P6KE Series
Glass Passivated Junction Transient Voltage Suppressor
VOLTAGE - 6.8 TO 550 Volts
600 Watt Peak Power 5.0 Watt Steady State
Features
• Plastic package has Underwriters Laboratory
Flammability Classification 94 V-O
• Glass passivated chip junction in DO-15
(DO-204AC) package
• 600W surge capability at 10/1000 µs
• Low zenen impedance
• Excellent clamping capability
• Fast response time: typically less than
1.0 ps from 0 volts to BV min.
• Typical IR less than 1µA above 10V
• High temperature soldering guaranteed:
265°C/10 seconds/ .375", (9.5mm) lead
length, 5lbs., (2.3kg) tension
Mechanical Data
Case: JEDEC DO-15 Molded plastic
Terminals: Plated Axial leads, solderable per
MIL-STD-750, Method 2026
Polarity: Color band denoted positive end (cathode)
except Bipolar
Mounting Position: Any
Weight: 0.015 ounces, 0.4 grams
DEVICES FOR BIPOLAR APPLICATIONS
For Bidirectional use C or CA Suffix for types P6KE6.80 thru types P6KE550 (e.g. P6KE6.8C, P6KE550CA)
Electrical characteristics apply in both directions.
MAXIMUM RATINGS AND CHARACTERISTICS
Ratings at 25°C ambient temperature unless otherwise specified.
RATING
Peak Pulse Power Dissipation at TA = 25 °C, TP = 1ms
(NOTE 1)
Peak Pulse Current of on 10/1000 µs waveform (Note 1)
Steady State Power Dissipation at T L = 75°C
Lead lengths .375", 9.5mm (Note 2)
Peak Forward Surge Current, 8.3ms Single Half Sine-wave
Superimposed on Rated Load, (JEDEC Method)(Note 3)
Operatings and Storage Temperature Range
SYMBOL
VALUE
UNITS
PPPM
Minimum 600
Watts
IPPM
SEE TABLE 1
Amps
PM(AV)
1.0
Watts
IFSM
40
Amps
T J, T STG
-55 +175
°C
NOTES:
1. Non-repetitive current pulse, per Fig.3 and derated above Ta=25 °C per Fig.2.
2. Mounted on Copper Pad area of 1.6x1.6" (40x40mm) per Fig.5.
3. 8.3ms single half sine-wave, or equivalent square wave, Duty cycle=4 pulses per minutes maximum.
Certified RoHS Compliant
ht t p : //
Revision:20170701-P1
www.lgesemi .c o m
mail:lge@lgesemi.com
P6KE Series
RATING AND CHARACTERISTIC CURVES P6KE SERIES
Peak Pulse Power (PPP)
or Current (IPPM)
Derating in Percentage,%
PPPM-Peak Pulse
Non-repetitive Pulse
Waveform shown in Fig.
3
100
10
1
0.1
0.1µs
1.0µs
10µs
100µs
1.0ms
Fig.2 - Pulse Derating Curve
100
Pig.1 - Peak Pulse Power Rating Curve
87.5
75
62.5
50
37.5
25
12.5
10ms
td - Pulse Width (sec.)
0.2
0.4
0.6
0.8
1
1.2
TA - Ambient Temperature
Fig.3 - Pulse Waveform
tr = 10µsec.
Half Value- IPPM
2
10/1000µsec.Waveform
as defined by R.E.A.
50
td
t - Time(ms)
1.0
4.0
3
4.0
L=0.375" (9.5mm)
Lead Lengths
4.38
100
Measured at
Stand-Off
Voltage, V WM
1000
10
1.0
1
60 HZ Resistive or
Inductive Load
2.50
1.88
1.6x1.6x.040"
(40x40x1mm)
Copper Heat Sinks
0.63
50
75
100
125
150
175
100
50
10
200
1
Transient Thermal Impedance
(℃ /W)
ID - Instantaneous Reverse
Leakage Current (µA)
Measured at Devices
Stand-off Voltage,V WM
TA = 25°C
1
0.1
0.01
0.001
0.2
0.4
0.6
0.8
1
V(BR) - Breakdown Voltage (V)
ht t p : //
50
100
Fig. 8 - Typ.Transient Thermal Impedance
100
5
Number of Cycles at 60
Fig.7 - Typical Reverse Leakage Characteristics
10
200
TJ = TJ max.
8.3ms Single Half SineWave
Uni-Directional Only
TL - Lead Temperature (°C
1000
100
VWM - Reverse Stand-Off Voltage (V)
Fig.6 - Max.Non-Repetitive Forward Surge
3.13
1.25
Measured at
Zero Bias
200
3.75
0.00
Fig.5 - steady State Power Derating Curve
5.00
- Typ.Junction Capacitance Uni-
TJ = 25°C
f = 1.0MH Z
Vsig = 50mVp-p
IFSM - Peak Forward
Surge Current (A)
PM(AV ),Steady State
Power
Dissipation (W)
6000
Pulse Width(td)is
defined
as the point where the
peak current decays to
50% of IPPM
Peak Value
IPPM
100
10000 Fig.4
TJ = 25°C
CJ - Junction Capacitance(pF)
IPPM - Peak Pulse Current,
% IRSM
150
1.2
100
10
1
0.1
0.4
0.6
0.8
tp-Pulse Duration (sec)
www.lgesemi .c o m
1
1.2
P6KE Series
UNI-POLAR
BI-POLAR
REVERSE
STANDOFF
VOLTAGE
VRWM (V)
BREAKDOWN BREAKDOWN
TEST
VOLTAGE
VOLTAGE
CURRENT
VBR (V)
VBR (V)
MIN.
