VCTA25201B-2R2MS6
VCTA25201B-2R2MS6
    CYNTEC(乾坤)
    SMD,2.5x2mm
    功率电感 2.2μH ±20% 2.6A 70mΩ SMD,2.5x2mm
VCTA25201B-2R2MS6 数据手册
CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : CYNVC-175-021 REVISION : B2 PAGE : 1 OF 8 The history of revision change for the specification Document  REV.  Modified date  CYNVC‐175‐021  A0  2017.5.17  CYNVC‐175‐021  A1  2017.6.19  CYNVC‐175‐021  A2  2017.9.7  CYNVC‐175‐021  A3  2017.10.13  CYNVC‐175‐021  A4  2018.3.13  CYNVC‐175‐021  A5  2018.10.17  CYNVC‐175‐021  A6  2019.3.4  CYNVC‐175‐021  A7  2019.9.5  CYNVC‐175‐021  A8  2019.10.2  CYNVC‐175‐021  A9  2020.5.13  CYNVC‐175‐021  B0  2020.6.23  CYNVC‐175‐021  B1  2020.7.31  CYNVC‐175‐021  B2  2020.10.21  Description  New Approval  1. May ‐> Jun.  2. Add spec of R15, R22, R33, R50, R68, 6R8  3. Add curve of R15, R22, R33, R50, R68, 6R8  1. Jun. ‐> Sep.  2. Remove spec of R15, R22, R33, R50, R68  3. Remove curve of R15, R22, R33, R50, R68  1. Add spec of R33  2. Add curve of R33  3. Sep. ‐> Oct.  1. Add “AEC‐Q200” logo on page 2  2. Oct., 2017 ‐> Mar., 2018  1. Mar. ‐> Oct.  2. Remove spec & curve of 100, 150  3. Specifications add Rated voltage on page 3  1. Oct., 2018 ‐> Mar., 2019  2. Add spec & curve of R22  1. Mar. ‐> Sep.  2. Add spec & curve of 100  1. Sep. ‐> Oct.  2. Remove spec & curve of R22  1. Oct., 2019 ‐> May, 2020  2. Add spec & curve of R22  1. May ‐> Jun.  2. R22 Isat Typ. 8.4 ‐> 9.0 ; Isat Max. 7.2 ‐> 8.0  3. R33 Isat Typ. 7.5 ‐> 7.8 ; Isat Max. 6.4 ‐> 7.0  1. Jun. ‐> Jul.  2. Add spec & curve of R68  1. Jul. ‐> Oct.  2. Add spec & curve of R15  Oct., 2020 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : CYNVC-175-021 REVISION : B2 PAGE : 2 OF 8 Power Choke Coil VCTA25201B MS6 type  AEC-Q200 Features High performance (Isat) realized by metal dust core. Low profile:2.5mm x 2.0mm x 1.2mm Low loss realized with low DCR Compliance with RoHS and Halogen Free AEC-Q200 qualified  Application Automotive applications  Outline Dimensions L Code W P P Dimensions (mm) L 2.5  0.2 W 2.0  0.2 T 1.2 Max. P 0.7  0.2 T  Recommend Land Pattern Dimensions The customer shall determine the land dimensions shown below after confirming and safety. B A C A 2.3 B 1.2 C 2.8 Unit : mm Oct., 2020 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CYNVC-175-021 REVISION : B2 PAGE : 3 OF 8 Marking The point on the top surface represents winding direction of choke. Upside of Chip PIN 1 PIN 2 Coil clockwise around  Specifications Part Number L0 ◇ Inductance ( H ) @ (0A) Rdc ( m ) ◇ Typical Maximum Heat Rating Current DC Amps. Idc ( A ) Typical Maximum Saturation Current DC Amps. Isat ( A ) Rated Voltage (V) Typical Maximum Maximum VCTA25201B-R10MS6 0.10 9.0 11.0 7.7 7.0 12.8 11.0 20 VCTA25201B-R15MS6 0.15 10.6 12.8 6.5 5.8 10.2 8.7 20 VCTA25201B-R22MS6 0.22 11.2 13.5 6.3 5.7 9.0 8.0 20 VCTA25201B-R33MS6 0.33 16.0 20.0 5.4 4.8 7.8 7.0 20 VCTA25201B-R47MS6 