P6KE Series
DOWOSEMI
Breakdown Voltage: 6.8 to 600 V
Peak Pulse Power: 600 W
Axial Lead
Transient Voltage Suppressors
Features
ϥ
ϥ
ϥ
ϥ
ϥ
ϥ
ϥ
DO-15
Glass passivated chip
600 W peak pulse power capability with a
10/1000 ȝs waveform, repetitive rate (duty
cycle):0.01 %
Low leakage
Uni and Bidirectional unit
Excellent clamping capability
Very fast response time
RoHS compliant
1.000 [25.40]
MIN
ϥ
ϥ
Case: Molded plastic
Epoxy: UL 94V-0 rate flame retardant
Lead: Solderable per MIL-STD-202, method
208 guranteed
Polarity: Color band denotes cathode end
except Bipolar
Mounting position: Any
DIA.
0.142 3.61
0.102 2.60
1.000 [25.40]
MIN
DO
ϥ
WO
ϥ
DIA.
0.033 0.84
0.028 0.71
0.300 7.63
0.230 5.85
Mechanical Data
ϥ
P6KE Series
东沃电子
Dimensions :
inch [ mm ]
Maximum Ratings(TA=25к unless otherwise noted)
Parameter
Peak power dissipation with a 10/1000ȝs waveform(1)
Peak pulse current wih a 10/1000ȝs waveform(1)
Power dissipation on infinite heatsink at TL = 75 °C
Peak forward surge current, 8.3 ms single half sinewave unidirectional only(2)
Maximum instantaneous forward voltage at 50 A for
(3)
unidirectional only
Operating junction and storage temperature range
Value
Symbol
PPP
600
IPP
See Next Table
PD
5.0
UNIT
W
A
W
IFSM
100
A
VF
3.5/5.0
V
TJ, TSTG
–55 to +150
°C
Note:
(1)Non-repetitive current pulse per Fig.5 and derated above TA= 25 °C per Fig.1
(2)Measured on 8.3 ms single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minute maximum
(3)VF
很抱歉,暂时无法提供与“P6KE600A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.21652
- 50+0.95526
- 150+0.84327
- 500+0.70352
- 2000+0.64131
- 4000+0.60394
- 国内价格
- 1+0.91080
- 50+0.60830
- 2000+0.54890
- 国内价格
- 1+1.64454
- 30+1.58822
- 100+1.47558
- 500+1.36294
- 1000+1.30662
- 2000+1.25030
