MPC356B1(T1)-GV
MPC356B1(T1)-GV
    MTC(美禄)
    SOP-4
    光电耦合器 3.75KV SOP-4
MPC356B1(T1)-GV 数据手册
MPC356 Series SOP4, DC Input Photo Transistor Coupler  Features  Applications  High isolation 3750 VRMS  Switch mode power supplies  CTR flexibility available see order information  Programmable controllers  DC input with transistor output  Office equipment  Operating temperature range - 55 °C to 110 °C  System appliances, measuring  REACH compliance  Halogen free  Telecommunication equipments  MSL class 1  Signal  Regulatory Approvals  UL - UL1577  VDE - EN60747-5-5(VDE0884-5)  CQC – GB4943.1-2022 instruments transmission between circuits of different potentials and impedances  Home appliances, such as fan heaters, etc.  Description  Schematic The MPC356 series combine an AlGaAs infrared emitting diode as the emitter which is optically coupled to a silicon planar phototransistor detector in a plastic SOP4 package. With the robust coplanar double mold structure, MPC356 series provide the most stable isolation feature. Miracle Technology Co., Ltd. 1 Rev 1.1 MPC356 Series SOP4, DC Input Photo Transistor Coupler ABSOLUTE MAXIMUM RATINGS PARAMETER SYMBOL VALUE UNIT REMARK INPUT Forward Current IF 60 mA Peak Forward Current IFP 1 A Reverse Voltage VR 6 V Input Power Dissipation PI 100 mW Collector - Emitter Voltage VCEO 80 V Emitter - Collector Voltage VECO 7 V Collector Current IC 50 mA Output Power Dissipation PO 150 mW Total Power Dissipation Ptot 200 mW Isolation Voltage Viso 3750 Vrms Operating Temperature Topr -55~110 °C Storage Temperature Tstg -55~125 °C Soldering Temperature Tsol 260 °C (Note 1) OUTPUT COMMON (Note 2) Note 1. 100μs pulse, 100Hz frequency Note 2. AC For 1 Minute, R.H. = 40 ~ 60% Miracle Technology Co., Ltd. 2 Rev 1.1 MPC356 Series SOP4, DC Input Photo Transistor Coupler ELECTRICAL OPTICAL CHARACTERISTICS at Ta=25°C PARAMETER SYMBOL MIN TYP. MAX. UNIT TEST CONDITION REMARK INPUT Forward Voltage VF - 1.24 1.4 V IF=10mA Reverse Current IR - - 10 μA VR=6V Input Capacitance Cin - 10 - pF V=0, f=1kHz OUTPUT Collector Dark Current ICEO - - 100 nA VCE=20V, IF=0 Collector-Emitter Breakdown Voltage BVCEO 80 - - V IC=0.1mA, IF=0 Emitter-Collector Breakdown Voltage BVECO 6 - - V IE=0.1mA, IF=0 TRANSFER CHARACTERISTICS Current Transfer Ratio MPC356 50 - 600 MPC356A 80 - 160 130 - 260 MPC356C 200 - 400 MPC356D 300 - 600 - 0.06 MPC356B CTR % IF=5mA, VCE=5V 0.2 V IF=20mA, IC=1mA - Ω DC500V, 40 ~ 60% R.H. Collector-Emitter Saturation Voltage VCE(sat) Isolation Resistance RISO Floating Capacitance CIO - 0.4 1 pF V=0, f=1MHz Cut-off Frequency fc - 80 - kHz VCE=2V, IC=2mA RL=100Ω,-3dB (Note 4) Response Time (Rise) tr - 6 18 μs Response Time (Fall) tf - 8 18 μs VCE=2V, IC=2mA RL=100Ω (Note 3) 10^12 10^14 Note 3. Fig.12&13 Note 4. Fig.14 Miracle Technology Co., Ltd. 3 Rev 1.1 MPC356 Series SOP4, DC Input Photo Transistor Coupler CHARACTERISTIC CURVES Fig.1 Forward Current vs. Ambient Temperature Fig.2 Collector Power Dissipation vs. Ambient Temperature Fig.3 Forward Current vs. Forward Voltage Fig.4 Collector Dark Current vs. Ambient Temperature Fig.5 Collector Current vs. Collector-emitter Voltage Fig.6 Collector Current vs. Collector-emitter Voltage Miracle Technology Co., Ltd. 4 Rev 1.1 MPC356 Series SOP4, DC Input Photo Transistor Coupler CHARACTERISTIC CURVES Fig.7 Normalized Current Transfer Ratio vs. Forward Current Fig.8 