SS52-SS520
5.0AMP.
Schottky Barrier
Rectifiers
VOLTAGE RANGE:20-200V
CURRENT:5.0A
Fetures
Plastic package has Underwriters Laboratory
SMB
Flammability Classification 94V-0 utilizing
Flame Retardant Epoxy Molding Compound.
◇ Guard ring for overvoltage protection
High current capability, low forward voltage drop
Low power loss, high efficiency
High surge capability
Mechanicla Data
◇ Case: Molded plastic SMB
Terminals: Plated leads solderable per
MIL-STD-202,Method 208 guaranteed
Polarity: Color band dentes cathode end
Mounting Position: Any
Weight: 0.093 gram
Dimensions in inches and (millimeters)
◇ Lead Free: For RoHS/Lead Free Version
◇ Marking: LGE SS5XX
MAXIMUM RATINGS AND ELECTRICAL CHARACTERS
Ratings at 25℃ ambient temperature unless otherwise specified.
Single phase,half wave,60HZ,resistive or inductive load.For capacitive load,derate by 20%.
Type Numger
Symbol
SS
SS
SS
SS
SS
SS5
SS5
SS5
52
54
55
56
58
10
15
UNITS
Maximum Recurrent Peak Reverse Voltage
VRRM
50
60
80
100
150
200
V
Maxium RMS Voltage
VRMS
14
28
35
42
56
70
105
140
V
Maxium DC Blocking Voltage
VDC
50
60
80
100
150
200
V
Average Rectified Output Current (Note 1) @TL=100℃
IF(AV)
5.0
A
IFSM
175
A
I2t
127
A2S
Peak forward surge current:8.3ms single half-sine-wave
superimposed on rated load (JEDEC Method)
I2t Rating for Fusing (t < 8.3ms)
Forward Voltage
@IF= 5.0A
VFM
Peak Reverse Current
@TA=25℃
At Rated DC Blocking Voltage @TA=100℃
Typical Junction Capacitance (Note 2)
Typical Thermal Resistance Junction toAmbient(Note 1)
Operating Temperature Range
Storage Temperature Range
0.45
0.55
IR
IR
0.5
CJ
500
0.7
0.85
0.85
0.5
V
Ma
10
350
pF
℃/W
RθJA
55
TJ
-55 to +150
TSTG
-55 to +150
Note: 1.Pulse test:300¦ÌS pulse width,1%duty cycle.
2.P.C.B.mounted with 0.55"X0.55"(14.0X14.0mm2)copper pad areas.
Revision:20170701-P1
ht t p : //
www.lgesem i .c o m
mail:lge@lgesemi.com
SS52-SS520
5.0 AMP.
Schottky Barrier
Rectifiers
CURRENT:5.0A
F i g . 2 Ty p i c a l R e v e r s e C h a r a c t e r i s t i c s
6.0
100LFM
5.0
4.0
3.0
2.0
Single phase half wave resistive
or inductive P.C.B mounted on
0.55×0.55"(14mm×14mm pad) areas
1.0
0.0
25
75
50
100
125
Instaneous Reverse Current ( μA)
Average Forward Current (A)
Fig.1 Forward Current Derating Curve
10 4
T J =100°C
10 3
SS54B/SS520B
10 1
60
100
80
F i g . 4 Ty p i c a l J u n c t i o n C a p a c i t a n c e
T J =25°C
Junction Capacitance ( pF)
1
SS52B
SS54B
SS56B/SS58B
SS510B/SS520B
0.1
1.0
1.5
500
100
SS52B/SS54B
SS54F/SS520F
SS56B-SS520B
0.1
10
1
100
Instaneous Forward Voltage (V)
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
F i g . 6 - Ty p i c a l Tr a n s i e n t T h e r m a l I m p e d a n c e
250
8.3 ms Single Half Sine Wave
(JEDEC Method)
200
150
SS54B~SS520B
100
50
00
1
1000
2.0
10
100
Number of Cycles at 60Hz
ht t p : //
Transient Thermal Impedance( °C /W)
Instaneous Forward Current (A)
Percent of Rated Peak Reverse Voltage(%)
F i g . 3 Ty p i c a l F o r w a r d C h a r a c t e r i s t i c
Peak Forward Surage Current (A)
T J =25°C
10 0
Lead Temperature (°C)
T J =75°C
10 2
100
10
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
www.lgesem i .c o m
很抱歉,暂时无法提供与“SS54”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.54287
- 50+0.42623
- 150+0.36791
- 500+0.32417
- 3000+0.28519
- 6000+0.26769
