P6KE7.5CA/B
P6KE7.5CA/B
    YAGEO(国巨)
    DO-15(DO-204AC)
    11.3V 夹子 54A Ipp TVS - 二极管 通孔 DO-204AC(DO-15)
P6KE7.5CA/B 数据手册
DATA SHEET TRANSIENT VOLTAGE SUPPRESSORS AC/DC POWER SUPPLY P6KE series Product specification– June 30, 2023 V.3 RoHS compliant & Halogen free Circuit Protection Product Specification Transient Voltage Suppressors 2 8 P6KE Transient Voltage Suppressors (TVS) Data Sheet Features ■ Glass passivated junction ■ Low zener impedance ■ Excellent clamping capability ■ 600W peak pulse power capability at 10/1000μs waveform, repetition rate (duty cycle): 0.01% ■ Fast response time ■ Typical IR less than 1μA above 12V. ■ High Temperature soldering guaranteed: 265℃/10 seconds/.375″, (9.5mm) lead length, 5lbs (2.3kg) tension ■ Plastic package has underwriters laboratory flammability 94V-0 ■ Meets MSL level 1, per J-STD-020. ■ Safety certification: UL ■ IEC61000-4-2 ESD 30KV Air, 30KV contact compliance Mechanical Data ■ Case: JEDEC DO-15 Moulded plastic ■ Terminal: Axial leads, solderable per MIL-STD-750, Method 2026 ■ Polarity: Color band denotes cathode except bi-directional models ■ Mounting Position: Any ■ Weight: 0.42g Applications ■ I/O interface ■ AC/DC power supply ■ Low frequency signal transmission line (RS232, RS485, etc.) Maximum Ratings and Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Rating Symbol Value Units Peak pulse power dissipation at 10/1000μs waveform (Note1, Fig.1) PPPM Minimum 600 Watts Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3) IPPM See Table Amps PM(AV) 5.0 Watts IFSM 100 Amps TJ,TSTG -55 to +150 ℃ Typical thermal resistance junction to lead RθJL 20 ℃/W Typical thermal resistance junction to ambient RθJA 75 ℃/W Steady state power dissipation at TL=75℃ (Fig.5) Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load, (JEDEC Method) (Note2, Fig.6) Operating junction and Storage Temperature Range. Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above T A=25℃ per Fig.2. 2. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum. www.ya geo.com Jun. 30, 2023 V.3 Circuit Protection Product Specification Transient Voltage Suppressors 3 8 P6KE Dimensions (DO-204AC/DO-15) Millimeters Cathode Band L T Inches Symbol d Min. Max. Min. Max. L 25.40 - 1.000 - T 5.80 7.60 0.230 0.300 d 2.60 3.60 0.104 0.140 s 0.71 0.86 0.028 0.034 s DIA. DIA. L Electrical Characteristics (TA=25℃) Part Number Reverse Breakdown Stand-Off Voltage Voltage @IT Test Current Maximum Peak Reverse Clamping Pulse Leakage Voltage @IPP Current @VRWM Unidirectional Bidirectional VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) P6KE6.8A P6KE6.8CA 5.80 6.45~7.14 10 10.5 58.1 1000 P6KE7.5A P6KE7.5CA 6.40 7.13~7.88 10 11.3 54.0 500 P6KE8.2A P6KE8.2CA 7.02 7.79~8.61 10 12.1 50.4 200 P6KE9.1A P6KE9.1CA 7.78 8.65~9.55 1 13.4 45.5 50 P6KE10A P6KE10CA 8.55 9.50~10.50 1 14.5 42.1 10 P6KE11A P6KE11CA 9.40 10.50~11.60 1 15.6 39.1 5 P6KE12A P6KE12CA 10.20 11.40~12.60 1 16.7 36.5 5 P6KE13A P6KE13CA 11.10 12.40~13.70 1 18.2 33.5 1 P6KE15A P6KE15CA 12.80 14.30~15.80 1 21.2 28.8 1 P6KE16A P6KE16CA 13.60 15.20~16.80 1 22.5 27.1 1 P6KE18A P6KE18CA 15.30 17.10~18.90 1 25.2 24.2 1 P6KE20A P6KE20CA 17.10 19.00~21.00 1 27.7 22.0 1 P6KE22A P6KE22CA 18.80 20.90~23.10 1 30.6 19.9 1 P6KE24A P6KE24CA 20.50 22.80~25.20 1 33.2 18.4 1 P6KE27A P6KE27CA 23.10 25.70~28.40 1 37.5 16.3 1 P6KE30A P6KE30CA 25.60 28.50~31.50 1 41.4 14.7 1 P6KE33A P6KE33CA 28.20 31.40~34.70 1 45.7 13.3 1 P6KE36A P6KE36CA 30.80 34.20~37.80 1 49.9 12.2 1 P6KE39A P6KE39CA 33.30 37.10~41.00 1 53.9 11.3 1 P6KE43A P6KE43CA 