P6KE20A
P6KE20A
    SMCDIODESOLUTIONS(桑德斯)
    DO-15(DO-204AC)
P6KE20A 数据手册
P6KE SERIES Technical Data Data Sheet N0157, Rev. C P6KE SERIES TRANSIENT VOLTAGE SUPPRESSOR Features Glass Passivated Die Construction 600W Peak Pulse Power Dissipation 5.8V- 376V Standoff Voltage Uni- and Bi-Directional Versions Available Excellent Clamping Capability Fast Response Time Plastic Case Material has UL Flammability Classification Rating 94V-O This is a Pb − Free Device All SMC Parts are Traceable to the Wafer Lot Additional testing can be offered upon request          DO-15  Circuit Diagram Mechanical Data     Unipolar Case: JEDEC DO-15 Low Profile Molded Plastic Terminals: Solder Plated , Solderable per MIL-STD202, Method 208 Polarity: Cathode Band or Cathode Notch Weight: 0.41 grams(approx.) Bipolar Maximum Ratings and Thermal Characteristics@TA=25°C unless otherwise specified Parameter Symbol Value Unit PPPM Minimum 600 W IFSM 100 A PM(AV) 5.0 W Typical Thermal Resistance Junction to Lead RθJL 20 °C/W Typical Thermal Resistance Junction to Ambient RθJA 75 °C/W TJ,TSTG -55 to + 175 °C Peak Pulse Power Dissipation at TA=25°C (Fig.1)(Note 1, 2, 5) Peak Forward Surge Current, 8.3ms Single Half Sine Wave (Note 3) Steady State Power Dissipation( Note 2, 4) Operating Junction and Storage Temperature Range Notes: 1. Non-repetitive current pulse, per Fig. 3 and derated above TA = 25°C per Fig. 2. 2. Mounted on 40mm² copper pad. 3. 8.3ms Single Half Sine Wave duty cycle = 4 pulses per minutes maximum 4. Lead temperature at 75°C= TL 3. Peak pulse power waveform is 10/1000μs.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  P6KE SERIES Technical Data Data Sheet N0157, Rev. C Electrical Characteristics @TA=25°C unless otherwise specified UNIPOLAR P6KE6.8A P6KE7.5A P6KE8.2A P6KE9.1A P6KE10A P6KE11A P6KE12A P6KE13A P6KE15A P6KE16A P6KE18A P6KE20A P6KE22A P6KE24A P6KE27A P6KE30A P6KE33A P6KE36A P6KE39A P6KE43A P6KE47A P6KE51A P6KE56A P6KE62A P6KE68A P6KE75A P6KE82A P6KE91A P6KE100A P6KE110A P6KE120A P6KE130A P6KE150A P6KE160A P6KE170A P6KE180A P6KE200A P6KE220A P6KE250A P6KE300A P6KE350A P6KE400A P6KE440A BI-POLAR P6KE6.8CA P6KE7.5CA P6KE8.2CA P6KE9.1CA P6KE10CA P6KE11CA P6KE12CA P6KE13CA P6KE15CA P6KE16CA P6KE18CA P6KE20CA P6KE22CA P6KE24CA P6KE27CA P6KE30CA P6KE33CA P6KE36CA P6KE39CA P6KE43CA P6KE47CA P6KE51CA P6KE56CA P6KE62CA P6KE68CA P6KE75CA P6KE82CA P6KE91CA P6KE100CA P6KE110CA P6KE120CA P6KE130CA P6KE150CA P6KE160CA P6KE170CA P6KE180CA P6KE200CA P6KE220CA P6KE250CA P6KE300CA P6KE350CA P6KE400CA P6KE440CA REVERSE STAND-OFF VOLTAGE VRWM (V) BREAKDOWN VOLTAGE VBR (V) MIN. @IT BREAKDOWN VOLTAGE VBR (V) MAX. @IT TEST CURRE NT IT(MA) MAXMUM CLAMPING VOLTAGE @IPP VC(V) PEAK PULSE CURRENT IPP(A) REVERSE LEAKAGE @VRWM IR(uA) 5.8 6.4 7.02 7.78 8.55 9.4 10.2 11.1 12 12.9 14.5 17.1 18.8 20.5 23.1 25.6 28.2 30.8 33.3 36.8 40.2 43.6 47.8 53 58.1 64.1 70.1 77.8 85.5 94 102 111 128 136 145 154 171 185 214 256 300 342 376 6.45 7.13 7.79 8.65 9.5 10.5 11.4 12.4 14.3 15.2 17.1 19 20.9 22.8 25.7 28.5 31.4 34.2 37.1 40.9 44.7 48.5 53.2 58.9 64.6 71.3 77.9 86.5 95 105 114 124 143 152 162 171 190 209 237 285 333 380 418 7.14 7.88 8.61 9.55 10.5 11.6 12.6 13.7 15.8 16.8 18.9 21 23.1 25.2 28.4 31.5 34.7 37.8 41 45.2 49.4 53.6 58.8 65.1 71.4 78.8 86.1 95.5 105 116 126 137 158 168 179 189 210 231 263 315 368 420 462 10 10 10 10 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 10.5 11.3 12.1 13.4 14.5 15.6 16.7 18.2 21.2 22.5 25.2 27.7 30.6 33.2 37.5 41.4 45.7 49.9 53.9 59.3 64.8 70.1 77 85 92 103 113 125 137 152 165 179 207 219 234 246 274 328 344 414 482 548 602 58.1 54 50.4 45.5 42.1 39.1 36.5 33.5 28.8 27.1 24.2 22 19.9 18.4 16.3 14.7 13.3 12.2 11.3 10.3 9.4 8.7 7.9 7.2 6.6 5.9 5.4 4.9 4.5 4 3.7 3.4 2.9 2.8 2.6 2.5 2.2 1.9 1.8 1.5 1.3 1.1 1 1000 500 200 50 10 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 For bidirectional type having VRWM of 10 volts and less, the IR limit is double. For parts without A, the VBR is + 10% .  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  P6KE SERIES Technical Data Data Sheet N0157, Rev. C Ratings and Characteristics Curves  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  P6KE SERIES Technical Data Data Sheet N0157, Rev. C Mechanical Dimensions DO-15 SYMBOL Ordering Information Device P6KE SERIES P6KE SERIES TA Package DO-15 (Pb-Free) DO-15 (Pb-Free) Millimeters Inches Min. Max. Min. Max. A 25.4 - 1.000 - B 5.5 7.62 0.217 0.300 C 0.56 0.9 0.022 0.034 D 2.6 3.6 0.104 0.140 Marking Diagram Shipping 3000pcs / tape 3000pcs / tape For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification. P6KE6.8A/P6KE6.8CA = Part Name Carrier Tape Specification DO-15 SYMBOL Millimeters Min. Max. A 4.50 5.50 B 50.9 53.9 Z - 1.20 T 5.60 6.40 E - 0.80 IL1-L2I - 1.0  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  P6KE SERIES Technical Data Data Sheet N0157, Rev. C DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC Diode Solutions sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC Diode Solutions be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC Diode Solution assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC Diode Solutions be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC Diode Solutions. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC Diode Solutions. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
