P6KE SERIES
Transient Voltage Suppressors (TVS) Data Sheet
Features
Glass passivated junction
Low zener impedance
Excellent clamping capability
600W peak pulse power capability at 10/1000μs waveform,
repetition rate (duty cycle): 0.01%
Fast response time
Typical IR less than 1μA above 12V.
High Temperature soldering guaranteed: 265℃/10 seconds/.375″,
(9.5mm) lead length, 5lbs (2.3kg) tension
Plastic package has underwriters laboratory flammability 94V-0
Meets MSL level 1, per J-STD-020.
Safety certification: UL: E244458
Mechanical Data
Case: JEDEC DO-15 Moulded plastic
Terminal: Axial leads, solderable per MIL-STD-750, Method 2026
Polarity: Color band denotes cathode except bi-directional models
Mounting Position: Any
Weight: 0.42g
Applications
■ I/O interface
■ AC/DC power supply
■ Low frequency signal transmission line (RS232, RS485, etc.)
Maximum Ratings and Characteristics
Ratings at 25℃ ambient temperature unless otherwise specified.
Rating
Symbol
Value
Units
Peak pulse power dissipation at 10/1000μs waveform
(Note1, Fig.1)
PPPM
Minimum 600
Watts
Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3)
IPPM
See Table
Amps
PM(AV)
5.0
Watts
IFSM
100
Amps
TJ,TSTG
-55 to +175
Typical thermal resistance junction to lead
RθJL
℃/W
Typical thermal resistance junction to ambient
RθJA
75
℃/W
Steady state power dissipation at TL=75℃ (Fig.5)
Peak forward surge current, 8.3ms single half sine-wave
superimposed on rated load, (JEDEC Method) (Note2, Fig.6)
Operating junction and Storage Temperature Range.
Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2.
2. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum.
Revision:21-Jul-14
www.brightking.com
P6KE SERIES
Dimensions (DO-204AC/DO-15)
Cathode Band
L
T
Millimeters
Symbol
d
Min.
Max.
Min.
Max.
L
25.40
1.000
T
5.80
7.60
0.230
0.300
d
2.60
3.60
0.104
0.140
s
0.71
0.86
0.028
0.034
s
DIA.
DIA.
L
Inches
Electrical Characteristics (TA=25℃)
Part Number
Reverse
Stand-Off
Voltage
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage @IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
Unidirectional
Bidirectional
VRWM(V)
VBR(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
P6KE6.8A
P6KE6.8CA
5.80
6.45~7.14
10
10.5
58.1
1000
P6KE7.5A
P6KE7.5CA
6.40
7.13~7.88
10
11.3
54.0
500
P6KE8.2A
P6KE8.2CA
7.02
7.79~8.61
10
12.1
50.4
200
P6KE9.1A
P6KE9.1CA
7.78
8.65~9.55
1
13.4
45.5
50
P6KE10A
P6KE10CA
8.55
9.50~10.50
1
14.5
42.1
10
P6KE11A
P6KE11CA
9.40
10.50~11.60
1
15.6
39.1
5
P6KE12A
P6KE12CA
10.20
11.40~12.60
1
16.7
36.5
5
P6KE13A
P6KE13CA
11.10
12.40~13.70
1
18.2
33.5
1
P6KE15A
P6KE15CA
12.80
14.30~15.80
1
21.2
28.8
1
P6KE16A
P6KE16CA
13.60
15.20~16.80
1
22.5
27.1
1
P6KE18A
P6KE18CA
15.30
17.10~18.90
1
25.2
24.2
1
P6KE20A
P6KE20CA
17.10
19.00~21.00
1
27.7
22.0
1
P6KE22A
P6KE22CA
18.80
20.90~23.10
1
30.6
19.9
1
P6KE24A
P6KE24CA
20.50
22.80~25.20
1
33.2
18.4
1
P6KE27A
P6KE27CA
23.10
25.70~28.40
1
37.5
16.3
1
P6KE30A
P6KE30CA
25.60
28.50~31.50
1
41.4
14.7
1
P6KE33A
P6KE33CA
28.20
31.40~34.70
1
45.7
13.3
1
P6KE36A
P6KE36CA
30.80
34.20~37.80
1
49.9
12.2
1
P6KE39A
P6KE39CA
33.30
37.10~41.00
1
53.9
11.3
1
P6KE43A
P6KE43CA
36.80
40.90~45.20
1
59.3
10.3
1
Revision:21-Jul-14
www.brightking.com
P6KE SERIES
Part Number
Reverse
Stand-Off
Voltage
