P6KE12A
P6KE12A
    JKSEMI(金开盛)
    DO-15(DO-204AC)
    单向TVS 10.2V截止 峰值脉冲电流:35.93A
P6KE12A 数据手册
TVS Surface Mount – 600W > P6KE Series Description The P6KE series is designed specifically to protect sensitive electronic equipment from voltage transients induced by lightning and other transient voltage events. Features ◆ 600W peak pulsepower capability at 10 x 1000μs waveform, repetition rate (duty cycle): 0.01% ◆ Glass Passivated chip junction ◆ For surface mounted applications to optimize board space ◆ Low profile package ◆ Built-in strain relief ◆ Low incremental surge resistance ◆ Excellent clamping capability ◆ Plastic package has UL flammability classification 94V-O ◆ Fast response time: typically less than 1.0ps from 0 Volts to BV min ◆ Typical IR less than 5uA above 22V ◆ High temperature soldering: 260°C/40 seconds at terminals ◆ IEC-61000-4-2 ESD 15KV(Air),8KV(Contact) ◆ ESD protection of data lines in accordance with IEC 61000-4-2(IEC801-2) ◆ EFT protection of data lines in accordance with IEC61000-4-4(IEC801-4) Applications TVS devices are ideal for the protection of I/O Interfaces, VCC bus and other vulnerable circuits used in Telecom, Computer, Industrial and Consumer electronic applications. Maximum Ratings and Electrical Characteristics (TA=25℃ unless otherwise noted) Parameter Symbol Value Unit PPPM 600 W Power Dissipation on infinite heat sink at TA=50℃ PD 6.5 W Peak Forward Surge Current, 8.3ms Single Half Sine Wave Unidirectional only(Note 3) IFSM 300 A Maximum Instantaneous Forward Voltage at 100A for Unidirectional only VF 3.5V/5.0 V TJ, TSTG -55 to + 150 ℃ Typical Thermal Resistance Junction to Lead RuJL 15 ℃/W Typical Thermal Resistance Junction to Ambient RuJA 75 ℃/W Peak Pulse Power Dissipation at TA=25℃ by 10x1000μs waveform (Fig.2)(Note 1) (Note 2) Operating Junction Temperature Range and Storage Notes: 1. Non-repetitive current pulse, per Fig.3and derated above TA=25℃ per Fig. 2. 2. Mounted on copper pad area of 0.31x0.31” (8.0 x 8.0mm) to each terminal. 3. Measured on 8.3ms single half sine wave or equivalent square wave for unidirectional device only, duty cycle=4 per minute maximum. BI- POLAR UNI-POLAR VRWM VBR VBR IT IR Ipp Vc (V) MIN(V) MAX(V) (mA) (µA) (A) (v) P6KE6.8CA P6KE6.8A 5.80 6.45 7.14 10 1000 57.14 10.5 P6KE7.5CA P6KE7.5A 6.40 7.13 7.88 10 500 53.10 11.3 P6KE8.2CA P6KE8.2A 7.02 7.79 8.61 10 200 49.59 12.1 P6KE9.1CA P6KE9.1A 7.78 8.65 9.50 1 50 44.78 13.4 P6KE10CA P6KE10A 8.55 9.50 10.50 1 10 41.38 14.5 P6KE11CA P6KE11A 9.40 10.50 11.60 1 1 38.46 15.6 P6KE12CA P6KE12A 10.20 11.40 12.60 1 1 35.93 16.7 P6KE13CA P6KE13A 11.10 12.40 13.70 1 1 32.97 18.2 P6KE15CA P6KE15A 12.80 14.30 15.80 1 1 28.30 21.2 P6KE16CA P6KE16A 13.60 15.20 16.80 1 1 26.67 22.5 P6KE18CA P6KE18A 15.30 17.10 18.90 1 1 23.81 25.2 P6KE20CA P6KE20A 17.10 19.00 21.00 1 1 21.66 27.7 P6KE22CA P6KE22A 18.80 20.90 23.10 1 1 19.61 30.6 P6KE24CA P6KE24A 20.50 22.80 25.20 1 1 18.07 33.2 P6KE27CA P6KE27A 23.10 25.70 28.40 1 1 16.00 37.5 P6KE30CA P6KE30A 25.60 28.50 31.50 1 1 14.49 41.4 P6KE33CA P6KE33A 28.20 31.40 34.70 1 1 13.13 45.7 P6KE36CA P6KE36A 30.80 34.20 37.80 1 1 12.02 49.9 P6KE39CA P6KE39A 33.30 37.10 41.00 1 1 11.13 53.9 P6KE43CA P6KE43A 36.80 40.90 45.20 1 1 10.12 59.3 P6KE47CA P6KE47A 40.20 44.70 49.40 1 1 9.26 64.8 P6KE51CA P6KE51A 43.60 48.5 53.60 1 1 8.56 70.1 P6KE56CA P6KE56A 47.80 53.20 58.80 1 1 7.79 77.0 P6KE62CA P6KE62A 53.00 58.90 65.10 1 1 7.06 85.0 @Ipp VOLTAGE MAXIMUM CLAMPING CURRENT PEAK PULSE @VRWM LEAKAGE REVERSE CURRENT TEST T VBR(V)MAX.