0.47 21.0 26.0 4.7 4.0 6.5 5.6 20 VCTA25201B-R68MS6 0.68 30.0 37.0 4.1 3.5 5.3 4.8 20 VCTA25201B-1R0MS6 1.0 35.0 42.0 3.8 3.4 4.8 4.2 20 VCTA25201B-1R5MS6 1.5 50.0 60.0 3.1 2.7 3.9 3.3 20 VCTA25201B-2R2MS6 2.2 70.0 84.0 2.6 2.2 3.5 3.0 20 VCTA25201B-3R3MS6 3.3 115.0 140.0 2.0 2.3 20 4.7 165.0 200.0 1.7 1.8 1.4 2.7 VCTA25201B-4R7MS6 2.2 2.0 20 VCTA25201B-6R8MS6 6.8 330.0 400.0 1.2 1.0 1.8 1.6 20 VCTA25201B-100MS6 10.0 440.0 530.0 1.0 0.8 1.5 1.3 20 ◇:Significant Characteristic * :If you require another part number please contact with us. **:Inductance Tolerance  20% Note 1.: All test data is referenced to 25 ambient. Note 2.: Test Condition:1MHz, 1.0Vrms Note 3.: Idc : DC current (A) that will cause an approximate ΔT of 40℃ Note 4.: Isat : DC current (A) that will cause L0 to drop approximately 30% Note 5.: Operating Temperature Range -55℃ to +165℃ Note 6.: The part temperature (ambient + temp rise) should not exceed 165℃ under the worst case operating conditions. Circuit design, component placement, PCB trace size and thickness, airflow and other cooling provision all affect the part temperature. Part temperature should be verified in the end application. Note 7.: The rated current as listed is either the saturation current or the heating current depending on which value is lower. Note 8.: Cleaning Process Note (a) If this power choke is dipped in the cleaning agent, such as toluene, xylene, ketone, and ether system, there is a possibility that the performance decreases greatly (b) The high power ultrasonic washing may damage the choke body. (c) Please contact us if you need the cleaning via the above agents or ultrasonic washing. Oct., 2020 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司  60 INDUCTANCE(μH) TEMP. RISE(℃) 40 0.04 20 : 4 OF 8 6 8 10 12 14 16 TEMP. RISE(℃) 20 0 0.00 18 0 2 4 TEMP. RISE(℃) 60 40 0.08 20 0.04 0.00 INDUCTANCE(μH) TEMP. RISE(℃) 80 INDUCTANCE(μH) 1 2 3 4 5 6 7 8 9 10 80 0.24 INDUCTANCE(μH) 0.18 TEMP. RISE(℃) 20 0 0.10 0.00 2.4 0.84 80 0.70 3.2 4.0 4.8 5.6 6.4 7.2 8.0 INDUCTANCE(μH) 100 40 TEMP. RISE(℃) 1.6 1 2 3 4 5 6 7 8 9 10 0.28 TEMP. RISE(℃) 0.14 0 0.00 TEMP. RISE(℃) 0.40 60 40 0 0.00 0.0 0.4 0.8 1.2 1.6 2.0 2.4 2.8 3.2 3.6 4.0 4.4 4.8 5.2 5.6 1.80 100 20 0.20 0 1 2 3 4 5 6 7 DC BIAS(Amps) INDUCTANCE(μH) INDUCTANCE(μH) 40 20 0 80 0.80 60 INDUCTANCE(μH) 20 TEMP. RISE(℃) 1.00 100 80 0.42 8.8 VCTA25201B-1R0MS6 VCTA25201B-R68MS6 0.56 DC BIAS(Amps) DC BIAS(Amps) 40 0.12 0 60 INDUCTANCE(μH) 0.8 60 0.00 TEMP. RISE (℃) 0.40 0.0 100 DC BIAS(Amps) 0.50 0.20 14 0.30 11 VCTA25201B-R47MS6 0.30 12 0.36 DC BIAS(Amps) 0.60 10 0.06 0 0 8 VCTA25201B-R33MS6 0.42 100 0.20 0.12 6 DC BIAS(Amps) VCTA25201B-R22MS6 0.16 40 0.06 DC BIAS(Amps) 0.24 60 INDUCTANCE(μH) 0.09 TEMP. RISE(℃) 4 80 0.12 TEMP. RISE(℃) 2 100 0.15 0.03 0 0 INDUCTANCE(μH) PAGE VCTA25201B-1R5MS6 100 1.50 80 1.20 0.90 60 INDUCTANCE(μH) TEMP. RISE(℃) 40 0.60 