Transient Voltage Suppressors (TVS)
P6KE Series
Description
The P6KE series is designed specifically to protect sensitive
electronic equipment from voltage transients induced by
lightning and other transient voltage events.
Features
Fast response time
Matte tin lead–free Plated
Low incremental surge resistance
Halogen free and RoHS compliant
Electrical symbol
Typical IR less than 1μA above 12V
Compatible with industrial standard package DO-15
For surface mounted applications to optimize board space
BI
600W peak pulse power capability with at 10/1000μs
waveform, repetition rate (duty cycle): 0.01%
Cathode
Anode
High temperature soldering guaranteed:260°C/10 seconds
UNI
Part Number Code
P
6
K
E
Series code
x
x
x
C
Reverse
Stand-Off
Voltage
A
5% Voltage
Tolerance
Blank:Uni-Directional
C:Bi-Directional
Mechanical Characteristics
Rating
Symbol
Value
Units
Peak Pulse Power Dissipation by 10x1000μs test Waveform(Fig.2) (Note1)
PPP
600
W
Steady State Power Dissipation on inifinite heat sink at TL=75°C(Fig.6)
PD
5.0
W
Peak Forward Surge Current, 8.3ms Single Half Sine Wave Unidirectional only
(Note 2)
IFSM
100
A
Maximum instantaneous forward voltage at 25 A for unidirectional only
VF
3.5/6.5
V
TJ,TSTG
-55 to 150
°C
Operating junction and Storage Temperature Range.
Notes:
1. Non-repetitive current pulse , per Fig. 4 and derated above TA = 25°C per Fig. 3.
2. Measured on 8.3ms single half sine wave or equivalent square wave, duty cycle=4 pulses per minute maximum.
Specifications are subject to change without notice.
Please refer to http://www.ruilon.com.cn for current information.
Revised: 2023-12-13
Version: A1
Page 1
P6KE Series
Electrical Characteristics
Reverse
Stand-Off
Voltage
Type Number
VRWM
Breakdown
Voltage
VBR @IT
Min
Max
Test Current
Max.
Clamping
Voltage
10/1000µs
Max.
Peak Pulse
Current
10/1000µs
Reverse
Leakage
IT
VC@IPP
IPP
IR@VRWM
UNI
BI
V
V
V
mA
V
A
µA
P6KE6.8A
P6KE6.8CA
5.80
6.45
7.14
10
10.5
57.0
1000
P6KE7.5A
P6KE7.5CA
6.40
7.13
7.88
10
11.3
53.0
500
P6KE8.2A
P6KE8.2CA
7.02
7.79
8.61
10
12.1
50.0
200
P6KE9.1A
P6KE9.1CA
7.78
8.65
9.55
1
13.4
45.0
50
P6KE10A
P6KE10CA
8.55
9.50
10.50
1
14.5
41.0
10
P6KE11A
P6KE11CA
9.40
10.50
11.60
1
15.6
38.0
5
P6KE12A
P6KE12CA
10.20
11.40
12.60
1
16.7
36.0
5
P6KE13A
P6KE13CA
11.10
12.40
13.70
1
18.2
33.0
1
P6KE15A
P6KE15CA
12.80
14.30
15.80
1
21.2
28.0
1
P6KE16A
P6KE16CA
13.60
15.20
16.80
1
22.5
27.0
1
P6KE18A
P6KE18CA
15.30
17.10
18.90
1
25.2
24.0
1
P6KE20A
P6KE20CA
17.10
19.00
21.00
1
27.7
22.0