Normalized Current Transfer Ratio vs. Ambient Temperature Fig.9 Collector-emitter Saturation Voltage vs. Ambient Temperature Fig.10 Switching Time vs. Load Resistance Fig.11 Frequency Response Miracle Technology Co., Ltd. 5 Rev 1.1 MPC356 Series SOP4, DC Input Photo Transistor Coupler TEST CIRCUITS Fig.12 Test Circuits of Response Time Fig.13 Curves of Response Time Fig.14 Test Circuits of Frequency Response Miracle Technology Co., Ltd. 6 Rev 1.1 MPC356 Series SOP4, DC Input Photo Transistor Coupler PACKAGE DIMENSIONS (Dimensions in mm unless otherwise stated) Recommended Solder Mask (Dimensions in mm unless otherwise stated) Miracle Technology Co., Ltd. 7 Rev 1.1 MPC356 Series SOP4, DC Input Photo Transistor Coupler CARRIER TAPE SPECIFICATIONS (Dimensions in mm unless otherwise stated) Option T1 Option T2 Miracle Technology Co., Ltd. 8 Rev 1.1 MPC356 Series SOP4, DC Input Photo Transistor Coupler ORDERING AND MARKING INFORMATION MARKING INFORMATION MPC : Company Abbr. 356 : Part Number X : CTR Rank V : VDE Option Y : Fiscal Year A :Manufacturing Code WW : Work Week ORDERING INFORMATION MPC356XN(Z)-GV MPC – Company Abbr. Z – Tape and Reel Option (T1/T2) 356 – Part Number G – Green X – Rank1 (A/B/C/D or None) V – VDE Option (V or None) N – Rank2 (1~9 or None) PACKING QUANTITY Option Quantity Quantity – Inner box Quantity – Outer box T1 3000 Units/Reel 3 Reels/Inner box 5 Inner box/Outer box = 45k Units T2 3000 Units/Reel 3 Reels/Inner box 5 Inner box/Outer box = 45k Units Miracle Technology Co., Ltd. 9 Rev 1.1 MPC356 Series SOP4, DC Input Photo Transistor Coupler REFLOW INFORMATION REFLOW PROFILE Profile Feature Sn-Pb Assembly Profile Pb-Free Assembly Profile Temperature Min. (Tsmin) 100 150°C Temperature Max. (Tsmax) 150 200°C Time (ts) from (Tsmin to Tsmax) 60-120 seconds 60-120 seconds Ramp-up Rate (tL to tP) 3°C/second max. 3°C/second max. Liquidous Temperature (TL) 183°C 217°C Time (tL) Maintained Above (TL) 60 – 150 seconds 60 – 150 seconds Peak Body Package Temperature 235°C +0°C / -5°C 260°C +0°C / -5°C Time (tP) within 5°C of 260°C 20 seconds 30 seconds Ramp-down Rate (TP to TL) 6°C/second max 6°C/second max Time 25°C to Peak Temperature 6 minutes max. 8 minutes max. Miracle Technology Co., Ltd. 10 Rev 1.1 MPC356 Series SOP4, DC Input Photo Transistor Coupler DISCLAIMER  Our company is continually improving the quality, reliability, function and design. Our company reserves the right to make changes without further notices.  The characteristic curves shown in this datasheet are representing typical performance which are not guaranteed.  This product is not intended to be used for military, aircraft, automotive, medical, life sustaining or lifesaving applications or any other application which can result in human injury or death.  Immerge unit’s body in solder paste is not recommended.  Discoloration might be occurred on the package surface after soldering, reflow or long-time use. It neither impacts the performance nor reliability.  Revision History Version Date 1.0 2018-12-21 Datasheet Complete 1.1 2023-07-05 Upgrade Datasheet Miracle Technology Co., Ltd. Subjects (major changes since last revision) 11 Rev 1.1
MPC356B1(T1)-GV 价格&库存
很抱歉,暂时无法提供与“MPC356B1(T1)-GV”相匹配的价格&库存,您可以联系我们找货
MPC356B1(T1)-GV
    • 10+0.35650
    • 100+0.33350
    • 500+0.31050
    • 2000+0.27600
    • 5000+0.26450
    • 10000+0.25760
    库存:8636
