SS54
SS54
    YENJI(台湾元基)
    SMC(DO-214AB)
    肖特基二极管 电压:40V 电流:5A SMC(DO-214AB)
SS54 数据手册
SS52~SS520 5.0Amp Surface Mounted Schottky Barrier Rectifiers Features DO-214AB/SMC The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 For surface mounted applications 0.245(6.22) 0.220(5.59) 0.126 (3.20) 0.114 (2.90) Built-in strain relief,ideal for automated placement Low reverse leakage High forward surge current capability 0.280(7.11) 0.260(6.60) High temperature soldering guaranteed 0.012(0.305) 0.006(0.152) 250 C/10 seconds at terminals 0.103(2.62) 0.079(2.06) Mechanical Data Case : Molded plastic body Terminals : Solder plated, solderable per MIL-STD-750,Method 2026 0.060(1.52) 0.030(0.76) 0.008(0.203)MAX. 0.320(8.13) 0.305(7.75) Polarity : Polarity symbol marking on body Mounting Position : Any Weight : 0.008 ounce, 0.225 grams Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load, for capacitive load current derate by 20%. Parameter SYMBOLS SS52 SS54 SS56 SS58 SS510 SS515 SS520 UNITS Maximum repetitive peak reverse voltage VRRM 20 40 60 80 100 150 200 V Maximum RMS voltage VRMS 14 28 42 56 70 105 140 V Maximum DC blocking voltage VDC 20 40 60 80 100 150 200 V Maximum average forward rectified current at TL =100 C I(AV) 5.0 A Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load IFSM 120.0 A Maximum instantaneous forward voltage at 5.0A VF Maximum DC reverse current T A =25 C at rated DC blocking voltage TA=125 C Typical thermal resistance Operating junction temperature range Storage temperature range 0.68 0.55 0.85 0.15 50 IR 0.95 0.05 10 V mA RqJA 45.0 C/W TJ -55 to +150 C TSTG -55 to +150 C 1/3 SS52~SS520 5.0Amp Surface Mounted Schottky Barrier Rectifiers Ratings And Characteristic Curves FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT PERLEG 140 Peak Forward Surage Current Amperes 8.0 7.0 6.0 Amperes Average Forward Rectified Current FIG. 1- DERATING CURVE OUTPUT RECTIFIED CURRENT 5.0 4.0 3.0 2.0 1.0 0.0 0 20 40 60 80 100 120 140 120 100 80 60 f=60Hz 40 20 1Cycle 0 160 1 10 100 Lead Temperature Number of cycles FIG. 3-TYPICAL FORWARD VOLTAGE CHARACTERISTICS FIG. 4-TYPICAL REVERSE LEAKAGE CHARACTERISTICS 50 100 TJ=25 C INSTANTANEOUS REVERSE CURRENT, MICROAMPERES INSTANTANEOUS FORWARD CURRENT,AMPERES SS52-SS56 SS58-SS520 10.0 1 0.1 SS52-SS54 SS56 SS58-SS510 SS515-SS520 0.01 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 INSTANTANEOUS FORWARD VOLTAGE, VOLTS 10 TJ=100 C 1 0.1 0.01 0.001 0 TJ=25 C 20 40 60 80 100 PERCENT OF PEAK REVERSE VOLTAGE,% Suggested Pad Layout Symbol Unit (mm) Unit (inch) A 0.130 B 3.30 2.50 C 6.80 0.268 D 4.40 0.173 E 9.40 0.370 2/3 0.098 SS52~SS520 5.0Amp Surface Mounted Schottky Barrier Rectifiers Suggested Soldering Temperature Profile Note R ecom m ended reflow m ethods: IR , vap or phase ov en, hot air oven, w ave solder. Th e dev ice can b e exp osed to a m axim um tem p erature of 265 °C for 10 second s. D evices can b e cleaned using standa rd industry m ethods and solvents. If reflow tem peratures exceed the re c o m m e n d e d p ro file , d e v ic e s m a y n o t m e e t th e p e rfo rm a n c e re q u ire m e n ts . Package Information Carrier Dimension(mm) A0 B0 K0 D0 E F 6.05 8.31 2.54 1.55 1.75 7.50 P0 P1 P2 T W Tolerance 4.0 8.0 2.0 0.25 16 0.1 Package Specifications Package Reel Size SMC 13' Reel DIA. (mm) Q'TY/Reel (Kpcs) Box Size (mm) QTY/Box (Kpcs) Carton Size (mm) Q'TY/Carton (Kpcs) 330 3.0 340 6.0 360*360*360 48 3/3
很抱歉,暂时无法提供与“SS54”相匹配的价格&库存,您可以联系我们找货