36.80 40.90~45.20 1 59.3 10.3 1 www.ya geo.com Jun. 30, 2023 V.3 Circuit Protection Product Specification Transient Voltage Suppressors 4 8 P6KE Electrical Characteristics (TA=25℃) Part Number Reverse Breakdown Stand-Off Voltage Voltage @IT Test Current Maximum Peak Reverse Clamping Pulse Leakage Voltage @IPP Current @VRWM Unidirectional Bidirectional VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) P6KE47A P6KE47CA 40.20 44.70~49.40 1 64.8 9.4 1 P6KE51A P6KE51CA 43.60 48.50~53.60 1 70.1 8.7 1 P6KE56A P6KE56CA 47.80 53.20~58.80 1 77.0 7.9 1 P6KE62A P6KE62CA 53.00 58.90~65.10 1 85.0 7.2 1 P6KE68A P6KE68CA 58.10 64.60~71.40 1 92.0 6.6 1 P6KE75A P6KE75CA 64.10 71.30~78.80 1 103.0 5.9 1 P6KE82A P6KE82CA 70.10 77.90~86.10 1 113.0 5.4 1 P6KE91A P6KE91CA 77.80 86.50~95.50 1 125.0 4.9 1 P6KE100A P6KE100CA 85.50 95.00~105.00 1 137.0 4.5 1 P6KE110A P6KE110CA 94.00 105.00~116.00 1 152.0 4.0 1 P6KE120A P6KE120CA 102.00 114.00~126.00 1 165.0 3.7 1 P6KE130A P6KE130CA 111.00 124.00~137.00 1 179.0 3.4 1 P6KE150A P6KE150CA 128.00 143.00~158.00 1 207.0 2.9 1 P6KE160A P6KE160CA 136.00 152.00~168.00 1 219.0 2.8 1 P6KE170A P6KE170CA 145.00 162.00~179.00 1 234.0 2.6 1 P6KE180A P6KE180CA 154.00 171.00~189.00 1 246.0 2.5 1 P6KE200A P6KE200CA 171.00 190.00~210.00 1 274.0 2.2 1 P6KE220A P6KE220CA 185.00 209.00~231.00 1 328.0 1.9 1 P6KE250A P6KE250CA 214.00 237.00~263.00 1 344.0 1.8 1 P6KE300A P6KE300CA 256.00 285.00~315.00 1 414.0 1.5 1 P6KE350A P6KE350CA 300.00 332.00~368.00 1 482.0 1.3 1 P6KE400A P6KE400CA 342.00 380.00~420.00 1 548.0 1.1 1 P6KE440A P6KE440CA 376.00 418.00~462.00 1 602.0 1.04 1 P6KE480A P6KE480CA 408.00 456.00~504.00 1 658.0 0.9 1 P6KE510A P6KE510CA 434.00 485.00~535.00 1 698.0 0.9 1 P6KE530A P6KE530CA 450.00 503.50~556.50 1 725.0 0.8 1 P6KE540A P6KE540CA 459.00 513.00~567.00 1 740.0 0.8 1 P6KE550A P6KE550CA 467.00 522.50~577.50 1 760.0 0.8 1 P6KE600A P6KE600CA 510.00 570.00~630.00 1 828.0 0.75 1 www.ya geo.com Jun. 30, 2023 V.3 Circuit Protection Product Specification Transient Voltage Suppressors 5 8 P6KE Ratings and Characteristic Curves (T A=25℃ unless otherwise noted) Figure 1. Peak Pulse Power Rating Curve Figure 2. Pulse Derating Curve Peak Pulse Power (PPP) or Current (IPP) Derating in Percentage % PPPM - Peak Pulse Power (kW) 100 10 1 0.1 0.1 1 10 100 1000 100 75 50 25 0 10000 0 td-Pulse Width (µs) 75 100 125 150 175 200 Figure 4. Typical Junction Capacitance 10000 150 TJ=25℃ Pulse Width(td) is defined as the point where the peak current decays to 50% of IPPM tr=10µs Bi-directional V=0V 1000 Uni-directional V=0V Peak Value IPPM 100 Uni-directional @VR Cj (pF) IPPM - Peak Pulse Current, %IRSM 50 TA-Ambient Temperature (℃) Figure 3. Pulse Waveform Half Value IPPM (IPPM/2) 100 50 td 0 1 1.0 2.0 3.0 Bi-directional @VR 10 10/1000µs Waveform as defined by R.E.A 0 4.0 TJ=25℃ f=1.0MHz Vsig=50mVp-p 1 Figure 5. Steady State Power Dissipation Derating IFSM - Peak Forward Surve Current (A) 5 4 3 L= 0.375″(9.5mm) Lead Lengths 1 0 25 1000 Surge Current Uni-Directional Only 6 0 100 Figure 6. Maximum Non-Repetitive Forward Curve 2 10 VBR-Reverse Breakdown Voltage (V) t-Time (ms) Steady State Power Dissipation (W) 25 50 75 100 125 150 TL-Lead Temperature (℃) 175 200 120 100 80 60 40 20 0 1 10 100 Number of Cycles at 60Hz www.ya geo.com Jun. 30, 2023 V.3 Circuit Protection Product Specification Transient Voltage Suppressors 6 8 P6KE Recommended Soldering Conditions Wave Soldering 300 Preheating Maximum Wave 265℃ Soldering Cooling Temperature (℃) 250 200 150 100 50 0 0 0.5 1 1.5 2 2.5 3 3.5 4 