@I VOLTAGE BREAKDOWN VOLTAGE STAND-OFF PART NUMBER REVERSE Electrical Characteristics Electrical Characteristics VRWM VBR VBR IT IR Ipp Vc (V) MIN(V) MAX(V) (mA) (µA) (A) (v) P6KE68CA P6KE68A 58.10 64.60 71.40 1 1 6.52 92.0 P6KE75CA P6KE75A 64.10 71.30 78.80 1 1 5.83 103.0 P6KE82CA P6KE82A 70.10 77.90 86.10 1 1 5.31 113.0 P6KE91CA P6KE91A 77.80 86.50 95.50 1 1 4.80 125.0 P6KE100CA P6KE100A 84.00 95.00 105.00 1 1 4.38 137.0 P6KE110CA P6KE110A 94.00 105.00 116.00 1 1 3.95 152.0 P6KE120CA P6KE120A 102.00 114.00 126.00 1 1 3.95 152.0 P6KE130CA P6KE130A 111.00 124.00 137.00 1 1 3.35 179.0 P6KE150CA P6KE150A 128.00 143.00 158.00 1 1 2.90 207.0 P6KE160CA P6KE160A 136.00 152.00 168.00 1 1 2.74 219.0 P6KE170CA P6KE170A 145.00 162.00 179.00 1 1 2.56 234.0 P6KE180CA P6KE180A 154.00 171.00 189.00 1 1 2.44 246.0 P6KE200CA P6KE200A 171.00 190.00 210.00 1 1 2.19 274.0 P6KE220CA P6KE220A 185.00 209.00 231.00 1 1 1.83 328.0 P6KE300CA P6KE300A 256.00 285.00 315.00 1 1 1.45 414.0 P6KE350CA P6KE350A 300.00 332.00 368.00 1 1 1.24 482.0 P6KE400CA P6KE400A 342.00 380.00 420.00 1 1 1.09 548.0 P6KE440CA P6KE440A 376.00 418.00 462.00 1 1 1.00 602.0 P6KE480CA P6KE480A 408.00 456.00 504.00 1 1 0.91 658.0 P6KE520CA P6KE520A 442.00 494.00 546.00 1 1 0.86 710.0 P6KE530CA P6KE530A 450.00 503.50 556.5 1 1 0.83 725.0 P6KE540CA P6KE540A 459.00 513.00 567.00 1 1 0.81 740.0 P6KE550CA P6KE550A 467.00 522.5 577.50 1 1 0.79 760.0 Notes: For bidirectional type having VRWM of 20 volts and less, the IR limit is double. For parts without A (VBR is ± 10% and VC is 5% higher than A parts @Ipp VOLTAGE CLAMPING MAXIMUM CURRENT PULSE PEAK @VRWM LEAKAGE REVERSE CURRENT TEST @IT VBR(V)MAX. N VOLTAGE BREAKDOW VOLTAGE UNI-POLAR STAND-OFF BI- POLAR REVERSE PART NUMBER I-V Curve Characteristics Ratings and Characteristic Curves (TA=25°C unless otherwise noted) Figure 1 - Peak Pulse Power Rating Curve Figure 2 - Pulse Derating Curve Figu re 3 - Pulse Waveform Figure 4 - Typical Junction Capacitance Ratings and Characteristic Curves (TA=25°C unless otherwise noted) Figure 5 - Steady State Power Dissipation Figure 6 - Maximum Non-Repetitive Derating Curve Forward Surge Current Uni-Directional Only Part Numbering P6KE (1) XXX (2) System C A (3) (4) (1) (2) (3) (4) SERIES. VR VOLTAGE. BI-DIRECTIONAL. 5% VOLTAGE TOLERANCE. Product Dimensions A D C D B DO-15 Dimension Inches Millimeters NOTE MIN MAX MIN MAX A 0.230 0.300 5.80 7.60 B 0.104 0.140 2.60 3.60 Φ C 0.026 0.034 0.70 0.90 Φ D 1.000 25.40 Summary of Packing Options Package Type Description Packing Industry Quantity Standard 2000PCS EIA-481-D DO-15 Embossed Carrier Reel Pack
P6KE12A 价格&库存
很抱歉,暂时无法提供与“P6KE12A”相匹配的价格&库存,您可以联系我们找货
