WSD3066DN33
WSD3066DN33
    WINSOK(微硕)
    DFN-8-EP(3.3x3.3)
    MOSFETs N-沟道 30V 66A DFN8_3.3X3.3MM_EP
WSD3066DN33 数据手册
WSD3066DN33 N-Channel MOSFET General Description Product Summery The WSD3066DN33 is the highest performance trench N-Channel MOSFETs with extreme high cell density, which provide excellent RDS(ON) and gate charge for most of the synchronous buck converter applications. BVDSS RDS(ON) ID 30V 4.7mΩ 66A Applications The WSD3066DN33 meet the RoHS and Green Product requirement, 100% EAS guaranteed with full function reliability approved. ⚫ High Frequency Point-of-Load Synchronous Buck Converter for MB/NB/UMPC/VGA ⚫ Networking DC-DC Power System ⚫ Load Switch Features ⚫ ⚫ ⚫ ⚫ ⚫ DFN3x3-8L Pin Configuration Advanced high cell density Trench technology Super Low Gate Charge Excellent CdV/dt effect decline 100% EAS Guaranteed Green Device Available D1 (5,6,7,8) (4) G1 S1 (1,2,3) Absolute Maximum Ratings Symbol Parameter Rating VDS Drain-Source Voltage 30 VGS Gate-Source Voltage ±20 ID @TC =25°C Continuous Drain Current, VGS @ 10V 1 66 ID @TC =100°C Continuous Drain Current, VGS @ 10V 1 40 ID @TA =25°C Continuous Drain Current, VGS @ 10V 1 15 ID @TA =70°C Continuous Drain Current, VGS @ 10V 1 10 IDM @TC =25°C Pulsed Drain Current 2 V A 150 EAS Avalanche Energy, Single Pulse (L=0.1mH) 3 IAS Avalanche Current, Single pulse(L=0.1mH) 3 PD @TC =25°C Total Power Dissipation 4 45 Total Power Dissipation 4 1.78 PD @TA =25°C Units 125 mJ 50 A TSTG Storage Temperature Range -55 to 150 TJ Operating Junction Temperature Range -55 to 150 W °C Thermal Data Symbol Parameter RθJA Thermal Resistance, Junction-to-Ambient RθJC Thermal Resistance, Junction-to-Case www.winsok.tw Page 1 1 1 Typ. Max. --- 70 --- 2.7 Units °C/W Rev 3.0: Nov. 2023 WSD3066DN33 N-Channel MOSFET Electrical Characteristics (TJ =25°C, Unless Otherwise Noted) Symbol BVDSS ∆BVDSS /∆TJ Parameter Conditions Min. Typ. Max. Units --- V V/°C Drain-Source Breakdown Voltage VGS =0V , ID =250μA 30 --- BVDSS Temperature Coefficient Reference to 25°C, ID =1mA --- 0.028 --- VGS =10V , ID =40A --- 4.7 5.7 VGS =4.5V , ID =20A --- 5.8 7.6 1.5 1.8 2.5 V --- -6.06 --- mV/°C ----- 1.0 VDS =24V , VGS =0V , TJ =55°C ----- RDS(ON) Static Drain-Source On-Resistance VGS(th) Gate Threshold Voltage 2 VGS =VDS , ID =250μA mΩ ∆VGS(th) VGS(th) Temperature Coefficient IDSS Drain-Source Leakage Current IGSS Gate-Source Leakage Current VGS =±20V , VDS =0V --- --- ±100 nA gfs Forward Transconductance VDS =5V , ID =20A --- 44 --- S VDS =0V , VGS =0V , f = 1.0MHz --- 1.0 1.1 Ω --- 27.5 38.5 --- 9.6 13.4 VDS =24V , VGS =0V , TJ =25°C 30 μA Rg Gate Resistance Qg Total Gate Charge (4.5V) Qgs Gate-Source Charge Qgd Gate-Drain Charge --- 9.4 13.7 Td(on) Turn-On Delay Time --- 18.5 34 --- 11.3 21 --- 62.5 114 Fall Time --- 23.5 43 Ciss Input Capacitance --- 1320 1420 Coss Output Capacitance --- 610 640 Crss Reverse Transfer Capacitance --- 112 150 Min. Typ. Max. Units --- 125 --- mJ Min. Typ. Max. Units --- --- 15 A --- --- 45 A --- --- 1.0 V --- 23 --- ns --- 7 --- nC Tr Td(off) Tf VDS =15V , VGS =4.5V , ID =20A Rise Time VDD =15V , VGEN =10V , RG =6Ω , ID =1A , RL =15Ω Turn-Off Delay Time VDS =15V , VGS =0V , f = 1.0MHz nC ns pF Guaranteed Avalanche Characteristics Symbol EAS Parameter Conditions Single Pulse Avalanche Energy 5 VDD =25V , L=0.5mH , IAS =20A Diode Characteristics Symbol IS Parameter Continuous Source Current Pulsed Source Curren 2,6 VSD Diode Forward Voltage 2 trr Reverse Recovery Time Qrr Reverse Recovery Charge ISM Conditions 1,6 VG =VD =0V , Force Current VGS =0V , IS =1A , TJ =25°C IF =40A, dI/dt=100A/µs,TJ =25°C Note: 1. The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper, t
WSD3066DN33 价格&库存
很抱歉,暂时无法提供与“WSD3066DN33”相匹配的价格&库存,您可以联系我们找货
WSD3066DN33
  • 5+1.70193
  • 50+1.36677
  • 1000+1.04386
  • 2000+0.83857
  • 5000+0.79059
库存:4623
