SA6.5CA R0G
SA6.5CA R0G
    TAIWANSEMICONDUCTOR(台半)
    DO-15(DO-204AC)
SA6.5CA R0G 数据手册
SA SERIES Taiwan Semiconductor CREAT BY ART 500W, 5V - 170V Transient Voltage Suppressor FEATURES - Excellent clamping capability - Low dynamic impedance - 500W surge capability at 10 / 1000 μs waveform - Fast response time: Typically less than 1.0ps from 0 volt to VBR for unidirectional and 5.0ns for bidirectional - Typical IR less than 1μA above 10V - Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC - Halogen-free according to IEC 61249-2-21 DO-204AC (DO-15) MECHANICAL DATA Case: DO-204AC (DO-15) Molding compound: UL flammability classification rating 94V-0 Part no. with suffix "H" means AEC-Q101 qualified Packing code with suffix "G" means green compound (halogen-free) Terminal: Pure tin plated leads, solderable per JESD22-B102 Meet JESD 201 class 2 whisker test Weight: 0.4g (approximately) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted) PARAMETER SYMBOL VALUE UNIT Peak power dissipation at TA=25°C, Tp=1ms (Note 1) PPK 500 W Steady state power dissipation at TL=75°C lead lengths .375", 9.5mm (Note 2) PD 3 W Peak forward surge current, 8.3 ms single half sine-wave superimposed on rated load (Note 3) IFSM 70 A Maximum instantaneous forward voltage at 35 A for Unidirectional only VF 3.5 V Operating junction temperature range TJ - 55 to +175 °C TSTG - 55 to +175 °C Storage temperature range Note 1: Non-repetitive current pulse per fig. 3 and derated above TA=25°C per fig. 2 Note 2: Mounted on 10 x 10 mm copper pads to each terminal Note 3: 8.3ms single half sine-wave or equivalent square wave, duty cycle=4 pulses per minute maximum Devices for Bipolar Applications 1. For bidirectional use C or CA suffix for types SA5.0 - types SA170. 2. Electrical characteristics apply in both directions Version: K1602 SA SERIES Taiwan Semiconductor CREAT BY ART ORDERING INFORMATION PART NO. PART NO. SAxxx (Note 1) SUFFIX PACKING CODE PACKING CODE SUFFIX (*) A0 H R0 G B0 PACKAGE PACKING DO-15 1,500 / Ammo box DO-15 3,500 / 13" Paper reel DO-15 1,000 / Bulk packing Note 1: "xxx" defines voltage from 5.0V (SA5.0) to 170V (SA170) *: Optional available EXAMPLE EXAMPLE PART NO. SA10HA0G PART NO. SA10 PART NO. SUFFIX H PACKING CODE A0 PACKING CODE SUFFIX G DESCRIPTION AEC-Q101 qualified Green compound Version: K1602 SA SERIES Taiwan Semiconductor CREAT BY ART RATINGS AND CHARACTERISTICS CURVES (TA=25°C unless otherwise noted) FIG. 1 PEAK PULSE POWER RATING CURVE FIG.2 POWER DERATING CURVE 125 Non-repetitive pulse waveform shown in fig.3 PEAK POWER (PPP ) DERATING IN PERCENTAGE, % PPPM, PEAK PULSE POWER, KW 100 10 IMPULSE EXPONENTIAL DECAY PPK".5" 1 HALF SINE PPK 0.1 SQUARE PPK 0.01 0 1 10 100 1,000 TL 100 75 TA 50 25 0 0 10,000 PEAK PULSE CURRENT- % Pulse