P6KE Series 600W Transient Voltage Suppressor
DESCRIPTION:
The P6KE series of high current uni/bi-directional transient
suppressors are designed for A.C. line protection and high
power DC bus clamping applications. These devices offer
uni/bi-directional port protection from 6.8 volts to 600 volts.
They provide a clamping voltage lower than the avalanche
voltage. Therefore, any voltage rise due to increased
current conduction is contained to a minimum, providing
the best possible protection level. They can also be
connected in series and/or parallel to create very high
capacity protection solutions.
DO-15
FEATURES:
Symbol
Low zener impedance.
Excellent clamping capability.
Repetition rate (duty cycle): 0.01%.
JEDEC DO-15/DO-204AC Molded Plastic.
Color band denoted cathode except bidirectional.
High temperature soldering: 260℃/10s at terminals.
Glass passivated or plannar chip junction in DO-15/DO-204AC package.
600W Peak Pulse power capability at 10×1000μs waveform.
Fast response time: typically less than 1.0ps from 0V to VBR min.
AEC-Q101 qualified.
ABSOLUTE MAXIMUM RATINGS (TA=25ºC, RH=45%-75%, unless otherwise noted)
Parameter
Symbol
Value
Unit
PPP
600
W
IPP
See next table
A
PM(AV)
5.0
W
TSTG, TJ
-55 to +125
IFSM
100
A
Peak pulse power dissipation on 10/1000μs
waveform
Peak pulse current of on 10/1000μs
waveform
Steady state power dissipation at TL=75℃
Operating junction and Storage temperature
range
Peak forward surge current, 8.3ms single
half sine-wave
Rev : 01.06.2014
1/5
www.leiditech.com
ELECTRICAL CHARACTERISTICS (TA=25℃)
Part Number
VR
IR@VR
VBR@IT
IT
VC@IPP
IPP①
Uni-Polar
Bi-Polar
V
μA
min(V)
max(V)
mA
max(V)
A
P6KE6.8A
P6KE6.8CA
5.8
150
6.45
7.14
10
10.5
57.2
P6KE7.5A
P6KE7.5CA
6.4
100
7.13
7.88
10
11.3
53.1
P6KE8.2A
P6KE8.2CA
7.02
50
7.79
8.61
10
12.1
49.6
P6KE9.1A
P6KE9.1CA
7.78
9.55
1
13.4
44.8
P6KE10A
P6KE10CA
8.55
10
9.50
10.50
1
14.5
41.4
P6KE11A
P6KE11CA
9.4
5
10.50
11.60
1
15.6
38.5
P6KE12A
P6KE12CA
10.2
2
11.40
12.60
1
16.7
36
P6KE13A
P6KE13CA
11.1
1
12.40
13.70
1
18.2
33
P6KE15A
P6KE15CA
12.8
1
14.30
15.80
1
21.2
28.3
P6KE16A
P6KE16CA
13.6
1
15.20
16.80
1
22.5
26.7
P6KE18A
P6KE18CA
15.3
1
17.10
18.90
1
25.2
23.8
P6KE20A
P6KE20CA
17.1
1
19.00
21.00
1
27.7
21.7
P6KE22A
P6KE22CA
18.8
1
20.90
23.10
1
30.6
19.7
P6KE24A
P6KE24CA
20.5
1
22.80
25.20
1
33.2
18.1
P6KE27A
P6KE27CA
23.1
1
25.70
28.40
1
37.5
16
P6KE30A
P6KE30CA
25.6
1
28.50
31.50
1
41.4
14.5
P6KE33A
P6KE33CA
28.2
1
31.40
34.70
1
45.7
13.2
P6KE36A
P6KE36CA
30.8
1
34.20
37.80
1
49.9
12.1
P6KE39A
P6KE39CA
33.3
1
37.10
41.00
1
53.9
11.2
P6KE43A
P6KE43CA
36.8
1
40.90
45.20
1
59.3
10.2
P6KE47A
P6KE47CA
40.2
1
44.70
49.40
1
64.8
9.3
P6KE51A
P6KE51CA
43.6
1
48.50
53.60
1
70.1
8.6
P6KE56A
P6KE56CA
47.8
1
53.20
58.80
1
77.0
7.8
P6KE62A
P6KE62CA
53.0
1
58.90
65.10
1
85.0
7.1
P6KE68A
P6KE68CA
58.1
1
64.60
71.40
1
92.0
6.6
P6KE75A
P6KE75CA
64.1
1
71.30
78.80
1
103.0
5.9
P6KE82A
P6KE82CA
70.1
1
77.90
86.10
1
113.0
5.4
P6KE91A
P6KE91CA
77.8
1
86.50
95.50
1
125.0
4.8
P6KE100A
P6KE100CA
85.5
1
95.00
105.0
1
137.0
4.4
P6KE110A
P6KE110CA
94.0
1
105.0
116.0
1
152.0
4.0
Rev : 01.06.2014
2/5
www.leiditech.com
ELECTRICAL CHARACTERISTICS (TA=25℃, continued)
Part Number
VR
IR@VR
VBR@IT
IT
