P6KE150CA
P6KE150CA
    LIOWN(里阳)
    DO-15(DO-204AC)
    双向TVS 128V截止 峰值脉冲电流:2.9A@10/1000US
P6KE150CA 数据手册
TVS Diodes Datasheet P6KE Series Axial Leaded – 600W Description The P6KE series is designed specifically to protect sensitive electronic equipment from voltage transients induced by lightning and other transient voltage events. DO-15 Features Additional Information  Halogen free and RoHS compliant  Low incremental surge resistance  Excellent clamping capability  600W peak pulse power capability at 10/1000 μ s waveform, repetition rate (duty cycle): 0.01% Maximum Ratings and Characteristics (TA=25℃) Rating Symbol Value Peak pulse power dissipation at 10/1000μs waveform(Note1, Note2, Fig.1) PPPM 600W Peak pulse current of at 10/1000 μs waveform (Note 1, Fig.3) IPPM See Table(A) Steady state power dissipation at TL=75℃ (Fig.5) PM(AV) 5.0W Maximum Instantaneous Forward Voltage at 50A for Unidirectional Only VF 3.5V/5.0V Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load, (JEDEC Method) (Note3, Fig.6) Fast response time  Typical IR less than 1μA above 12V devices  High Temperature soldering guaranteed: 265℃/10 seconds/.375 ″ ,(9.5mm) lead length, 5lbs (2.3kg) tension  Plastic package has underwriters laboratory flammability 94V-0  Meet MSL level1, per J-STD-020  IEC-61000-4-2 ESD 30kV(Air), 30kV (Contact)  Unit Weight: 0.42g Applications TVS components are ideal for the protection of I/O Interfaces, VCC bus and other vulnerable circuits used in telecom, computer, Industrial and consumer electronic applications. IFSM 100A TJ、TSTG -55℃ to +150℃ Typical thermal resistance junction to lead RθJL 20℃/W Typical thermal resistance junction to ambient RθJA 75℃/W Operating junction and Storage Temperature Ranges  Functional Diagram Notes: 1. Non-repetitive current pulse, per Fig.3 and derating above TA=25℃ per Fig.2. 2. 8.3ms single half sine-wave or equivalent square wave, duty cycle=4 pulses per minutes maximum. 3. VF
P6KE150CA 价格&库存
很抱歉,暂时无法提供与“P6KE150CA”相匹配的价格&库存,您可以联系我们找货
P6KE150CA
  • 5+0.34915
  • 50+0.27813
  • 150+0.24262
  • 500+0.21598
  • 2000+0.19466
  • 4000+0.18397
库存:1383
