SAC SERIES
Transient Voltage Suppressors (TVS) Data Sheet
Features
Glass passivated junction
Low inductance
Excellent clamping capability
500W peak pulse power capability at 10/1000μs waveform,
repetition rate (duty cycle): 0.01%
Fast response time
Ideal for data line applications.
High Temperature soldering guaranteed: 265℃/10 seconds/.375″,
(9.5mm) lead length, 5lbs (2.3kg) tension
Plastic package has underwriters laboratory flammability 94V-0
Meets MSL level 1, per J-STD-020
Safety certification: UL: E244458
Mechanical Data
Case: JEDEC DO-15 Moulded plastic
Terminal: Axial leads, solderable per MIL-STD-750, Method 2026
Polarity: Color band denotes cathode except bi-directional models
Mounting Position: Any
Weight: 0.42g
Applications
■ I/O interface
■ AC/DC power supply
■ Low frequency signal transmission line (RS232, RS485, etc.)
Maximum Ratings and Characteristics
Ratings at 25℃ ambient temperature unless otherwise specified.
Rating
Symbol
Value
Units
Peak pulse power dissipation at 10/1000μs waveform
(Note1, Note2, Fig.1)
PPPM
Minimum 500
Watts
Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3)
IPPM
See Table
Amps
PM(AV)
3.0
Watts
TJ,TSTG
-55 to +150
Steady state power dissipation at TA=50℃ (Fig.5)
Operating junction and Storage Temperature Range.
Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2.
Revision:TVS-SAC SERIES-001(A1)
1/5
http://brightking.pulseelectronics.com
SAC SERIES
Dimensions (DO-204AC/DO-15)
Millimeters
Cathode Band
L
d
T
Inches
Symbol
s
DIA.
DIA.
L
Min.
Max.
Min.
Max.
L
25.40
1.000
T
5.80
7.60
0.230
0.300
d
2.60
3.60
0.104
0.140
s
0.71
0.86
0.028
0.034
Electrical Characteristics (TA=25℃)
Reverse
Part
Number
Stand-Off
Minimum
Maximum
Maximum
Maximum
Maximum
Working
Inverse
Peak
Breakdown
Reverse
Clamping
Peak
Junction
Inverse
Blocking
Inverse
Voltage
Leakage
Voltage
Pulse
Capacitance
Blocking
Leakage
Blocking
@IT=1mA
@VRWM
@IPP=5A
Current
@0V
Voltage
Current
Voltage
VRWM(V)
VBR(V)
IR(μA)
VC(V)
IPP(A)
pF
VWIB(V)
IIB(mA)
VPIB(V)
SAC5.0
5.0
7.60
300
10.0
44.0
50
75
1.0
100
SAC6.0
6.0
7.90
300
11.2
41.0
50
75
1.0
100
SAC7.0
7.0
8.33
300
12.6
38.0
50
75
1.0
100
SAC8.0
8.0
8.89
100
13.4
36.0
50
75
1.0
100
SAC8.5
8.5
9.44
50
14.0
34.0
50
75
1.0
100
SAC10
10.0
11.10
5
16.3
29.0
50
75
1.0
100
SAC12
12.0
13.30
1
19.0
25.0
50
75
1.0
100
SAC15
15.0
16.70
1
23.6
20.0
50
75
1.0
100
SAC18
18.0
20.00
1
28.8
15.0
50
75
1.0
100
SAC22
22.0
24.40
1
35.4
14.0
50
75
1.0
100
SAC26
26.0
28.90
1
42.3
11.1
50
75
1.0
100
SAC30
30.0
33.30
1
48.6
10.0
50
75
1.0
100
SAC36
36.0
40.00
1
60.0
8.6
50
75
1.0
100
SAC45
45.0
50.00
1
77.0
6.8
50
150
1.0
200
SAC50
50.0
55.50
1
88.0
5.8
50
150
1.0
200
Voltage
2/5
SAC SERIES
Ratings and Characteristic Curves (T A=25℃ unless otherwise noted)
Figure 1. Peak Pulse Power Rating Curve
Figure 2. Pulse Derating Curve
100
Percentage of Rated Power (%)
PPPM - Peak Pulse Power (kW)
100
10
1
0.1
Peak Power
(Single Pulse)
50
25
10
100
1000
td-Pulse Width (µs)
150
25
50
75
100 125
150 175
200
TL-Lead Temperature (℃)
Figure 4. AC Line Protection Application
Figure 3. Pulse Waveform
IPPM - Peak Pulse Current, %IRSM
Average Power
75
TJ=25℃
Pulse Width(td) is defined as
the point where the peak
current decays to 50% of IPPM
tr=10µs
Peak Value IPPM
100
Half Value IPPM (IPPM/2)
50
10/1000µs Waveform
as defined by R.E.A
Low Capacitance
Application Note: Device must be used with two
units in parallel, opposite in polarity as shown in
circuit for AC signal line protection.
td
2.0
3.0
4.0
t-Time (ms)
Figure 5. Steady State Power Dissipation Derating
Curve
Steady State Power Dissipation (W)
3.5
3
2.5
2
1.5
L= 0.375″(9.5mm)
Lead Lengths
1
0.5
50
75
100
125
150
175 200
3/5
SAC SERIES
Recommended Soldering Conditions
Wave Soldering
300
Preheating
Maximum Wave 265℃
Soldering
Cooling
Temperature (℃)
250
200
150
100
50
1
1.5
2
2.5
3
3.5
4
Time (minutes)
Recommended Conditions
Item
Conditions
Peak Temperature
265℃
Dipping Time
10 seconds
Soldering
1 time
Marking Code
Cathode Band
Logo
YXXX
SAC5.0
Date Code
Marking Code
4/5
SAC SERIES
Part Number Code
SAC XX
VRWM Voltage
Series Code
Ordering Code for Different Package
Box package: Add suffix “/B” at the end of the part number, such as SAC5.0/B
Reel package: Add suffix “/TR13” at the end of the part number, such as SAC50/TR13
Packaging
Tape
Z
±5°
A
E
L1
B
L2
T
E
Box
H
L
W
Dimension (mm)
A
5.0±0.5
B
53.0±1.0
Z
1.2Max.
T
6.0±0.4
E
0.8Max.
L1-L2
1.0Max.
L
250.0±5.0
W
75.0±5.0
H
114.0±5.0
Quantity: 2000PCS
Reel
D0
D
Symbol
D1
D
330.0±3.0
D0
16.4±2.0
D1
86.0±2.0
W1
76.0±3.0
W1
Quantity: 4000PCS
5/5
很抱歉,暂时无法提供与“SAC7.0/B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.11062
- 50+0.08994
- 150+0.08107
- 500+0.07001
- 2000+0.06508
- 4000+0.06213
- 10000+0.06139
- 20000+0.06089
