P6KE6.8A
P6KE6.8A
    AM(安美)
    DO-15(DO-204AC)
    单向TVS 5.8V截止 峰值脉冲电流:57.1A
P6KE6.8A 数据手册
  P6KE SERIES Transient Voltage Suppressor Diodes Uni-directional Features ● Excellent clamping capability ● Low dynamic impedance ● Solder dip 275 °C max. 7 s, per JESD 22-B106 Mechanical Data ● Package: DO-204AC(DO-15) Molding compound meets UL 94 V-0 flammability rating, RoHS-compliant ● Terminals: Tin plated leads, solderable per J-STD002 and JESD22-B102 ● Polarity:Color band denotes cathode end Bi-directional ■Maximum Ratings (Ta=25℃ Unless otherwise specified) PARAMETER Peak power dissipation, with a 10/1000us waveform Peak pulse current, with a 10/1000us waveform SYMBOL (1) (1) Power dissipation, on infinite heat sink at TL=75℃ (2) Peak forward surge current, 8.3 ms single half sine-wave unidirectional only Operating junction and storage temperature range UNIT Max PPPM W 600 IPPM A See Next Table PD W 5 IFSM A 100 TJ,TSTG ℃ -55 to +150 SYMBOL UNIT VALUE VFM V 3.5/5.0 ■Electrical Characteristics(Ta=25℃ Unless otherwise specified) PARAMETER Maximum instantaneous forward voltage at 25A for unidirectional only(3) ■Thermal Characteristics (Ta=25℃ Unless otherwise specified) PARAMETER SYMBOL UNIT Conditions VALUE RθJ-A ℃/W Junction to ambient 75 RθJ-L ℃/W Junction to lead 20 Thermal Resistance(Typical) Notes: (1) (2) (3) Non-repetitive current pulse, per Fig. 3 and derated above TA= 25℃per Fig.2. Measured on 8.3ms single half sine-wave or equivalent square wave,duty cycle=4 pulses per minute maximum. VF=3.5V Max for devices of VBR≤220V,and VF=5.0V Max for devices of VBR>220V. Document Number:8060009 Revision:21-Apr-28 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn ~1~   P6KE SERIES ■ Electrical Characteristics (TA=25℃ unless otherwise noted) Part Number( U ni) Part Number(Bi) VBR@IT Breakdown Voltage VBR@IT Min(V) Max (V) IT(mA) IR Maximum Reverse Leakage IR @ VWM (μA) VRWM Working Peak Reverse Voltage VRWM (V) IPP Maximum Reverse Surge Current IPP (A) Maximum Clamping Voltage Vc @ IPP (V) P6KE6.8 P6KE6.8C 6.12 7.48 10 1000 5.50 55.6 10.8 P6KE6.8A P6KE6.8CA 6.45 7.14 10 1000 5.80 57.1 10.5 P6KE7.5 P6KE7.5C 6.75 8.25 10 500 6.05 51.3 11.7 P6KE7.5A P6KE7.5CA 7.13 7.88 10 500 6.40 53.1 11.3 P6KE8.2 P6KE8.2C 7.38 9.02 10 200 6.63 48.0 12.5 P6KE8.2A P6KE8.2CA 7.79 8.61 10 200 7.02 49.6 12.1 P6KE9.1 P6KE9.1C 8.19 10.0 1.0 50 7.37 43.5 13.8 P6KE9.1A P6KE9.1CA 8.65 9.55 1.0 50 7.78 44.8 13.4 P6KE10 P6KE10C 9.00 11.0 1.0 10 8.10 40.0 15 P6KE10A P6KE10CA 9.50 10.5 1.0 10 8.55 41.4 14.5 P6KE11 P6KE11C 9.90 12.1 1.0 5.0 8.92 37.0 16.2 P6KE11A P6KE11CA 10.5 11.6 1.0 5.0 9.40 38.5 15.6 P6KE12 P6KE12C 10.8 13.2 1.0 5.0 9.72 34.7 17.3 P6KE12A P6KE12CA 11.4 12.6 1.0 5.0 10.2 35.9 16.7 