P6KE12A TB
P6KE12A TB
    YFW(佑风微)
    DO-15(DO-204AC)
    单向TVS 10.2V截止 峰值浪涌电流:35.9A@10/1000US
P6KE12A TB 数据手册
P6KE6.8A(CA) THRU P6KE600A(CA) DO-15 Transient voltage suppressor power 600 watts FEATURES  PPP 600W  VRWM 6.8V~600V  Glass passivated chip MECHANICAL DATA  Case: DO-15  Terminals: Solderable per MIL-STD-750, Method 2026 DO-15  Approx. Weight: 0.33g / 0.0116oz Limiting Values(Absolute Maximum Rating) Parameter Symbol Conditions Value Unit Peak power dissipation PPPM with a 10/1000us waveform 600 W Peak forward surge current IFSM 8.3 ms single half sine-wave unidirectional only 100 A Peak pulse current IPPM with a 10/1000us waveform See Next Table A Power dissipation PD on infinite heat sink at TL=75℃ 5 W -55 to +175 °C Operating junction and storage emperature range TJ,TSTG Electrical Characteristics(Ta=25℃ Unless otherwise specified) Parameter Maximum instantaneous forward Voltage(1) Symbol Conditions Value Unit PPPM at 25A for unidirectional only 3.5/5.0 V RθJL junction to lead 20 °C/W RθJA junction to ambient, LLead = 10 mm 75 °C/W Thermal resistance NOTES: 1. VF = 3.5 V for P6KE220(A) and below; VF = 5.0 V for P6KE250(A) and above www.yfwdiode.com 1/6 G uangDong YFW Electronics Co, Ltd. Dongguan YFW Electronics Co, Ltd. P6KE6.8A(CA) THRU P6KE600A(CA) DO-15 Breakdown Voltage VBR@IT Part Number(U ni) Part Number(Bi) P6KE6.8 Maximum Reverse Leakage IR @ VWM (μA) Working Peak Reverse Voltage VRWM (V) Maximum Reverse Surge Current IPP (A) Maximum Clamping Voltage Vc @ IPP (V) Maximum Temperature Coefficient of VBR (%/°C) Min(V) Max (V) IT(mA) P6KE6.8C 6.12 7.48 10 1000 5.50 55.6 10.8 0.057 P6KE6.8A P6KE6.8CA 6.45 7.14 10 1000 5.80 57.1 10.5 0.057 P6KE7.5 P6KE7.5C 6.75 8.25 10 500 6.05 51.3 11.7 0.061 P6KE7.5A P6KE7.5CA 7.13 7.88 10 500 6.40 53.1 11.3 0.061 P6KE8.2 P6KE8.2C 7.38 9.02 10 200 6.63 48.0 12.5 0.065 P6KE8.2A P6KE8.2CA 7.79 8.61 10 200 7.02 49.6 12.1 0.065 P6KE9.1 P6KE9.1C 8.19 10.0 1.0 50 7.37 43.5 13.8 0.068 P6KE9.1A P6KE9.1CA 8.65 9.55 1.0 50 7.78 44.8 13.4 0.068 P6KE10 P6KE10C 9.00 11.0 1.0 10 8.10 40.0 15.0 0.073 P6KE10A P6KE10CA 9.50 10.5 1.0 10 8.55 41.4 14.5 0.073 P6KE11 P6KE11C 9.90 12.1 1.0 5.0 8.92 37.0 16.2 0.075 P6KE11A P6KE11CA 10.5 11.6 1.0 5.0 9.40 38.5 15.6 0.075 P6KE12 P6KE12C 10.8 13.2 1.0 5.0 9.72 34.7 