 1. TVSTransients Clamping Waveform T J =25°C Pulse Width(td) is defined as the point where the peak current decays to 50% of I PPM Peak Value I PPM 100 Half Value I PPM (I PPM /2) 50 0 10/1000µsec. Waveform as defined by R.E.A tC 0 100 80 60 40 20 0 1.0 2.0 t - Time (ms) 3.0 4.0 Figure 3. Peak Pulse Power Derating Curve 0 25 50 75 100 125 150 175 T A -Ambient temperature(°C) Figure 4. Pulse Waveform http://www.szshaoxin.com/ 绍 鑫 实 业 Transient Voltage Suppressors - P6KE Series Figure 6. Maximum Non-Repetitive Forward Surge Current Uni-Directional Only Figure 5. Typical Junc tion Capacittance 7. DO-15 PACKAGE INFORMATION D C A Inches Dimension Cathode Band Min. Max. Min. Max. A 0.230 0.300 5.800 7.600 B 0.104 0.140 2.600 3.600 C 0.026 0.034 0.700 0.900 D 1.000 --- 25.400 --- D B Millimeters 8. ORDERING INFORMATION Part Number Size QTY/BOX P6KExx(C)A DO-15 2000PCS http://www.szshaoxin.com/
