P6KE15A
P6KE15A
    PINGWEI(平伟)
    DO-15(DO-204AC)
    TVS 12.8V截止 28A峰值脉冲
P6KE15A 数据手册
P6KE SERIES P6KE SERIES TRANSIENT VOLTAGE SUPPRESSOR DIODES Voltage Range 6.8 to 400 Vots 600 Watts Peak Power 5.0Watt Steady State FEATURES ·UL Recognized File # E-96005 ·Plastic package has Underwriters Laboratory Flammability Classification 94V-0 ·500W surge capability at10×100us waveform,Duty cycle:0.01% ·Excellent clamping capability ·Low zener impedance ·Fast response time:Typically less then 1.0ps from 0 volts to VBR for unidirectional and 5.0ns for bidirectional ·Typical IR less then 1 μΑ above 10V ·High temperature soldering guaranteed:260℃/10 seconds .375〞,(9.5mm)lead length / 5lbs.,(2.3kg)tension DO-15 1.0(25.4) M IN . + .300(7.6) .230(5.8) MECHANICAL DATA - 1.0(25.4) M IN . ·Terminal: Plated axial leads solderable per MIL-STD 202E, method 208C ·Case: Molded with UL-94 Class V-0 recognized Flame Retardant Epoxy ·Polarity: color band denotes cathode except bipolar .140(3.6) D IA. .104(2.6) .034(0.9) D IA. .028(0.7) Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS single-phase, half-wave, 60HZ, resistive or inductive load. Rating at 25°C ambient temperature unless otherwise stated Type Number Peak Power Dissipation at Ta=25℃,Tp=1ms (note 1) Steady State Power Dissipation at Tl=75℃ Lead lengths .375〞,(9.5mm) (note 2) For capacotive load,derate current by 20% SYM BOL Value units PPPM Minimum 600 Watts PD 5.0 Watts IFSM 60 Amps TSTG TJ -55 to +150 °C -55 to +150 °C Peak Forward Surge Current,8.3ms Single Half Sine-wave Superimposed on Rated Load (JEDEC method) (note 3) Storage Temperature Operating Junction Temperature Note: 1. Non-repetitive Current Pulse Per Fig.3 and Derated above Ta=25℃ Per Fig.2 . 2. Mounted on Copper Pad Area of 1.6×1.6〞(40×40mm)Per Fig.4 . 3. 8.3ms Single Half Sine-wave or Equivalent Square Wave,Duty Cycle=4 Pulses Per Minutes Maximum. 4. Vf=3.5V for Devices of Vbr≤200V and Vf=5.0V MAX.for Devices Vbr>200V. Devices for Bipolar Applications 1. For Bidirectional Use C or CA Suffix for Types P6KE6.8 thru Types P6KE400. 2. Electrical Characteristics Apply in Both Directions. 1 P6KE SERIES ELECTRICAL CHARACTERISTICS(TA=25℃ unless otherwise noted) Device Nominal Voltage (volts) UNI P6KE6.8 P6KE6.8A P6KE7.5 P6KE7.5A P6KE8.2 P6KE8.2A P6KE9.1 P6KE9.1A P6KE10 P6KE10A P6KE11 P6KE11A P6KE12 P6KE12A P6KE13 P6KE13A P6KE15 P6KE15A P6KE16 P6KE16A P6KE18 P6KE18A P6KE20 P6KE20A P6KE22 P6KE22A P6KE24 P6KE24A P6KE27 P6KE27A P6KE30 P6KE30A P6KE33 P6KE33A P6KE36 P6KE36A P6KE39 P6KE39A P6KE43 P6KE43A P6KE47 P6KE47A P6KE51 P6KE51A P6KE56 P6KE56A P6KE62 P6KE62A P6KE68 P6KE68A P6KE75 P6KE75A P6KE82 P6KE82A BI P6KE6.8C P6KE6.8CA P6KE7.5C P6KE7.5CA P6KE8.2C P6KE8.2CA P6KE9.1C P6KE9.1CA