P6KE56CA
P6KE56CA
    SCME(晟驰微)
    DO-15(DO-204AC)
    P6KE56CA
P6KE56CA 数据手册
SEMICON CHAMPION Axial 600W_P6KE Series Quality | Customer Focus Features - 600W peak pulse power capability at 10/1000μs waveform, repetition rate (duty cycles):0.01% - Excellent clamping capability - Typical failure mode is a short circuit condition for current events exceeding component rating - Plastic package is flammability rated V-0 per UL-94 - IEC61000-4-2 +/-30kV both contact and air - IEC61000-4-4 50A(5/50nS) Applications TVS devices are ideal for the transient voltage clamp protection of I/O Interfaces, DC power line bus and other circuits used in Telecom, Computer, Industrial and Consumer electronic applications. Function Diagram Maximum Ratings and Thermal Characteristics (TA=25OC unless otherwise noted) Parameter Peak Pulse Power Dissipation at T A=25 ºC by 10/1000µs Waveform (Fig.3)-single die Symbol Value Unit PPPM 600 W PPPM 800 W PD 5 W IFSM 100 A AGENCY AGENCY FILE NUMBER Pending Peak Pulse Power Dissipation at T A=25 ºC by 10/1000µs Waveform (Fig.3)-stack die Power Dissipation on Infinite Heat Sink at T L=50 OC Peak Forward Surge Current, 8.3ms Single Half Sine Wave (Note 1) Maximum Instantaneous Forward Voltage at 50A for Unidirectional Only(Note 2) Operating Temperature Range Storage Temperature Range Notes: 3.5/5 V TJ -55 to 150 °C TSTG -55 to 150 °C VF 1. Measured on 8.3ms single half sine wave or equivalent square wave for unidirectional device only, duty cycle=4 per minute maximum. 2. 3.5V for single die, 5V for stack die Jiangsu Semicon Champion Microelectronics Co., Ltd. 1/7 SEMICON CHAMPION Axial 600W_P6KE Series Quality | Customer Focus Characteristics (T =25°C unless otherwise noted) Part Number Part Number (Uni) (Bi) Reverse Stand off Voltage VR (Volts) Breakdown Voltage VBR (Volts) @ IT MIN Test Maximum Maximum Current Clamping Peak IT MAX (mA) Maximum Agency Reverse Leakage Approval Voltage VC @ Ipp Pulse Current Ipp (A) IR @ VR (µA) (V) P6KE6.8A P6KE6.8CA 5.80 6.45 7.14 10 10.5 58.1 1000 P6KE7.5A P6KE7.5CA 6.40 7.13 7.88 10 11.3 54.0 500 P6KE8.2A P6KE8.2CA 7.02 7.79 8.61 10 12.1 50.4 200 P6KE9.1A P6KE9.1CA 7.78 8.65 9.55 1 13.4 45.5 50 P6KE10A P6KE10CA 8.55 9.50 10.50 1 14.5 42.1 10 P6KE11A P6KE11CA 9.40 10.50 11.60 1 15.6 39.1 5 P6KE12A P6KE12CA 10.20 11.40 12.60 1 16.7 36.5 5 P6KE13A P6KE13CA 11.10 12.40 13.70 1 18.2 33.5 1 P6KE15A P6KE15CA 12.80 14.30 15.80 1 21.2 28.8 1 P6KE16A P6KE16CA 13.60 15.20 16.80 1 22.5 27.1 1 P6KE18A P6KE18CA 15.30 17.10 18.90 1 25.2 24.2 1 P6KE20A P6KE20CA 17.10 19.00 21.00 1 27.7 22.0 1 P6KE22A P6KE22CA 18.80 20.90 23.10 1 30.6 19.9 1 P6KE24A P6KE24CA 20.50 22.80 25.20 1 33.2 18.4 1 P6KE27A P6KE27CA 23.10 25.70 28.40 1 37.5 16.3 1 P6KE30A P6KE30CA 25.60 28.50 31.50 1 41.4 14.7 1 P6KE33A P6KE33CA 28.20 31.40 34.70 1 45.7 13.3 1 P6KE36A P6KE36CA 30.80 34.20 37.80 1 49.9 12.2 1 P6KE39CA 33.30 37.10 41.00 1 53.9 11.3 1 P6KE43A P6KE43CA 36.80 40.90 45.20 1 59.3 10.3 1 P6KE47A P6KE47CA 40.20 44.70 49.40 1 64.8 9.4 1 P6KE51A P6KE51CA 43.60 48.50 53.60 1 70.1 8.7 1 P6KE56A P6KE56CA 47.80 53.20 58.80 1 77.0 7.9 1 P6KE62A P6KE62CA 53.00 58.90 65.10 1 85.0 7.2 1 P6KE68A P6KE68CA 58.10 64.60 71.40 1 92.0 6.6 1 P6KE75A P6KE75CA 64.10 71.30 78.80 1 103.0 5.9 1 P6KE82A P6KE82CA 70.10 77.90 86.10 1 113.0 5.4 1 P6KE91A P6KE91CA 77.80 86.50 95.50 1 125.0 4.9 1 P6KE100A P6KE100CA 85.50 95.00 105.00 1 137.0 4.5 1 P6KE110A P6KE110CA 94.00 105.00 116.00 1 152.0 4.0 1 P6KE120A P6KE120CA 102.00 114.00 126.00 1 165.0 3.7 1 P6KE130A P6KE130CA 111.00 124.00 137.00 1 179.0 3.4 1 P6KE150A P6KE150CA 128.00 143.00 158.00 1 207.0 2.9 1 P6KE160A P6KE160CA 136.00 152.00 168.00 1 219.0 2.8 1 P6KE170A P6KE170CA 145.00 162.00 179.00 1 234.0 2.6 1 P6KE180A P6KE180CA 154.00 171.00 189.00 1 246.0 