1
P6KE22A
P6KE22CA
18.80
20.90
23.10
1
30.6
20.0
1
P6KE24A
P6KE24CA
20.50
22.80
25.20
1
33.2
18.0
1
P6KE27A
P6KE27CA
23.10
25.70
28.40
1
37.5
16.0
1
P6KE30A
P6KE30CA
25.60
28.50
31.50
1
41.4
14.4
1
P6KE33A
P6KE33CA
28.20
31.40
34.70
1
45.7
13.2
1
P6KE36A
P6KE36CA
30.80
34.20
37.80
1
49.9
12.0
1
P6KE39A
P6KE39CA
33.30
37.10
41.00
1
53.9
11.2
1
P6KE43A
P6KE43CA
36.80
40.90
45.20
1
59.3
10.1
1
P6KE47A
P6KE47CA
40.20
44.70
49.40
1
64.8
9.30
1
P6KE51A
P6KE51CA
43.60
48.50
53.60
1
70.1
8.60
1
P6KE56A
P6KE56CA
47.80
53.20
58.80
1
77.0
7.80
1
P6KE62A
P6KE62CA
53.00
58.90
65.10
1
85.0
7.10
1
P6KE68A
P6KE68CA
58.10
64.60
71.40
1
92.0
6.50
1
P6KE75A
P6KE75CA
64.10
71.30
78.80
1
103.0
5.80
1
P6KE82A
P6KE82CA
70.10
77.90
86.10
1
113.0
5.30
1
P6KE91A
P6KE91CA
77.80
86.50
95.50
1
125.0
4.80
1
P6KE100A
P6KE100CA
85.50
95.00
105.00
1
137.0
4.40
1
P6KE110A
P6KE110CA
94.00
105.00
116.00
1
152.0
4.00
1
P6KE120A
P6KE120CA
102.00
114.00
126.00
1
165.0
3.60
1
P6KE130A
P6KE130CA
111.00
124.00
137.00
1
179.0
3.30
1
Revised: 2023-12-13
Version: A1
Page 2
P6KE Series
Reverse
Stand-Off
Voltage
Type Number
VRWM
Breakdown
Voltage
VBR @IT
Min
Max
Test Current
Max.
Clamping
Voltage
10/1000µs
Max.
Peak Pulse
Current
10/1000µs
Reverse
Leakage
IT
VC@IPP
IPP
IR@VRWM
UNI
BI
V
V
V
mA
V
A
µA
P6KE150A
P6KE150CA
128.00
143.00
158.00
1
207.0
2.90
1
P6KE160A
P6KE160CA
136.00
152.00
168.00
1
219.0
2.70
1
P6KE170A
P6KE170CA
145.00
162.00
179.00
1
234.0
2.60
1
P6KE180A
P6KE180CA
154.00
171.00
189.00
1
246.0
2.40
1
P6KE200A
P6KE200CA
171.00
190.00
210.00
1
274.0
2.20
1
P6KE220A
P6KE220CA
185.00
209.00
231.00
1
328.0
1.83
1
P6KE250A
P6KE250CA
214.00
237.00
263.00
1
344.0
1.75
1
P6KE300A
P6KE300CA
256.00
285.00
315.00
1
414.0
1.45
1
P6KE350A
P6KE350CA
300.00
332.00
368.00
1
482.0
1.25
1
P6KE400A
P6KE400CA
342.00
380.00
420.00
1
548.0
1.10
1
P6KE440A
P6KE440CA
376.00
418.00
462.00
1
602.0
1.00
1
P6KE500A
P6KE500CA
427.50
475.00
525.00
1
690.0
0.87
1
P6KE520A
P6KE520CA
444.60
494.00
546.00
1
717.6
0.84
1
P6KE530A
P6KE530CA
450.00
503.5
556.50
1
725.0
0.80
1
P6KE550A
P6KE550CA
470.30
522.50
577.50
1
759.0
0.79
1
P6KE600A
P6KE600CA
513.00
570.00
630.00
1
828.0
0.72
1
Revised: 2023-12-13
Version: A1
Page 3
P6KE Series
I-V Curve Characteristics
Uni-directional
Bi-directional
I
VC VBR VR
IR VF
IT
IPP
IT
IR
VC VBR VR
V
IR
IT
VR VBR VC
V
IPP
IPP
PPPM Peak Pulse Power Dissipation -- Max power dissipation
VR Stand-off Voltage -- Maximum voltage that can be applied to the TVS without operation