P6KE13 P6KE13C 11.7 14.3 1.0 5.0 10.5 31.6 19 P6KE13A P6KE13CA 12.4 13.7 1.0 5.0 11.1 33.0 18.2 P6KE15 P6KE15C 13.5 16.5 1.0 5.0 P6KE15A P6KE15CA 14.3 15.8 1.0 5.0 12.8 28.3 21.2 P6KE16 P6KE16C 14.4 17.6 1.0 5.0 12.9 25.5 23.5 P6KE16A P6KE16CA 15.2 16.8 1.0 5.0 13.6 26.7 22.5 P6KE18 P6KE18C 16.2 19.8 1.0 5.0 14.5 22.6 26.5 P6KE18A P6KE18CA 17.1 18.9 1.0 5.0 15.3 23.8 25.2 P6KE20 P6KE20C 18.0 22.0 1.0 5.0 16.2 20.6 29.1 P6KE20A P6KE20CA 19.0 21.0 1.0 5.0 17.1 21.7 27.7 P6KE22 P6KE22C 19.8 24.2 1.0 5.0 17.8 18.8 31.9 P6KE22A P6KE22CA 20.9 23.1 1.0 5.0 18.8 19.6 30.6 P6KE24 P6KE24C 21.6 26.4 1.0 5.0 19.4 17.3 34.7 P6KE24A P6KE24CA 22.8 25.2 1.0 5.0 20.5 18.1 33.2 P6KE27 P6KE27C 24.3 29.7 1.0 5.0 21.8 15.3 39.1 12.1 27.3 22 P6KE27A P6KE27CA 25.7 28.4 1.0 5.0 23.1 16.0 37.5 P6KE30 P6KE30C 27.0 33.0 1.0 5.0 24.3 13.8 43.5 P6KE30A P6KE30CA 28.5 31.5 1.0 5.0 25.6 14.5 41.4 P6KE33 P6KE33C 29.7 36.3 1.0 5.0 26.8 12.6 47.7 P6KE33A P6KE33CA 31.4 34.7 1.0 5.0 28.2 13.1 45.7 P6KE36 P6KE36C 32.4 39.6 1.0 5.0 29.1 11.5 52 P6KE36A P6KE36CA 34.2 37.8 1.0 5.0 30.8 12.0 49.9 Document Number:8060009 Revision:21-Apr-28 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn ~2~   P6KE SERIES ■ Electrical Characteristics (TA=25℃ unless otherwise noted) Part Number(Uni) Part Number(Bi) VBR@IT Breakdown Voltage VBR@IT Min(V) Max (V) IT(mA) IR Maximum Reverse Leakage IR @ VWM (μA) VRWM Working Peak Reverse Voltage VRWM (V) IPP Maximum Reverse Surge Current IPP (A) Maximum Clamping Voltage Vc @ IPP (V) P6KE39 P6KE39C 35.1 42.9 1.0 5.0 31.6 10.6 56.4 P6KE39A P6KE39CA 37.1 41.0 1.0 5.0 33.3 11.1 53.9 P6KE43 P6KE43C 38.7 47.3 1.0 5.0 34.8 9.7 61.9 P6KE43A P6KE43CA 40.9 45.2 1.0 5.0 36.8 10.1 59.3 P6KE47 P6KE47C 42.3 51.7 1.0 5.0 38.1 8.8 67.8 P6KE47A P6KE47CA 44.7 49.4 1.0 5.0 40.2 9.3 64.8 P6KE51 P6KE51C 45.9 56.1 1.0 5.0 41.3 8.2 73.5 P6KE51A P6KE51CA 48.5 53.6 1.0 5.0 43.6 8.6 70.1 P6KE56 P6KE56C 50.4 61.6 1.0 5.0 45.4 7.5 80.5 P6KE56A P6KE56CA 53.2 58.8 1.0 5.0 47.8 7.8 77 P6KE62 P6KE62C 55.8 68.2 1.0 5.0 50.2 6.7 89 P6KE62A P6KE62CA 58.9 65.1 1.0 5.0 53.0 7.1 85 P6KE68 P6KE68C 61.2 74.8 1.0 5.0 55.1 6.1 98 P6KE68A P6KE68CA 64.6 71.4 1.0 5.0 58.1 6.5 92 P6KE75 P6KE75C 67.5 82.5 1.0 5.0 60.7 5.6 108 P6KE75A P6KE75CA 71.3 78.8 1.0 5.0 64.1 5.8 103 P6KE82 P6KE82C 73.8 90.2 1.0 5.0 66.4 5.1 118 P6KE82A P6KE82CA 77.9 86.1 1.0 5.0 70.1 5.3 113 P6KE91 P6KE91C 81.9 100 1.0 5.0 73.7 4.6 131 P6KE91A P6KE91CA 86.5 95.5 1.0 5.0 77.8 4.8 125 P6KE100 P6KE100C 90.0 110 1.0 5.0 81.0 4.2 144 P6KE100A P6KE100CA 95.0 105 1.0 5.0 85.5 4.4 137 P6KE110 P6KE110C 99.0 121 1.0 5.0 89.2 3.8 158 P6KE110A P6KE110CA 105 116 1.0 5.0 94.0 3.9 152 P6KE120 P6KE120C 108 132 1.0 5.0 97.2 3.5 173 P6KE120A P6KE120CA 114 126 1.0 