P6KE Series
Transient Voltage Suppressor
HF LF RoHS
P6KExxxXX
»Features
Excellent clamping capability
Low leakage current
Low capacitance
High surge capability
Glass passivated chip
Epoxy resin package
Built-in strain relief
Will not fatigue
RoHS Compliant
Fast response time:
typically less than 1.0ps from 0 Volts to VBR min
»Mechanical
DO-15 (DO-204AC)
»Applications
Characteristics
Package: DO-15 plastic package.
Lead Finish: Matte Tin
Case Material: Epoxy Molding Compound.
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 1 per J-STD-020
Telecom
Computer
Industrial electronic
Consumer electronic
»Electrical Parameters
Parameter
Definition
+I
CJ
Junction Capacitance - typical capacitance measured
with 0V or VR bias
IPP
Peak Pulse Current - maximum rated peak impulse
current
VC
Clamping Voltage - Peak voltage measured across the
suppressor at a specified Ippm (peak impulse current)
VBR
Breakdown Voltage - Maximum voltage that flows
though the TVS at a specified test current (IT)
IR
Leakage Current - maximum peak off-state current
measured at VR
VR
Peak Off-state Voltage - maximum voltage that can be
applied while maintaining off state
VF
Uni
Bi
Ipp
IT
IR
VR
VBR
VC
+V
»Summary of Packing Options
Package
DO-15
Revision: 2018
Packing Description
Packing Quantity
Industry Standard
Tape/Box,Box
2000
BORN SPEC
Tape/Reel,13" reel
4000
EIA STD RS-296
www.born-tw.com
1/5
P6KE Series
»Absolute Maximum Ratings (TA=25℃ unless otherwise noted)
Parameter
Symbol
Value
Units
Remarks
PPPM
600
W
(Note1)
Steady State Power Dissipation
PD
5
W
(Note2)
Peak Forward Surge Current
IFSM
100
A
(Note3)
Maximum Instantaneous Forward Voltage at 50A
VFM
3.5/5
V
(Note4)
Typical Thermal Resistance Junction to Lead
RθJL
℃/W
Typical Thermal Resistance Junction to Ambient
RθJA
75
℃/W
TJ
-55 to 150
TSTG
-55 to 150
Peak Pulse Power Dissipation
Operating Temperature Range
Storage Temperature Range
Notes1: Non-repetitive current pulse , 10/1000us Waveform.
Notes2: Infinite Heat Sink at TL=75℃, at 0.375”(9.5mm) lead length, P.C.B. mounted.
Notes3: Measured on 8.3ms single half sine wave or equivalent square wave, duty cycle=4 per minute maximum.
Notes4: For Unidirectional Only, VFM
很抱歉,暂时无法提供与“P6KE6.8CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.46894
- 100+0.38081
- 300+0.33675
- 2000+0.27065
- 4000+0.24419
- 10000+0.23102
- 国内价格
- 1+0.22990
- 2000+0.20680
- 国内价格
- 10+0.46880
- 100+0.37890
- 300+0.33440
- 2000+0.26840
- 4000+0.24210
- 10000+0.22890
