P6KE200A
P6KE200A
    JKSEMI(金开盛)
    DO-15(DO-204AC)
    单向TVS 171V截止 峰值脉冲电流:2.2A@10/1000US
P6KE200A 数据手册
P6KE Series 600W Transient Voltage Suppressor DESCRIPTION: The P6KE series of high current uni/bi-directional transient suppressors are designed for A.C. line protection and high power DC bus clamping applications. These devices offer uni/bi-directional port protection from 6.8 volts to 400 volts. They provide a clamping voltage lower than the avalanche voltage. Therefore, any voltage rise due to increased current conduction is contained to a minimum, providing the best possible protection level. They can also be connected in series and/or parallel to create very high capacity protection solutions. FEATURES:       Symbol Low zener impedance. Excellent clamping capability. Repetition rate (duty cycle): 0.01%. JEDEC DO-15/DO-204AC Molded Plastic. Color band denoted cathode except bidirectional. High temperature soldering: 260℃/10s at terminals.  Glass passivated or plannar chip junction in DO-15/DO-204AC package.  600W Peak Pulse power capability at 10×1000μs waveform.  Fast response time: typically less than 1.0ps from 0V to VBR min. ABSOLUTE MAXIMUM RATINGS (TA=25ºC, RH=45%-75%, unless otherwise noted) Parameter Peak pulse power dissipation on 10/1000μs waveform Peak pulse current of on 10/1000μs waveform Steady state power dissipation at TL=75℃ Operating junction and Storage temperature range Peak forward surge current, 8.3ms single half sine-wave http:// www.jksemi.com Symbol Value Unit PPP 600 W IPP See next table A PM(AV) 5.0 W TSTG, TJ -55 to +150 ℃ IFSM 100 A 2021-10-21 版次: c P6KE Series 600W Transient Voltage Suppressor ELECTRICAL CHARACTERISTICS (TA=25℃) Part Number VR IR@VR VBR@IT IT VC@IPP IPP① Uni-Polar Bi-Polar V μA min(V) max(V) mA max(V) A P6KE6.8A P6KE6.8CA 5.8 1000 6.45 7.14 10 10.5 57.2 P6KE7.5A P6KE7.5CA 6.4 500 7.13 7.88 10 11.3 53.1 P6KE8.2A P6KE8.2CA 7.02 200 7.79 8.61 10 12.1 49.6 P6KE9.1A P6KE9.1CA 7.78 50 8.65 9.55 1 13.4 44.8 P6KE10A P6KE10CA 8.55 10 9.50 10.50 1 14.5 41.4 P6KE11A P6KE11CA 9.4 5 10.50 11.60 1 15.6 38.5 P6KE12A P6KE12CA 10.2 5 11.40 12.60 1 16.7 36 P6KE13A P6KE13CA 11.1 5 12.40 13.70 1 18.2 33 P6KE15A P6KE15CA 12.8 1 14.30 15.80 1 21.2 28.3 P6KE16A P6KE16CA 13.6 1 15.20 16.80 1 22.5 26.7 P6KE18A P6KE18CA 15.3 1 17.10 18.90 1 25.2 23.8 P6KE20A P6KE20CA 17.1 1 19.00 21.00 1 27.7 21.7 P6KE22A P6KE22CA 18.8 1 20.90 23.10 1 30.6 19.7 P6KE24A P6KE24CA 20.5 1 22.80 25.20 1 33.2 18.1 P6KE27A P6KE27CA 23.1 1 25.70 28.40 1 37.5 16 P6KE30A P6KE30CA 25.6 1 28.50 31.50 1 41.4 14.5 P6KE33A P6KE33CA 28.2 1 31.40 34.70 1 45.7 13.2 P6KE36A P6KE36CA 30.8 1 34.20 37.80 1 49.9 12.1 P6KE39A P6KE39CA 33.3 1 37.10 41.00 1 53.9 11.2 P6KE43A P6KE43CA 36.8 1 40.90 45.20 1 59.3 10.2 P6KE47A P6KE47CA 40.2 1 44.70 49.40 1 64.8 9.3 P6KE51A P6KE51CA 43.6 1 48.50 53.60 1 70.1 8.6 P6KE56A P6KE56CA 47.8 1 53.20 58.80 1 77.0 7.8 P6KE62A P6KE62CA 53.0 1 58.90 65.10 1 85.0 7.1 P6KE68A P6KE68CA 58.1 1 64.60 71.40 1 92.0 6.6 P6KE75A P6KE75CA 64.1 1 71.30 78.80 1 103.0 5.9 P6KE82A P6KE82CA 70.1 1 77.90 86.10 1 113.0 5.4 P6KE91A P6KE91CA 77.8 1 86.50 95.50 1 125.0 4.8 P6KE100A P6KE100CA 85.5 