RS3005
150mA, Low Power Consumption,
High Voltage CMOS LDO Regulator
1 FEATURES
Low Quiescent Current IQ:
11µA Typical at Light Loads
18µA Maximum at Light Loads
150mA Nominal Output Current
Low Dropout Voltage
Low Temperature Coefficient
High Input Voltage (up to 36V)
Output Voltage Accuracy: ±2.5%
Fixed 3.0V、3.3V、3.6V、4.36V、
5.0V、9.0V and 12.0V Output Voltage
Operating Temperature Range:
-40°C to +85°C
Micro SIZE PACKAGES: SOT23-3、
3 DESCRIPTIONS
The RS3005 series is a set of low power high voltage
regulators implemented in CMOS technology. It can
operate from 2.5V to 36V. Which can provide 150mA
output current. The device allows input voltage as high
as 36V.
The RS3005 series is available in several fixed output
voltages. CMOS technology ensures low dropout voltage
and ultralow quiescent current.
The RS3005 is available in Green SOT23-3, SOT23,
SOT23-5,SOT89-3L and TO-92 packages. It operates
over an ambient temperature range of -40°C to +85°C.
Device Information (1)
PART NUMBER
PACKAGE
BODY SIZE (NOM)
SOT23、SOT23-5、SOT89-3L 、
SOT23-3(3)
1.60mm×2.92mm
SOT89-3L(L-Type) and TO-92
SOT23(3)
1.30mm×2.92mm
SOT23-5(5)
1.60mm×2.92mm
SOT89-3L(3)
2.45mm×4.50mm
TO-92(3)
4.60mm×4.60mm
RS3005
2 APPLICATIONS
Audio/Video Equipment
Communication Equipment
Battery-Powered Equipment
Automotive Head Unit
Laptop, Palmtops, Notebook Computers
(1)
For all available packages, see the orderable addendum at the
end of the data sheet.
4 Typical Application Schematic
VIN
VIN
CIN
1μF
VOUT
RS3005
VOUT
COUT
1μF
GND
REV B.3
1 / 23
www.run-ic.com
RS3005
Table of Contents
1 FEATURES ...................................................................................................................................................... 1
2 APPLICATIONS ............................................................................................................................................... 1
3 DESCRIPTIONS ............................................................................................................................................... 1
4 Typical Application Schematic...................................................................................................................... 1
5 Revision History ............................................................................................................................................. 3
6 Pin Configuration and Functions (Top View) .............................................................................................. 4
7 PACKAGE/ORDERING INFORMATION (1) ..................................................................................................... 7
8 Specifications ................................................................................................................................................. 9
8.1 Absolute Maximum Ratings ....................................................................................................................... 9
8.2 ESD Ratings............................................................................................................................................... 9
8.3 Recommended Operating Conditions ........................................................................................................ 9
8.4 Thermal Information ................................................................................................................................. 10
8.5 ELECTRICAL CHARACTERISTICS ........................................................................................................ 11
8.6 TYPICAL CHARACTERISTICS ............................................................................................................... 13
9 DETAILED DESCRIPTION ............................................................................................................................ 15
9.1 Overview .................................................................................................................................................. 15
9.2 Thermal Considerations ........................................................................................................................... 15
9.3 Operation with VIN Lower Than 2.5V ....................................................................................................... 15
9.4 Operation with VIN Larger Than 2.5V ....................................................................................................... 15
10 PACKAGE OUTLINE DIMENSIONS ........................................................................................................... 16
11 TAPE AND REEL INFORMATION .............................................................................................................. 21
2 / 23
www.run-ic.com
RS3005
5 Revision History
Note: Page numbers for previous revisions may different from page numbers in the current version.
VERSION
Change Date
A.1
2018/11/13
A.2
2019/07/12
A.3
2019/11/05
B.1
2020/09/26
B.2
2021/12/15
B.3
2022/09/29
Change Item
Initial version completed
1) Add item No
2) Added SOT23-5L package
The thermal protection temperature is increased to 150 °C
Add 9V and 12V output voltage item No
1) Add the TAPE AND REEL INFORMATION
2) Change SOT23-5, SOT23-3 and SOT89-3L (L-Type) Thermal Information on
Page 7 @B.1 Version.