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage @IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
Unidirectional
Bidirectional
VRWM(V)
VBR(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
P6KE47A
P6KE47CA
40.20
44.70~49.40
1
64.8
9.4
1
P6KE51A
P6KE51CA
43.60
48.50~53.60
1
70.1
8.7
1
P6KE56A
P6KE56CA
47.80
53.20~58.80
1
77.0
7.9
1
P6KE62A
P6KE62CA
53.00
58.90~65.10
1
85.0
7.2
1
P6KE68A
P6KE68CA
58.10
64.60~71.40
1
92.0
6.6
1
P6KE75A
P6KE75CA
64.10
71.30~78.80
1
103.0
5.9
1
P6KE82A
P6KE82CA
70.10
77.90~86.10
1
113.0
5.4
1
P6KE91A
P6KE91CA
77.80
86.50~95.50
1
125.0
4.9
1
P6KE100A
P6KE100CA
85.50
95.00~105.00
1
137.0
4.5
1
P6KE110A
P6KE110CA
94.00
105.00~116.00
1
152.0
4.0
1
P6KE120A
P6KE120CA
102.00
114.00~126.00
1
165.0
3.7
1
P6KE130A
P6KE130CA
111.00
124.00~137.00
1
179.0
3.4
1
P6KE150A
P6KE150CA
128.00
143.00~158.00
1
207.0
2.9
1
P6KE160A
P6KE160CA
136.00
152.00~168.00
1
219.0
2.8
1
P6KE170A
P6KE170CA
145.00
162.00~179.00
1
234.0
2.6
1
P6KE180A
P6KE180CA
154.00
171.00~189.00
1
246.0
2.5
1
P6KE200A
P6KE200CA
171.00
190.00~210.00
1
274.0
2.2
1
P6KE220A
P6KE220CA
185.00
209.00~231.00
1
328.0
1.9
1
P6KE250A
P6KE250CA
214.00
237.00~263.00
1
344.0
1.8
1
P6KE300A
P6KE300CA
256.00
285.00~315.00
1
414.0
1.5
1
P6KE350A
P6KE350CA
300.00
332.00~368.00
1
482.0
1.3
1
P6KE400A
P6KE400CA
342.00
380.00~420.00
1
548.0
1.1
1
P6KE440A
P6KE440CA
376.00
418.00~462.00
1
602.0
1.04
1
P6KE480A
P6KE480CA
408.00
456.00~504.00
1
658.0
0.9
1
P6KE510A
P6KE510CA
434.00
485.00~535.00
1
698.0
0.9
1
P6KE530A
P6KE530CA
450.00
503.50~556.50
1
725.0
0.8
1
P6KE540A
P6KE540CA
459.00
513.00~567.00
1
740.0
0.8
1
P6KE550A
P6KE550CA
467.00
522.50~577.50
1
760.0
0.8
1
P6KE600A
P6KE600CA
512.00
570.00~630.00
1
828.0
0.75
1
Notes: For bidirectional type having VRWM of 10V and less, the IR limit is double.
Revision:21-Jul-14
www.brightking.com
P6KE SERIES
Ratings and Characteristic Curves (TA=25℃ unless otherwise noted)
Figure 1. Peak Pulse Power Rating Curve
Figure 2. Pulse Derating Curve
PPPM - Peak Pulse Power (kW)
100
75
50
25
50
75
100 125
150 175
200
TA-Ambient Temperature (℃)
Figure 4. Typical Junction Capacitance
IPPM - Peak Pulse Current, %IRSM
Figure 3. Pulse Waveform
Figure 6. Maximum Non-Repetitive Forward
Surge Current Uni-Directional Only
Steady State Power Dissipation (W)
Figure 5. Steady State Power Dissipation Derating
Curve
Revision:21-Jul-14
www.brightking.com
P6KE SERIES
Recommended Soldering Conditions
Wave Soldering
Item
Conditions
Peak Temperature
265℃
Dipping Time
10 seconds
Soldering
1 time
Marking Code
Cathode Band
YXXX
Logo
P6KE6.8A
YXXX
Date Code
Marking Code
Revision:21-Jul-14
Logo
P6KE6.8CA
Date Code
Marking Code
www.brightking.com
P6KE SERIES
Part Number Code
Packaging
Tape
Z
±5°
A
E
Symbol
Dimension (mm)
A
5.0±0.5
B
53.0±1.0
Z
1.2Max.
T
6.0±0.4
E
0.8Max.
L1-L2
1.0Max.
L
250.0±5.0
W
75.0±5.0
H
114.0±5.0
L1
B
L2
E
T
c
Box
Quantity: 2000PCS
Reel
D
330.0±3.0
D0
16.4±2.0
D1
86.0±2.0
W1
76.0±3.0
Quantity: 4000PCS
Revision:21-Jul-14
www.brightking.com
很抱歉,暂时无法提供与“P6KE180A/B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.45998
- 100+0.38168
- 300+0.34247
- 国内价格
- 10+0.42164
- 100+0.34987
- 400+0.34637
- 800+0.33944
- 2000+0.32926
- 国内价格
- 1+0.38500
- 50+0.22660
- 2000+0.20350