TEMP. RISE(℃) 0.06 INDUCTANCE(μH) TEMP. RISE(℃) INDUCTANCE(μH) 80 0.08 0.00 INDUCTANCE (μH) : B2 VCTA25201B-R15MS6 0.18 100 0.02 INDUCTANCE(μH) REVISION TEMP. RISE(℃) VCTA25201B-R10MS6 0.10 0.60 : CYNVC-175-021 Current Characteristic 0.12 1.20 DOCUMENT 20 0.30 0.00 0 0.0 0.4 0.8 1.2 1.6 2.0 2.4 2.8 3.2 3.6 4.0 4.4 4.8 5.2 DC BIAS(Amps) Oct., 2020 Issued 1.60 80 3.50 60 INDUCTANCE(μH) TEMP. RISE(℃) 40 0.80 20 0.40 0.00 0.4 0.8 1.2 1.6 2.0 2.4 2.8 3.2 3.6 4.0 60 2.10 40 1.40 INDUCTANCE(μH) 0 0.4 0.8 1.2 1.6 INDUCTANCE(μH) 0.00 2.0 3.2 3.6 4.0 2.4 2.8 3.2 80 60 4.20 40 2.80 0 0.00 3.6 100 INDUCTANCE(μH) 20 TEMP. RISE(℃) 0 0.0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 2.0 2.2 DC BIAS(Amps) VCTA25201B-100MS6 100 10.0 80 8.0 60 6.0 4.0 INDUCTANCE(μH) 2.0 TEMP. RISE(℃) 40 TEMP. RISE(℃) INDUCTANCE(μH) 2.8 5.60 1.40 DC BIAS(Amps) 12.0 2.4 7.00 20 TEMP. RISE(℃) 1.6 2.0 VCTA25201B-6R8MS6 8.40 INDUCTANCE(μH) 40 2.00 TEMP. RISE(℃) INDUCTANCE(μH) 60 3.00 1.2 20 TEMP. RISE(℃) 0.00 100 4.00 0.8 100 80 0.0 80 0.4 : 5 OF 8 DC BIAS(Amps) 5.00 0.0 PAGE 2.80 4.4 VCTA25201B-4R7MS6 1.00 : B2 VCTA25201B-3R3MS6 DC BIAS(Amps) 6.00 REVISION 0.70 0 0.0 : CYNVC-175-021 TEMP. RISE(℃) 1.20 4.20 INDUCTANCE(μH) INDUCTANCE(μH) 2.00 100 TEMP. RISE(℃) VCTA25201B-2R2MS6 2.40 DOCUMENT TEMP. RISE(℃) CYNTEC CO., LTD. 乾坤科技股份有限公司 20 0.0 0 0.0 0.3 0.6 0.9 1.2 1.5 1.8 2.1 DC BIAS(Amps) Oct., 2020 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CYNVC-175-021 REVISION : B2 PAGE : 6 OF 8 Packaging (1) Tape packaging dimensions t +0.1 1.5 -0.0 4.0 ± 0.1 2.0 ± 0.1 Sprocket hole 1.75 ± 0.10 3.5 ± 0.1 8.0 ± 0.3 B0 K0 4.0 ± 0.1 A0 Pulling direction Dimensions Code (mm) A0 B0 K0 t 2.35  0.10 2.80  0.10 1.35  0.10 0.25  0.05 UNITS/REEL 2,000 (2) Tape Direction The direction shall be seen from the top cover tape side. Pulling direction Oct., 2020 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : CYNVC-175-021 REVISION : B2 PAGE : 7 OF 8 (3) Reel dimensions 2.0 ±0.5 13.0 ± 0.5 A N 21.0 ± 0.8 A φ178.0  2.0 W1 N φ60.0  2.0 W2 W1 9.0  0.3 W2 11.4  1.0 Unit : mm (4) Peel force of top cover tape The peel speed shall be about 300 mm/minute. The peel force of top cover tape shall be between 0.1 to 0.7N. Top Cover Tape 165 ~ 180° 0.1 ~ 0.7N Carrier tape Oct., 2020 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CYNVC-175-021 REVISION : B2 PAGE : 8 OF 8 Reflow Profile Power Choke Coil Type Tp Temperature 260℃ tp:30 Sec max. Max. Ramp Up Rate =3℃/s Max. Ramp Down Rate =6℃/s 217℃ 60~150 Sec Preheat Area 200℃ 150℃ 60~120 Sec 25℃ 25°C to Peak ( 8 minutes max.) Time (1) Reflow Soldering Method : Reflow Soldering Tp:255~260℃ Max.30 seconds ( tp ) 217℃ 60~150 seconds Pre-Heat 150 ~ 200℃ 60~120 seconds Time 25℃ to peak temperature 8 minutes max. (2) Soldering iron Method : 350  5℃ max.3 seconds Oct., 2020 Issued
VCTA25201B-2R2MS6 价格&库存
很抱歉,暂时无法提供与“VCTA25201B-2R2MS6”相匹配的价格&库存,您可以联系我们找货
