SA16A
SA16A
    SUNMATE(森美特)
    DO-15(DO-204AC)
    单向TVS 16V截止 峰值脉冲电流:19.6A
SA16A 数据手册
SA5.0A(CA) - SA440A(CA) AXIAL LEADED TRANSIENT VOLTAGE SUPPRESSOR VOLTAGE RANGE: 5.0 - 440 V POWER: 500 Wa t t s Features ! Glass Passivated Die Construction ! Uni- and Bi-Directional Versions Available Excellent Clamping Capability ! ! ! Fast Response Time Plastic Case Material has UL Flammability B A A Mechanical Data ! ! Case: DO-15 Terminals: Axial Leads, Solderable per MIL-STD-750, Method 2026 ! Polarity: Cathode Band or Cathode Notch ! Marking: DO-15 Unidirectional – Device Code and Cathode Band ! C D Dim Min A 25.40 — B 5.50 7.62 C 0.686 0.889 2.60 3.60 Bidirectional – Device Code Only Weight: 0.40 grams (approx.) D Max All Dimensions in mm Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Symbol Value Unit Peak Pulse Power Dissipation at TA = 25°C (Note 1, 2, 5) Figure 3 PPPM 500 Minimum W Peak Forward Surge Current (Note 3) IFSM 70 A Peak Pulse Current on 10/1000µS Waveform (Note 1) Figure 1 IPPM See Table 1 A Steady State Power Dissipation (Note 2, 4) PM(AV) 1.0 W Operating and Storage Temperature Range Tj, TSTG -65 to +175 °C Characteristic Note: 1. Non-repetitive current pulse, per Figure 1 and derated above TA = 25°C per Figure 4. 2. Mounted on 40mm2 copper pad. 3. 8.3ms single half sine-wave duty cycle = 4 pulses per minutes maximum. 4. Lead temperature at 75°C = TL . 5. Peak pulse power waveform is 10/1000µS. 1 of 5 www.sunmate.tw Reverse Stand-Off Voltage TYPE VRWM (V) Breakdown Breakdown Voltage Voltage Min. @IT Max. @ IT VBR MIN(V) VBR MAX(V) Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM IT (mA) VC(V) IPP(A) IR(uA) (UNI) (BI) SA5.0 SA5.0C 5.0 6.40 7.55 10 9.6 55.4 600.0 SA5.0A SA5.0CA 5.0 6.40 7.25 10 9.2 55.4 600.0 SA6.0 SA6.0C 6.0 6.67 8.45 10 11.4 49.5 600.0 SA6.0A SA6.0CA 6.0 6.67 7.67 10 10.3 49.5 600.0 SA6.5 SA6.5C 6.5 7.22 9.14 10 12.3 45.5 400.0 SA6.5A SA6.5CA 6.5 7.22 8.30 10 11.2 45.5 400.0 SA7.0 SA7.0C 7.0 7.78 9.86 10 13.3 42.5 150.0 SA7.0A SA7.0CA 7.0 7.78 8.95 10 12.0 42.5 150.0 SA7.5 SA7.5C 7.5 8.33 10.67 1.0 14.3 39.5 50.0 SA7.5A SA7.5CA 7.5 8.33 9.58 1.0 12.9 39.5 50.0 SA8.0 SA8.0C 8.0 8.89 11.3 1.0 15.0 37.5 25.0 SA8.0A SA8.0CA 8.0 8.89 10.23 1.0 13.6 37.5 25.0 SA8.5 SA8.5C 8.5 9.44 11.92 1.0 15.9 35.4 10.0 SA8.5A SA8.5CA 8.5 9.44 10.82 1.0 14.4 35.4 10.0 SA9.0 SA9.0C 9.0 10.0 12.6 1.0 16.9 33.1 5.0 SA9.0A SA9.0CA 9.0 10.0 11.5 1.0 15.4 33.1 5.0 SA10 SA10C 10 11.1 14.1 1.0 18.8 30.0 3.0 SA10A SA10CA 10 11.1 12.8 1.0 17.0 30.0 3.0 SA11 SA11C 11 12.2 15.4 1.0 20.1 28.0 3.0 SA11A SA11CA 11 12.2 14.0 1.0 18.2 28.0 3.0 SA12 SA12C 12 13.3 16.9 1.0 22.0 25.6 