Update PACKAGE MARKING on Page 6@RevB.2
3 / 23
www.run-ic.com
RS3005
VIN
VIN
3
3
SCXX
SCXX
1
1
2
GND
VOUT
2
VOUT
GND
SOT23
SOT23-3
GND
VIN
SCXX
SCXXL
SCXX
1
2
3
1
2
3
1
2
3
VOUT
GND
VIN
GND
VIN
VOUT
GND
VIN
VOUT
SOT89-3L
SOT89-3L(L-Type)
TO-92
NOTE: XX indicate Output Voltage, xx indicate Date Code
For example: SC33(VOUT=3.3V)
PIN DESCRIPTION
PIN
NAME
SOT23-3
SOT23
SOT89-3L
GND
1
1
2
SOT89-3L(L-Type)/
TO-92
1
VOUT
2
2
1
3
VIN
3
3
3
2
4 / 23
FUNCTION
Ground.
Regulator Output. Recommended output
capacitor range:1μF to 10μF.
Regulator Input. Up to 36V input voltage. At
least 1μF supply bypass capacitor is
recommended.
www.run-ic.com
RS3005
(TOP VIEW)
(TOP VIEW)
OUT
NC
5
4
OUT
5
1
2
3
1
2
3
VIN
GND
NC
VIN
GND
EN
SOT23-5
RS3005-XXYF5
SOT23-5
RS3005-XXYF5
NUMBER
(1)
NC
4
I/O (1)
SOT23-5
RS3005-XXSYF5
FUNCTION
NAME
1
VIN
I
Regulator Input. Up to 36V input voltage. At least 1μF supply bypass capacitor is
recommended.
2
GND
G
Ground.
3
NC
Not connect
4
NC
Not connect
5
OUT
O
Regulator Output. Recommended output capacitor range:1μF to 10μF.
I = Input, O = Output, G=Ground.
SOT23-5
RS3005-XXSYF5
NUMBER
I/O (1)
FUNCTION
NAME
1
VIN
I
recommended.
2
GND
G
Ground.
3
EN
I
Enable pin. Drive EN greater than VEN(H) to turn on the regulator. Drive EN less than
VEN(L) to put the LDO into shutdown mode.
4
NC
Not connect
5
OUT
O
(1) I = Input, O = Output, G=Ground.
5 / 23
www.run-ic.com
RS3005
(TOP VIEW)
NC
5
NC
4
1
2
3
GND
VIN
OUT
SOT23-5
RS3005-XXTYF5
SOT23-5
RS3005-XXTYF5
NUMBER
I/O (1)
FUNCTION
NAME
1
GND
G
Ground.
2
VIN
I
recommended.
3
OUT
O
4
NC
Not connect
5
NC
Not connect
6 / 23
www.run-ic.com
RS3005
PRODUCT
ORDERING
NUMBER
VOUT(V)
PACKAGE LEAD
PACKAGE
MARKING (2)
RS3005-3.0YF3
3.0
SOT23-3
SC30
Tape and Reel,3000
RS3005-3.0YF5
3.0
SOT23-5
SC30
Tape and Reel,3000
RS3005-3.0SYF5
3.0
SOT23-5
SC30S
Tape and Reel,3000
RS3005-3.0YSF3
3.0
SOT23
SC30
Tape and Reel,3000
RS3005-3.0YE3
3.0
SOT89-3L
SC30
Tape and Reel,1000
RS3005-3.0YE3L
3.0
SOT89-3L(L-Type)
SC30L
Tape and Reel,1000
RS3005-3.3YF3
3.3
SOT23-3
SC33
Tape and Reel,3000
RS3005-3.3YF5
3.3
SOT23-5
SC33
Tape and Reel,3000
RS3005-3.3SYF5
3.3
SOT23-5
SC33S
Tape and Reel,3000
RS3005-3.3TYF5
3.3
SOT23-5
SC33T
Tape and Reel,3000
RS3005-3.3YSF3
3.3
SOT23
SC33
Tape and Reel,3000
RS3005-3.3YSF3B
3.3
SOT23
SC33B
Tape and Reel,3000
RS3005-3.3YE3
3.3
SOT89-3L
SC33
Tape and Reel,1000
RS3005-3.3YE3L
3.3
SOT89-3L(L-Type)
SC33L
Tape and Reel,1000
RS3005-3.6YF3
3.6
SOT23-3
SC36
Tape and Reel,3000
RS3005-3.6YF5
3.6
SOT23-5
SC36
Tape and Reel,3000
RS3005-3.6SYF5
3.6
SOT23-5
SC36S
Tape and Reel,3000
RS3005-3.6YSF3
3.6
SOT23
SC36
Tape and Reel,3000
RS3005-3.6YE3
3.6
SOT89-3L
SC36
Tape and Reel,1000
RS3005-3.6YE3L
3.6
SOT89-3L(L-Type)
SC36L
Tape and Reel,1000
RS3005-5.0YF3
5.0
SOT23-3
SC50
Tape and Reel,3000
RS3005-5.0YF5