VBR Breakdown Voltage -- Maximum voltage that flows though the TVS at a specified test current (IT)
VC Clamping Voltage -- Peak voltage measured across the TVS at a specified Ippm (peak impulse current)
IR Reverse Leakage Current – Current measured at VR
VF Forward Voltage Drop for Uni-directional
Ratings and Characteristic Curves (TA=25°C unless otherwise noted)
Figure 1 - TVS Transients Clamping Waveform
Figure 2 - Peak Pulse Power Rating Curve
100
PPPM-Peak Pulse Power (kW)
Voltage or Current
Voltage Transients
Voltage Across TVS
Current Through TVS
TJ initial =
Tamb
stacked-die, 800W
at 10x1000μs, 25°C
10
Single die, 600W
at 10x1000μs, 25°C
1
0.1
Time
Revised: 2023-12-13
Version: A1
0.001
0.01
0.1
1
10
td-Pulse Width (ms)
Page 4
Peak Pulse Power (PPP) or Current (IPP)
Derating in Percentage %
Figure 3 - Pulse Derating Curve
Figure 4 - Pulse Waveform
150
IPPM - Peak Pulse Cur rent, % IRSM
100
75
50
25
tr=10μsec
50
75
100
125
150
175
TJ =25°C
Pulse Width(td) is defined
as the point where the peak
current decays to 50% of IPPM
Peak Value
IPPM
100
Half Value
IPPM ( IPPM )
2
50
P6KE Series
200
10/1000μsec.Waveform
as defined by R.E.A
td
2.0
3.0
4.0
t-Time(ms)
TA-Ambient temperature (ºC)
Figure 5 - Typical Junction Capacitance
Figure 6 - Steady State Power Derating Curve
Bi-directional V=0V
Uni-directional V=0V
1000
Uni-directional @VR
Cj (pF)
100
Bi-directional @VR
10
Tj=25ºC
f=1.0MHz
Vsig=50mVp-p
1
1.0
10.0
100.0
1000.0
VBR - Reverse Breakdown Voltage (V)
PM(AV), Steady State Power Dissipation (W)
10000
5.0
4.0
3.0
2.0
60Hz Resistive or
Inductive Load
1.0
0.0
50
75
100 125 150
TL-Lead Temperature(ºC)
175
200
IFSM - Peak Forward Surve Current
(A)
Figure 7 - Maximum Non-Repetitive Surge Current
120
Pulse Width 8.3ms
Single Half-Sine-Wave
(JEDEC METHOD)
100
80
60
40
10
100
Number of Cycles at 60 Hz
Revised: 2023-12-13
Version: A1
Page 5
P6KE Series
Part Marking System
Cathode band(for Uni-directional products only)
P6KExxxCA
Type Number
Dimensions
Millimeters
DIM
Inches
Min
Max
Min
Max
A
25.40
1.000
B
5.80
7.60
0.228
0.299
C
0.70
0.90
0.028
0.035
D
2.60
3.60
0.102
0.142
Packaging Information
Symbol
Millimeters
Inches
A
5.08±0.5
0.2±0.019
B
53.0±1.0
2.087±0.039
Z
1.2Max
0.047 Max
T
6.0±0.4
0.236±0.015
E
0.8Max
0.031 Max
L1-L2
1.0Max
0.039 Max
Symbol
Millimeters
Inches
D
250.0±5.0
9.843±0.197
C
75.0±5.0
2.953±0.197
H
114.0±5.0
4.488±0.197
Quantity
Revised: 2023-12-13
Version: A1
2000PCS / inner box
Page 6
很抱歉,暂时无法提供与“P6KE300A”相匹配的价格&库存,您可以联系我们找货
