SAC5.0/B
SAC5.0/B
    YAGEO(国巨)
    DO-15(DO-204AC)
    10V 夹子 44A Ipp TVS - 二极管 通孔 DO-204AC(DO-15)
SAC5.0/B 数据手册
DATA SHEET TRANSIENT VOLTAGE SUPPRESSORS AC/DC POWER SUPPLY SA series Product specification– June 30, 2023 V.3 RoHS compliant & Halogen free Circuit Protection Product Specification Transient Voltage Suppressors 2 8 SA Transient Voltage Suppressors (TVS) Data Sheet Features ■ Glass passivated junction ■ Low inductance ■ Excellent clamping capability ■ 500W peak pulse power capability at 10/1000μs waveform, repetition rate (duty cycle): 0.01% ■ Fast response time ■ Typical IR less than 1μA above 10V ■ High Temperature soldering guaranteed: 265℃/10 seconds/.375″, (9.5mm) lead length, 5lbs (2.3kg) tension ■ Plastic package has underwriters laboratory flammability 94V-0 ■ Meets MSL level 1, per J-STD-020 ■ Safety certification: UL ■ IEC61000-4-2 ESD 30KV Air, 30KV contact compliance Mechanical Data ■ Case: JEDEC DO-15 Moulded plastic ■ Terminal: Axial leads, solderable per MIL-STD-750, Method 2026 ■ Polarity: Color band denotes cathode except bi-directional models ■ Mounting Position: Any ■ Weight: 0.42g Applications ■ I/O interface ■ AC/DC power supply ■ Low frequency signal transmission line (RS232, RS485, etc.) Maximum Ratings and Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Rating Symbol Value Units Peak pulse power dissipation at 10/1000μs waveform (Note1, Fig.1) PPPM Minimum 500 Watts Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3) IPPM See Table Amps PM(AV) 3.0 Watts IFSM 70 Amps TJ,TSTG -55 to +150 ℃ Typical thermal resistance junction to lead RθJL 20 ℃/W Typical thermal resistance junction to ambient RθJA 75 ℃/W Steady state power dissipation at TL=75℃ (Fig.5) Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load, (JEDEC Method) (Note2, Fig.6) Operating junction and Storage Temperature Range. Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2. 2. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum. www.ya geo.com Jun. 30, 2023 V.3 Circuit Protection Product Specification Transient Voltage Suppressors 3 8 SA Dimensions (DO-204AC/DO-15) Millimeters Cathode Band L T Inches Symbol d s DIA. DIA. L Min. Max. Min. Max. L 25.40 - 1.000 - T 5.80 7.60 0.230 0.300 d 2.60 3.60 0.104 0.140 s 0.71 0.86 0.028 0.034 Peak Pulse Current Reverse Leakage @VRWM Electrical Characteristics (TA=25℃) Part Number Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage @IPP Unidirectional Bidirectional VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) SA5.0A SA5.0CA 5.0 6.40~7.00 10 9.2 55.4 600 SA6.0A SA6.0CA 6.0 6.67~7.37 10 10.3 49.5 600 SA6.5A SA6.5CA 6.5 7.22~7.98 10 11.2 45.5 400 SA7.0A SA7.0CA 7.0 7.78~8.60 10 12.0 42.5 150 SA7.5A SA7.5CA 7.5 8.33~9.21 1 12.9 39.5 50 SA8.0A SA8.0CA 8.0 8.89~9.83 1 13.6 37.5 25 SA8.5A SA8.5CA 8.5 9.44~10.40 1 14.4 35.4 10 SA9.0A SA9.0CA 9.0 10.00~11.10 1 15.4 33.1 5 SA10A SA10CA 10.0 11.10~12.30 1 17.0 30.0 3 SA11A SA11CA 11.0 12.20~13.50 1 18.2 28.0 1 SA12A SA12CA 12.0 13.30~14.70 1 19.9 25.6 1 SA13A SA13CA 13.0 14.40~15.90 1 21.5 23.7 1 SA14A SA14CA 14.0 15.60~17.20 1 23.2 22.0 1 SA15A SA15CA 15.0 16.70~18.50 1 24.4 20.9 1 SA16A SA16CA 16.0 17.80~19.70 1 26.0 19.6 1 SA17A SA17CA 17.0 18.90~20.90 1 27.6 18.5 1 SA18A SA18CA 18.0 20.00~22.10 1 29.2 17.5 1 SA20A SA20CA 20.0 22.20~24.50 1 32.4 15.7 1 SA22A SA22CA 22.0 24.40~26.90 1 35.5 14.4 1 SA24A SA24CA 24.0 26.70~29.50 1 38.9 13.1 1 SA26A SA26CA 26.0 28.90~31.90 1 42.1 12.1 1 SA28A