SA5.0A(CA) - SA440A(CA)
AXIAL LEADED TRANSIENT VOLTAGE SUPPRESSOR
VOLTAGE RANGE: 5.0 - 440 V
POWER: 500 Wa t t s
Features
Glass Passivated Die Construction
Uni- and Bi-Directional Versions Available
Excellent Clamping Capability
Fast Response Time
Plastic Case Material has UL Flammability
B
A
A
Mechanical Data
Case: DO-15
Terminals: Axial Leads, Solderable per
MIL-STD-750, Method 2026
Polarity: Cathode Band or Cathode Notch
Marking:
DO-15
Unidirectional – Device Code and Cathode Band
C
D
Dim
Min
A
25.40
B
5.50
7.62
C
0.686
0.889
2.60
3.60
Bidirectional – Device Code Only
Weight: 0.40 grams (approx.)
D
Max
All Dimensions in mm
Maximum Ratings and Electrical Characteristics
@TA=25°C unless otherwise specified
Symbol
Value
Unit
Peak Pulse Power Dissipation at TA = 25°C (Note 1, 2, 5) Figure 3
PPPM
500 Minimum
W
Peak Forward Surge Current (Note 3)
IFSM
70
A
Peak Pulse Current on 10/1000µS Waveform (Note 1) Figure 1
IPPM
See Table 1
A
Steady State Power Dissipation (Note 2, 4)
PM(AV)
1.0
W
Operating and Storage Temperature Range
Tj, TSTG
-65 to +175
°C
Characteristic
Note: 1. Non-repetitive current pulse, per Figure 1 and derated above TA = 25°C per Figure 4.
2. Mounted on 40mm2 copper pad.
3. 8.3ms single half sine-wave duty cycle = 4 pulses per minutes maximum.
4. Lead temperature at 75°C = TL .
5. Peak pulse power waveform is 10/1000µS.
1 of 5
www.sunmate.tw
Reverse
Stand-Off
Voltage
TYPE
VRWM (V)
Breakdown Breakdown
Voltage
Voltage
Min. @IT
Max. @ IT
VBR MIN(V)
VBR MAX(V)
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
IT (mA)
VC(V)
IPP(A)
IR(uA)
(UNI)
(BI)
SA5.0
SA5.0C
5.0
6.40
7.55
10
9.6
55.4
600.0
SA5.0A
SA5.0CA
5.0
6.40
7.25
10
9.2
55.4
600.0
SA6.0
SA6.0C
6.0
6.67
8.45
10
11.4
49.5
600.0
SA6.0A
SA6.0CA
6.0
6.67
7.67
10
10.3
49.5
600.0
SA6.5
SA6.5C
6.5
7.22
9.14
10
12.3
45.5
400.0
SA6.5A
SA6.5CA
6.5
7.22
8.30
10
11.2
45.5
400.0
SA7.0
SA7.0C
7.0
7.78
9.86
10
13.3
42.5
150.0
SA7.0A
SA7.0CA
7.0
7.78
8.95
10
12.0
42.5
150.0
SA7.5
SA7.5C
7.5
8.33
10.67
1.0
14.3
39.5
50.0
SA7.5A
SA7.5CA
7.5
8.33
9.58
1.0
12.9
39.5
50.0
SA8.0
SA8.0C
8.0
8.89
11.3
1.0
15.0
37.5
25.0
SA8.0A
SA8.0CA
8.0
8.89
10.23
1.0
13.6
37.5
25.0
SA8.5
SA8.5C
8.5
9.44
11.92
1.0
15.9
35.4
10.0
SA8.5A
SA8.5CA
8.5
9.44
10.82
1.0
14.4
35.4
10.0
SA9.0
SA9.0C
9.0
10.0
12.6
1.0
16.9
33.1
5.0
SA9.0A
SA9.0CA
9.0
10.0
11.5
1.0
15.4
33.1
5.0
SA10
SA10C
10
11.1
14.1
1.0
18.8
30.0
3.0
SA10A
SA10CA
10
11.1
12.8
1.0
17.0
30.0
3.0
SA11
SA11C
11
12.2
15.4
1.0
20.1
28.0
3.0
SA11A
SA11CA
11
12.2
14.0
1.0
18.2
28.0
3.0
SA12
SA12C
12
13.3
16.9
1.0
22.0
25.6
3.0
SA12A
SA12CA
12
13.3
15.3
1.0
19.9
25.6
3.0
SA13
SA13C
13
14.4
18.2
