LM236/LM336
Description
The LM236 and LM336 are precision 5.0V regula- tor diodes. These voltage
reference monolithic ICs operate like 5.0V zener diodes with a low temperature coefficient and a dynamic impedance of 0.6 Ω . A third pin enables
adjusting the reference voltage and the temperature coefficient.
Features
SOP-8
Adjustable 4V to 6V
Low temperature coefficient
Wide operating current of 600 µA to 10 mA
0.6 dynamic impedance
± 1% initial tolerance available
Guaranteed temperature stability
Easily trimmed for minimum temperature drift
Fast turn-on
Three lead transistor package
TO-92
DFN-8
Ordering Information
DEVICE
Package Type
MARKING
Packing
Packing Qty
LM236D-5.0RG
SOP-8
236-5.0
REEL
2500pcs/reel
LM336D-5.0RG
SOP-8
336-5.0
REEL
2500pcs/reel
LM236LP-5.0G
TO-92
LM236-5.0
BAG
1000pcs/box
LM336LP-5.0G
TO-92
LM336-5.0
BAG
1000pcs/box
LM236DQ-5.0RG
DFN-8
236-5.0
REEL
2500pcs/reel
LM336DQ-5.0RG
DFN-8
336-5.0
REEL
2500pcs/reel
Typical Applications
深圳市汉芯半导体有限公司
http://www.hanschip.com
1 / 11
2018 SEP
LM236/LM336
Pin Connections
DFN-8 3*3
SOP-8
TO-92
Absolute Maximum Ratings
Symbol
Parameter
IR IF
Current
Reverse
Forward
Toper
Operating Free-air Temperature Range
TStg
Storage Temperature Range
TL
LM336
Unit
15
10
mA
LM336-5.0:
0 to +70
°C
LM236-5.0:
-40 to +85
°C
-65 to +150
°C
245
°C
Lead Temperature (Soldering, 10 seconds)
Note:Absolute Maximum Ratings indicate limits beyond which damage to the device may occur. Operating Ratings indicate
conditions for which the device is intended to be functional, but specific performance is not ensured.
Electrical Characteristics
Symbol
VR
LM236/LM336
Parameter
Reference Breakdown Voltage
Tamb = +25°C, IR = 1mA
Unit
Min.
Typ.
Max.
4.9
5.0
5.1
V
6
mV
0.6
2.0
4
12
mV
ppm
Reverse Breakdown Voltage Change with Current
VR
600µA ≤ IR ≤ 10mA
Tamb = +25°C
Tmin. ≤ Tamb ≤ Tmax.
Reverse Dynamic Impedance (IR = 1mA)
ZD
Tamb = +25°C f=100Hz
KVT
Temperature Stability (VR = 5.0V, I
KVH
Long Term Stability (Tamb = +25°C ±0.1°C, IR= 1mA)
深圳市汉芯半导体有限公司
R
= 1mA)
2 / 11
2018 SEP
LM236/LM336
Typical Performance Characteristics
深圳市汉芯半导体有限公司
3 / 11
2018 SEP
LM236/LM336
Typical Performance Characteristics (Continued)
Application Hints
The LMx36-5.0 series voltage references are much easier to use than ordinary zener diodes. Their low
impedance and wide operating current range simplify biasing in almost any circuit. Further, either the
breakdown voltage or the temperature coefficient can be adjusted to optimize circuit performance.
Figure 1 showsanLM336-5.0witha10kpotentiometerfor adjusting the reverse breakdown voltage. With the
addition of R1 the breakdown voltage can be adjusted without affecting the temperature coefficient of the
device. The adjustment range is usually sufficient to adjust for both the initial device tolerance and inaccuracies
in buffer circuitry.
If minimum temperature coefficient is desired, four diodes can be added in series with the adjustment
potentiometer as shown in Figure 2. When the device is adjusted to 5.00V the temperature coefficient is
minimized. Almost any silicon signal diode can be used for this purpose such as a 1N914, 1N4148 or a 1N457.
For proper temperature compensation the diodes should be in the same thermal environment as
theLM336-5.0.Itisusuallysufficienttomountthediodesnear the LM336-5.0ontheprintedcircuitboard.Theabsolute
resistance of the network is not critical and any value from 2k to 20k will work. Because of the wide adjustment
range, fixed resistors should be connected in series with the pot to make pot setting less critical.