SA28CA 28.0 31.10~34.40 1 45.4 11.2 1 SA30A SA30CA 30.0 33.30~36.80 1 48.4 10.5 1 www.ya geo.com Jun. 30, 2023 V.3 Circuit Protection Product Specification Transient Voltage Suppressors Part Number 4 8 SA Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM Unidirectional Bidirectional VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) SA33A SA33CA 33.0 36.70~40.60 1 53.3 9.6 1 SA36A SA36CA 36.0 40.00~44.20 1 58.1 8.8 1 SA40A SA40CA 40.0 44.40~49.10 1 64.5 7.9 1 SA43A SA43CA 43.0 47.80~52.80 1 69.4 7.3 1 SA45A SA45CA 45.0 50.00~55.30 1 72.7 7.0 1 SA48A SA48CA 48.0 53.30~58.90 1 77.4 6.6 1 SA51A SA51CA 51.0 56.70~62.70 1 82.4 6.2 1 SA54A SA54CA 54.0 60.00~66.30 1 87.1 5.9 1 SA58A SA58CA 58.0 64.40~71.20 1 93.6 5.4 1 SA60A SA60CA 60.0 66.70~73.70 1 96.8 5.3 1 SA64A SA64CA 64.0 71.10~78.60 1 103.0 5.0 1 SA70A SA70CA 70.0 77.80~86.00 1 113.0 4.5 1 SA75A SA75CA 75.0 83.30~92.10 1 121.0 4.2 1 SA78A SA78CA 78.0 86.70~95.80 1 126.0 4.0 1 SA85A SA85CA 85.0 94.40~104.00 1 137.0 3.7 1 SA90A SA90CA 90.0 100.00~111.00 1 146.0 3.5 1 SA100A SA100CA 100.0 111.00~123.00 1 162.0 3.1 1 SA110A SA110CA 110.0 122.00~135.00 1 177.0 2.9 1 SA120A SA120CA 120.0 133.00~147.00 1 193.0 2.6 1 SA130A SA130CA 130.0 144.00~159.00 1 209.0 2.4 1 SA150A SA150CA 150.0 167.00~185.00 1 243.0 2.1 1 SA160A SA160CA 160.0 178.00~197.00 1 259.0 2.0 1 SA170A SA170CA 170.0 189.00~209.00 1 275.0 1.9 1 SA180A SA180CA 180.0 201.00~222.00 1 292.0 1.7 1 SA190A SA190CA 190.0 211.00~233.00 1 308.0 1.6 1 SA200A SA200CA 200.0 224.00~247.00 1 324.0 1.5 1 SA210A SA210CA 210.0 237.00~263.00 1 340.0 1.5 1 SA220A SA220CA 220.0 246.00~272.00 1 356.0 1.4 1 www.ya geo.com Jun. 30, 2023 V.3 Circuit Protection Product Specification Transient Voltage Suppressors 5 8 SA Ratings and Characteristic Curves (T A=25℃ unless otherwise noted) PPPM - Peak Pulse Power (kW) 100 Figure 2. Pulse Derating Curve Peak Pulse Power (PPP) or Current (IPP) Derating in Percentage % Figure 1. Peak Pulse Power Rating Curve Non-repetitive pulse waveform shown in fig.3 TA=25℃ 10 P 1 Exponentia l Td P Td P Td 0.1 0.1 Half SINE Square 1 10 100 1000 100 75 50 25 0 0 10000 100 125 150 175 200 Figure 4. Typical Junction Capacitance TJ=25℃ Pulse Width(td) is defined as the point where the peak current decays to 50% of IPPM tr=10µs Bi-directional V=0V 1000 Uni-directional V=0V Peak Value IPPM 100 Cj (pF) IPPM - Peak Pulse Current, %IRSM 75 10000 150 Half Value IPPM (IPPM/2) Uni-directional @VR 100 50 10/1000µs Waveform as defined by R.E.A 10 td 0 0 1.0 2.0 3.0 Bi-directional @VR TJ=25℃ f=1.0MHz Vsig=50mVp-p 1 4.0 1 t-Time (ms) 3 2.5 2 1.5 L= 0.375″(9.5mm) Lead Lengths 0.5 0 0 25 50 75 100 125 100 1000 Figure 6. Maximum Non-Repetitive Forward Surge Current Uni-Directional Only IFSM - Peak Forward Surve Current (A) 3.5 1 10 VBR-Reverse Breakdown Voltage (V) Figure 5. Steady State Power Dissipation Derating Curve Steady State Power Dissipation (W) 50 TA-Ambient Temperature (℃) td-Pulse Width (µs) Figure 3. Pulse Waveform 25 150 TL-Lead Temperature (℃) 175 200 80 70 60 50 40 30 20 10 0 1 10 100 Number of Cycles at 60Hz www.ya geo.com Jun. 30, 2023 V.3 Circuit Protection Product Specification Transient Voltage Suppressors 6 8 SA Recommended Soldering Conditions Wave Soldering 300 Preheating Maximum Wave 265℃ Soldering Cooling Temperature (℃) 250 200 150 100 50 0 0 0.5 1 1.5 2 2.5 3 3.5 4 Time (minutes) Recommended Conditions Item Conditions Peak Temperature 265℃ Dipping Time 10 