1.0
23.8
23.7
3.0
SA13A
SA13CA
13
14.4
16.5
1.0
21.5
23.7
3.0
SA14
SA14C
14
15.6
19.8
1.0
25.8
22.0
3.0
SA14A
SA14CA
14
15.6
17.9
1.0
23.2
22.0
3.0
SA15
SA15C
15
16.7
21.1
1.0
26.9
20.9
3.0
SA15A
SA15CA
15
16.7
19.2
1.0
24.4
20.9
3.0
SA16
SA16C
16
17.8
22.6
1.0
28.8
19.6
3.0
SA16A
SA16CA
16
17.8
20.5
1.0
26.0
19.6
3.0
SA17
SA17C
17
18.9
23.9
1.0
30.5
18.5
3.0
SA17A
SA17CA
17
18.9
21.7
1.0
27.6
18.5
3.0
SA18
SA18C
18
20.0
25.3
1.0
32.2
17.5
3.0
SA18A
SA18CA
18
20.0
23.3
1.0
29.2
17.5
3.0
SA20
SA20C
28.1
1.0
35.8
15.7
3.0
SA20A
SA20CA
25.5
1.0
32.4
15.7
3.0
SA22
SA22C
22
24.4
29.8
1.0
39.4
12.9
3.0
2 of 5
www.sunmate.tw
TYPE
(UNI)
(BI)
Reverse
Stand-Off
Voltage
Breakdown
Voltage
Min. @IT
Breakdown
Voltage
Max. @ IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
VRWM (V)
VBR MIN(V)
VBR MAX(V)
IT (mA)
VC(V)
IPP(A)
IR(uA)
SA22A
SA22CA
22
24.4
26.9
1.0
35.5
14.4
3.0
SA24
SA24C
24
26.7
32.6
1.0
43.0
11.9
3.0
SA24A
SA24CA
24
26.7
29.5
1.0
38.9
13.1
3.0
SA26
SA26C
26
28.9
35.3
1.0
46.6
10.9
3.0
SA26A
SA26CA
26
28.9
31.9
1.0
42.1
12.1
3.0
SA28
SA28C
28
31.1
38.0
1.0
50.0
10.2
3.0
SA28A
SA28CA
28
31.1
34.4
1.0
45.4
11.2
3.0
SA30
SA30C
30
33.3
40.7
1.0
53.5
9.5
3.0
SA30A
SA30CA
30
33.3
36.8
1.0
48.4
10.5
3.0
SA33
SA33C
33
36.7
44.9
1.0
59.0
8.6
3.0
SA33A
SA33CA
33
36.7
40.6
1.0
53.3
9.6
3.0
SA36
SA36C
36
40.0
48.9
1.0
64.3
7.9
3.0
SA36A
SA36CA
36
40.0
44.2
1.0
58.1
8.8
3.0
SA40
SA40C
40
44.4
54.3
1.0
71.4
7.1
3.0
SA40A
SA40CA
40
44.4
49.1
1.0
64.5
7.9
3.0
SA43
SA43C
43
47.8
58.4
1.0
76.7
6.6
3.0
SA43A
SA43CA
43
47.8
52.8
1.0
69.4
7.3
3.0
SA45
SA45C
45
50.0
61.1
1.0
80.3
6.4
3.0
SA45A
SA45CA
45
50.0
55.3
1.0
72.7
7.0
3.0
SA48
SA48C
48
53.3
65.2
1.0
85.5
6.0
3.0
SA48A
SA48CA
48
53.3
58.9
1.0
77.4
6.6
3.0
SA51
SA51C
51
56.7
69.3
1.0
91.1
5.6
3.0
SA51A
SA51CA
51
56.7
62.7
1.0
82.4
6.2
3.0
SA54
SA54C
54
60.0
73.3
1.0
96.3
5.3
3.0
SA54A
SA54CA
54
60.0
66.3
1.0
87.1
5.9
3.0
SA58
SA58C
58
64.4
78.7
1.0
103
5.0
3.0
SA58A
SA58CA
58
64.4
71.2
1.0
93.6
5.4
3.0
SA60
SA60C
60
66.7
81.5
1.0
107
4.8
3.0
SA60A
SA60CA
60
66.7
73.7
1.0
96.8
5.3
3.0
SA64
SA64C
64
71.1
86.9
1.0
114
4.5
3.0
SA64A
SA64CA
64
71.1
78.6
1.0
103
5.0
3.0
SA70
SA70C
70
77.8
95.1
1.0
125
4.1
3.0
SA70A
SA70CA
70
77.8
86.0
1.0
113
4.5
3.0
SA75
SA75C
75
83.0
102
1.0
134
3.8
3.0
SA75A
SA75CA
75
83.0
92.1
1.0
121
4.2
3.0
SA78
SA78C
78
86.0
106
1.0
139
3.7
3.0
3 of 5
www.sunmate.tw
TYPE
(UNI)
Breakdown
Voltage
Min. @IT
Breakdown
Voltage
Max. @ IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
VRWM (V)
VBR MIN(V)
VBR MAX(V)
IT (mA)
VC(V)
IPP(A)
IR(uA)
Reverse
Stand-Off
Voltage
(BI)
SA78A
SA78CA
78
86.0
95.8
1.0
126
4.0
3.0
SA85