5.0 102 3.6 165 P6KE130 P6KE130C 117 143 1.0 5.0 105 3.2 187 P6KE130A P6KE130CA 124 137 1.0 5.0 111 3.4 179 P6KE150 P6KE150C 135 165 1.0 5.0 121 2.8 215 P6KE150A P6KE150CA 143 158 1.0 5.0 128 2.9 207 P6KE160 P6KE160C 144 176 1.0 5.0 130 2.6 230 P6KE160A P6KE160CA 152 168 1.0 5.0 136 2.7 219 P6KE170 P6KE170C 153 187 1.0 5.0 138 2.5 244 P6KE170A P6KE170CA 162 179 1.0 5.0 145 2.6 234 P6KE180 P6KE180C 162 198 1.0 5.0 146 2.3 258 P6KE180A P6KE180CA 171 189 1.0 5.0 154 2.4 246 Document Number:8060009 Revision:21-Apr-28 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn ~3~   P6KE SERIES ■ Electrical Characteristics (TA=25℃ unless otherwise noted) Part Number(Uni) Part Number(Bi) Min(V) Max (V) IT(mA) IR Maximum Reverse Leakage IR @ VWM (μA) VBR@IT Breakdown Voltage VBR@IT VRWM Working Peak Reverse Voltage VRWM (V) IPP Maximum Reverse Surge Current IPP (A) Maximum Clamping Voltage Vc @ IPP (V) P6KE200 P6KE200C 180 220 1.0 5.0 162 2.1 287 P6KE200A P6KE200CA 190 210 1.0 5.0 171 2.2 274 P6KE220 P6KE220C 198 242 1.0 5.0 175 1.7 344 P6KE220A P6KE220CA 209 231 1.0 5.0 185 1.8 328 P6KE250 P6KE250C 225 275 1.0 5.0 202 1.7 360 P6KE250A P6KE250CA 237 263 1.0 5.0 214 1.7 344 P6KE300 P6KE300C 270 330 1.0 5.0 243 1.4 430 P6KE300A P6KE300CA 285 315 1.0 5.0 256 1.4 414 P6KE350 P6KE350C 315 385 1.0 5.0 284 1.2 505 P6KE350A P6KE350CA 333 368 1.0 5.0 300 1.2 482 P6KE400 P6KE400C 360 440 1.0 5.0 324 1.0 574 P6KE400A P6KE400CA 380 420 1.0 5.0 342 1.1 548 P6KE440 P6KE440C 396 484 1.0 5.0 356 0.95 631 P6KE440A P6KE440CA 418 462 1.0 5.0 376 1.0 602 P6KE500 P6KE500C 450 550 1.0 5.0 406 0.83 723 P6KE500A P6KE500CA 475 525 1.0 5.0 427.5 0.87 690 P6KE520 P6KE520C 468 572 1.0 5.0 422.2 0.80 750 P6KE520A P6KE520CA 494 546 1.0 5.0 444.6 0.84 714 P6KE540 P6KE540C 486 594 1.0 5.0 437 0.78 769 P6KE540A P6KE540CA 513 567 1.0 5.0 459 0.81 741 P6KE550 P6KE550C P6KE550A P6KE550CA P6KE600 P6KE600A 495 605 1.0 5.0 446 0.76 789 522.5 577 1.0 5.0 470 0.79 759 P6KE600C 540 660 1.0 5.0 487.2 0.69 870 P6KE600CA 570 630 1.0 5.0 513 0.72 833 Document Number:8060009 Revision:21-Apr-28 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn ~4~   P6KE SERIES ■ Characteristics(Typical) PPPM(KW) FIG1:Peak Pulse Power Rating Curve 100 : 100 不重复脉冲波形见图 3 Non-Repetitive Pulse Waveform shown in Fige.3 TA=25℃ 75 10 50 1.0 25 0.1 0.1 1 10 100 1000 0 10000 0 25 50 75 100 125 150 175 td(μs) 200 ℃) FIG3: Pulse Waveform IPPM(%) : 150 tr=10μs Peak Value IPPM 8.0 TJ=25 ℃ Pulse Width(td) is defined as the Point where the Peak Current Decays to 50% of IPPM 60 6.0 100 Half Value - IPP 2 IPPM 4.0 50 10/1000μs Waveform as Defined by R.E.A. ) 2.0 td 0 1.0 0 2.0 3.0 4.0 t(ms) 0 0 25 50 75 100 125 150 175 200 ℃) : FIG6:Typical Transient Thermal