TVS Diodes Datasheet
P6KE Series
Axial Leaded – 600W
Description
The P6KE series is designed specifically to protect
sensitive electronic equipment from voltage transients
induced by lightning and other transient voltage events.
DO-15
Features
Additional Information
Halogen free and RoHS compliant
Low incremental surge resistance
Excellent clamping capability
600W peak pulse power capability at 10/1000 μ s
waveform, repetition rate (duty cycle): 0.01%
Maximum Ratings and Characteristics
(TA=25℃)
Rating
Symbol
Value
Peak pulse power dissipation at
10/1000μs waveform(Note1,
Note2, Fig.1)
PPPM
600W
Peak pulse current of at 10/1000
μs waveform (Note 1, Fig.3)
IPPM
See
Table(A)
Steady state power dissipation at
TL=75℃ (Fig.5)
PM(AV)
5.0W
Maximum Instantaneous Forward
Voltage at 50A for Unidirectional
Only
VF
3.5V/5.0V
Peak forward surge current,
8.3ms single half sine-wave
superimposed on rated load,
(JEDEC Method) (Note3, Fig.6)
Fast response time
Typical IR less than 1μA above 12V devices
High Temperature soldering guaranteed: 265℃/10
seconds/.375 ″ ,(9.5mm) lead length, 5lbs (2.3kg)
tension
Plastic
package
has
underwriters
laboratory
flammability 94V-0
Meet MSL level1, per J-STD-020
IEC-61000-4-2 ESD 30kV(Air), 30kV (Contact)
Unit Weight: 0.42g
Applications
TVS components are ideal for the protection of I/O
Interfaces, VCC bus and other vulnerable circuits used in
telecom, computer, Industrial and consumer electronic
applications.
IFSM
100A
TJ、TSTG
-55℃ to
+150℃
Typical thermal resistance
junction to lead
RθJL
20℃/W
junction to ambient
RθJA
75℃/W
Operating junction and Storage
Temperature Ranges
Functional Diagram
Notes:
1. Non-repetitive current pulse, per Fig.3 and derating above TA=25℃ per Fig.2.
2. 8.3ms single half sine-wave or equivalent square wave, duty cycle=4 pulses per
minutes maximum.
3. VF
很抱歉,暂时无法提供与“P6KE8.2CA”相匹配的价格&库存,您可以联系我们找货