(IT)
@ IT
MAX. @ IT
mA
5.80
6.45
7.14
P6KE6.8A
P6KE6.8CA
6.40
7.13
7.88
P6KE7.5A
P6KE7.5CA
7.02
7.79
8.61
P6KE8.2A
P6KE8.2CA
7.78
8.65
9.55
P6KE9.1A
P6KE9.1CA
8.55
9.50
10.50
P6KE10A
P6KE10CA
9.40
10.50
11.60
P6KE11A
P6KE11CA
10.20
11.40
12.60
P6KE12A
P6KE12CA
11.10
12.40
13.70
P6KE13A
P6KE13CA
10.00
14.30
15.80
P6KE15A
P6KE15CA
12.90
15.20
16.80
P6KE16A
P6KE16CA
14.50
17.10
18.90
P6KE18A
P6KE18CA
17.10
19.00
21.00
P6KE20A
P6KE20CA
18.80
20.90
23.10
P6KE22A
P6KE22CA
20.50
22.80
25.20
P6KE24A
P6KE24CA
23.10
25.70
28.40
P6KE27A
P6KE27CA
25.60
28.50
31.50
P6KE30A
P6KE30CA
28.20
31.40
34.70
P6KE33A
P6KE33CA
30.80
34.20
37.80
P6KE36A
P6KE36CA
33.30
37.10
41.00
P6KE39A
P6KE39CA
36.80
40.90
45.20
P6KE43A
P6KE43CA
40.20
44.70
49.40
P6KE47A
P6KE47CA
43.60
48.50
53.60
P6KE51A
P6KE51CA
47.80
53.20
58.80
P6KE56A
P6KE56CA
53.00
58.90
65.10
P6KE62A
P6KE62CA
58.10
64.60
71.40
P6KE68A
P6KE68CA
P6KE75A
P6KE75CA
64.10
71.30
78.80
70.10
77.90
86.10
P6KE82A
P6KE82CA
77.80
86.50
95.50
P6KE91A
P6KE91CA
85.50
95.00
105.00
P6KE100A
P6KE100CA
94.00
105.00
116.00
P6KE110A
P6KE110CA
102.00
114.00
126.00
P6KE120A
P6KE120CA
111.00
124.00
137.00
P6KE130A
P6KE130CA
128.00
143.00
158.00
P6KE150A
P6KE150CA
136.00
152.00
168.00
P6KE160A
P6KE160CA
145.00
162.00
179.00
P6KE170A
P6KE170CA
154.00
171.00
189.00
P6KE180A
P6KE180CA
171.00
190.00
210.00
P6KE200A
P6KE200CA
185.00
209.00
231.00
P6KE220A
P6KE220CA
214.00
237.00
263.00
P6KE250A
P6KE250CA
256.00
285.00
315.00
P6KE300A
P6KE300CA
300.00
333.00
368.00
P6KE350A
P6KE350CA
342.00
380.00
420.00
P6KE400A
P6KE400CA
376.00
418.00
462.00
P6KE440A
P6KE440CA
408.00
456.00
504.00
P6KE480A
P6KE480CA
434.00
485.00
535.00
P6KE510A
P6KE510CA
450.00
503.50
556.50
P6KE530A
P6KE530CA
459.00
513.00
567.00
P6KE540A
P6KE540CA
467.00
522.50
577.50
P6KE550A
P6KE550CA
For bidirectional type having Vrwm of 10 volts and less, the IR limit is double.
For parts without A , the VBR is ± 10%
MAXIMUM
CLAMPING
VOLTAGE
@IPP VC (V)
PEAK
PULSE
CURRENT
IPP (A)
REVERSE
LEAKAGE
@ VRWM
IR (µA)
10
10
10
10
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
10.5
11.3
12.1
13.4
14.5
15.6
16.7
18.2
21.2
22.5
25.2
27.7
30.6
33.2
37.5
41.4
45.7
49.9
53.9
59.3
64.8
70.1
77.0
85.0
92.0
58.1
54.0
50.4
45.5
42.1
39.1
36.5
33.5
28.8
27.1
24.2
22.0
19.9
18.4
16.3
14.7
13.3
12.2
11.3
10.3
9.4
8.7
7.9
7.2
6.6
1000
500
200
50
10
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
103.0
113.0
125.0
137.0
152.0
165.0
179.0
207.0
219.0
234.0
246.0
274.0
328.0
344.0
414.0
482.0
548.0
602.0
658.0
698.0
725.0
740.0
760.0
5.9
5.4
4.9
4.5
4.0
3.7
3.4
2.9
2.8
2.6
2.5
2.2
1.9
1.8
1.5
1.3
1.1
1.0
0.9
0.9
0.8
0.8
0.8
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
PACKAGE
SPQ/PCS
CARTON
SPQ/PCS
CARTON
SIZE/CM
CARTON
GW/KG
CARTON
NW/KG
DO-15
3000/AMMO
30000
42X28X31
12.00
10.00
ht t p : //
www.lgesemi .c o m
很抱歉,暂时无法提供与“P6KE6.8CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.49022
- 100+0.39183
- 300+0.34258
- 2000+0.28523
- 4000+0.25575
- 10000+0.24095