17.3 0.078 P6KE12A P6KE12CA 11.4 12.6 1.0 5.0 10.2 35.9 16.7 0.078 P6KE13 P6KE13C 11.7 14.3 1.0 5.0 10.5 31.6 19.0 0.081 P6KE13A P6KE13CA 12.4 13.7 1.0 5.0 11.1 33.0 18.2 0.081 P6KE15 P6KE15C 13.5 16.5 1.0 1.0 12.1 27.3 22.0 0.084 P6KE15A P6KE15CA 14.3 15.8 1.0 1.0 12.8 28.3 21.2 0.084 P6KE16 P6KE16C 14.4 17.6 1.0 1.0 12.9 25.5 23.5 0.086 P6KE16A P6KE16CA 15.2 16.8 1.0 1.0 13.6 26.7 22.5 0.086 P6KE18 P6KE18C 16.2 19.8 1.0 1.0 14.5 22.6 26.5 0.088 P6KE18A P6KE18CA 17.1 18.9 1.0 1.0 15.3 23.8 25.2 0.088 P6KE20 P6KE20C 18.0 22.0 1.0 1.0 16.2 20.6 29.1 0.090 P6KE20A P6KE20CA 19.0 21.0 1.0 1.0 17.1 21.7 27.7 0.090 P6KE22 P6KE22C 19.8 24.2 1.0 1.0 17.8 18.8 31.9 0.092 P6KE22A P6KE22CA 20.9 23.1 1.0 1.0 18.8 19.6 30.6 0.092 P6KE24 P6KE24C 21.6 26.4 1.0 1.0 19.4 17.3 34.7 0.094 P6KE24A P6KE24CA 22.8 25.2 1.0 1.0 20.5 18.1 33.2 0.094 P6KE27 P6KE27C 24.3 29.7 1.0 1.0 21.8 15.3 39.1 0.096 P6KE27A P6KE27CA 25.7 28.4 1.0 1.0 23.1 16.0 37.5 0.096 P6KE30 P6KE30C 27.0 33.0 1.0 1.0 24.3 13.8 43.5 0.097 P6KE30A P6KE30CA 28.5 31.5 1.0 1.0 25.6 14.5 41.4 0.097 P6KE33 P6KE33C 29.7 36.3 1.0 1.0 26.8 12.6 47.7 0.098 P6KE33A P6KE33CA 31.4 34.7 1.0 1.0 28.2 13.1 45.7 0.098 P6KE36 P6KE36C 32.4 39.6 1.0 1.0 29.1 11.5 52.0 0.099 P6KE36A P6KE36CA 34.2 37.8 1.0 1.0 30.8 12.0 49.9 0.099 www.yfwdiode.com 2/6 G uangDong YFW Electronics Co, Ltd. P6KE6.8A(CA) THRU P6KE600A(CA) DO-15 Breakdown Voltage VBR@IT Working Peak Reverse Voltage VRWM (V) Maximum Reverse Surge Current IPP (A) Maximum Clamping Voltage Vc @ IPP (V) Maximum Temperature Coefficient of VBR (%/°C) Min(V) Max (V) IT(mA) Maximum Reverse Leakage IR @ VWM (μA) P6KE39C 35.1 42.9 1.0 1.0 31.6 10.6 56.4 0.100 P6KE39A P6KE39CA 37.1 41.0 1.0 1.0 33.3 11.1 53.9 0.100 P6KE43 P6KE43C 38.7 47.3 1.0 1.0 34.8 9.7 61.9 0.101 P6KE43A P6KE43CA 40.9 45.2 1.0 1.0 36.8 10.1 59.3 0.101 P6KE47 P6KE47C 42.3 51.7 1.0 1.0 38.1 8.8 67.8 0.101 P6KE47A P6KE47CA 44.7 49.4 1.0 1.0 40.2 9.3 64.8 0.101 P6KE51 P6KE51C 45.9 56.1 1.0 1.0 41.3 8.2 73.5 0.102 P6KE51A P6KE51CA 48.5 53.6 1.0 1.0 43.6 8.6 70.1 0.102 P6KE56 P6KE56C 50.4 61.6 1.0 1.0 45.4 7.5 80.5 0.103 P6KE56A P6KE56CA 53.2 58.8 1.0 1.0 47.8 7.8 77.0 0.103 P6KE62 P6KE62C 55.8 68.2 1.0 1.0 50.2 6.7 89.0 0.104 P6KE62A P6KE62CA 58.9 65.1 1.0 1.0 53.0 7.1 85.0 0.104 P6KE68 P6KE68C 