SA15CA
SA15CA
    AM(安美)
    DO-15(DO-204AC)
    双向TVS 15V截止 峰值脉冲电流:20.5A@10/1000US
SA15CA 数据手册
SA SERIES Transient Voltage Suppressor Diodes Uni-directional Features ● Excellent clamping capability ● Low dynamic impedance ● Solder dip 275 °C max. 7 s, per JESD 22-B106 Mechanical Data ● Package: DO-204AC(DO-15) Molding compound meets UL 94 V-0 flammability rating, RoHS-compliant ● Terminals: Tin plated leads, solderable per J-STD002 and JESD22-B102 ● Polarity:Color band denotes cathode end Bi-directional ■Maximum Ratings (Ta=25℃ Unless otherwise specified) PARAMETER SYMBOL UNIT Max Peak power dissipation, with a 10/1000us waveform (1) PPPM W 500 Peak pulse current, with a 10/1000us waveform (1) IPPM A See Next Table Power dissipation, on infinite heat sink at TL=75℃ PD W 3 Peak forward surge current, 8.3 ms single half sine-wave unidirectional only(2) IFSM A 70 TJ,TSTG ℃ -55 to +150 Operating junction and storage temperature range ■Electrical Characteristics(Ta=25℃ Unless otherwise specified) PARAMETER Maximum instantaneous forward voltage at 35A for unidirectional only SYMBOL UNIT VALUE VFM V 3.5 Notes: (1) Non-repetitive current pulse, per Fig. 3 and derated above TA= 25℃per Fig.2. (2) Measured on 8.3ms single half sine-wave or equivalent square wave,duty cycle=4 pulses per minute maximum. Document Number:8060007 Revision:21-Apr-28 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn ~1~ SA SERIES ■ Electrical Characteristics (TA=25℃ unless otherwise noted) Part Number(U ni) VBR@IT Breakdown Voltage VBR@IT Part Number(Bi) Min(V) Max (V) IT(mA) IR Maximum Reverse Leakage IR @ VWM (μA) VRWM Working Peak Reverse Voltage VRWM (V) IPP Maximum Reverse Surge Current IPP (A) Maximum Clamping Voltage Vc @ IPP (V) Maximum Temperature Coefficient of VBR (%/°C) SA5.0 SA5.0C 6.40 7.30 10 600 5.0 52.1 9.6 5.0 SA5.0A SA5.0CA 6.4 7.07 10 600 5.0 54.3 9.2 5.0 SA6.0 SA6.0C 6.67 8.15 10 600 6.0 43.9 11.4 5.0 SA6.0A SA6.0CA 6.67 7.37 10 600 6.0 48.5 10.3 5.0 SA6.5 SA6.5C 7.22 8.82 10 400 6.5 40.7 12.3 5.0 SA6.5A SA6.5CA 7.22 7.98 10 400 6.5 44.7 11.2 5.0 SA7.0 SA7.0C 7.78 9.51 10 150 7.0 37.6 13.3 6.0 SA7.0A SA7.0CA 7.78 8.60 10 150 7.0 41.7 12.0 6.0 SA7.5 SA7.5C 8.33 10.2 1.0 50 7.5 35.0 14.3 7.0 SA7.5A SA7.5CA 8.33 9.21 1.0 50 7.5 38.8 12.9 7.0 SA8.0 SA8.0C 8.89 10.9 1.0 25 8.0 33.3 15.0 7.0 SA8.0A SA8.0CA 8.89 9.83 1.0 25 8.0 36.8 13.6 7.0 SA8.5 SA8.5C 9.44 11.5 1.0 5.0 8.5 31.4 15.9 8.0 SA8.5A SA8.5CA 9.44 10.4 1.0 5.0 8.5 34.7 14.4 8.0 SA9.0 SA9.0C 10.0 12.2 1.0 5.0 9.0 29.6 16.9 9.0 SA9.0A SA9.0CA 10.0 11.1 1.0 5.0 9.0 32.5 15.4 9.0 SA10 SA10C 11.1 13.6 1.0 5.0 10 26.6 18.8 10 SA10A SA10CA 11.1 12.3 1.0 5.0 10 29.4 17.0 10 SA11 SA11C 12.2 14.9 1.0 5.0 11 24.9 20.1 