SA85C
85
94.0
115
1.0
151
3.4
3.0
SA85A
SA85CA
85
94.0
104
1.0
137
3.7
3.0
SA90
SA90C
90
100
122
1.0
160
3.2
3.0
SA90A
SA90CA
90
100
111
1.0
146
3.3
3.0
SA100
SA100C
100
111
136
1.0
179
2.8
3.0
SA100A
SA100CA
100
111
123
1.0
162
3.1
3.0
SA110
SA110C
110
122
149
1.0
196
2.6
3.0
SA110A
SA110CA
110
122
135
1.0
177
2.9
3.0
SA120
SA120C
120
133
163
1.0
214
2.4
3.0
SA120A
SA120CA
120
133
147
1.0
193
2.6
3.0
SA130
SA130C
130
144
176
1.0
231
2.2
3.0
SA130A
SA130CA
130
144
159
1.0
209
2.4
3.0
SA150
SA150C
150
167
204
1.0
268
1.9
3.0
SA150A
SA150CA
150
167
185
1.0
243
2.1
3.0
SA160
SA160C
160
178
218
1.0
287
1.7
3.0
SA160A
SA160CA
160
178
197
1.0
259
2.0
3.0
SA170
SA170C
170
189
231
1.0
304
1.7
3.0
SA170A
SA170CA
170
189
209
1.0
275
1.9
3.0
SA180
SA180C
180
200
244
1.0
321
1.56
3.0
SA180A
SA180CA
180
200
221
1.0
290
1.73
3.0
SA190
SA190C
190
211
258
1.0
339
1.48
3.0
SA190A
SA190CA
190
211
233
1.0
306
1.64
3.0
SA200
SA200C
200
222
271
1.0
356
1.41
3.0
SA200A
SA200CA
200
222
245
1.0
322
1.56
3.0
SA220
SA220C
220
244
298
1.0
392
1.29
3.0
SA220A
SA220CA
220
244
270
1.0
355
1.42
3.0
SA250
SA250C
250
278
340
1.0
447
1.13
3.0
SA250A
SA250CA
250
278
307
1.0
403
1.25
3.0
SA300
SA300C
300
333
407
1.0
535
0.94
3.0
SA300A
SA300CA
300
333
368
1.0
484
1.04
3.0
SA350
SA350C
350
389
475
1.0
624
0.81
3.0
SA350A
SA350CA
350
389
430
1.0
565
0.89
3.0
SA400
SA400C
400
444
523
1.0
687
0.74
3.0
SA400A
SA400CA
400
444
491
1.0
645
0.79
3.0
SA440C
440
489
598
1.0
786
0.65
3.0
SA440CA
440
489
540
1.0
710
0.71
3.0
SA440
SA440A
4 of 5
www.sunmate.tw
Tj = 25°C
f = 1.0 MHz
Vsig = 50mV p-p
tr = 10ms
100
Peak Value Ipp
Cj, CAPACITANCE (pF)
IP, PEAK PULSE CURRENT (%pp)
10,000
Half Value Ipp/2
50
tp
Measured at
Stand-off Voltage
100
10 X 1000 Waveform
as defined by R.E.A.
Measured at
Zero Bias
1000
10
1
3
2
10
100
1000
VRWM, REVERSE STANDOFF VOLTAGE (V)
t, TIME (ms)
Fig. 1 Pulse Waveform
Fig. 2 Typical Junction Capacitance
PP, PEAK PULSE POWER (kW)
100
IMPULSE
10
1.0
TC = 25°C
0.1
0.1
1.0
10
1000
100
10000
100
Pd , STEADY STATE POWER DISSIPATION (W)
PK PULSE DERATING (% PK PWR OR CURRENT)
Tp, PULSE WIDTH (µs)
Fig. 3 Pulse Rating Curve
75
50
25
10 X 1000 Waveform
as defined by REA
50
75
100 125 150 175
1.00
Single Phase
Half-Wave 60Hz
Resistive or
Inductive Load
0.75
0.50
L = 9.5 mm
0.25
40 x 40 x 1 mm Cu
TA, AMBIENT TEMPERATURE (°C)
Fig. 4 Pulse Derating Curve
25
50
75
100
125
150
175
200
TL , LEAD TEMPERATURE (°C)
Fig. 5, Steady State Power Derating
5 of 5
www.sunmate.tw
很抱歉,暂时无法提供与“SA5.0CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.31724
- 100+0.25322
- 300+0.22121
- 2000+0.19987
- 4000+0.18068
- 10000+0.17114
