P6KE62CA
P6KE62CA
    SEMBO(深波)
    DO-15(DO-204AC)
    双向TVS 53V截止 7.1A峰值脉冲
P6KE62CA 数据手册
P6KE SERIES FEATURES Glass passivated junction. 600W Peak Pulse Power capability at1.0 ms. Excellent clamping capability. Low incremental surge resistance. Fast response time; typically lessthan 1.0 ps from 0 volts to BV forunidirectional and 5.0 ns forbidirectional.  Typical IR less than 1.0 A above 10V.      DO-204AC/DO-15 MECHANICAL DATA  Case: Molded plastic  Lead: Pure tin plated lead free, solderable per MIL-STD-202, Method 208.  Polarity : Color band denotes cathode except bipolar.  Weight : 0.42 gram. DEVICES FOR BIPOLAR APPLICATIONS  Bidirectional types use CA suffix.  Electrical Characteristics apply in both directions. MAXIMUM RATINGS AND CHARACTERISTICS Ratings at 25 ambient temperature unless otherwise specified. Type Number Peak Power Dissipation at TA= 25°C, Tp= 1ms (Note 1) Steady State Power Dissipation at TL= 75°C Lead Lengths 0.375 Inch 9.5mm (Note 2) Peak Forward Surge Current, 8.3ms Single Half Sine-wave Superimposed on Rated Load (JEDEC method) (Note 3) Maximum Instantaneous Forward Voltage at 50.0A for Unidirectional Only (Note 4) Operating and Storage Temperature Range Symbol PPPK Value Units Minimum 600 Watts PD 3.2 IFSM 40 VF TJ, TSTG 3.5 / 5.0 -55 to + 175 Notes: Notes: 1. Non-repetitive current pulse and derated above TA= 25°C. 2. Mounted on copper pad area of 1.6 x 1.6 inch (40 x 40mm) per. 3. 8.3ms single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minutes maximum. 4. VF= 3.5V for devices of VBR≤200V and VF= 5.0V maximum for devices of VBR>200V. http://www.sembo.com.cn Amps Volts °C P6KE SERIES PACKAGE DIMENSIONS DO-204AC/DO-15 ORDERING INFORMATION P6KE □□□ C A 5% Voltage Tolerance Bi-Directional Voltage PACKAGING Part Number Component Package Quantity P6KExxxA/CA DO-204AC/DO-15 2000 http://www.sembo.com.cn P6KE SERIES ELECTRICAL CHARACTERISTICS P6KE DEVICES REVERSE STAND-OFF VOLTAGE VRWM(v) BREAKDOWN VOLTAGE Min.@IT VBR Min.(V) BREAKDOWN VOLTAGE Max.@IT VBR Max.(V) TEST CURRENT IT(mA) MAXIMUM CLAMPING VOLTAGE @Ipp VC(V) PEAK PULSE CURRENT Ipp(A) REVERSE LEAKAGE @VRWM IR(uA) P6KE6.8CA/A P6KE7.5CA/A P6KE8.2CA/A P6KE9.1CA/A P6KE10CA/A P6KE11CA/A P6KE12CA/A P6KE13CA/A P6KE15CA/A P6KE16CA/A P6KE18CA/A P6KE20CA/A P6KE22CA/A P6KE24CA/A P6KE27CA/A P6KE30CA/A P6KE33CA/A P6KE36CA/A P6KE39CA/A P6KE43CA/A P6KE47CA/A P6KE51CA/A P6KE56CA/A P6KE62CA/A P6KE68CA/A P6KE75CA/A P6KE82CA/A P6KE91CA/A P6KE100CA/A P6KE110CA/A P6KE120CA/A P6KE130CA/A P6KE150CA/A P6KE160CA/A P6KE170CA/A P6KE180CA/A P6KE200CA/A P6KE220CA/A P6KE250CA/A P6KE300CA/A P6KE350CA/A P6KE400CA/A P6KE440CA/A P6KE480CA/A 5.80 6.40 7.02 7.78 8.55 9.40 10.20 11.10 12.80 13.60 15.30 17.10 18.80 20.50 23.10 25.60 28.20 30.80 33.30 36.80 40.20 43.60 47.80 53.00 58.10 64.10 70.10 77.80 85.50 94.00 102.00 111.00 128.00 136.00 145.00 154.00 171.00 185.00 214.00 256.00 300.00 342.00 376.00 408.00 6.45 7.13 7.79 8.65 9.50 10.50 11.40 12.40 14.30 15.20 17.10 19.00 20.90 22.80 25.70 28.50 31.40 34.20 37.10 40.90 44.70 48.50 53.20 58.90 64.60 71.30 77.90 86.50 95.00 105.00 114.00 124.00 143.00 152.00 162.00 171.00 190.00 209.00 237.00 285.00 332.00 380.00 418.00 456.00 7.14 7.88 8.61 9.55 10.50 11.60 12.60 13.70 15.80 16.80 18.90 21.00 23.10 25.20 28.40 31.50 34.70 37.80 41.00 45.20 49.40 53.60 58.80 65.10 71.40 78.80 86.10 95.50 105.00 116.00 126.00 137.00 158.00 168.00 179.00 189.00 210.00 231.00 263.00 315.00 368.00 420.00 462.00 504.00 10 10 10 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 10.5 11.3 12.1 13.4 14.5 15.6 16.7 18.2 21.2 22.5 25.2 27.7 30.6 33.2 37.5 41.4 45.7 49.9 53.9 59.3 64.8 70.1 77.0 85.0 92.0 103.0 113.0 125.0 137.0 152.0 165.0 179.0 207.0 219.0 234.0 246.0 274.0 328.0 344.0 414.0 482.0 548.0 602.0 658.0 57.0 53.0 50.0 45.0 41.0 38.0 36.0 33.0 28.0 27.0 24.0 22.0 20.0 18.0 16.0 14.4 13.2 12.0 11.2 10.1 9.3 8.6 7.8 7.1 6.5 5.8 5.3 4.8 4.4 4.0 3.6 3.3 2.9 2.7 2.6 2.4 2.2 1.9 1.8 1.5 1.3 1.1 1.04 0.9 1000 500 200 50 10 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 TYPICAL CHARACTERISTICS http://www.sembo.com.cn P6KE SERIES http://www.sembo.com.cn
P6KE62CA 价格&库存
很抱歉,暂时无法提供与“P6KE62CA”相匹配的价格&库存,您可以联系我们找货