11 SA11A SA11CA 12.2 13.5 1.0 5.0 11 27.5 18.2 11 SA12 SA12C 13.3 16.3 1.0 5.0 12 22.7 22.0 12 SA12A SA12CA 13.3 14.7 1.0 5.0 12 25.1 19.9 12 SA13 SA13C 14.4 17.6 1.0 5.0 13 21.0 23.8 13 SA13A SA13CA 14.4 15.9 1.0 5.0 13 23.3 21.5 13 SA14 SA14C 15.6 19.1 1.0 5.0 14 19.4 25.8 14 SA14A SA14CA 15.6 17.2 1.0 5.0 14 21.6 23.2 14 SA15 SA15C 16.7 20.4 1.0 5.0 15 18.6 26.9 16 SA15A SA15CA 16.7 18.5 1.0 5.0 15 20.5 24.4 16 SA16 SA16C 17.8 21.8 1.0 5.0 16 17.4 28.8 19 SA16A SA16CA 17.8 19.7 1.0 5.0 16 19.2 26.0 17 SA17 SA17C 18.9 23.1 1.0 5.0 17 16.4 30.5 20 SA17A SA17CA 18.9 20.9 1.0 5.0 17 18.1 27.6 19 SA18 SA18C 20.0 24.4 1.0 5.0 18 15.5 32.2 21 SA18A SA18CA 20.0 22.1 1.0 5.0 18 17.1 29.2 20 SA19 SA19C 21.13 25.76 1.0 5.0 19.0 14.7 34.0 23 SA19A SA19CA 21.1 23.3 1.0 5.0 19.0 16.24 30.8 21 SA20 SA20C 22.2 27.1 1.0 5.0 20 14.0 35.8 25 Document Number:8060007 Revision:21-Apr-28 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn ~2~ SA SERIES ■ Electrical Characteristics (TA=25℃ unless otherwise noted) Part Number(U ni) Part Number(Bi) SA20A VBR@IT Breakdown Voltage VBR@IT IR Maximum Reverse Leakage IR @ VWM (μA) VRWM Working Peak Reverse Voltage VRWM (V) IPP Maximum Reverse Surge Current IPP (A) Maximum Clamping Voltage Vc @ IPP (V) Maximum Temperature Coefficient of VBR (%/°C) 5.0 20 15.4 32.4 23 Min(V) Max (V) IT(mA) SA20CA 22.2 24.5 1.0 SA22 SA22C 24.4 29.8 1.0 5.0 22 22.7 39.4 28 SA22A SA22CA 24.4 26.9 1.0 5.0 22 14.1 35.5 25 SA24 SA24C 26.7 32.6 1.0 5.0 24 11.6 43.0 31 SA24A SA24CA 26.7 29.5 1.0 5.0 24 12.9 38.9 28 SA26 SA26C 28.9 35.3 1.0 5.0 26 10.7 46.6 31 SA26A SA26CA 28.9 31.9 1.0 5.0 26 11.9 42.1 30 SA28 SA28C 31.1 38.0 1.0 5.0 28 10.0 50.1 35 SA28A SA28CA 31.1 34.4 1.0 5.0 28 11.0 45.4 31 SA30 SA30C 33.3 40.7 1.0 5.0 30 9.3 53.5 39 SA30A SA30CA 33.3 36.8 1.0 5.0 30 10.0 48.4 36 SA33 SA33C 36.7 44.9 1.0 5.0 33 8.5 59.0 42 SA33A SA33CA 36.7 40.6 1.0 5.0 33 9.4 53.3 39 SA36 SA36C 40.0 48.9 1.0 5.0 36 7.8 64.3 46 SA36A SA36CA 40.0 44.2 1.0 5.0 36 8.6 58.1 41 SA40 SA40C 44.4 54.3 1.0 5.0 40 7.0 71.4 51 SA40A SA40CA 44.4 49.1 1.0 5.0 40 7.8 64.5 46 SA43 SA43C 47.8 58.4 1.0 5.0 43 6.5 76.7 55 SA43A SA43CA 47.8 52.8 1.0 5.0 43 7.2 69.4 50 SA45 SA45C 50.0 61.1 1.0 5.0 45 6.2 80.3 58 SA45A SA45CA 50.0 55.3 1.0 5.0 45 6.9 72.7 52 SA48 SA48C 53.3 65.2 1.0 5.0 48 5.8 85.5 63 SA48A SA48CA 53.3 58.9 1.0 5.0 48 6.5 77.4 56 SA51 SA51C 56.7 69.3 1.0 5.0 51 5.5 91.1 66 SA51A SA51CA 56.7 62.7 1.0 5.0 51 6.1 82.4 61 SA54 SA54C 60.0 73.3 1.0 5.0 54 5.2 96.3 71 SA54A SA54CA 60.0 66.3 1.0 5.0 54 5.7 87.1 65 SA58 SA58C 64.4 78.7 1.0 5.0 58 4.9 103 78 SA58A SA58CA 64.4 71.2 1.0 5.0 58 5.3 93.6 70 SA60 SA60C 66.7 81.5 1.0 5.0 60 4.7 107 80 SA60A SA60CA 66.7 73.7 1.0 5.0 60 