P6KE10C P6KE10CA P6KE11C P6KE11CA P6KE12C P6KE12CA P6KE13C P6KE13CA P6KE15C P6KE15CA P6KE16C P6KE16CA P6KE18C P6KE18CA P6KE20C P6KE20CA P6KE22C P6KE22CA P6KE24C P6KE24CA P6KE27C P6KE27CA P6KE30C P6KE30CA P6KE33C P6KE33CA P6KE36C P6KE36CA P6KE39C P6KE39CA P6KE43C P6KE43CA P6KE47C P6KE47CA P6KE51C P6KE51CA P6KE56C P6KE56CA P6KE62C P6KE62CA P6KE68C P6KE68CA P6KE75C P6KE75CA P6KE82C P6KE82CA 6.8 6.8 7.5 7.5 8.2 8.2 9.1 9.1 10 10 11 11 12 12 13 13 15 15 16 16 18 18 20 20 22 22 24 24 27 27 30 30 33 33 36 36 39 39 43 43 47 47 51 51 56 56 62 62 68 68 75 75 82 82 Breakdown Voltage VBR (volts)(note1) Min Max 6.12 6.45 6.75 7.13 7.38 7.79 8.19 8.65 9.00 9.50 9.90 10.5 10.8 11.4 11.7 12.4 13.5 14.3 14.4 15.2 16.2 17.1 18.0 19.0 19.8 20.9 21.6 22.8 24.3 25.7 27.0 28.5 29.7 31.4 32.4 34.2 35.1 37.1 38.7 40.9 42.3 44.7 45.9 48.5 50.4 53.2 55.8 58.9 61.2 64.6 67.5 71.3 73.8 77.9 7.48 7.14 8.25 7.88 9.02 8.61 10.0 9.55 11.0 10.5 12.1 11.6 13.2 12.6 14.3 13.7 16.5 15.8 17.6 16.8 19.8 18.9 22.0 21.0 24.2 23.1 26.4 25.2 29.7 28.4 33.0 31.5 36.3 34.7 39.6 37.8 42.9 41.0 47.3 45.2 51.7 49.4 56.1 53.6 61.6 58.8 68.2 65.1 74.8 71.4 82.5 78.8 90.2 86.1 Test Current @IT (mA) StandOff Voltage VWM (volts) Maximum Reverse Leakage At VWM ID(μΑ) Maximum Peak Pulse Current IPPM (note2)(Amps) Maximum Clamping Voltage at IPPM VC(Volts) Maximum Temperature Coefficient Of VBR(%/℃) 10 10 10 10 10 10 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 5.50 5.80 6.05 6.4 6.63 7.02 7.37 7.78 8.10 8.55 8.92 9.40 9.72 10.2 10.5 11.1 12.1 12.8 12.9 13.6 14.5 15.3 16.2 17.1 17.8 18.8 19.4 20.5 21.8 23.1 24.3 25.6 26.8 28.2 29.1 30.8 31.6 33.3 34.8 36.8 38.1 40.2 41.3 43.6 45.4 47.8 50.2 53.0 55.1 58.1 60.7 64.1 66.4 70.1 1000 1000 500 500 200 200 50 50 10 10 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 58 60 53 55 50 52 45 47 42 43 38 40 36 37 33 34 28 29 26 28 23 25 21 22 19 20 18 19 16 16.8 14 15 13 13.8 12 12.6 11.1 11.6 10 10.6 8.2 9.7 8.5 8.9 7.8 8.1 7 7.4 6.4 6.8 5.8 6.1 5.3 5.5 10.8 10.5 11.7 11.3 12.5 12.1 13.8 13.4 15.0 14.5 16.2 15.6 17.3 16.7 19.0 18.2 22.0 21.2 23.5 22.5 26.5 25.2 29.1 27.7 31.9 30.6 34.7 33.2 39.1 37.5 43.5 41.4 47.7 45.7 52 49.9 56.4 53.9 61.9 59.3 67.8 64.8 73.5 70.1 80.5 77 89 85 98 92 108 103 118 113 0.057 0.057 0.061 0.061 0.065 0.065 0.068 0.068 0.073 0.073 0.075 0.075 0.078 0.078 0.081 0.081 0.084 0.084 0.086 0.086 0.088 0.088 0.090 0.090 0.092 0.092 0.094 0.094 0.096 0.096 0.097 0.097 0.098 0.098 0.099 0.099 0.100 0.100 0.101 0.101 0.101 0.101 0.102 0.102 0.103 0.103 0.104 0.104 0.104 0.104 0.105 0.105 0.105 0.105 2 P6KE SERIES Nominal Voltage Device (volts) UNI BI Breakdown Voltage VBR (volts)(note1) Min Max Test Current @IT (mA) StandOff Voltage VWM (volts) Maximum Reverse Leakage