SS52-SS510
Surface Mount Schottky Barrier Rectifiers
REVERSE VOLTAGE: 20 --- 100 V
CURRENT: 5.0 A
SMC
Features
Plastic package has Underwriters Laborator
Flammability Classification 94V-0
For surface mounted applications
Low profile package
Built-in strain relief
Metal silicon junction, majority carrier conduction
High surge capability
High current capability,low forward voltage drop
11
5.8± 0.3
8.3± 0.2
Low power loss,high effciency
0.25± 0.06
1.5± 0.25
For use in low voltage high frequency inverters,free
wheeling and polarity protection applications
Guardring for overvoltage protection
High temperature soldering guaranteed:250oC/10 1
seconds at terminals
0.203MAX
111
3.0± 0.15
7.5± 0.25
2.4± 0.2
111
Dimensions in millimeters
Mechanical Data
Case:JEDEC SMC,molded plastic over
1111passivated chip
Polarity: Color band denotes cathode end
Weight: 0.007 ounces, 0.21 gram
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25oC ambient temperature unless otherwise specified
SS52
Maximum recurrent peak reverse voltage
VRRM
SS53 SS54
30
40
SS58
SS59
SS510 UNITS
SS55
SS56
50
60
80
90
100
V
56
63
70
V
90
100
V
Maximum RMS voltage
VRWS
14
21
28
35
42
Maximum DC blocking voltage
V DC
40
50
60
Maximum average forw ord rectified current at
c TL(SEE FIG.1) (NOTE 2)
I(AV)
5.0
A
Peak forw ard surge current 8.3ms single halfc sine-w ave superimposed on rated load(JEDEC
c Method)
IFSM
175
A
Maximum instantaneous forw ard voltage at
v 5.0A(NOTE.1)
Maximum DC reverse current @TA=25oC
at rated DC blockjing voltage(NOTE1) @TA=100oC
Typical thermal resitance (NOTE2)
Operating junction temperature range
Storage temperature range
VF
IR
0.55
0.70
80
0.5
RθJA
55
RθJL
17
V
0.85
mA
o
C/W
TJ
-55--- +150
o
TSTG
-55--- +150
o
NOTE: 1.Pulse test:300μS pulse width,1%duty cy cle
2. P.C.B.mounted with 0.55"X0.55"(14.0X14.0mm 2)copper pad areas
C
C
SS52-SS510
Ratings AND Charactieristic Curves
FIG.2-- PEAK FORWARD SURGE CURRENT
175
5.0
Resistive or
inductive Load
PEAK FORWARD SURGE
CURRENT,AMPERES
AVERAGE FORWARD RECTIFIED
CURRENT,AMPERES
FIG.1 -- FORWARD DERATING CURVE
2.5
P.C.B.MOUNTED ON
0.2X0.2(5.0X5.0mm)
COPPERPAD AREAS
50
60
70 80
90 100 110 120 130 140 150 160 170
140
8.3ms Single Half Sine Wave
TJ=125
105
70
35
AMBIENT TEMPERATURE ℃
100
NUMBER OF CYCLES AT 60HZ
FIG.3 -- TYPICAL FORWARD CHARACTERISTICS
FIG.4 -- TYPICAL REVERSE CHARACTERISTICS
10
SS52-SS54
SS58-SS510
SS55-SS56
1
TJ =25
Pulse width=300 s
1% duty Cycle
.1
.1
.3
.5
.7
.9
1.1
1.3
1.5
1.7
1.9
2.1
INSTANTANEOUS REVERSE
CURRENT,MICROAMPERES
INSTANTANEOUS FORWARD
CURRENT,AMPERES
10
5.0
.5
.1
.05
TJ = 25
.01
INSTANTANEOUS FORWARD VOLTAGE,VOLTS
TJ = 125
1.0
60
80
100
120
140
PERCENT OF RATED PEAK REVERSE VOLTAGE,%
很抱歉,暂时无法提供与“SS54”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.58520
- 200+0.37840
- 1500+0.32780
- 3000+0.29040
- 国内价格
- 5+0.56798
- 50+0.44658
- 150+0.38589
- 500+0.34031
- 3000+0.29409
- 6000+0.27584