5.0
SOT23-5
SC50
Tape and Reel,3000
RS3005-5.0SYF5
5.0
SOT23-5
SC50S
Tape and Reel,3000
RS3005-5.0TYF5
5.0
SOT23-5
SC50T
Tape and Reel,3000
RS3005-5.0YSF3
5.0
SOT23
SC50
Tape and Reel,3000
RS3005-5.0YE3
5.0
SOT89-3L
SC50
Tape and Reel,1000
RS3005-5.0YE3L
5.0
SOT89-3L(L-Type)
SC50L
Tape and Reel,1000
RS3005-5.0YT3
5.0
TO-92
SC50
Tape and Reel,2000
RS3005-4.36YSF3
4.36
SOT23
SC436
Tape and Reel,3000
RS3005-9.0YE3
9.0
SOT89-3L
SC90
Tape and Reel,1000
RS3005-9.0YE3L
9.0
SOT89-3L(L-Type)
SC90L
Tape and Reel,1000
RS3005-12.0YE3
12.0
SOT89-3L
SCC0
Tape and Reel,1000
RS3005-12.0YE3L
12.0
SOT89-3L(L-Type)
SCC0L
Tape and Reel,1000
PACKAGE OPTION
RS3005-3.0
RS3005-3.3
RS3005-3.6
RS3005-5.0
RS3005-4.36
RS3005-9.0
RS3005-12.0
7 / 23
www.run-ic.com
RS3005
NOTE:
(1) This information is the most current data available for the designated devices. This data is subject to change without notice and revision
of this document. For browser-based versions of this data sheet, refer to the right-hand navigation.
(2) There may be additional marking, which relates to the lot trace code information (data code and vendor code), the logo or the
environmental category on the device.
8 / 23
www.run-ic.com
RS3005
8 Specifications
over operating free-air temperature range (unless otherwise noted) (1)(2)
VIN
Input voltage
VEN
Enable input voltage
(3)
TJ
Junction temperature
PD
Continuous power dissipation (4)
Tstg
Storage temperature
(1)
(2)
(3)
(4)
MIN
MAX
UNIT
-0.3
40
V
-0.3
VIN
V
-40
150
°C
W
Internally Limited
-65
150
°C
Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings
only, and functional operation of the device at these or any other conditions beyond those indicated under Recommended Operating
Conditions is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability.
All voltages are with respect to the GND pin.
The maximum power dissipation is a function of TJ(MAX), RθJA, and TA. The maximum allowable power dissipation at any ambient
temperature is PD = (T J(MAX) - TA) / RθJA. All numbers apply for packages soldered directly onto a PCB.
Internal thermal shutdown circuitry protects the device from permanent damage.
8.2 ESD Ratings
The following ESD information is provided for handling of ESD-sensitive devices in an ESD protected area only.
V(ESD)
Electrostatic discharge
Human-body model (HBM), per ANSI/ESDA/JEDEC
JS-001(1)
VALUE
UNIT
±1000
V
±100
V
Machine model (MM)
(1) JEDEC document JEP155 states that 500 V HBM allows safe manufacturing with a standard ESD control process.
ESD SENSITIVITY CAUTION
ESD damage can range from subtle performance degradation to complete device failure. Precision integrated circuits may
be more susceptible to damage because very small parametric changes could cause the device not to meet its published
specifications.
