P6KE
R
Transient Voltage Suppressors
FEATURES
Plastic package
Glass passivated chip junction in DO-15 Package
600W peak pulse power capability on 10/1000us waveform
Excellent clamping capability
DO-15
Low zener impedance
Fast response time:typically less than 1.0ps from 0 Volts to BV min
Typical IR less than 1uA above 12V
Polarity:Color band denoted cathode except bidirectional
Bi-directional
Mounting Position:Any
Anode
Cathode
Uni-drectional
Schematic Symbol
APPROVALS
RoHS Compliance with 2011/65/EU
HF
Compliance with IEC61249-2-21:2003
MAXIMUM RATINGS AND CHARACTERISTICS(TA=25°C )
Parameter
Symbol
Value
Unit
Peak pulse power dissipation at 10/1000μs waveform
PPP
600
Steady state power dissipation at TL=75℃
PD
5.0
Peak Pulse Current of on 10/1000us waveform(Note1)
IPPM
See Table
Peak forward surge current, 8.3ms single half sine-wave for unidirectional only
IFSM
100
Typical thermal resistance, junction to ambient
RθJA
75
℃/W
Operating junction and storage temperature range
TJ,TSTG
-55 to +150
W
A
Product Datasheet
Mar.2022-Rev. A2
1/7
Build Your Design As You Will
Http://semiware.com
P6KE
R
ELECTRICAL CHARACTERISTICS (TA=25°C)
Part Number
Marking Code
VR
VBR@IT
IT
VC@IPP
IPP①
IR@VR
Uni-Polar
Bi-Polar
Uni-Polar
Bi-Polar
V
Min(V)
Max (V)
mA
V
A
Max(μA)
P6KE6.8A
P6KE6.8CA
P6KE6.8A
P6KE6.8CA
5.8
6.45
7.14
10
10.5
58.1
1000
P6KE7.5A
P6KE7.5CA
P6KE7.5A
P6KE7.5CA
6.4
7.13
7.88
10
11.3
54.0
500
P6KE8.2A
P6KE8.2CA
P6KE8.2A
P6KE8.2CA
7.02
7.79
8.61
10
12.1
50.4
200
P6KE9.1A
P6KE9.1CA
P6KE9.1A
P6KE9.1CA
7.78
8.65
9.55
1.0
13.4
45.5
50
P6KE10A
P6KE10CA
P6KE10A
P6KE10CA
8.55
9.50
10.5
1.0
14.5
42.1
10
P6KE11A
P6KE11CA
P6KE11A
P6KE11CA
9.4
10.5
11.6
1.0
15.6
39.1
5.0
P6KE12A
P6KE12CA
P6KE12A
P6KE12CA
10.2
11.4
12.6
1.0
16.7
36.5
5.0
P6KE13A
P6KE13CA
P6KE13A
P6KE13CA
11.1
12.4
13.7
1.0
18.2
33.5
1.0
P6KE15A
P6KE15CA
P6KE15A
P6KE15CA
12.8
14.3
15.8
1.0
21.2
28.8
1.0
P6KE16A
P6KE16CA
P6KE16A
P6KE16CA
13.6
15.2
16.8
1.0
22.5
27.1
1.0
P6KE18A
P6KE18CA
P6KE18A
P6KE18CA
15.3
17.2
18.9
1.0
25.5
24.2
1.0
P6KE20A
P6KE20CA
P6KE20A
P6KE20CA
17.1
19.0
21.0
1.0
27.7
22.0
1.0
P6KE22A
P6KE22CA
P6KE22A
P6KE22CA
18.8
20.9
23.1
1.0
30.6
19.9
1.0
P6KE24A
P6KE24CA
P6KE24A
P6KE24CA
20.5
22.8
25.2
1.0
33.2
18.4
1.0
P6KE27A
P6KE27CA
P6KE27A
P6KE27CA
23.1
25.7
28.4
1.0
37.5
16.3
1.0
P6KE30A
P6KE30CA
P6KE30A
P6KE30CA
25.6
28.5
31.5
1.0
41.4
14.7
1.0
P6KE33A
P6KE33CA
P6KE33A
P6KE33CA
28.2
31.4
34.7
1.0
45.7
13.3
1.0
P6KE36A
P6KE36CA
P6KE36A
P6KE36CA
30.8
34.2
37.8
1.0
49.9
12.2
1.0
P6KE39A
P6KE39CA
P6KE39A
P6KE39CA
33.3
37.1
41.0
1.0
53.9
11.3
1.0
P6KE43A
P6KE43CA
P6KE43A
P6KE43CA
36.8
40.9
45.2
1.0
59.3
10.3
1.0
P6KE47A
P6KE47CA
P6KE47A
P6KE47CA
40.2
44.7
49.4
1.0
64.8
9.4
1.0
P6KE51A
P6KE51CA
P6KE51A
P6KE51CA