width(td) is defined as the point where the peak current decays to 50% of IPPM Half value-IPPM/2 10/1000μs, waveform as defined by R.E.A. 50 td 0 0.0 1.0 2.0 3.0 4.0 t, TIME(ms) IFSM, PEAK FORWARD SURGE CURRENT, AMPERES 150 100 75 100 125 150 175 200 (°C) FIG. 4 MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT UNIDIRECTIONAL ONLY FIG. 3 CLAMPING POWER PULSE WAVEFORM Peak value IPPM 50 TEMPERATURE, tp, PULSE WIDTH, sec tr=10μs 25 100 8.3ms single half sine wave 10 1 10 100 NUMBER OF CYCLES AT 60 Hz FIG. 5 TYPICAL JUNCTION CAPACITANCE (UNIDIRECTIONAL) CJ, JUNCTION CAPACITANCE. (pF) A 10000 VR=0 1000 f=1.0MHz Vsig=50mVp-p 100 Measured at stand-off voltage,VWM 10 1 10 100 1000 V(BR), BREAKDOWN VOLTAGE. VOLTS Version: K1602 SA SERIES Taiwan Semiconductor CREAT BY ART General Part Number Breakdown Voltage (Note 1) Test Current Stand-Off Voltage Maximum Reverse Leakage @ VWM Maximum Peak Surge Current Maximum Clamping Voltage @ IPPM Maximum Temperature Coefficient VBR IT VWM IR IPPM Vc VBR mA V μA A V mV / °C V Min. Max. (Note 2) SA5.0 6.40 7.30 10 5.0 600 54.0 9.6 5 SA5.0A 6.40 7.00 10 5.0 600 57.0 9.2 5 SA6.0 6.67 8.15 10 6.0 600 46.0 11.4 5 SA6.0A 6.67 7.37 10 6.0 600 50.0 10.3 5 SA6.5 7.22 8.82 10 6.5 400 42.0 12.3 5 SA6.5A 7.22 7.98 10 6.5 400 46.0 11.2 5 SA7.0 7.78 9.51 10 7.0 150 39.0 13.3 6 SA7.0A 7.78 8.60 10 7.0 150 43.0 12.0 6 SA7.5 8.33 10.20 1 7.5 50 36.0 14.3 7 SA7.5A 8.33 9.21 1 7.5 50 40.0 12.9 7 SA8.0 8.89 10.9 1 8.0 25 35.0 15.0 7 SA8.0A 8.89 9.83 1 8.0 25 38.0 13.6 7 SA8.5 9.44 11.5 1 8.5 10 33.0 15.9 8 SA8.5A 9.44 10.4 1 8.5 10 36.0 14.4 8 SA9.0 10.0 12.2 1 9.0 5 31.0 16.9 9 SA9.0A 10.0 11.1 1 9.0 5 34.0 15.4 9 SA10 11.1 13.6 1 10 1 27.0 18.8 10 SA10A 11.1 12.3 1 10 1 30.0 17.0 10 SA11 12.2 14.9 1 11 1 26.0 20.1 11 SA11A 12.2 13.5 1 11 1 28.0 18.2 11 SA12 13.3 16.3 1 12 1 23.0 22.0 12 SA12A 13.3 14.7 1 12 1 26.3 19.9 12 SA13 14.4 17.6 1 13 1 22.0 23.8 13 SA13A 14.4 15.9 1 13 1 24.0 21.5 13 SA14 15.6 19.1 1 14 1 20.3 25.8 14 SA14A 15.6 17.2 1 14 1 22.6 23.2 14 SA15 16.7 20.4 1 15 1 19.5 26.9 16 SA15A 16.7 18.5 1 15 1 21.0 24.4 16 SA16 17.8 21.8 1 16 1 18.0 28.8 19 SA16A 17.8 19.7 1 16 1 20.0 26.0 17 SA17 18.9 23.1 1 17 1 17.0 30.5 20 SA17A 18.9 20.9 1 17 1 19.0 27.7 19 SA18 20.0 24.4 1 18 1 16.3 32.2 21 SA18A 20.0 22.1 1 18 1 17.9 39.4 20 SA20 22.2 27.1 1 20 1 14.0 35.5 25 SA20A 22.2 24.5 1 20 1 16.0 43.0 23 SA22 24.4 29.8 1 22 1 13.0 38.9 28 SA22A 24.4 26.9 1 22 1 14.7 46.6 25 SA24 26.7 32.6 1 24 1 12.0 42.1 31 SA24A 26.7 29.5 1 24 1 13.4 50.1 28 SA26 28.9 35.3 1 26 1 11.0 45.4 31 SA26A 28.9 31.9 1 26 1 12.4 53.5 30 SA28 31.1 38.0 1 28 1 10.0 48.4 35 SA28A 31.1 34.4 1 28 1 11.5 59.0 31 SA30 33.3 40.7 1 30 1 9.8 53.3 39 SA30A 33.3 36.8 1 30 1 10.8 64.3 36 SA33 36.7 44.9 1 33 1 8.8 58.1 42 SA33A 36.7 40.6 1 