3.0 SA12A SA12CA 12 13.3 15.3 1.0 19.9 25.6 3.0 SA13 SA13C 13 14.4 18.2 1.0 23.8 23.7 3.0 SA13A SA13CA 13 14.4 16.5 1.0 21.5 23.7 3.0 SA14 SA14C 14 15.6 19.8 1.0 25.8 22.0 3.0 SA14A SA14CA 14 15.6 17.9 1.0 23.2 22.0 3.0 SA15 SA15C 15 16.7 21.1 1.0 26.9 20.9 3.0 SA15A SA15CA 15 16.7 19.2 1.0 24.4 20.9 3.0 SA16 SA16C 16 17.8 22.6 1.0 28.8 19.6 3.0 SA16A SA16CA 16 17.8 20.5 1.0 26.0 19.6 3.0 SA17 SA17C 17 18.9 23.9 1.0 30.5 18.5 3.0 SA17A SA17CA 17 18.9 21.7 1.0 27.6 18.5 3.0 SA18 SA18C 18 20.0 25.3 1.0 32.2 17.5 3.0 SA18A SA18CA 18 20.0 23.3 1.0 29.2 17.5 3.0 SA20 SA20C 20 22.2 28.1 1.0 35.8 15.7 3.0 SA20A SA20CA 20 22.2 25.5 1.0 32.4 15.7 3.0 SA22 SA22C 22 24.4 29.8 1.0 39.4 12.9 3.0 2 of 5 www.sunmate.tw TYPE (UNI) (BI) Reverse Stand-Off Voltage Breakdown Voltage Min. @IT Breakdown Voltage Max. @ IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM VRWM (V) VBR MIN(V) VBR MAX(V) IT (mA) VC(V) IPP(A) IR(uA) SA22A SA22CA 22 24.4 26.9 1.0 35.5 14.4 3.0 SA24 SA24C 24 26.7 32.6 1.0 43.0 11.9 3.0 SA24A SA24CA 24 26.7 29.5 1.0 38.9 13.1 3.0 SA26 SA26C 26 28.9 35.3 1.0 46.6 10.9 3.0 SA26A SA26CA 26 28.9 31.9 1.0 42.1 12.1 3.0 SA28 SA28C 28 31.1 38.0 1.0 50.0 10.2 3.0 SA28A SA28CA 28 31.1 34.4 1.0 45.4 11.2 3.0 SA30 SA30C 30 33.3 40.7 1.0 53.5 9.5 3.0 SA30A SA30CA 30 33.3 36.8 1.0 48.4 10.5 3.0 SA33 SA33C 33 36.7 44.9 1.0 59.0 8.6 3.0 SA33A SA33CA 33 36.7 40.6 1.0 53.3 9.6 3.0 SA36 SA36C 36 40.0 48.9 1.0 64.3 7.9 3.0 SA36A SA36CA 36 40.0 44.2 1.0 58.1 8.8 3.0 SA40 SA40C 40 44.4 54.3 1.0 71.4 7.1 3.0 SA40A SA40CA 40 44.4 49.1 1.0 64.5 7.9 3.0 SA43 SA43C 43 47.8 58.4 1.0 76.7 6.6 3.0 SA43A SA43CA 43 47.8 52.8 1.0 69.4 7.3 3.0 SA45 SA45C 45 50.0 61.1 1.0 80.3 6.4 3.0 SA45A SA45CA 45 50.0 55.3 1.0 72.7 7.0 3.0 SA48 SA48C 48 53.3 65.2 1.0 85.5 6.0 3.0 SA48A SA48CA 48 53.3 58.9 1.0 77.4 6.6 3.0 SA51 SA51C 51 56.7 69.3 1.0 91.1 5.6 3.0 SA51A SA51CA 51 56.7 62.7 1.0 82.4 6.2 3.0 SA54 SA54C 54 60.0 73.3 1.0 96.3 5.3 3.0 SA54A SA54CA 54 60.0 66.3 1.0 87.1 5.9 3.0 SA58 SA58C 58 64.4 78.7 1.0 103 5.0 3.0 SA58A SA58CA 58 64.4 71.2 1.0 93.6 5.4 3.0 SA60 SA60C 60 66.7 81.5 1.0 107 4.8 3.0 SA60A SA60CA 60 66.7 73.7 1.0 96.8 5.3 3.0 SA64 SA64C 64 71.1 86.9 1.0 114 4.5 3.0 SA64A SA64CA 64 71.1 78.6 1.0 103 5.0 3.0 SA70 SA70C 70 77.8 95.1 1.0 125 4.1 3.0 SA70A SA70CA 70 77.8 86.0 1.0 113 4.5 3.0 SA75 SA75C 75 83.0 102 1.0 134 3.8 3.0 SA75A SA75CA 75 83.0 92.1 1.0 121 4.2 3.0 SA78 SA78C 78 86.0 106 1.0 139 3.7 3.0 3 of 5 www.sunmate.tw TYPE (UNI) Breakdown Voltage Min. @IT Breakdown Voltage Max. @ IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM VRWM (V) VBR MIN(V) VBR MAX(V) IT (mA) VC(V) IPP(A) IR(uA) Reverse