43.6
48.5
53.6
1.0
70.1
8.7
1.0
P6KE56A
P6KE56CA
P6KE56A
P6KE56CA
47.8
53.2
58.8
1.0
77.0
7.9
1.0
P6KE62A
P6KE62CA
P6KE62A
P6KE62CA
53.0
58.9
65.1
1.0
85.0
7.2
1.0
Product Datasheet
Mar.2022-Rev. A2
2/7
Http://semiware.com
P6KE
R
Part Number
Marking Code
VR
VBR@IT
IT
VC@IPP
IPP①
IR@VR
Uni-Polar
Bi-Polar
Uni-Polar
Bi-Polar
V
Min(V)
Max (V)
mA
V
A
Max(μA)
P6KE68A
P6KE68CA
P6KE68A
P6KE68CA
58.1
64.6
71.4
1.0
92.0
6.6
1.0
P6KE75A
P6KE75CA
P6KE75A
P6KE75CA
64.1
71.3
78.8
1.0
103.0
5.9
1.0
P6KE82A
P6KE82CA
P6KE82A
P6KE82CA
70.1
77.9
86.1
1.0
113.0
5.4
1.0
P6KE91A
P6KE91CA
P6KE91A
P6KE91CA
77.8
86.5
95.5
1.0
125.0
4.9
1.0
P6KE100A
P6KE100CA
P6KE100A
P6KE100CA
85.5
95.0
105.0
1.0
137.0
4.5
1.0
P6KE110A
P6KE110CA
P6KE110A
P6KE110CA
94.0
105.0
116.0
1.0
152.0
4.0
1.0
P6KE120A
P6KE120CA
P6KE120A
P6KE120CA
102.0
114.0
126.0
1.0
165.0
3.7
1.0
P6KE150A
P6KE150CA
P6KE150A
P6KE150CA
128.0
143.0
158.0
1.0
207.0
2.9
1.0
P6KE160A
P6KE160CA
P6KE160A
P6KE160CA
136.0
152.0
168.0
1.0
219.0
2.8
1.0
P6KE170A
P6KE170CA
P6KE170A
P6KE170CA
145.0
162.0
179.0
1.0
234.0
2.6
1.0
P6KE180A
P6KE180CA
P6KE180A
P6KE180CA
154.0
171.0
189.0
1.0
246.0
2.5
1.0
P6KE200A
P6KE200CA
P6KE200A
P6KE200CA
171.0
190.0
210.0
1.0
274.0
2.2
1.0
P6KE220A
P6KE220CA
P6KE220A
P6KE220CA
185.0
209.0
231.0
1.0
328.0
1.9
1.0
P6KE250A
P6KE250CA
P6KE250A
P6KE250CA
214.0
237.0
263.0
1.0
344.0
1.8
1.0
P6KE300A
P6KE300CA
P6KE300A
P6KE300CA
256.0
285.0
315.0
1.0
414.0
1.5
1.0
P6KE350A
P6KE350CA
P6KE350A
P6KE350CA
300.0
332.0
368.0
1.0
482.0
1.3
1.0
P6KE400A
P6KE400CA
P6KE400A
P6KE400CA
342.0
380.0
420.0
1.0
548.0
1.1
1.0
P6KE440A
P6KE440CA
P6KE440A
P6KE440CA
376.0
418.0
462.0
1.0
602.0
1.0
1.0
P6KE480A
P6KE480CA
P6KE480A
P6KE480CA
408.0
456.0
504.0
1.0
658.0
0.9
1.0
P6KE510A
P6KE510CA
P6KE510A
P6KE510CA
434.0
485.0
535.0
1.0
698.0
0.9
1.0
P6KE520A
P6KE520CA
P6KE520A
P6KE520CA
442.0
494.0
546.0
1.0
698.0
0.9
1.0
P6KE530A
P6KE530CA
P6KE530A
P6KE530CA
451.0
503.5
557.0
1.0
725.0
0.8
1.0
P6KE540A
P6KE540CA
P6KE540A
P6KE540CA
459.0
513.0
567.0
1.0
740.0
0.8
1.0
P6KE550A
P6KE550CA
P6KE550A
P6KE550CA
467.0
522.5
578.0
1.0
760.0
0.8
1.0
P6KE600A
P6KE600CA
P6KE600A
P6KE600CA
510.0
570.0
630.0
1.0
828.0
0.75
1.0
Note:
①.Surge waveform:10/1000μs
VR: Stand-off voltage -- Maximum voltage that can be applied
VBR: Breakdown voltage
VC: Clamping voltage -- Peak voltage measured across the suppressor at a specified IPP
IR: Reverse leakage current
Product Datasheet
Mar.2022-Rev. A2
3/7
Http://semiware.com
P6KE
R
CHARACTERISTIC CURVES
TVS Transients Clamping Waveform
Peak Pulse Power Rating Curve
100
P PPM -Peak Pulse Power(kW)
Voltage Transients
Voltage or Current
Voltage Across T VS
Current Through T VS
10
1
0.1
0.001
0.01
0.1
1
10
Time
t d -Pulse Width(mS.)