33 1 9.8 71.4 39 Version: K1602 SA SERIES Taiwan Semiconductor General Part Number Breakdown Voltage (Note 1) Test Current Stand-Off Voltage Maximum Reverse Leakage @ VWM Maximum Peak Surge Current Maximum Clamping Voltage @ IPPM Maximum Temperature Coefficient VBR IT VWM IR IPPM Vc VBR V mA V μA A V mV / °C 64.5 46 Min. Max. (Note 2) SA36 40.0 48.9 SA36A 40.0 44.2 1 36 1 9.0 58.1 41 SA40 44.4 54.3 1 40 1 7.3 71.4 51 SA40A 44.4 49.1 1 40 1 8.1 64.5 46 SA43 47.8 58.4 1 43 1 6.8 76.7 55 SA43A 47.8 52.8 1 43 1 7.5 69.4 50 SA45 50.0 61.1 1 45 1 6.5 80.3 58 SA45A 50.0 55.3 1 45 1 7.2 72.7 52 SA48 53.3 65.2 1 48 1 6.1 85.5 63 SA48A 53.3 58.9 1 48 1 6.7 77.4 56 SA51 56.7 69.3 1 51 1 5.7 91.1 66 SA51A 56.7 62.7 1 51 1 6.3 82.4 61 SA54 60.0 73.3 1 54 1 5.4 86.3 71 SA54A 60.0 66.3 1 54 1 6.0 87.1 65 SA58 64.4 78.7 1 58 1 5.0 103 78 SA58A 64.4 71.2 1 58 1 5.6 93.6 70 SA60 66.7 81.5 1 60 1 4.9 107 80 SA60A 66.7 73.7 1 60 1 5.4 96.8 71 SA64 71.1 86.9 1 64 1 4.6 114 86 SA64A 71.1 78.6 1 64 1 5.0 103 76 SA70 77.8 95.1 1 70 1 4.2 125 94 SA70A 77.8 86.0 1 70 1 4.6 113 85 SA75 83.3 102 1 75 1 3.9 134 101 SA75A 83.3 92.1 1 75 1 4.3 121 91 SA78 86.7 103 1 78 1 3.7 139 105 SA78A 86.7 95.8 1 78 1 4.1 126 95 SA85 94.4 115 1 85 1 3.4 151 114 SA85A 94.4 104 1 85 1 3.8 137 103 SA90 100 122 1 90 1 3.2 160 121 SA90A 100 111 1 90 1 3.5 146 110 SA100 111 136 1 100 1 2.9 179 135 SA100A 111 123 1 100 1 3.2 162 123 1 36 1 8.1 SA110 122 149 1 110 1 2.6 196 148 SA110A 122 135 1 110 1 2.9 177 133 SA120 133 163 1 120 1 2.4 214 162 SA120A 133 147 1 120 1 2.7 193 146 SA130 144 176 1 130 1 2.2 230 175 SA130A 144 159 1 130 1 2.5 209 158 SA150 167 204 1 150 1 1.9 268 203 SA150A 167 185 1 150 1 2.1 243 184 SA160 178 218 1 160 1 2.0 257 217 SA160A 178 197 1 160 1 2.0 259 196 SA170 189 231 1 170 1 1.7 304 230 SA170A 189 209 1 170 1 0.1 275 208 Notes: 1. VBR measure after IT applied for 300us, IT=square wave pulse or equivalent. 2. Surge current waveform per figure. 3 and derate per figure. 2. 3. For bipolar types having VWM of 10 volts and under, the IR limit is doubled. 4. All terms and symbols are consistent with ANSI/IEEE C62.35. Version: K1602 SA SERIES Taiwan Semiconductor CREAT BY ART PACKAGE OUTLINE DIMENSIONS DO-204AC (DO-15) DIM. Unit (mm) Unit (inch) Min Max Min Max A 2.60 3.60 0.102 0.142 B 0.70 0.90 0.028 0.035 C 25.40 - 1.000 - D 5.80 7.60 0.228 0.299 E 25.40 - 1.000 - MARKING DIAGRAM P/N = Specific Device Code G= Green Compound YWW = Date Code F= Factory Code Note: Cathode band for uni-directional products only Version: K1602 SA SERIES Taiwan Semiconductor CREAT BY ART Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. Version: K1602
SA6.5CA R0G 价格&库存
很抱歉,暂时无法提供与“SA6.5CA R0G”相匹配的价格&库存,您可以联系我们找货
SA6.5CA R0G
  • 5+0.71410
  • 50+0.57197
  • 150+0.50091
库存:5