Stand-Off Voltage (BI) SA78A SA78CA 78 86.0 95.8 1.0 126 4.0 3.0 SA85 SA85C 85 94.0 115 1.0 151 3.4 3.0 SA85A SA85CA 85 94.0 104 1.0 137 3.7 3.0 SA90 SA90C 90 100 122 1.0 160 3.2 3.0 SA90A SA90CA 90 100 111 1.0 146 3.3 3.0 SA100 SA100C 100 111 136 1.0 179 2.8 3.0 SA100A SA100CA 100 111 123 1.0 162 3.1 3.0 SA110 SA110C 110 122 149 1.0 196 2.6 3.0 SA110A SA110CA 110 122 135 1.0 177 2.9 3.0 SA120 SA120C 120 133 163 1.0 214 2.4 3.0 SA120A SA120CA 120 133 147 1.0 193 2.6 3.0 SA130 SA130C 130 144 176 1.0 231 2.2 3.0 SA130A SA130CA 130 144 159 1.0 209 2.4 3.0 SA150 SA150C 150 167 204 1.0 268 1.9 3.0 SA150A SA150CA 150 167 185 1.0 243 2.1 3.0 SA160 SA160C 160 178 218 1.0 287 1.7 3.0 SA160A SA160CA 160 178 197 1.0 259 2.0 3.0 SA170 SA170C 170 189 231 1.0 304 1.7 3.0 SA170A SA170CA 170 189 209 1.0 275 1.9 3.0 SA180 SA180C 180 200 244 1.0 321 1.56 3.0 SA180A SA180CA 180 200 221 1.0 290 1.73 3.0 SA190 SA190C 190 211 258 1.0 339 1.48 3.0 SA190A SA190CA 190 211 233 1.0 306 1.64 3.0 SA200 SA200C 200 222 271 1.0 356 1.41 3.0 SA200A SA200CA 200 222 245 1.0 322 1.56 3.0 SA220 SA220C 220 244 298 1.0 392 1.29 3.0 SA220A SA220CA 220 244 270 1.0 355 1.42 3.0 SA250 SA250C 250 278 340 1.0 447 1.13 3.0 SA250A SA250CA 250 278 307 1.0 403 1.25 3.0 SA300 SA300C 300 333 407 1.0 535 0.94 3.0 SA300A SA300CA 300 333 368 1.0 484 1.04 3.0 SA350 SA350C 350 389 475 1.0 624 0.81 3.0 SA350A SA350CA 350 389 430 1.0 565 0.89 3.0 SA400 SA400C 400 444 523 1.0 687 0.74 3.0 SA400A SA400CA 400 444 491 1.0 645 0.79 3.0 SA440C 440 489 598 1.0 786 0.65 3.0 SA440CA 440 489 540 1.0 710 0.71 3.0 SA440 SA440A 4 of 5 www.sunmate.tw Tj = 25°C f = 1.0 MHz Vsig = 50mV p-p tr = 10ms 100 Peak Value Ipp Cj, CAPACITANCE (pF) IP, PEAK PULSE CURRENT (%pp) 10,000 Half Value Ipp/2 50 tp Measured at Stand-off Voltage 100 10 X 1000 Waveform as defined by R.E.A. 0 0 1 Measured at Zero Bias 1000 10 1 3 2 10 100 1000 VRWM, REVERSE STANDOFF VOLTAGE (V) t, TIME (ms) Fig. 1 Pulse Waveform Fig. 2 Typical Junction Capacitance PP, PEAK PULSE POWER (kW) 100 IMPULSE 10 1.0 TC = 25°C 0.1 0.1 1.0 10 1000 100 10000 100 Pd , STEADY STATE POWER DISSIPATION (W) PK PULSE DERATING (% PK PWR OR CURRENT) Tp, PULSE WIDTH (µs) Fig. 3 Pulse Rating Curve 75 50 25 10 X 1000 Waveform as defined by REA 0 0 25 50 75 100 125 150 175 1.00 Single Phase Half-Wave 60Hz Resistive or Inductive Load 0.75 0.50 L = 9.5 mm 0.25 40 x 40 x 1 mm Cu 0 200 0 TA, AMBIENT TEMPERATURE (°C) Fig. 4 Pulse Derating Curve 25 50 75 100 125 150 175 200 TL , LEAD TEMPERATURE (°C) Fig. 5, Steady State Power Derating 5 of 5 www.sunmate.tw
SA16A 价格&库存
很抱歉,暂时无法提供与“SA16A”相匹配的价格&库存,您可以联系我们找货
SA16A
库存:1911