MIN
MAX
UNIT
2.5
36
V
VIN
Input supply voltage
VEN
Enable voltage
V
IOUT
Output current
mA
TA
Operating temperature
-40
+85
°C
(1)
9 / 23
www.run-ic.com
RS3005
RS3005
THERMAL METRIC (1)
RθJA
RθJC(top)
RθJB
ѰJT
ѰJB
RθJC(bot)
PD
Junction-to-ambient thermal
resistance
Junction-to-case (top)
thermal resistance
Junction-to-board thermal
resistance
Junction-to-top
characterization parameter
Junction-to-board
Junction-to-case (bottom)
thermal resistance
Power Dissipation
SOT23
SOT233
SOT23-5
SOT893L
SOT89-3L
(L-Type)
TO-92
3 PINS
3 PINS
5 PINS
3 PINS
3 PINS
3 PINS
185.6
312.5
250
75
208.3
143.6
°C/W
104.3
134.3
84.3
88.1
88.5
74.4
°C/W
54.5
84.5
39.5
9.6
39.6
°C/W
31.0
4.8
2.86
6.2
26.5
24.2
°C/W
54.5
81.5
58.7
9.7
49.7
120.9
°C/W
N/A
N/A
N/A
7.7
77.7
°C/W
0.7
0.4
0.5
1.7
0.6
0.9
W
UNIT
(1) Thermal resistance varies with operating conditions.
10 / 23
www.run-ic.com
RS3005
(VIN = VOUT + 2V, CIN = COUT = 1μF, VOUT = 3.3V, Full = -40°C to +85°C, typical values are at TA = +25°C, unless otherwise
noted.)
PARAMETER
SYMBOL
Input Voltage
VIN
CONDITIONS
TEMP
MIN
VOUT = 3.3V
+25°C
2.5(1)
IOUT = 1mA
+25°C
-2.5
No load
Ground Pin Current
VIN = VOUT + 2V
VIN = 36V
+25°C
IOUT = 50mA
Maximum Output Current
Dropout Voltage
Line Regulation
Load Regulation
Power Supply Rejection
Ratio
+25°C
VDROP
IOUT = 150mA
ΔVOUT
VIN = VOUT + 2V to 36V, IOUT = 1mA
ΔVIN × VOUT
ΔVOUT
PSRR
VIN =VOUT+2V, IOUT = 1mA to150mA
VOUT = 3.3V,
IOUT = 10mA
MAX
UNITS
36
V
11
18
16
25
μA
11
(2)
(3)
TYP
f = 217Hz
f = 1KHz
ΔVOUT
Output Voltage Temperature
IOUT = 1mA
Coefficient (4)
ΔTA × VOUT
150
mA
+25°C
1300
1800
mV
+25°C
0.005
0.012
%/V
+25°C
10
25
mV
65
+25°C
dB
63
FULL
70
ppm/°C
150
°C
THERMAL PROTECTION
Thermal Shutdown
Temperature
TSHDN
SHUTDOWN
EN Voltage Range
EN Input Threshold
EN Input Bias Current
Shutdown Supply Current
Start-Up Time (5)
VEN
FULL
-0.3
1.1
VIN+0.3
VIH
FULL
VIL
FULL
IBH
EN=36V
+25°C
0.01
1
IBL
EN=0V
FULL
0.01
1
IQ(SHDN)
EN=0V
FULL
1.5
3
COUT = 1μF, No Load
+25°C
230
tSTR
0.4
V
V
μA
μA
μs
NOTES:
1. VIN = VOUT (NOMINAL) or 2.5V, whichever is greater.
2. Maximum output current is affected by the PCB layout, size of metal trace, the thermal conduction path between metal layers, ambient
temperature and the other environment factors of system. Attention should be paid to the dropout voltage when VIN < VOUT + VDROP.
3. The dropout voltage is defined as VIN - VOUT, when VOUT is 100mV below the value of VOUT for VIN = VOUT (NOMINAL) + 2V.
4. Output voltage temperature coefficient is defined as the worst-case voltage change divided by the total temperature range.
5.Time needed for VOUT to reach 90% of final value.