Pulse Waveform
Pulse Derating Curve
150
I PPM - Peak Pulse Current,%I RSM
Peak Pulse Power (P PP ) or Current (I PP )
Derating in Percentage %
100
80
60
40
tr=10μsec
Peak Value I PPM
100
Half Value=(I PPM /2)
50
10/1000μsec. Waveform
as defined by R.E.A
50
75
100
125
150
T A - Initial Junction Temperature (℃)
Product Datasheet
Mar.2022-Rev. A2
TJ=25℃
Pulse Width(td)is defined
as the point where the peak
current decays to 50% of IPPM
td
2.0
3.0
4.0
t-Time (ms)
4/7
Http://semiware.com
P6KE
R
Steady State Power Dissipaton
Deraiting Curve
Typical Junction Capacittance
10000
P D , Steady State Power Dissipation(W)
5.0
Bi-directional V=0V
cj(PF)
1000
Uni-directional V=0V
Uni-directional@V R
100
Bi-directional @V R
10
Tj=25℃
f=1.0MHZ
Vsig=50mV P ‐ P
4.0
3.0
2.0
1.0
1.0
10.0
100.0
1000.0
V BR -Reverse Breakdown Voltage(v)
50
75
100
125
150
175
T A -Ambient temperature( ℃ )
WAVE SOLDERING
Wave Parameter
Temperature(℃)-Measured on bottom side of board
300
Lead–free assembly
280
260
Temperature Min
240
Pre Heat
220
200
180
160
100°C
Temperature Max
150°C
Time(min to max)
60 – 180 secs
Solder pot Temperature
280°C Max
140
Solder Dwell Time
120
2-5 seconds
100
80
60
40
40
50
60
70
80
90 100 110 120 130 140 150 160 170 180 190 200 210 220 230 240
Preheat Time
Cooling Time
Dwell Time
Product Datasheet
Mar.2022-Rev. A2
5/7
Http://semiware.com
P6KE
R
DO-15 PACKAGE INFORMATION
D
Ref.
D
Inches
Min.
Max.
Min.
Max.
A
5.80
7.60
0.230
0.300
B
2.60
3.60
0.104
0.140
C
0.70
0.90
0.026
0.034
D
25.40
1.000
B
C
A
Millimeters
Cathode Band
ORDERING INFORMATION
Part Number
Component Package
Per Carton
Description
P6KExxA/CA
DO-15
2000pcs
Box
Product Datasheet
Mar.2022-Rev. A2
6/7
Http://semiware.com
P6KE
R
Headquarters
Sales Center
No.3387 Shendu Road Pujiang
I&E Park
Minhang Shanghai China
201000
Tel: 86-21-3463-7458
Email: sales18@semiware.com
Customer Service
Hotline
Tel: 86-21-5484-1001
Email: sales17@semiware.com
400-021-5756
Technical Support
Web
Https://www.semiware.com
Tel: 86-21-3463-7654
Email: fae01@semiware.com
Complaint & Suggestions
Tel: 86-21-3463-7172
Ext: 8868
Email: cs03@semiware.com
By QR Code
Website
Wechat
To find your local partner within Semiware‘s global network: www.semiware.com
C 2022 Semiware Semiconductor Inc.
The content of this document has been carefully checked and understood. However, neither Semiware nor its subsidiaries
assume any liability whatsoever for any errors or inaccuracies of this document and theconsequences thereof. Published
specifications are subject to change without notice. Product suitability for any area of applic-ation must ultimately be
determined by the customer. In all cases,products must never be operated outside their published specifications.Semiware does not guarantee the availability of all published products. This disclaimer shall be governed by substantive Swiss
law and resulting disputes shall be settled by the courts at the place of business of Semiware . Latest publications and a
complete disclaimer can be downloaded from the Semiware website. All trademarks recognized.
Product Datasheet
Mar.2022-Rev. A2
7/7
Http://semiware.com
很抱歉,暂时无法提供与“P6KE30CA”相匹配的价格&库存,您可以联系我们找货