61.2 74.8 1.0 1.0 55.1 6.1 98.0 0.104 P6KE68A P6KE68CA 64.6 71.4 1.0 1.0 58.1 6.5 92.0 0.104 P6KE75 P6KE75C 67.5 82.5 1.0 1.0 60.7 5.6 108 0.105 P6KE75A P6KE75CA 71.3 78.8 1.0 1.0 64.1 5.8 103 0.105 P6KE82 P6KE82C 73.8 90.2 1.0 1.0 66.4 5.1 118 0.105 P6KE82A P6KE82CA 77.9 86.1 1.0 1.0 70.1 5.3 113 0.105 P6KE91 P6KE91C 81.9 100 1.0 1.0 73.7 4.6 131 0.106 Part Number(Uni) (双向) Part Number(Bi) P6KE39 P6KE91A P6KE91CA 86.5 95.5 1.0 1.0 77.8 4.8 125 0.106 P6KE100 P6KE100C 90.0 110 1.0 1.0 81.0 4.2 144 0.106 P6KE100A P6KE100CA 95.0 105 1.0 1.0 85.5 4.4 137 0.106 P6KE110 P6KE110C 99.0 121 1.0 1.0 89.2 3.8 158 0.107 P6KE110A P6KE110CA 105 116 1.0 1.0 94.0 3.9 152 0.107 P6KE120 P6KE120C 108 132 1.0 1.0 97.2 3.5 173 0.107 P6KE120A P6KE120CA 114 126 1.0 1.0 102 3.6 165 0.107 P6KE130 P6KE130C 117 143 1.0 1.0 105 3.2 187 0.107 P6KE130CA 124 137 1.0 1.0 111 3.4 179 0.107 P6KE150 P6KE150C 135 165 1.0 1.0 121 2.8 215 0.108 P6KE150A P6KE150CA 143 158 1.0 1.0 128 2.9 207 0.108 P6KE160 P6KE160C 144 176 1.0 1.0 130 2.6 230 0.108 P6KE130A P6KE160A P6KE160CA 152 168 1.0 1.0 136 2.7 219 0.108 P6KE170 P6KE170C 153 187 1.0 1.0 138 2.5 244 0.108 P6KE170A P6KE170CA 162 179 1.0 1.0 145 2.6 234 0.108 P6KE180 P6KE180C 162 198 1.0 1.0 146 2.3 258 0.108 P6KE180A P6KE180CA 171 189 1.0 1.0 154 2.4 246 0.108 www.yfwdiode.com 3/6 G uangDong YFW Electronics Co, Ltd. P6KE6.8A(CA) THRU P6KE600A(CA) DO-15 Breakdown Voltage VBR@IT Part Number(Uni) Part Number(Bi) P6KE200 P6KE200C Min(V) Max (V) IT(mA) 180 220 1.0 Maximum Reverse Leakage IR @ VWM (μA) Working Peak Reverse Voltage VRWM (V) Maximum Reverse Surge Current IPP (A) Maximum Clamping Voltage Vc @ IPP (V) Maximum Temperature Coefficient of VBR (%/°C) 1.0 162 2.1 287 0.108 P6KE200A P6KE200CA 190 210 1.0 1.0 171 2.2 274 0.108 P6KE220 P6KE220C 198 242 1.0 1.0 175 1.7 344 0.108 P6KE220A P6KE220CA 209 231 1.0 1.0 185 1.8 328 0.108 P6KE250 P6KE250C 225 275 1.0 1.0 202 1.7 360 0.110 P6KE250A P6KE250CA 237 263 1.0 1.0 214 1.7 344 0.110 P6KE300 P6KE300C 270 330 1.0 1.0 243 1.4 430 0.110 P6KE300A P6KE300CA 285 315 1.0 1.0 256 1.4 414 0.110 P6KE350 P6KE350C 315 385 1.0 1.0 284 1.2 504 0.110 P6KE350A P6KE350CA 333 368 1.0 1.0 300 1.2 482 0.110 P6KE400 P6KE400C 360 440 1.0 1.0 324 1.0 574 0.110 P6KE400A P6KE400CA 380 420 1.0 1.0 342 1.1 