seconds Soldering 1 time Marking Code Cathode Band YXXX YXXX Logo SA5.0A Intermal Control Code Logo SA5.0CA Intermal Control Code Marking Code Marking Code Part Number Code SA XXX C A / XXXX Package Code B: Box package TR13: Reel package 5% VBR Voltage Tolerance Bidirectional VRWM Voltage Series Code www.ya geo.com Jun. 30, 2023 V.3 Circuit Protection Product Specification Transient Voltage Suppressors 7 8 SA Ordering Code for Different Package Box package: Add suffix “/B” at the end of the part number, such as SAXXXCA/B Reel package: Add suffix “/TR13” at the end of the part number, such as SAXXXCA/TR13 Packaging Tape Z ±5° A E Symbol Dimension (mm) A 5.0±0.5 B 53.0±1.0 Z 1.2Max. T 6.0±0.4 E 0.8Max. L1-L2 1.0Max. L 250.0±5.0 W 75.0±5.0 H 114.0±5.0 L1 B L2 T E Box H L Quantity: 2000PCS W Reel D 330.0±3.0 D0 16.4±2.0 D1 86.0±2.0 W1 76.0±3.0 D0 D1 D W1 Quantity: 4000PCS www.ya geo.com Jun. 30, 2023 V.3 Product specification Circuit Protection Components LEGAL DISCLAIMER YAGEO, its distributors and agents (collectively, “YAGEO”), hereby disclaims any and all liabilities for any errors, inaccuracies or incompleteness contained in any product related information, including but not limited to product specifications, datasheets, pictures and/or graphics. YAGEO may make changes, modifications and/or improvements to product related information at any time and without notice. YAGEO makes no representation, warranty, and/or guarantee about the fitness of its products for any particular purpose or the continuing production of any of its products. To the maximum exten t permitted by law, YAGEO disclaims (i) any and all liability arising out of the application or use of any YAGEO product, (ii) any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for a particular purpose, non -infringement and merchantability. YAGEO products are designed for general purpose applications under normal operation and usage conditions. Please contact YAGEO for the applications listed below which require especially high reliability for the prevention of defects which might directly cause damage to the third party's life, body or property: Aerospace equipment (artificial satellite, rocket, etc.), Atomic energy -related equipment, Aviation equipment, Disaster prevention equipment, crime prevention equipment, Electric heating apparatus, burning equipment, Highly public information network equipment, data-processing equipment , Medical devices, Military equipment, Power generation control equipment, Safety equipment, Traffic signal equipment, Transportation equipment and Undersea equipment, or for any other application or use in which the failure of YAGEO products could result in personal injury or death, or serious property damage. P articularly YAGEO Corporation and its affiliates do not recommend the use of commercial or automotive grade products for high reliability applications or manned space flight. Information provided here is intended to indicate product specifications only. YAGEO reserves all the rights for revising this content without further notification, as long as products are unchanged. Any product change will be announced by PCN. www.yageo.com
SAC5.0/B 价格&库存
很抱歉,暂时无法提供与“SAC5.0/B”相匹配的价格&库存,您可以联系我们找货
SAC5.0/B
  • 1+4.320371+0.56177
  • 10+2.6637010+0.34636
  • 50+1.9248650+0.25029
  • 100+1.68495100+0.21909
  • 500+1.26008500+0.16385
库存:3359
SAC5.0/B
  • 2000+1.007082000+0.13095
  • 6000+0.859916000+0.11181
库存:3359