FIGURE1.LM336-5.0withPotforAdjustmentof
FIGURE 2. Temperature Coefficient Adjustment
Breakdown Voltage (Trim Range = ±1.0V Typical)
(Trim Range = ±0.5V Typical)
深圳市汉芯半导体有限公司
4 / 11
2018 SEP
LM236/LM336
Precision Power Regulator with Low Temperature Coefficient
5V Crowbar
LM308A
Adjustable Shunt Regulator
深圳市汉芯半导体有限公司
5 / 11
2018 SEP
LM236/LM336
Typical Applications (Continued)
LM308
LM312
LM336
LM336
深圳市汉芯半导体有限公司
6 / 11
2018 SEP
LM236/LM336
LM308
LM312
Schematic Diagram
深圳市汉芯半导体有限公司
7 / 11
2018 SEP
LM236/LM336
Physical Dimensions
SOP-8
Q
A
C
C1
B
D
A1
a
0.25
b
Dimensions In Millimeters(SOP-8)
A
A1
B
C
C1
D
Min:
1.35
0.05
4.90
5.80
3.80
0.40
0°
0.35
Max:
1.55
0.20
5.10
6.20
4.00
0.80
8°
0.45
Symbol:
Q
a
b
1.27 BSC
TO-92
B
C
D1
D
L
C1
A
b
a
Dimensions In Millimeters(TO-92)
A
B
C
C1
D
D1
L
a
Min:
3.43
4.44
11.2
4.32
3.17
2.03
0.33
0.40
Max:
3.83
5.21
12.7
5.34
4.19
2.67
0.42
0.52
Symbol:
深圳市汉芯半导体有限公司
8 / 11
b
1.27BSC
2018 SEP
LM236/LM336
Physical Dimensions
DFN-8 3*3
B1
F
B
A
a
E
A1
b
Dimensions In Millimeters(DFN-8 3*3)
A
A1
B
B1
E
F
a
Min:
0.85
0.00
2.90
2.90
0.20
0.30
0.20
Max:
0.95
0.05
3.10
3.10
0.25
0.50
0.34
Symbol:
深圳市汉芯半导体有限公司
9 / 11
b
0.65 BSC
2018 SEP
LM236/LM336
Revision History
DATE
REVISION
2018-9-15
New
2023-9-13
Update Lead Temperature、Add annotation for Maximum Ratings.
深圳市汉芯半导体有限公司
PAGE
1-11
10 / 11
2
2018 SEP
LM236/LM336
IMPORTANT STATEMENT:
Hanschip Semiconductor reserves the right to change its products and services without notice. Before ordering, the customer shall obtain the latest relevant
information and verify whether the information is up to date and complete. Hanschip Semiconductor does not assume any responsibility or obligation for the
altered documents.
Customers are responsible for complying with safety standards and taking safety measures when using Hanschip Semiconductor products for system
design and machine manufacturing. You will bear all the following responsibilities: select the appropriate Hanschip Semiconductor products for your application;
Design, validate and test your application; Ensure that your application meets the appropriate standards and any other safety, security or other requirements. To
avoid the occurrence of potential risks that may lead to personal injury or property loss.
Hanschip Semiconductor products have not been approved for applications in life support, military, aerospace and other fields, and Hanschip Semiconductor
will not bear the consequences caused by the application of products in these fields. All problems, responsibilities and losses arising from the user's use beyond
the applicable area of the product shall be borne by the user and have nothing to do with Hanschip Semiconductor, and the user shall not claim any
compensation liability against Hanschip Semiconductor by the terms of this Agreement..
The technical and reliability data (including data sheets), design resources (including reference designs), application or other design suggestions, network
tools, safety information and other resources provided for the performance of semiconductor products produced by Hanschip Semiconductor are not guaranteed
to be free from defects and no warranty, express or implied, is made. The use of testing and other quality control technologies is limited to the quality assurance
scope of Hanschip Semiconductor. Not all parameters of each device need to be tested.
The documentation of Hanschip Semiconductor authorizes you to use these resources only for developing the application of the product described in this
document. You have no right to use any other Hanschip Semiconductor intellectual property rights or any third party intellectual property rights. It is strictly
forbidden to make other copies or displays of these resources. You should fully compensate Hanschip Semiconductor and its agents for any claims, damages,
costs, losses and debts caused by the use of these resources. Hanschip Semiconductor accepts no liability for any loss or damage caused by infringement.
深圳市汉芯半导体有限公司
11 / 11
2018 SEP
很抱歉,暂时无法提供与“LM336LP-5.0G”相匹配的价格&库存,您可以联系我们找货