5.2 96.8 71 SA64 SA64C 71.1 86.9 1.0 5.0 64 4.4 114 86 SA64A SA64CA 71.1 78.6 1.0 5.0 64 4.9 103 76 SA70 SA70C 77.8 95.1 1.0 5.0 70 4.0 125 94 SA70A SA70CA 77.8 86.0 1.0 5.0 70 4.4 113 85 SA75 SA75C 83.3 102 1.0 5.0 75 3.7 134 101 Document Number:8060007 Revision:21-Apr-28 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn ~3~ SA SERIES ■ Electrical Characteristics (TA=25℃ unless otherwise noted) Part Number(U ni) Part Number(Bi) SA75A VBR@IT Breakdown Voltage VBR@IT IR Maximum Reverse Leakage IR @ VWM (μA) VRWM Working Peak Reverse Voltage VRWM (V) IPP Maximum Reverse Surge Current IPP (A) Maximum Clamping Voltage Vc @ IPP (V) Maximum Temperature Coefficient of VBR (%/°C) Min(V) Max (V) IT(mA) SA75CA 83.3 92.1 1.0 5.0 75 4.1 121 91 SA78 SA78C 86.7 106 1.0 5.0 78 3.6 139 105 SA78A SA78CA 86.7 95.8 1.0 5.0 78 4.0 126 95 SA85 SA85C 94.4 115 1.0 5.0 85 3.3 151 114 SA85A SA85CA 94.4 104 1.0 5.0 85 3.6 137 103 SA90 SA90C 100 122 1.0 5.0 90 3.1 160 121 SA90A SA90CA 100 111 1.0 5.0 90 3.4 146 110 SA100 SA100C 111 136 1.0 5.0 100 2.8 179 135 SA100A SA100CA 111 123 1.0 5.0 100 3.1 162 123 SA110 SA110C 122 149 1.0 5.0 110 2.6 196 148 SA110A SA110CA 122 135 1.0 5.0 110 2.8 177 133 SA120 SA120C 133 163 1.0 5.0 120 2.3 214 162 SA120A SA120CA 133 147 1.0 5.0 120 2.6 193 146 SA130 SA130C 144 176 1.0 5.0 130 2.2 230 175 SA130A SA130CA SA140 SA140C 144 159 1.0 5.0 130 2.4 209 158 155.68 190.4 1.0 5.0 140.0 2.0 250.6 188 SA140A SA140CA 155 171 1.0 5.0 140.0 2.20 226.8 170 SA150 SA150C 167 204 1.0 5.0 150 1.9 268 203 SA150A SA150CA 167 185 1.0 5.0 150 2.1 243 184 SA160 SA160C 178 218 1.0 5.0 160 1.7 257 217 SA160A SA160CA 178 197 1.0 5.0 160 1.9 259 196 SA170 SA170C 189 231 1.0 5.0 170 1.6 304 230 SA170A SA170CA 189 209 1.0 5.0 170 1.8 275 208 SA180 SA180C 200.16 244.80 1.0 5.0 180.0 1.55 322.2 244 SA180A SA180CA 200.0 220.0 1.0 5.0 180.0 1.71 291.6 221 SA190 SA190C 211.28 258.40 1.0 5.0 190.0 1.47 340.1 258 SA190A SA190CA 211.0 232.0 1.0 5.0 190.0 1.62 307.8 234 Document Number:8060007 Revision:21-Apr-28 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn ~4~ SA SERIES ■ Characteristics(Typical) : PPPM(KW) FIG1:Peak Pulse Power Rating Curve 100 100 不重复脉冲波形见图 3 Non-Repetitive Pulse Waveform shown in Fige.3 TA=25℃ 75 10 50 1.0 25 0.1 0.1 1 10 100 1000 0 10000 0 25 50 75 100 125 150 175 200 td(μs) ℃) FIG3: Pulse Waveform IPPM(%) : 150 tr=10μs Peak Value IPPM 8.0 TJ=25 ℃ Pulse Width(td) is defined as the Point where the Peak Current Decays to 50% of IPPM 60 6.0 100 Half Value - IPP 2 IPPM 4.0 50 10/1000μs Waveform as Defined by R.E.A. ) 2.0 td 0 1.0 0 2.0 3.0 0 4.0 0 25 50 75 100 125 150 175 t(ms) 200 ℃) FIG6:Typical Instantaneous Forward Voltage : IF(A) 80 正弦半波 100 TJ=25℃ Pulse Width=300μs 1% Duty Cycle 60 20 10 40 2.0 20 1.0 0.2 0 1 10 100 0.1 0 0.5 1 1.5 2 2.5 VF(V) Document Number:8060007 Revision:21-Apr-28 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn ~5~ SA SERIES ■ Ordering Information (Example) PREFERED PACKAGE CODE MINIMUM PACKAGE(pcs) INNER BOX QUANTITY(pcs) OUTER CARTON QUANTITY(pcs) DELIVERY MODE SA Series DO-15 3000 3000 30000 Ammo box ■ Outline Dimensions DO-204AC(DO -15 ) 1.0(25.4) MIN 1.0(25.4) MIN .142(3.60) .031(0.80) .102(2.60) .028(0.70) DIA .300(7.60) .228(5.80) Unit: in inches (millimeters) Document Number:8060007 Revision:21-Apr-28 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn ~6~ SA SERIES IMPORTANT NOTICE AND DISCLAIMER AM RESERVES THE RIGHT TO MAKE CHANGES TO ALL PRODUCT, PRODUCT SPECIFICATIONS AND DATA WITHOUT NOTICE TO IMPROVE RELIABILITY, FUNCTION OR DESIGN OR OTHERWISE. CUSTOMERS SHOULD OBTAIN AND CONFIRM THE LATEST PRODUCT INFORMATION AND SPECIFICATIONS BEFORE FINAL DESIGN PURCHASE OR USE. AM disclaim any and all liability for any errors, inaccuracies or incompleteness contained in any datasheet or in any other disclosure relating to any product. All information are provided as-is, even it has qualified by the AEC-Q101 which satisfy industrial application requirement, except as expressly stated in this data sheet is applied for automotive grade, AM make no warranties, representation or guarantee, whether express, implied or statutory, including, without limitation, regarding any merchantability, satisfactory quality, or fitness for a particular purpose with respect to AM. AM does not assume any liability or compensation for any application assistance or customer product design, and make no warranty or accept any liability with products, which are purchased or used for any unintended or unauthorized application. Except as expressly indicated in writing, AM products are not designed for use in medical, life-saving, or lifesustaining applications or for any other application in which the failure of the AM product could result in personal injury or death. Customers using or selling AM products not expressly indicated for use in such applications do so at their own risk. Please contact authorized AM personnel to obtain written terms and conditions regarding products designed for such applications. No license, express or implied, by estoppel or otherwise, to any intellectual property rights is granted by this document or by any conduct of AM. Product names and markings noted herein may be trademarks of their respective owners. Document Number:8060007 Revision:21-Apr-28 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn ~7~
SA15CA 价格&库存
很抱歉,暂时无法提供与“SA15CA”相匹配的价格&库存,您可以联系我们找货