Time (minutes) Item Conditions Peak Temperature 265℃ Dipping Time 10 seconds Soldering 1 time Marking Code Cathode Band YXXX YXXX Logo P6KE6.8A Internal control code Logo P6KE6.8CA Internal control code Marking Code Marking Code Part Number Code P6KE XXX C A / XXXX Package Code B: Box package TR13: Reel package 5% VBR Voltage Tolerance Bidirectional VBR Voltage Series Code www.ya geo.com Jun. 30, 2023 V.3 Circuit Protection Product Specification Transient Voltage Suppressors 7 8 P6KE Ordering Code for Different Package Box package: Add suffix “/B” at the end of the part number, such as P6KEXXXCA/B Reel package: Add suffix “/TR13” at the end of the part number, such as P6KEXXXCA/TR13 Packaging Tape Z Dimension (mm) A 5.0±0.5 B 53.0±1.0 Z 1.2Max. T 6.0±0.4 E 0.8Max. L1-L2 1.0Max. L 250.0±5.0 W 75.0±5.0 H 114.0±5.0 ±5° A E Symbol L1 B L2 T E Box H L W Quantity: 2000PCS Reel D 330.0±3.0 D0 16.4±2.0 D1 86.0±2.0 W1 76.0±3.0 D0 D1 D W1 Quantity: 4000PCS www.ya geo.com Jun. 30, 2023 V.3 Product specification Circuit Protection Components LEGAL DISCLAIMER YAGEO, its distributors and agents (collectively, “YAGEO”), hereby disclaims any and all liabilities for any errors, inaccuracies or incompleteness contained in any product related information, including but not limited to product specifications, datasheets, pictures and/or graphics. YAGEO may make changes, modifications and/or improvements to product related information at any time and without notice. YAGEO makes no representation, warranty, and/or guarantee about the fitness of its products for any particular purpose or the continuing production of any of its products. To the maximum exten t permitted by law, YAGEO disclaims (i) any and all liability arising out of the application or use of any YAGEO product, (ii) any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for a particular purpose, non -infringement and merchantability. YAGEO products are designed for general purpose applications under normal operation and usage conditions. Please contact YAGEO for the applications listed below which require especially high reliability for the prevention of defects which might directly cause damage to the third party's life, body or property: Aerospace equipment (artificial satellite, rocket, etc.), Atomic energy -related equipment, Aviation equipment, Disaster prevention equipment, crime prevention equipment, Electric heating apparatus, burning equipment, Highly public information network equipment, data-processing equipment , Medical devices, Military equipment, Power generation control equipment, Safety equipment, Traffic signal equipment, Transportation equipment and Undersea equipment, or for any other application or use in which the failure of YAGEO products could result in personal injury or death, or serious property damage. P articularly YAGEO Corporation and its affiliates do not recommend the use of commercial or automotive grade products for high reliability applications or manned space flight. Information provided here is intended to indicate product specifications only. YAGEO reserves all the rights for revising this content without further notification, as long as products are unchanged. Any product change will be announced by PCN. www.yageo.com
P6KE7.5CA/B 价格&库存
很抱歉,暂时无法提供与“P6KE7.5CA/B”相匹配的价格&库存,您可以联系我们找货
P6KE7.5CA/B
  • 1+3.883001+0.50470
  • 10+2.3906110+0.31072
  • 50+1.7219650+0.22382
  • 100+1.50499100+0.19561
  • 500+1.12106500+0.14571
库存:1658
P6KE7.5CA/B
  • 2000+0.892492000+0.11600
  • 6000+0.759506000+0.09872
库存:1658
