P6KE350CA
P6KE350CA
    DOWO(东沃电子)
    DO-15(DO-204AC)
    特性:玻璃钝化芯片。 600W 峰值脉冲功率能力,波形为 10/1000μs,重复率(占空比)为 0.01%。 低泄漏。 单向和双向单元。 出色的钳位能力。 非常快的响应时间。 符合 RoHS 标准
P6KE350CA 数据手册
P6KE Series DOWOSEMI Breakdown Voltage: 6.8 to 600 V Peak Pulse Power: 600 W Axial Lead Transient Voltage Suppressors Features ϥ ϥ ϥ ϥ ϥ ϥ ϥ DO-15 Glass passivated chip 600 W peak pulse power capability with a 10/1000 ȝs waveform, repetitive rate (duty cycle):0.01 % Low leakage Uni and Bidirectional unit Excellent clamping capability Very fast response time RoHS compliant 1.000 [25.40] MIN ϥ ϥ [ ] Case: Molded plastic Epoxy: UL 94V-0 rate flame retardant Lead: Solderable per MIL-STD-202, method 208 guranteed Polarity: Color band denotes cathode end except Bipolar Mounting position: Any DIA. 0.142 3.61 0.102 2.60 [ ] 1.000 [25.40] MIN DO ϥ [ ] WO ϥ DIA. 0.033 0.84 0.028 0.71 0.300 7.63 0.230 5.85 Mechanical Data ϥ P6KE Series 东沃电子 Dimensions : inch [ mm ] Maximum Ratings(TA=25к unless otherwise noted) Parameter Peak power dissipation with a 10/1000ȝs waveform(1) Peak pulse current wih a 10/1000ȝs waveform(1) Power dissipation on infinite heatsink at TL = 75 °C Peak forward surge current, 8.3 ms single half sinewave unidirectional only(2) Maximum instantaneous forward voltage at 50 A for (3) unidirectional only Operating junction and storage temperature range Value Symbol PPP 600 IPP See Next Table PD 5.0 UNIT W A W IFSM 100 A VF 3.5/5.0 V TJ, TSTG –55 to +150 °C Note: (1)Non-repetitive current pulse per Fig.5 and derated above TA= 25 °C per Fig.1 (2)Measured on 8.3 ms single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minute maximum (3)VF
P6KE350CA 价格&库存
很抱歉,暂时无法提供与“P6KE350CA”相匹配的价格&库存,您可以联系我们找货
