TS1-00-6AU-1A-3B
TS1-00-6AU-1A-3B
    KFY(凯丰盈)
    插件,P=2.54mm
    轻触开关 插件,P=2.54mm 100000Cycles
TS1-00-6AU-1A-3B 数据手册
2.5 10.0 1 2 3- 1 4+ 4 3 2 10.0 10.0 2.54 2.54 . 0 8 1.0 2.5+0.3 - 3.1+0.3 - 1.2 13.6±0.25 9.0 3.0 3.8 7.7 NOTES: 1.RATING: 12VDC 50mA 2.CONTACT RESISTANCE: 100m Max 3.INSULATION RESISTANCE: 100M 250VDC FOR 1 MIN 4.DIELECTRIC STRENGTH: 250VAC( 50/60Hz) FOR1 MIN 5.LIFE TEST:100,000 CYCLES 6.OPERATION FORCE: 250 80g 7.TRAVEL: 0.25 0.1 mm 5 TERMINAL H65( C2680 ) 4 CONTACT SUS 3 BUTTON PA66 2 FIXITY PA66 1 HOUSING PA66 ITEM PART NAME MATERIAL TACT SWITCH 深圳市凯丰盈科技有限公司 TS1-00-6AU-1A-3B 文件编号 深圳市凯丰盈科技有限公司 TS1 SERIES 检验规范总则 审核 韩玲 批准 李新超 WI-RD-001 版 号 A-0 页 次 1/3 生效日期 2011.04.15 1. General 一般事项: 1-1 Application:This specification is applied to the switch used in electronic equipment. 适用范围:本规格主要适用于一般电子设备之开关。 1-2 Operating Temperature Range 使用温度范围:10~60℃ 1-3 RH 相对湿度:45~85%. 1-4 Atmospheric Pressure 气压: 860~1060mbr. 2.Appearance Construction and Dimensions 外观、结构、尺寸: 2-1 Appearance:Tiny push button switch shall have good finishing, and shall have no rust, crack or plating failure. 外观:各部分之加工须良好,开关上下不能生锈、刮伤、裂痕电镀不良及剥离等现象产生。 2-2 cleansing condition:Switch’s surface shall avoid contact with oil sludge and shall not be exposed to the air for a long time. 清洁条件:避免开关表面与空气长时间接触及油渍水溶剂沾污。 2-3 Construction and Dimensions:As per product drawing. 结构及尺寸:依组立图。 3.Rating 电器等级: 50mA 12VDC; 4.Electronic performance 电器性能: Property 项目 4.1 Contact Resistance 接触阻抗 4.2 Insulation Resistance 绝缘阻抗 4.3 Dielectric withstand Strength Test 耐电压 Test Conditions 测试条件 Measure by micro-ohm meter at DC0.2 V, 1A 以微欧姆计之 DC0.2 V 1A 测之. Measure with DC.100V applied between terminals of open contacts and between terminals of opposite polarity. 以 100VDC 于开路之端子间,及不同回路端子间. between terminals of open contacts and between terminals of opposite polarity, and between terminals and frame as following. 开关须施以一分钟电压于开路之端子与端子间,不同两极之 端子间及外壳与端子间,以下列额定电压测之. 250V.AC/50Hz for 1 min, 250V.AC/50HZ 1 分钟 Standards 判定标准 Max 100 mΩ 100 mΩ 以下 More than 100 MΩ 100MΩ 以上 A switch shall withstand for 1 minute without breakdown or arc in a potential applied 1 分钟内不能有电弧导 通或火花产生 深圳市凯丰盈科技有限公司 TS1 SERIES 检验规范总则 文件编号 WI-RD-001 版 号 A-0 页 次 2/3 5.Mechanical performance 机械性能: Property 项目 5.1 5.2 Pull test 拉力测试 Operating Force 操作力 Test Conditions 试验条件 Standards 判定标准 The terminal may be deformed, but shall not sustain any trouble as A static force of 2.5 pound (1kg) being applied in one deviation and breaking direction on the tip of the terminal for 1 minute. of terminal and breaking 拉力测试:施拉以同一方向之 2.5 磅静力(1 公斤)于端子前端 of insulation material 一分钟. 端 子可容 许变型 ,但 不 能 有脱离 ,断 裂及开 关 本体之绝缘部位破坏现 象 The switch should be cable of being operated within a force of Tolerance: 180gram±50gram or 250gram±50gram ±50g 开关能够在 180g±50g/250g±50g 范围内动作 Temperature and duration of dipping 焊锡温度和浸入时间: 5.3 Terminal of lead Temperature Time Soldering Heat 导线端子 温度(℃) 时间(秒) Resistance Manual Soldering 耐焊锡性 手焊式 Dip Soldering 锡炉式 No abnormalities shall be observed in appearance and 350±5℃ 3±0.5sec operation. 外观无显着变型及动作 260±5℃ 5±0.5sec 无异常. More than 75% of the 5.4 Soldering 焊锡性 230±5℃ 3±0.5sec dipped part shall be covered by solder 焊锡附着浸入 75%以上 The switch should Mechanical life test: 5.5 无负载机械寿命测 试 operate at least 100,000 The switch applied without electric load times, without 未施电器负载的情况下测试 mechanical failure 开关动作次数超过 100,000 次 5.6 Travel Push by recommended operating condition:0.25±0.1mm Tolerance: 行程 行程:0.25±0.1mm ±0.1mm 深圳市凯丰盈科技有限公司 TS1 SERIES 检验规范总则 文件编号 WI-RD-001 版 号 A-0 页 次 3/3 6 Weather Proof耐候性 Property 项目 6.1 Cold Proof 耐寒性 6.2 Hot Proof 耐热性 6.3 Resistance to humidity 耐湿性 Test Conditions Standards 试验条件 判定标准 Inlet socket for testing being kept in the normal condition at 10±2℃ for 96 hours, then to be measured within 1 hour after drops of water being taken away. 1.Max Contact Resistance:100 mΩ 10±2℃放置 96 小时试验后,置于常温常湿中 1 接触阻抗:100 mΩ 以下 小时;除去水滴后,在一小时内测试之。 Inlet socket for testing being kept in the normal condition at 60±2℃ for 96 hours, then to be 2.Clause 4.3shall be satisfied measured within 1 hour. 必须满足 4.3 项 60±2℃放置 96 小时试验后,置于常温常湿中 1 小时;在一小时内测试之。 Inlet socket for testing being kept in the normal 3.No abnormalities shall be observed on condition at 40±2℃,and 90~95%HR for 96 hours, the appearance and construction.. then to be measured within 1 hour after drops of 外观构造无异常现象。 water being taken away. 40±2℃,相对湿度 90~95%下,放置 96 小时试验 后,置于常温常湿中 1 小时;除去水滴后,在一 小时内测定之。
TS1-00-6AU-1A-3B 价格&库存
很抱歉,暂时无法提供与“TS1-00-6AU-1A-3B”相匹配的价格&库存,您可以联系我们找货