1 95.00 105.0 1 137.0 4.4 P6KE110A P6KE110CA 94.0 1 105.0 116.0 1 152.0 4.0 http:// www.jksemi.com 2021-10-21 版次: c P6KE Series 600W Transient Voltage Suppressor ELECTRICAL CHARACTERISTICS (TA=25℃, continued) Part Number VR IR@VR VBR@IT IT VC@IPP IPP① Uni-Polar Bi-Polar V μA min(V) max(V) mA max(V) A P6KE120A P6KE120CA 102.0 1 114.0 126.0 1 165.0 3.7 P6KE130A P6KE130CA 111.0 1 124.0 137.0 1 179.0 3.4 P6KE150A P6KE150CA 128.0 1 143.0 158.0 1 207.0 2.9 P6KE160A P6KE160CA 136.0 1 152.0 168.0 1 219.0 2.8 P6KE170A P6KE170CA 145.0 1 162.0 179.0 1 234.0 2.6 P6KE180A P6KE180CA 154.0 1 171.0 189.0 1 246.0 2.5 P6KE200A P6KE200CA 171.0 1 190.0 210.0 1 274.0 2.2 P6KE220A P6KE220CA 185.0 1 209.0 231.0 1 328.0 1.9 P6KE250A P6KE250CA 214.0 1 237.0 263.0 1 344.0 1.8 P6KE300A P6KE300CA 256.0 1 285.0 315.0 1 414.0 1.5 P6KE350A P6KE350CA 300.0 1 332.0 368.0 1 482.0 1.3 P6KE400A P6KE400CA 342.0 1 380.0 420.0 1 548.0 1.1 ① Surge waveform: 10/1000μs VR :Stand-off Voltage -- Maximum voltage that can be applied VBR:Breakdown Voltage VC:Clamping Voltage -- Peak voltage measured across the suppressor at a specified Ipp IR: Reverse Leakage Current RATINGS AND V‐I CHARACTERISTICS CURVES (TA=25ºC, unless otherwise noted) FIG .1:V- I curve characteristics (Uni-directional) FIG .2:V- I curve characteristics (Bi-directional) IPP V C VBR VR V VF IPP http:// www.jksemi.com V C VBR VR IT IR IR IT V R V BR V C V IPP 2021-10-21 版次: c P6KE Series 600W Transient Voltage Suppressor FIG.4: Pulse derating curve FIG.3: Pulse waveform IPPM(%IRSM) 150 PPP derating in percentage(%) 100 tr = rise time to peak value td = decay t ime to half value tr= 10μs 80 Pea 100 k value 60 Half val ue 40 50 20 0 0 td 1.0 t(ms) 2.0 3.0 0 0 4.0 25 TA(℃) 75 100 50 125 150 175 SOLDERING PARAMETERS Pb-Free assembly (see FIG.5) Reflow Condition +150℃ -Temperature Max(Ts(max)) +200℃ TP -Time (Min to Max) (ts) 60-180 secs. TL Average ramp up rate (Liquid us Temp (TL) to peak) 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max Reflow -Temperature(TL)(Liquid us) +217℃ -Temperature(tL) 60-150 secs. Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃ of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ tp Critical Zone TL to TP Ramp-up tL TS(max) Temperature Pre Heat FIG.5: Reflow condition -Temperature Min (Ts(min)) Ramp-down Preheat TS(min) 25 ts time to peak temperatue (t 25℃ to peak) Time MARKING & ORDERING INFORMATION P6KE XX C A (1) (2) (3) (4) (1) Series:600 watts series (2)Reverse Stand-off Voltage (3)Bi-directional (4)5% VBR Voltage tolerance Cathode Band Logo P 6KExxCA http:// www.jksemi.com Product Type 2021-10-21 版次: c P6KE Series 600W Transient Voltage Suppressor PACKAGE MECHANICAL DATA Dimensions A B A Ref. Inches C D Min. Millimeters Max. Min. - Max. A 1.000 25.40 - B 0.228 0.300 5.80 7.62 C 0.027 0.035 0.69 0.89 D 0.118 0.140 3.00 3.60 Part Number Case Type Quantity Packing Option P6KEXXCA/A DO-15/DO-204AC 2000 Box Website: http://www.jksemi.com For additional information, please contact your local SalesRepresentative. ©Copyright 2021, jksemi is a registered trademark of jksemi All rights arereserved http:// www.jksemi.com 2021-10-21 版次: c