548 0.110 P6KE440 P6KE440C 396 484 1.0 1.0 356 0.95 631 0.110 P6KE440A P6KE440CA 418 462 1.0 1.0 376 1.00 602 0.110 P6KE480 P6KE480C 432 528 1.0 1.0 389 0.88 686 0.110 P6KE480A P6KE480CA 456 504 1.0 1.0 408 0.91 658 0.110 P6KE510 P6KE510C 459 561 1.0 1.0 413 0.82 729 0.110 P6KE510A P6KE510CA 485 535 1.0 1.0 434 0.86 698 0.110 P6KE540 P6KE540C 486 594 1.0 1.0 437 0.78 772 0.110 P6KE540A P6KE540CA 513 567 1.0 1.0 459 0.81 740 0.110 P6KE550 P6KE550C 495 605 1.0 1.0 470 0.76 786 0.110 P6KE550A P6KE550CA 522.5 577.5 1.0 1.0 467 0.79 760 0.110 ŠŠŽR Š–ŽR ‘ŽR ‘ŽR ‘ŽR ‘ŽR ”ŽR •ŽR Ž‘“”R ‘ŽŽR Š“ŽR R Ž‘ŽR Ž‘ŽR ^Š‹ŒŠŽŽR ^Š‹ŒŠŽŽ}R •ŠŽR ^Š‹ŒŠŽŽpR ^Š‹ŒŠŽŽ}pR •’ŽR www.yfwdiode.com  4/6 G uangDong YFW Electronics Co, Ltd. P6KE6.8A(CA) THRU P6KE600A(CA) DO-15 FIG2: Pulse Power or Current vs. Initial Junction Temperature PPP or IPP(%) PPPM(KW) FIG1:Peak Pulse Power Rating Curve 100 Non-Repetitive Pulse Waveform shown in Fige.3 TA=25℃ 100 75 10 50 1.0 25 0 0.1 0.1μs 1.0μs 10μs 100μs 1.0ms 25 0 50 75 100 125 150 10ms 175 200 TJ (℃) td(μs) FIG4: Power Derating Curve 150 tr=10μs Peak Value IPPM PD(W) IPPM(%) FIG3: Pulse Waveform TJ=25 ℃ Pulse Width(td) is defined as the Point where the Peak Current Decays to 50% of IPPM 6 60Hz Resistive or Inductive Load 5 4 100 Half Value - IPP 2 IPPM 3 50 L=0.375''(9.5mm) Lead Lengths 2 10/1000μs Waveform as Defined by R.E.A. 1 td 0 1.0 0 2.0 3.0 0 4.0 0 25 50 75 100 125 150 t(ms) FIG6:Typical Transient Thermal Impedance Rth(℃/W) IFSM(A) TJ=TJMax. 100 200 TL (℃) FIG5: Maximum Non-Repetitive Surge Current 200 175 100 8.3ms Single Half Sine-Wave 10 50 1 10 0 10 100 Number of Cycles 0.1 0.001 0.01 0.1 1 10 100 1000 tp(s) www.yfwdiode.com 5/6 G uangDong YFW Electronics Co, Ltd. P6KE6.8A(CA) THRU P6KE600A(CA) DO-15 Package Outline DO-15 D DIMENSIONS A DIM A B C D Cathode Mark B INCHES MIN .230 .104 .028 1.000 MAX .300 .140 .034 --- MM MIN 5.8 2.6 0.71 25.40 MAX 7.6 3.6 0.86 --- NOTE D C Summary of Packing Options Package DO-15 www.yfwdiode.com Packing Description Packing Quantity BOX 500/3000 6/6 Industry Standard EIA-481-1 G uangDong YFW Electronics Co, Ltd.
P6KE12A TB 价格&库存
很抱歉,暂时无法提供与“P6KE12A TB”相匹配的价格&库存,您可以联系我们找货
P6KE12A TB
  • 10+0.31435
  • 100+0.24757
  • 300+0.21423
  • 3000+0.19343
  • 6000+0.17341
  • 9000+0.16340
库存:2104