Impedance Rth(℃/W) 100 正弦半波 80 100 10 60 1 40 0.1 0.001 20 10 1 0.01 0.1 1 10 100 100 1000 tp(s) 周波 Document Number:8060009 Revision:21-Apr-28 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn ~ 5~ P6KE SERIES ■ Ordering Information (Example) PREFERED P6 ESeries PACKAGE CODE MINIMUM PACKAGE(pcs) DO-15 OUTER CARTON INNER BOX QUANTITY(pcs) QUANTITY(pcs) 3000 3000 30000 DELIVERY MODE Ammo box ■ Outline Dimensions DO-204AC(DO -15 ) 1.0(25.4) MIN 1.0(25.4) MIN .142(3.60) .031(0.80) .102(2.60) .028(0.70) DIA .300(7.60) .228(5.80) Unit: in inches (millimeters) Document Number:8060009 Revision:21-Apr-28 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn ~6~ P6KE SERIES IMPORTANT NOTICE AND DISCLAIMER AM RESERVES THE RIGHT TO MAKE CHANGES TO ALL PRODUCT, PRODUCT SPECIFICATIONS AND DATA WITHOUT NOTICE TO IMPROVE RELIABILITY, FUNCTION OR DESIGN OR OTHERWISE. CUSTOMERS SHOULD OBTAIN AND CONFIRM THE LATEST PRODUCT INFORMATION AND SPECIFICATIONS BEFORE FINAL DESIGN PURCHASE OR USE. AM disclaim any and all liability for any errors, inaccuracies or incompleteness contained in any datasheet or in any other disclosure relating to any product. All information are provided as-is, even it has qualified by the AEC-Q101 which satisfy industrial application requirement, except as expressly stated in this data sheet is applied for automotive grade, AM make no warranties, representation or guarantee, whether express, implied or statutory, including, without limitation, regarding any merchantability, satisfactory quality, or fitness for a particular purpose with respect to AM. AM does not assume any liability or compensation for any application assistance or customer product design, and make no warranty or accept any liability with products, which are purchased or used for any unintended or unauthorized application. Except as expressly indicated in writing, AM products are not designed for use in medical, life-saving, or lifesustaining applications or for any other application in which the failure of the AM product could result in personal injury or death. Customers using or selling AM products not expressly indicated for use in such applications do so at their own risk. Please contact authorized AM personnel to obtain written terms and conditions regarding products designed for such applications. No license, express or implied, by estoppel or otherwise, to any intellectual property rights is granted by this document or by any conduct of AM. Product names and markings noted herein may be trademarks of their respective owners. Document Number:8060009 Revision:21-Apr-28 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn ~7~
P6KE6.8A 价格&库存
很抱歉,暂时无法提供与“P6KE6.8A”相匹配的价格&库存,您可以联系我们找货
