P6KE6.8A(CA) THRU P6KE600A(CA) DO-15
Transient voltage suppressor power 600 watts
FEATURES
PPP 600W
VRWM 6.8V~600V
Glass passivated chip
MECHANICAL DATA
Case: DO-15
Terminals: Solderable per MIL-STD-750, Method 2026
DO-15
Approx. Weight: 0.33g / 0.0116oz
Limiting Values(Absolute Maximum Rating)
Parameter
Symbol
Conditions
Value
Unit
Peak power dissipation
PPPM
with a 10/1000us waveform
600
W
Peak forward surge current
IFSM
8.3 ms single half sine-wave
unidirectional only
100
A
Peak pulse current
IPPM
See Next Table
A
Power dissipation
PD
on infinite heat sink at TL=75℃
5
W
-55 to +175
°C
Operating junction and storage
emperature range
TJ,TSTG
Electrical Characteristics(Ta=25℃ Unless otherwise specified)
Parameter
Maximum instantaneous forward
Voltage(1)
Symbol
Conditions
Value
Unit
PPPM
at 25A for unidirectional only
3.5/5.0
V
RθJL
junction to lead
°C/W
RθJA
junction to ambient,
LLead = 10 mm
75
°C/W
Thermal resistance
NOTES:
1. VF = 3.5 V for P6KE220(A) and below; VF = 5.0 V for P6KE250(A) and above
www.yfwdiode.com
1/6
G uangDong
YFW
Electronics
Co,
Ltd.
Dongguan
YFW
Electronics
Co,
Ltd.
Breakdown Voltage VBR@IT
Part
Number(U
ni)
Part
Number(Bi)
P6KE6.8
Maximum
Reverse
Leakage IR @
VWM (μA)
Working Peak
Reverse
Voltage
VRWM (V)
Maximum
Reverse Surge
Current IPP
(A)
Maximum
Clamping
Voltage Vc
@ IPP
(V)
Maximum
Temperature
Coefficient of VBR
(%/°C)
Min(V)
Max (V)
IT(mA)
P6KE6.8C
6.12
7.48
10
1000
5.50
55.6
10.8
0.057
P6KE6.8A
P6KE6.8CA
6.45
7.14
10
1000
5.80
57.1
10.5
0.057
P6KE7.5
P6KE7.5C
6.75
8.25
10
500
6.05
51.3
11.7
0.061
P6KE7.5A
P6KE7.5CA
7.13
7.88
10
500
6.40
53.1
11.3
0.061
P6KE8.2
P6KE8.2C
7.38
9.02
10
200
6.63
48.0
12.5
0.065
P6KE8.2A
P6KE8.2CA
7.79
8.61
10
200
7.02
49.6
12.1
0.065
P6KE9.1
P6KE9.1C
8.19
10.0
1.0
50
7.37
43.5
13.8
0.068
P6KE9.1A
P6KE9.1CA
8.65
9.55
1.0
50
7.78
44.8
13.4
0.068
P6KE10
P6KE10C
9.00
11.0
1.0
10
8.10
40.0
15.0
0.073
P6KE10A
P6KE10CA
9.50
10.5
1.0
10
8.55
41.4
14.5
0.073
P6KE11
P6KE11C
9.90
12.1
1.0
5.0
8.92
37.0
16.2
0.075
P6KE11A
P6KE11CA
10.5
11.6
1.0
5.0
9.40
38.5
15.6
0.075
P6KE12
P6KE12C
10.8
13.2
1.0
5.0
9.72
34.7
17.3
0.078
P6KE12A
P6KE12CA
11.4
12.6
1.0
5.0
10.2
35.9
16.7
0.078
P6KE13
P6KE13C
11.7
14.3
1.0
5.0
10.5
31.6
19.0
0.081
P6KE13A
P6KE13CA
12.4
13.7
1.0
5.0
11.1
33.0
18.2
0.081
P6KE15
P6KE15C
13.5
16.5
1.0
1.0
12.1
27.3
22.0
0.084
P6KE15A
P6KE15CA
14.3
15.8
1.0
1.0
12.8
28.3
21.2
0.084
P6KE16
P6KE16C
14.4
17.6
1.0
1.0
12.9
25.5
23.5
0.086
P6KE16A
P6KE16CA
15.2
16.8
1.0
1.0
13.6
26.7
22.5
0.086
P6KE18
P6KE18C
16.2
19.8
1.0
1.0
14.5
22.6
26.5
0.088
P6KE18A
P6KE18CA
17.1
18.9
1.0
1.0
15.3
23.8
25.2
0.088
P6KE20
P6KE20C
18.0
22.0
1.0
1.0
16.2
20.6
29.1
0.090
P6KE20A
P6KE20CA
19.0
21.0
1.0
1.0
17.1
21.7
27.7
0.090
P6KE22
P6KE22C
19.8
24.2
1.0
1.0
17.8
18.8
31.9
0.092
P6KE22A
P6KE22CA
20.9
23.1
1.0
1.0
18.8
19.6
30.6
0.092
P6KE24
P6KE24C
21.6
26.4
1.0
1.0
19.4
17.3
34.7
0.094
P6KE24A
P6KE24CA
22.8
25.2
1.0
1.0
20.5
18.1
33.2
0.094
P6KE27
P6KE27C
24.3
29.7
1.0
1.0
21.8
15.3
39.1
0.096
P6KE27A
P6KE27CA
25.7
28.4
1.0
1.0
23.1
16.0
37.5
0.096
P6KE30
P6KE30C
27.0
33.0
1.0
1.0
24.3
13.8
43.5
0.097
P6KE30A
P6KE30CA
28.5
31.5
1.0
1.0
25.6
14.5
41.4
0.097
P6KE33
P6KE33C
29.7
36.3
1.0
1.0
26.8
12.6
47.7
0.098
P6KE33A
P6KE33CA
31.4
34.7
1.0
1.0
28.2
13.1
45.7
0.098
P6KE36
P6KE36C
32.4
39.6
1.0
1.0
29.1
11.5
52.0
0.099
P6KE36A
P6KE36CA
34.2
37.8
1.0
1.0
30.8
12.0
49.9
0.099
www.yfwdiode.com
2/6
G uangDong YFW Electronics Co, Ltd.