VC@IPP
IPP①
Uni-Polar
Bi-Polar
V
μA
min(V)
max(V)
mA
max(V)
A
P6KE120A
P6KE120CA
102.0
1
114.0
126.0
1
165.0
3.7
P6KE130A
P6KE130CA
111.0
1
124.0
137.0
1
179.0
3.4
P6KE150A
P6KE150CA
128.0
1
143.0
158.0
1
207.0
2.9
P6KE160A
P6KE160CA
136.0
1
152.0
168.0
1
219.0
2.8
P6KE170A
P6KE170CA
145.0
1
162.0
179.0
1
234.0
2.6
P6KE180A
P6KE180CA
154.0
1
171.0
189.0
1
246.0
2.5
P6KE200A
P6KE200CA
171.0
1
190.0
210.0
1
274.0
2.2
P6KE220A
P6KE220CA
185.0
1
209.0
231.0
1
328.0
1.9
P6KE250A
P6KE250CA
214.0
1
237.0
263.0
1
344.0
1.8
P6KE300A
P6KE300CA
256.0
1
285.0
315.0
1
414.0
1.5
P6KE350A
P6KE350CA
300.0
1
332.0
368.0
1
482.0
1.3
P6KE400A
P6KE400CA
342.0
1
380.0
420.0
1
548.0
1.1
P6KE440A
P6KE440CA
376.0
1
418.0
462.0
1
602.0
1.0
P6KE480A
P6KE480CA
408.0
1
456.0
504.0
1
658.0
0.9
P6KE510A
P6KE510CA
434.0
1
485.0
535.0
1
698.0
0.9
P6KE550A
P6KE550CA
460.0
1
513.0
567.0
1
740.0
0.8
P6KE600A
P6KE600CA
512.0
1
570.0
630.0
1
828.0
0.75
① Surge waveform: 10/1000μs
VR :Stand-off Voltage -- Maximum voltage that can be applied
VBR:Breakdown Voltage
VC:Clamping Voltage -- Peak voltage measured across the suppressor at a specified Ipp
IR:Reverse Leakage Current
Rev : 01.06.2014
3/5
www.leiditech.com
RATINGS AND V-I CHARACTERISTICS CURVES (TA=25ºC, unless otherwise noted)
F IG .1:V - I cu rve ch aracteristics
(U n i-d irectio n al)
F IG .2:V - I cu rve ch aracteristics
(B i-d irectio n al)
IP P
V
V C V BR V R
IT
IR
V C VBR VR
V
IR
IT
VF
V R V BR V C
I PP
IP P
FIG.4: Pulse derating curve
FIG.3: Pulse waveform
P PP derating in percentage(%)
100
IPPM (%IRSM )
150
tr = rise time to peak value
td = decay time to half value
tr=10μs
100
80
Peak value
60
Half value
40
50
td
t(ms)
2.0
3.0
4.0
50
T A (℃ )
75
100
125
150
175
SOLDERING PARAMETERS
Reflow Condition
+150℃
-Temperature Max(Ts(max))
+200℃
TP
-Time (Min to Max) (ts)
60-180 secs.
TL
Average ramp up rate (Liquid us Temp
(TL) to peak)
3℃/sec. Max
Ts(max) to TL - Ramp-up Rate
3℃/sec. Max
Reflow
tp
Critical Zone
TL to TP
Ramp-up
tL
TS(max)
-Temperature(TL)(Liquid us)
+217℃
-Temperature(tL)
60-150 secs.
Peak Temp (Tp)
+260(+0/-5)℃
Time within 5℃ of actual Peak Temp (tp)
30 secs. Max
Ramp-down Rate
6℃/sec. Max
Time 25℃ to Peak Temp (TP)
8 min. Max
Do not exceed
+260℃
Rev : 01.06.2014
FIG.5: Reflow condition
-Temperature Min (Ts(min))
4/5
Temperature
Pre
Heat
Pb-Free assembly
(see FIG.5)
Ramp-down
Preheat
TS(min)
25
ts
time to peak temperatue
(t 25℃ to peak)
Time
www.leiditech.com
MARKING & ORDERING INFORMATION
P6KE
XX
C
A
(1)
(2)
(3)
(4)
(1)Series:600 watts series
(2)Reverse Stand-off Voltage
(3)Bi-directional
(4)5% V BR Voltage tolerance
Cathode Band
Logo
Product Type
P6KExxCA
PACKAGE MECHANICAL DATA
Dimensions
A
B
A
Ref.
Inches
C
D
Min.
Millimeters
Max.
Min.
Max.
25.40
5.80
7.62
A
1.000
B
0.228
0.300
C
0.027
0.035
0.69
0.89
D
0.118
0.140
3.00
3.60
Part Number
Case Type
Quantity
Packing Option
P6KEXXCA/A
DO-15/DO-204AC
2000
Box
Shanghai Leiditech Electronic Co.,Ltd
Email: sale1@leiditech.com
Tel : +86- 021 50828806
Fax : +86- 021 50477059
Rev : 01.06.2014
5/5
www.leiditech.com
很抱歉,暂时无法提供与“P6KE200A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.58298
- 50+0.46437
- 150+0.40507
- 500+0.36058
- 3000+0.32494
- 6000+0.30718
