P6KE SERIES
FEATURES
Glass passivated junction.
600W Peak Pulse Power capability at1.0 ms.
Excellent clamping capability.
Low incremental surge resistance.
Fast response time; typically lessthan 1.0 ps from
0 volts to BV forunidirectional and 5.0 ns forbidirectional.
Typical IR less than 1.0 A above 10V.
DO-204AC/DO-15
MECHANICAL DATA
Case: Molded plastic
Lead: Pure tin plated lead free, solderable per MIL-STD-202, Method 208.
Polarity : Color band denotes cathode except bipolar.
Weight : 0.42 gram.
DEVICES FOR BIPOLAR APPLICATIONS
Bidirectional types use CA suffix.
Electrical Characteristics apply in both directions.
MAXIMUM RATINGS AND CHARACTERISTICS
Ratings at 25 ambient temperature unless otherwise specified.
Type Number
Peak Power Dissipation at TA= 25°C, Tp= 1ms (Note 1)
Steady State Power Dissipation at TL= 75°C
Lead Lengths 0.375 Inch 9.5mm (Note 2)
Peak Forward Surge Current, 8.3ms Single Half Sine-wave
Superimposed on Rated Load (JEDEC method) (Note 3)
Maximum Instantaneous Forward Voltage at 50.0A for
Unidirectional Only (Note 4)
Operating and Storage Temperature Range
Symbol
PPPK
Value
Units
Minimum 600
Watts
PD
3.2
IFSM
40
VF
TJ, TSTG
3.5 / 5.0
-55 to + 175
Notes: Notes: 1. Non-repetitive current pulse and derated above TA= 25°C.
2. Mounted on copper pad area of 1.6 x 1.6 inch (40 x 40mm) per.
3. 8.3ms single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minutes
maximum.
4. VF= 3.5V for devices of VBR≤200V and VF= 5.0V maximum for devices of VBR>200V.
http://www.sembo.com.cn
Amps
Volts
°C
P6KE SERIES
PACKAGE DIMENSIONS
DO-204AC/DO-15
ORDERING INFORMATION
P6KE □□□ C A
5% Voltage Tolerance
Bi-Directional
Voltage
PACKAGING
Part Number
Component Package
Quantity
P6KExxxA/CA
DO-204AC/DO-15
2000
P6KE SERIES
ELECTRICAL CHARACTERISTICS
P6KE
DEVICES
REVERSE
STAND-OFF
VOLTAGE
VRWM(v)
BREAKDOWN
VOLTAGE
Min.@IT VBR
Min.(V)
BREAKDOWN
VOLTAGE
Max.@IT VBR
Max.(V)
TEST
CURRENT
IT(mA)
MAXIMUM
CLAMPING
VOLTAGE
@Ipp VC(V)
PEAK
PULSE
CURRENT
Ipp(A)
REVERSE
LEAKAGE
@VRWM
IR(uA)
P6KE6.8CA/A
P6KE7.5CA/A
P6KE8.2CA/A
P6KE9.1CA/A
P6KE10CA/A
P6KE11CA/A
P6KE12CA/A
P6KE13CA/A
P6KE15CA/A
P6KE16CA/A
P6KE18CA/A
P6KE20CA/A
P6KE22CA/A
P6KE24CA/A
P6KE27CA/A
P6KE30CA/A
P6KE33CA/A
P6KE36CA/A
P6KE39CA/A
P6KE43CA/A
P6KE47CA/A
P6KE51CA/A
P6KE56CA/A
P6KE62CA/A
P6KE68CA/A
P6KE75CA/A
P6KE82CA/A
P6KE91CA/A
P6KE100CA/A
P6KE110CA/A
P6KE120CA/A
P6KE130CA/A
P6KE150CA/A
P6KE160CA/A
P6KE170CA/A
P6KE180CA/A
P6KE200CA/A
P6KE220CA/A
P6KE250CA/A
P6KE300CA/A
P6KE350CA/A
P6KE400CA/A
P6KE440CA/A
P6KE480CA/A
5.80
6.40
7.02
7.78
8.55
9.40
10.20
11.10
12.80
13.60
15.30
17.10
18.80
20.50
23.10
25.60
28.20
30.80
33.30
36.80
40.20
43.60
47.80
53.00
58.10
64.10
70.10
77.80
85.50
94.00
102.00
111.00
128.00
136.00
145.00
154.00
171.00
185.00
214.00
256.00
300.00
342.00
376.00
408.00
6.45
7.13
7.79
8.65
9.50
10.50
11.40
12.40
14.30
15.20
17.10
19.00
20.90
22.80
25.70
28.50
31.40
34.20
37.10
40.90
44.70
48.50
53.20
58.90
64.60
71.30
77.90
86.50
95.00
105.00
114.00
124.00
143.00
152.00
162.00
171.00
190.00
209.00
237.00
285.00
332.00
380.00
418.00
456.00
7.14
7.88
8.61
9.55
10.50
11.60
12.60
13.70
15.80
16.80
18.90
21.00
23.10
25.20
28.40
31.50
34.70
37.80
41.00
45.20
49.40
53.60
58.80
65.10
71.40
78.80
86.10
95.50
105.00
116.00
126.00
137.00
158.00
168.00
179.00
189.00
210.00
231.00
263.00
315.00
368.00
420.00
462.00
504.00
10
10
10
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
10.5
11.3
12.1
13.4
14.5
15.6
16.7
18.2
21.2
22.5
25.2
27.7
30.6
33.2
37.5
41.4
45.7
49.9
53.9
59.3
64.8
70.1
77.0
85.0
92.0
103.0
113.0
125.0
137.0
152.0
165.0
179.0
207.0
219.0
234.0
246.0
274.0
328.0
344.0
414.0
482.0
548.0
602.0
658.0
57.0
53.0
50.0
45.0
41.0
38.0
36.0
33.0
28.0
27.0
24.0
22.0
20.0
18.0
16.0
14.4
13.2
12.0
11.2
10.1
9.3
8.6
7.8
7.1
6.5
5.8
5.3
4.8
4.4
4.0
3.6
3.3
2.9
2.7
2.6
2.4
2.2
1.9
1.8
1.5
1.3
1.1
1.04
0.9
1000
500
200
50
10
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
TYPICAL CHARACTERISTICS
P6KE SERIES
很抱歉,暂时无法提供与“P6KE6.8CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.53450
- 50+0.42563
- 150+0.37120
- 500+0.33038
- 2000+0.25683
- 4000+0.24041
