USBLC6-2SC6-JSM
USBLC6-2SC6-JSM
    JSMSEMI(杰盛微)
    SOT-23-6
    静电放电(ESD)保护器件@@单向 ESD,可防30kV静电
USBLC6-2SC6-JSM 数据手册
USBLC6-2SC6 2-Line Uni-directional TVS Diode Description Features The USBLC6-2SC6 is an ultra low capacitance TVS array, utilizing leading monolithic silicon technology to provide fast response time and low ESD clamping voltage, making this device an ideal solution for protecting voltage sensitive high-speed data  Ultra low capacitance: 0.6pF typical (I/O-GND)  Ultra low leakage: nA level  Low operating voltage: 5.0V to r IEC 61000-4-2 (ESD) standard with ±15kV air and ±8kV contact discharge. It is assembled into a 6-pin lead-free SOT23-6 package. The combination of small size, ultra low capacitance, and high ESD surge capability make it ideal for use in applications such as multimedia, and other high speed ports. Up to 4 data lines and one power lineprotects  Low clamping voltage  Complies with following standards: – IEC 61000-4-2 (ESD) immunity test uc with a typical value at 0.6 pF, and complies with the  Air : ±20kV; discharge: ±15kV – IEC61000-4-5 (Lightning) 4.5A (8/20μs) nd lines. The USBLC6-2SC6 has an ultra-low capacitance  SOT23-6 Package  co RoHS Compliant Se mi Circuit Diagram Applications 6 1 I/O1  Monitors and flat panel displays  Set-top box and Digital TV GND 2 5 VBUS  Video graphics cards I/O2 3 4 O I/O1  Digital Video Interface (DVI)  Notebook Computers  PCI Express and Serial SATA Ports MI CR I/O2 JS Marking Diagram UL26 Ordering Information Part Number Packaging Reel Size USBLC6-2SC6 3000/Tape & Reel 7 inch www.jsmsemi.com 第1页,共4页 USBLC6-2SC6 2-Line Uni-directional TVS Diode Absolute Maximum Ratings (TA=25°C unless otherwise specified) Value Unit Peak Pulse Power (8/20µs,I/O-GND) Ppk 60 W Peak Pulse Power (8/20µs,Vcc-GND) Ppk 300 W Peak Pulse Current (8/20µs,I/O-GND) IPP Peak Pulse Current (8/20µs,Vcc-GND) IPP ESD per IEC 61000−4−2 (Air) VESD,VDD ESD per IEC 61000−4−2 (Contact) VESD,I/O TJ 4.5 A 17 A ±20 kV ±15 −55 to +125 °C −55 to +150 °C nd Operating Temperature Range to r Symbol uc Parameter Tstg co Storage Temperature Range Parameter Se mi Electrical Characteristics (TA=25°C unless otherwise specified) Symbol Reverse Working Voltage VRWM O VBR Breakdown Voltage Test Condition Min Typ Pin 5 to GND,I/O-GND IT = 1mA(Pin 5 to GND,I/O-GND) 6.0 7.5 Max Unit 5.0 V 8.5 V 0.5 µA IR VRWM = 5.0V VF IF = 15mA,GND to Pin 5/IO 0.8 1.0 V Clamping Voltage VC IPP = 4.5A (8 x 20µs pulse, I/O to GND) 14.0 15.0 V Clamping Voltage VC 16.0 18.0 V Junction Capacitance CJ 0.6 0.7 pF Junction Capacitance CJ 0.3 0.4 pF CR Reverse Leakage Current JS MI Forward Breakdown Voltage IPP = 17A (8 x 20µs pulse,Pin 5 to GND) Vpin5 = 5V, I/O=0V, f = 1MHz,I/O-GND Vpin5 = 5V, I/O=0V, f = 1MHz,I/O-I/O pins www.jsmsemi.com 第2页,共4页 USBLC6-2SC6 2-Line Uni-directional TVS Diode Typical Performance Characteristics (TA=25°C unless otherwise Specified) CJ-Junction Capacitance (pF) 0.7 0.6 0.5 to r 0.4 0.3 0.2 uc 0.1 0 0 1 2 3 4 5 nd VR—Reverse Voltage(V) Clamping Voltage vs. Peak Pulse Current Junction Capacitance vs. Reverse Voltage co 0.1 -20 O 0.01 1.0 10.0 Pulse Duration_tp(uS) MI 40 20 0 50 75 100 125 150 Ipp-Peak Pulse Current-%of Ipp 60 25 60 80 100 120 80 0 40 IEC61000−4−2 Pulse Waveform JS % of Rated Power 100 20 Time (nS) Peak Pulse Power vs. Pulse Time 120 0 100.0 CR 0.1 Voltage (V) 1 Se mi Peak Power_Ppp(kW) 10 Ambient Temperature_Ta(℃) 100 80 60 40 20 0 -20 -20 0 20 40 60 T-Time(us) Power Derating Curve 8 X 20us Pulse Waveform www.jsmsemi.com 第3页,共4页 USBLC6-2SC6 2-Line Uni-directional TVS Diode SOT23-6 Package Outline Drawing 2X E/2 E1 ccc C A A1 A2 b c D E1 E e e1 N aaa ccc E e 2X N/2 TIPS B D aaa A2 C A1 0.045 0.114 0.063 0.110 BSC 0.037 BSC 0.075 BSC 6 0.004 0.008 MAX 0.057 0.006 0.051 0.020 0.009 0.122 0.069 Se mi co bxN A INCHES NOM to r SYM DIMENSIONS MILLIMETERS MIN NOM MAX MIN 0.90 1.45 0.035 0.00 0.15 0.000 0.90 1.15 1.30 0.035 0.25 0.50 0.010 0.08 0.22 0.003 2.80 2.90 3.10 0.110 1.50 1.60 1.75 0.060 2.80 BSC 0.95 BSC 1.90 BSC 6 0.10 0.20 uc e1 nd A Suggested Land Pattern X CR O SYM G MI C Y INCHES 0.098 0.055 0.037 0.024 0.043 0.141 JS P Z C G P X Y Z DIMENSIONS MILLIMETERS 2.50 1.40 0.95 0.60 1.10 3.60 www.jsmsemi.com 第4页,共4页
USBLC6-2SC6-JSM 价格&库存
很抱歉,暂时无法提供与“USBLC6-2SC6-JSM”相匹配的价格&库存,您可以联系我们找货
