SL78L06Z
SL78L06Z
    SLKOR(萨科微)
    TO-92-3
    6V 100MA 20V
SL78L06Z 数据手册
SL78L06Z TO-92 Encapsulate Three-terminal Voltage Regulators FEATURES TO-92 Maximum Output current IOM: 0.1 A 1.OUT Output voltage Vo: 6 V 2.GND Continuous total dissipation PD: 0. 625W 3.IN ABSOLUTE MAXIMUM RATINGS (Operating temperature range applies unless otherwise specified) Parameter Symbol Input Voltage Value Vl Operating Junction Temperature Range Storage Temperature Range Units V 30 TOPR 0a+1 ℃ TSTG -55a+150 ℃ ELECTRICAL CHARACTERISTICS AT SPECIFIED VIRTUAL JINCTION TEMPERATURE (Vi=11V,Io=40mA,Ci=0.33μF,Co=0.1μF, unless otherwise specified ) Parameter Symbol Test conditions Min 25℃ Output voltage Vo 8V≤V l≤20V, Io=1mA-40mA 0-125℃ Io=1mA-70mA Load Regulation △Vo Line regulation △Vo Quiescent Current Quiescent Current Change Io=1mA-100mA Unit 5.75 6.0 6.25 V 5.7 6.0 6.3 V 5.7 6.0 6.3 V 25℃ 16 80 mV 25℃ 9 40 mV 8V≤V l≤20V 25℃ 35 175 mV 9V≤V l≤20V 25℃ 29 125 mV 25℃ 3.9 6.0 mA 1.5 mA 0.1 mA Iq △Iq 9V≤V l≤20V 0-125℃ 0-125℃ △Iq 1mA≤I O≤40mA VN 10Hz≤f≤100KHz Ripple Rejection RR 9V≤V l≤19V,f=120Hz Dropout Voltage Vd vi Max Io=1mA-40mA Output Noise Voltage TYPICAL APPLICATION Typ 25℃ 0-125℃ 25℃ 3 1 40 46 μV 48 dB 1.7 V Vo UTC Ci 2 C0 0.1μF 0.33μF Note : Bypass capacitors are recommended for optimum stability and transient response and should be located as close as possible to the regulators. www.slkormicro.com 1 Rev.1 -- 21 December 2018
SL78L06Z 价格&库存
很抱歉,暂时无法提供与“SL78L06Z”相匹配的价格&库存,您可以联系我们找货
SL78L06Z
  • 10+0.36677
  • 100+0.29312
  • 300+0.25629
  • 1000+0.22875
  • 5000+0.20661
  • 10000+0.19559
库存:699