11 / 23
www.run-ic.com
RS3005
(VIN = VOUT + 2V, CIN = COUT = 1μF, VOUT = 5.0V, Full = -40°C to +85°C, typical values are at TA = +25°C, unless otherwise
noted.)
PARAMETER
SYMBOL
Input Voltage
VIN
Ground Pin Current
IQ
CONDITIONS
TEMP
MIN
VOUT = 5.0V
+25°C
2.5(1)
IOUT = 1mA
+25°C
-2.5
No load
VIN = VOUT + 2V
VIN = 36V
+25°C
IOUT = 50mA
Dropout Voltage
Line Regulation
Load Regulation
Ratio
+25°C
VDROP
IOUT = 150mA
ΔVOUT
ΔVIN × VOUT
ΔVOUT
PSRR
VOUT = 5.0V,
IOUT = 10mA
MAX
UNITS
36
V
11
18
16
25
μA
11
(2)
(3)
TYP
f = 217Hz
f = 1KHz
ΔVOUT
IOUT = 1mA
Coefficient (4)
ΔTA × VOUT
150
mA
+25°C
1100
1600
mV
+25°C
0.005
0.012
%/V
+25°C
10
25
mV
65
+25°C
dB
63
FULL
70
ppm/°C
150
°C
THERMAL PROTECTION
Thermal Shutdown
Temperature
TSHDN
SHUTDOWN
EN Voltage Range
EN Input Threshold
Start-Up Time (5)
VEN
FULL
-0.3
1.1
VIN+0.3
VIH
FULL
VIL
FULL
IBH
EN=36V
+25°C
0.01
1
IBL
EN=0V
FULL
0.01
1
IQ(SHDN)
EN=0V
FULL
1.5
3
COUT = 1μF, No Load
+25°C
230
tSTR
0.4
V
V
μA
μA
μs
NOTES:
12 / 23
www.run-ic.com
RS3005
NOTE: The graphs and tables provided following this note are a statistical summary based on a limited number of samples
and are provided for informational purposes only.
VIN = 5.3V, VOUT = 3.3V, CIN = COUT = 1μF, TA = 25°C unless otherwise noted.
VIN=5.3V to 6.3V,IOUT=50mA
IOUT=10mA to 100mA
100mV/div
VOUT
100mA/div
IOUT
100mV/div
VOUT
1V/div
VIN
Time(1ms/div)
Time(200us/div)
Figure 1. Line-Transient Response
Figure 2. Load-Transient Response
VIN=0 to 3.4V,IOUT=50mA
2V/div
VOUT
2V/div
VIN
100mA/div
2V/div
VOUT
IOUT
VIN=0 to 5.3V,IOUT=50mA
Time(2ms/div)
Time(1ms/div)
Figure 3. Power-Up/Power-Down Output
Waveform
Figure 4. Output Short Waveform
1600
600
IOUT=50mA
Dropout Voltage(mV)
Dropout Voltage(mV)
550
500
450
400
350
1200
800
400
-50
-25
50
Temperature(℃)
75
100
Figure 5. Dropout Voltage vs Temperature
50
75
100
125
150
Output Current(mA)
Figure 6. Dropout Voltage vs Output Current
13 / 23
www.run-ic.com
RS3005
16
VOUT=3.3V
35
Ground Pin Current(uA)
40
30
25
10
5
VOUT=3.3V
14
12
10
8
6
4
2
6
9 12 15 18 21 24 27 30 33 36
Input Voltage(V)
Figure 7. Ground Pin Current vs Input Voltage
60
90
120
Output Current(mA)
150
Figure 8. Ground Pin Current vs Load Current
3.31
3.4
VOUT=3.3V
VOUT=3.3V
Output Voltage(V)
30
Output Voltage(V)
3.305
3.3
3.295
3.35
3.3
3.25
3.2
3.29
4
8
12
16
28
Input Voltage(V)
Figure 9. Line Regulation
32
30
60
90
120
Output Current(mA)
Figure 10. Load Regulation
14 / 23
150
www.run-ic.com
RS3005
9.1 Overview
The RS3005 low-dropout regulators (LDO) consumes only 11µA of quiescent current at light load and delivers
excellent line and load transient performance. These characteristics, combined with low noise and good PSRR
with low dropout voltage, make this device ideal for portable consumer applications.