2.5 1 P6KE200A P6KE200CA 171.00 190.00 210.00 1 274.0 2.2 1 P6KE220A P6KE220CA 185.00 209.00 231.00 1 328.0 1.9 1 P6KE250A - 214.00 237.00 263.00 1 344.0 1.8 1 P6KE250CA* 214.00 237.00 263.00 1 344.0 2.4 1 - 256.00 285.00 315.00 1 414.0 1.5 1 P6KE300CA* 256.00 285.00 315.00 1 414.0 2.0 1 P6KE350A* P6KE350CA* 300.00 332.00 368.00 1 482.0 1.7 1 P6KE400A* P6KE400CA* 342.00 380.00 420.00 1 548.0 1.5 1 P6KE440A* P6KE440CA* 376.00 418.00 462.00 1 602.0 1.4 1 P6KE480A* P6KE480CA* 408.00 456.00 504.00 1 658.0 1.3 1 P6KE510A* P6KE510CA* 434.00 485.00 535.00 1 698.0 1.2 1 P6KE520A* P6KE520CA* 444.60 494.00 546.00 1 717.6 0.84 1 P6KE530A* P6KE530CA* 451.00 503.50 556.50 1 725.0 1.2 1 P6KE540A* P6KE540CA* 460.00 513.00 567.00 1 740.0 1.1 1 P6KE550A* P6KE550CA* 468.00 522.50 577.50 1 760.0 1.1 1 P6KE600A* P6KE600CA* 512.00 570.00 630.00 1 828.0 1.0 1 P6KE39A P6KE300A For stacked-die parts,use * to label the part number. Jiangsu Semicon Champion Microelectronics Co., Ltd. 2/7 SEMICON CHAMPION Axial 600W_P6KE Series Quality | Customer Focus I-V Curve Characteristics PPPM Peak Pulse Power Dissipation -- Max power dissipation VR Stand-off Voltage -- Maximum voltage that can be applied to the TVS without operation VBR Breakdown Voltage -- Maximum voltage that flows though the TVS at a specified test current (IT) VC Clamping Voltage -- Peak voltage measured across the TVS at a specified IPPM (peak impulse current) IR Reverse Leakage Current -- Current measured at VR VF Forward Voltage Drop for Uni-directional Jiangsu Semicon Champion Microelectronics Co., Ltd. 3/7 SEMICON CHAMPION Axial 600W_P6KE Series Quality | Customer Focus Ratings and Characteristic Curves (T =25°C unless otherwise noted) Figure 1. Peak pulse power derating curve Figure2. Pulse waveform Stack die 800W 10/1000uS, 25C Single die 600W 10/1000uS, 25C Figure 3. Peak pulse power rating curve Figure 4. Jiangsu Semicon Champion Microelectronics Co., Ltd. 4/7 Maximum non-repetitive surge current SEMICON CHAMPION Axial 600W_P6KE Series Soldering profile Quality | Customer Focus Soldering Parameters Reflow Condition Pre Heat - Temperature Min (Ts(min)) 150°C - Temperature Max (Ts(max)) 200°C - Time (min to max) (t s) 60 – 180 secs Average ramp up rate (Liquidus Temp (T A) to peak TS(max) to TA - Ramp-up Rate Reflow Lead–free assembly 3°C/second max 3°C/second max - Temperature (TA) (Liquidus) 217°C - Time (min to max) (t s) 60 – 150 seconds Peak Temperature (TP) Time within 5°C of actual peak Temperature (tp) 260 +0/-5 °C 20 – 40 seconds Ramp-down Rate 6°C/second max Time 25°C to peak Temperature (TP) 8 minutes Max. Do not exceed 260°C Flow/Wave Soldering (Solder Dipping) Peak Temperature: 265ºC Dipping Time: 10 seconds Soldering: 1 time Jiangsu Semicon Champion Microelectronics Co., Ltd. 5/7 SEMICON CHAMPION Axial 600W_P6KE Series Quality | Customer Focus Dimensions Cathode Band (for uni-directional products only) D C A A B Inches Dimensions Min Millimeters Max Min Max - 25.40 - A 1.000 B 0.230 0.300 5.80 7.60 C 0.028 0.034 0.71 0.86 D 0.104 0.140 2.60 3.60 Part Numbering Part Marking Product Type Marking Code P6KE xx xx A: Uni-directional CA: Bi-directional Reverse Standard off Voltage VR Product series Cathode band (for uni-directional products only) Packing Part number Package name Small packing quantity Packing method P6KEXXXX DO-15 4000 Tape & Reel Jiangsu Semicon Champion Microelectronics Co., Ltd. 6/7 SEMICON CHAMPION Axial 600W_P6KE Series Quality | Customer Focus Tape and Reel Specification Revision history of Specification Version Change Items 1.0 Initial Release 1.1 Change marking logo location Effective Date 14-July-2021 27-May-2021 Jiangsu Semicon Champion Microelectronics Co., Ltd. 7/7
P6KE56CA 价格&库存
很抱歉,暂时无法提供与“P6KE56CA”相匹配的价格&库存,您可以联系我们找货