At VWM ID(μΑ) Maximum Peak Pulse Current IPPM (note2)(Amps) Maximum Clamping Voltage at IPPM VC(Volts) Maximum Temperature Coefficient Of VBR(%/℃) P6KE91 P6KE91C 91 81.9 100.0 1.0 73.7 5.0 4.8 131 0.106 P6KE91A P6KE91CA 91 86.5 95.5 1.0 77.8 5.0 5 125 0.106 P6KE100 P6KE100C 100 90.0 110.0 1.0 81.0 5.0 4.3 144 0.106 P6KE100A P6KE100CA 100 95.0 105.0 1.0 85.5 5.0 4.5 137 0.106 P6KE110 P6KE110C 110 99.0 121.0 1.0 89.2 5.0 3.9 158 0.107 P6KE110A P6KE110CA 110 105.0 116.0 1.0 94.0 5.0 4.1 152 0.107 P6KE120 P6KE120C 120 108.0 132.0 1.0 97.2 5.0 3.6 173 0.107 P6KE120A P6KE120CA 120 114.0 126.0 1.0 102.0 5.0 3.8 165 0.107 P6KE130 P6KE130C 130 117.0 143.0 1.0 105.0 5.0 3.3 187 0.107 P6KE130A P6KE130CA 130 124.0 137.0 1.0 111.0 5.0 3.5 179 0.107 P6KE150 P6KE150C 150 135.0 165.0 1.0 121.0 5.0 2.9 215 0.108 P6KE150A P6KE150CA 150 143.0 158.0 1.0 128.0 5.0 3 207 0.108 P6KE160 P6KE160C 160 144.0 176.0 1.0 130.0 5.0 2.7 230 0.108 P6KE160A P6KE160CA 160 152.0 168.0 1.0 136.0 5.0 2.8 219 0.108 P6KE170 P6KE170C 170 153.0 187.0 1.0 138.0 5.0 2.5 244 0.108 P6KE170A P6KE170CA 170 162.0 179.0 1.0 145.0 5.0 2.6 234 0.108 P6KE180 P6KE180C 180 162.0 198.0 1.0 146.0 5.0 2.4 258 0.108 P6KE180A P6KE180CA 180 171.0 189.0 1.0 154.0 5.0 2.5 246 0.108 P6KE200 P6KE200C 200 180.0 220.0 1.0 162.0 5.0 2.2 287 0.108 P6KE200A P6KE200CA 200 190.0 210.0 1.0 171.0 5.0 2.1 274 0.108 P6KE220 P6KE220C 220 198.0 242.0 1.0 175.0 5.0 1.8 344 0.108 P6KE220A P6KE220CA 220 209.0 231.0 1.0 185.0 5.0 1.9 328 0.108 P6KE250 P6KE250C 250 225.0 275.0 1.0 202.0 5.0 1.7 360 0.110 P6KE250A P6KE250CA 250 237.0 263.0 1.0 214.0 5.0 1.8 344 0.110 P6KE300 P6KE300C 300 270.0 330.0 1.0 243.0 5.0 1.4 430 0.110 P6KE300A P6KE300CA 300 285.0 315.0 1.0 256.0 5.0 1.5 414 0.110 P6KE350 P6KE350C 350 315.0 385.0 1.0 284.0 5.0 1.2 504 0.110 P6KE350A P6KE350CA 350 332.0 368.0 1.0 300.0 5.0 1.3 482 0.110 P6KE400 P6KE400C 400 360.0 440.0 1.0 324.0 5.0 1.9 574 0.110 P6KE400A P6KE400CA 400 380.0 420.0 1.0 342.0 5.0 1.1 548 0.110 Note: 1. VBR measured afert IT applied for 300us,IT=square wave pulse or equivalent. 2. Surge cuttent waveform per Figure 3 and derate per Figure 2. 3. For bipolar types having VWM of 10 volts and under,the ID limit is doubled. 4. All terms and symbols are consistent with ANSI/IEEE C62.35. 3 P6KE SERIES RATING AND CHARACTERISTIC CURVES (P6KE SERIES) Non-Repetitive Pulse Waveform Shown in Fig.3 TA=25℃ ℃ 100000 Peak VAlue IPPM VR=0 10000 1000 VR =RATED STAND-OFF VOLTAGE f=1.0MHz Vsig=50mVp-p TJ=25℃ 100 60 7.5 60Hz Resistive or Inductive load 50 40 5.0 L= 0.375"(9.5mm) lead lengths 30 2.5 × 1.6 × .040" 1.6 × × (40 40 1mm) Copper HEAT Sinks 0 ℃ 4 8.3ms Single Half sine-Wave (JEDEC Method)
P6KE15A 价格&库存
很抱歉,暂时无法提供与“P6KE15A”相匹配的价格&库存,您可以联系我们找货