Functional Block Diagram
When the junction temperature is too high, the thermal protection circuitry sends a signal to the control logic
that will shut down the IC. The IC will restart when the temperature has sufficiently cooled down. The maximum
power dissipation is dependent on the thermal resistance of the case and the circuit board, the temperature
difference between the die junction and the ambient air, and the rate of air flow. The GND pin must be connected
to the ground plane for proper dissipation.
The device normally operates with input voltages above 2.5V. At input voltages below the 2.5V, the device does
not operate.
When VIN is greater than 2.5V, if VIN is also higher than the output set value plus the device dropout voltage,
VOUT is equal to the set value. Otherwise, VOUT is equal to VIN minus the dropout voltage.
15 / 23
www.run-ic.com
RS3005
SOT23-3
D
1.90
b
2.59
E1
E
0.99
0.95
0.69
e
e1
RECOMMENDED LAND PATTERN (Unit: mm)
0.2
A A2
c
θ
L
A1
Dimensions In Millimeters
Dimensions In Inches
Symbol
Min
Max
Min
Max
A
1.050
1.250
0.041
0.049
A1
0.000
0.100
0.000
0.004
A2
1.050
1.150
0.041
0.045
b
0.300
0.500
0.012
0.020
c
0.100
0.200
0.004
0.008
D
2.820
3.020
0.111
0.119
E
1.500
1.700
0.059
0.067
E1
2.650
2.950
0.104
0.116
e
0.950(BSC)
0.037(BSC)
e1
1.800
2.000
0.071
0.079
L
0.300
0.600
0.012
0.024
θ
0°
8°
0°
8°
16 / 23
www.run-ic.com
RS3005
SOT23
D
1.90
b
2.29
E1
E
0.76
0.95
0.76
e
e1
0.2
A A2
c
θ
L
A1
Symbol
Min
Max
Min
Max
A
0.900
1.150
0.035
0.045
A1
0.000
0.100
0.000
0.004
A2
0.900
1.050
0.035
0.041
b
0.300
0.500
0.012
0.020
c
0.080
0.150
0.003
0.006
D
2.800
3.000
0.110
0.118
E
1.200
1.400
0.047
0.055
E1
2.250
2.550
0.089
0.100
e
0.950(BSC)
0.037(BSC)
e1
1.800
2.000
0.071
0.079
L
0.300
0.500
0.012
0.020
θ
0°
8°
0°
8°
17 / 23
www.run-ic.com
RS3005
SOT23-5
D
1.90
b
2.59
E1
E
0.99
0.95
0.69
e
e1
0.2
A A2
c
θ
L
A1
Symbol
Min
Max
Min
Max
A
1.050
1.250
0.041
0.049
A1
0.000
0.100
0.000
0.004
A2
1.050
1.150
0.041
0.045
b
0.300
0.500
0.012
0.020
c
0.100
0.200
0.004
0.008
D
2.820
3.020
0.111
0.119
E
1.500
1.700
0.059
0.067
E1
2.650
2.950
0.104
0.116
e
0.950(BSC)
0.037(BSC)
e1
1.800
2.000
0.071
0.079
L
0.300
0.600
0.012
0.024
θ
0°
8°
0°
8°
18 / 23
www.run-ic.com
RS3005
SOT89-3L
D
2.0
A
D1
3.0
E
E1
0.7
45°
b1
L
e
1.5
b
c
1.5
e1
1.0
Symbol
Min
Max
Min
Max
A
1.400
1.600
0.055
0.063
b
0.320
0.520
0.013
0.020
b1
0.400
0.580
0.016
0.023
c
0.350
0.440
0.014
0.017
D
4.400
4.600
0.173
0.181
D1
1.550 REF
0.061 REF
E
2.300
2.600
0.091
0.102
E1
3.940
4.250
0.155
0.167
e
1.500 BSC
0.060 BSC
e1
3.000 BSC
0.118 BSC
L
0.900
1.200
19 / 23
0.035
0.047
www.run-ic.com
RS3005
TO-92
TOP
3.60±0.15
4.60±0.10
12.70 MIN
4.00 MAX
#1 PIN
4.60±0.10
1.30±0.10
0.46±0.08
2.50±0.50
0.38±0.05
NOTE:
A. All linear dimension is in millimeters.
B. This drawing is subject to change without notice.
C. Body dimensions do not include mold flash or protrusion. Mold flash and protrusion shall not exceed 0.15 per side.
D. BSC: Basic Dimension. Theoretically exact value shown without tolerances.
E. REF: Reference Dimension, usually without tolerance, for information purposes only.
20 / 23
www.run-ic.com
RS3005
REEL DIMENSIONS
TAPE DIMENSION
Reel
Diameter
Reel Width(W1)
DIRECTION OF FEED
NOTE: The picture is only for reference. Please make the object as the standard.
KEY PARAMETER LIST OF TAPE AND REEL
Package
Type
Reel
Diameter
SOT23
7’’
Reel
Width
(mm)
9.5
SOT23-3
7’’
SOT23-5
SOT89-3L
A0
(mm)
B0
(mm)
K0
(mm)
P0
(mm)
P1
(mm)
P2
(mm)
W
(mm)
Pin1
Quadrant
3.15
2.77
1.22
4.0
4.0
2.0
8.0
Q3
9.0
3.20
3.30
1.30
4.0
4.0
2.0
8.0
Q3
7’’
9.5
3.20
3.20
1.40
4.0
4.0
2.0
8.0
Q3
7’’
13.2
4.85
4.45
1.85
4.0
8.0
2.0
12.0
Q3
NOTE:
1. All dimensions are nominal.
2. Plastic or metal protrusions of 0.15mm maximum per side are not included.
21 / 23
www.run-ic.com
RS3005
TAPE AND REEL INFORMATION (Continued)
h
P
A1
A
P
T
H
HO
L1
W0
F1 F2
P1
P2
W
W1
W2
d
t2
t1
P0
TO-92
Item
Symbol
Value and Tolerance (Unit: mm)
Body width
A1
4.5 ± 0.2
Body height
A
4.5 ± 0.2
Body thickness
T
3.5 ± 0.1
Lead wire diameter
d
0.46 +0.09, -0.08
Pitch of component
P
12.7 ± 0.3
Feed hole pitch
P0
12.7 ± 0.2
Hole center to component center
P2
6.35 ± 0.3
F1, F2
2.5 ± 0.3
△h
0 ± 1.0
Type width
W
18.0 + 1.0, - 0.5
Hole down tape width
W0
6.0 ± 0.5
Hole position
W1
9.0 ± 0.5
Hole down tape position
W2
1.0 MAX
Height of component from tape center
H
19.0 +2.0, -1.0
Lead wire clinch height
H0
16.0 ± 0.5
Lead wire (tape portion)
L1
2.5 MIN
Feed hole diameter
D0
4.0 ± 0.2
Carrier Tape Thickness
t1
0.4 ± 0.05
Taped Lead Thickness
t2
0.2 ± 0.05
Position of hole
P1
3.85 ± 0.3
Component alignment
△P
0 ± 1.0
Lead to lead distance
Component alignment, F-R
22 / 23
www.run-ic.com
RS3005
IMPORTANT NOTICE AND DISCLAIMER
Jiangsu RUNIC Technology Co., Ltd. will accurately and reliably provide technical and reliability data (including
data sheets), design resources (including reference designs), application or other design advice, WEB tools,
safety information and other resources, without warranty of any defect, and will not make any express or implied
warranty, including but not limited to the warranty of merchantability Implied warranty that it is suitable for a
specific purpose or does not infringe the intellectual property rights of any third party.
These resources are intended for skilled developers designing with RUNIC products You will be solely
responsible for: (1) Selecting the appropriate products for your application; (2) Designing, validating and testing
your application; (3) Ensuring your application meets applicable standards and any other safety, security or
other requirements; (4) RUNIC and the RUNIC logo are registered trademarks of RUNIC INCORPORATED. All
trademarks are the property of their respective owners; (5) For change details, review the revision history
included in any revised document. The resources are subject to change without notice. Our company will not
be liable for the use of this product and the infringement of patents or third-party intellectual property rights due
to its use.
23 / 23
www.run-ic.com