Working Peak
Reverse
Voltage
VRWM (V)
Maximum
Reverse Surge
Current IPP
(A)
Maximum
Clamping
Voltage Vc
@ IPP
(V)
Maximum
Temperature
Coefficient of VBR
(%/°C)
Min(V)
Max (V)
IT(mA)
Maximum
Reverse
Leakage IR @
VWM (μA)
P6KE39C
35.1
42.9
1.0
1.0
31.6
10.6
56.4
0.100
P6KE39A
P6KE39CA
37.1
41.0
1.0
1.0
33.3
11.1
53.9
0.100
P6KE43
P6KE43C
38.7
47.3
1.0
1.0
34.8
9.7
61.9
0.101
P6KE43A
P6KE43CA
40.9
45.2
1.0
1.0
36.8
10.1
59.3
0.101
P6KE47
P6KE47C
42.3
51.7
1.0
1.0
38.1
8.8
67.8
0.101
P6KE47A
P6KE47CA
44.7
49.4
1.0
1.0
40.2
9.3
64.8
0.101
P6KE51
P6KE51C
45.9
56.1
1.0
1.0
41.3
8.2
73.5
0.102
P6KE51A
P6KE51CA
48.5
53.6
1.0
1.0
43.6
8.6
70.1
0.102
P6KE56
P6KE56C
50.4
61.6
1.0
1.0
45.4
7.5
80.5
0.103
P6KE56A
P6KE56CA
53.2
58.8
1.0
1.0
47.8
7.8
77.0
0.103
P6KE62
P6KE62C
55.8
68.2
1.0
1.0
50.2
6.7
89.0
0.104
P6KE62A
P6KE62CA
58.9
65.1
1.0
1.0
53.0
7.1
85.0
0.104
P6KE68
P6KE68C
61.2
74.8
1.0
1.0
55.1
6.1
98.0
0.104
P6KE68A
P6KE68CA
64.6
71.4
1.0
1.0
58.1
6.5
92.0
0.104
P6KE75
P6KE75C
67.5
82.5
1.0
1.0
60.7
5.6
108
0.105
P6KE75A
P6KE75CA
71.3
78.8
1.0
1.0
64.1
5.8
103
0.105
P6KE82
P6KE82C
73.8
90.2
1.0
1.0
66.4
5.1
118
0.105
P6KE82A
P6KE82CA
77.9
86.1
1.0
1.0
70.1
5.3
113
0.105
P6KE91
P6KE91C
81.9
100
1.0
1.0
73.7
4.6
131
0.106
Part
Number(Uni)
(双向)
Part
Number(Bi)
P6KE39
P6KE91A
P6KE91CA
86.5
95.5
1.0
1.0
77.8
4.8
125
0.106
P6KE100
P6KE100C
90.0
110
1.0
1.0
81.0
4.2
144
0.106
P6KE100A
P6KE100CA
95.0
105
1.0
1.0
85.5
4.4
137
0.106
P6KE110
P6KE110C
99.0
121
1.0
1.0
89.2
3.8
158
0.107
P6KE110A
P6KE110CA
105
116
1.0
1.0
94.0
3.9
152
0.107
P6KE120
P6KE120C
108
132
1.0
1.0
97.2
3.5
173
0.107
P6KE120A
P6KE120CA
114
126
1.0
1.0
102
3.6
165
0.107
P6KE130
P6KE130C
117
143
1.0
1.0
105
3.2
187
0.107
P6KE130CA
124
137
1.0
1.0
111
3.4
179
0.107
P6KE150
P6KE150C
135
165
1.0
1.0
121
2.8
215
0.108
P6KE150A
P6KE150CA
143
158
1.0
1.0
128
2.9
207
0.108
P6KE160
P6KE160C
144
176
1.0
1.0
130
2.6
230
0.108
P6KE130A
P6KE160A
P6KE160CA
152
168
1.0
1.0
136
2.7
219
0.108
P6KE170
P6KE170C
153
187
1.0
1.0
138
2.5
244
0.108
P6KE170A
P6KE170CA
162
179
1.0
1.0
145
2.6
234
0.108
P6KE180
P6KE180C
162
198
1.0
1.0
146
2.3
258
0.108
P6KE180A
P6KE180CA
171
189
1.0
1.0
154
2.4
246
0.108
www.yfwdiode.com
3/6
Part
Number(Uni)
Part
Number(Bi)
P6KE200
P6KE200C
Min(V)
Max (V)
IT(mA)
180
220
1.0
Maximum
Reverse
Leakage IR @
VWM (μA)
Working Peak
Reverse
Voltage
VRWM (V)
Maximum
Reverse Surge
Current IPP
(A)
Maximum
Clamping
Voltage Vc
@ IPP
(V)
Maximum
Temperature
Coefficient of VBR
(%/°C)
1.0
162
2.1
287
0.108
P6KE200A
P6KE200CA
190
210
1.0
1.0
171
2.2
274
0.108
P6KE220
P6KE220C
198
242
1.0
1.0
175
1.7
344
0.108
P6KE220A
P6KE220CA
209
231
1.0
1.0
185
1.8
328
0.108
P6KE250
P6KE250C
225
275
1.0
1.0
202
1.7
360
0.110
P6KE250A
P6KE250CA
237
263
1.0
1.0
214
1.7
344
0.110
P6KE300
P6KE300C
270
330
1.0
1.0
243
1.4
430
0.110
P6KE300A
P6KE300CA
285
315
1.0
1.0
256
1.4
414
0.110
P6KE350
P6KE350C
315
385
1.0
1.0
284
1.2
504
0.110
P6KE350A
P6KE350CA
333
368
1.0
1.0
300
1.2
482
0.110
P6KE400
P6KE400C
360
440
1.0
1.0
324
1.0
574
0.110
P6KE400A
P6KE400CA
380
420
1.0
1.0
342
1.1
548
0.110
P6KE440
P6KE440C
396
484
1.0
1.0
356
0.95
631
0.110
P6KE440A
P6KE440CA
418
462
1.0
1.0
376
1.00
602
0.110
P6KE480
P6KE480C
432
528
1.0
1.0
389
0.88
686
0.110
P6KE480A
P6KE480CA
456
504
1.0
1.0
408
0.91
658
0.110
P6KE510
P6KE510C
459
561
1.0
1.0
413
0.82
729
0.110
P6KE510A
P6KE510CA
485
535
1.0
1.0
434
0.86
698
0.110
P6KE540
P6KE540C
486
594
1.0
1.0
437
0.78
772
0.110
P6KE540A
P6KE540CA
513
567
1.0
1.0
459
0.81
740
0.110
P6KE550
P6KE550C
495
605
1.0
1.0
470
0.76
786
0.110
P6KE550A
P6KE550CA
522.5
577.5
1.0
1.0
467
0.79
760
0.110
R
R
R
R
R
R
R
R
R
R
R
R
R
R
^R ^}R R
^pR ^}pR R
www.yfwdiode.com
4/6
FIG2: Pulse Power or Current vs. Initial Junction Temperature
PPP or IPP(%)
PPPM(KW)
FIG1:Peak Pulse Power Rating Curve
100
Non-Repetitive Pulse
Waveform shown in Fige.3
TA=25℃
100
75
10
50
1.0
25
0.1μs
1.0μs
10μs
100μs
1.0ms
25
75
100
125
150
10ms
175
200
TJ (℃)
td(μs)
FIG4: Power Derating Curve
150
tr=10μs
Peak Value
IPPM
PD(W)
IPPM(%)
FIG3: Pulse Waveform
TJ=25 ℃
Pulse Width(td) is defined as
the Point where the Peak
Current Decays to 50% of IPPM
6
60Hz
Resistive or
Inductive Load
5
4
100
Half Value - IPP
2
IPPM
3
50
L=0.375''(9.5mm)
Lead Lengths
2
10/1000μs Waveform as
Defined by R.E.A.
1
td
3.0
50
75
100
125
150
t(ms)
FIG6:Typical Transient Thermal Impedance
Rth(℃/W)
IFSM(A)
TJ=TJMax.
100
200
TL (℃)
FIG5: Maximum Non-Repetitive Surge Current
200
175
100
8.3ms Single Half Sine-Wave
10
50
1
10
100
Number of Cycles
0.1
0.001
0.01
0.1
1
10
100
1000
tp(s)
www.yfwdiode.com
5/6
Package Outline
DO-15
D
DIMENSIONS
A
DIM
A
B
C
D
Cathode
Mark
B
INCHES
MIN
.230
.104
.028
1.000
MAX
.300
.140
.034
MM
MIN
5.8
2.6
0.71
25.40
MAX
7.6
3.6
0.86
NOTE
D
C
Summary of Packing Options
Package
DO-15
www.yfwdiode.com
Packing Description
Packing Quantity
BOX
500/3000
6/6
Industry Standard
EIA-481-1
很抱歉,暂时无法提供与“P6KE30CA TB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.34074
- 100+0.26666
- 300+0.22950
- 3000+0.20639
- 6000+0.18414
- 9000+0.17302
