1N4007W
1N4007W
    MSKSEMI(美森科)
    SMF(SOD-123FL)
    整流二极管 VR=1KV VF=1.1V@1A SOD-123FL
1N4007W 数据手册
1N4001W-1N4007W Product specification 1N4001W-1N4007W FEATURES MECHANICAL DATA  Case: Molded plastic Easy pick and place  Epoxy: UL 94V-0 rate flame retardant  Built-in strain relief  Terminals: Solder plated, solderable per MIL-STD-202F,  High surge current capability  Ideal for surface mount applications  method 208 guranteed  Polarity: Color band denotes cathode end  Mounting position: Any Reference News PACKAGE OUTLINE Circuit PINNING PIN SOD-123FL DESCRIPTION 1 Cathode 2 Anode MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 2 5 C ambient temperature unless otherwise specified. Single phase half- wave 6 0 Hz, resistive or inductive load, for capacitive load current derate by 2 0 % . Parameter Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current at TA=65 C (NOTE 1) Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) TL=25 C Maximum instantaneous forward voltage at 1 . 0 A Maximum DC reverse current at TA=25℃ rated DC blocking voltage TA=125℃ Typical junction capacitance (NOTE 2) Typical thermal resistance (NOTE 3) Operating junction and storage temperature range SYMBOLS VRRM VRMS VDC 1N4001W 1N4002W 1N4003W A1 A2 A3 50 35 50 100 70 100 200 140 200 1N4004W 1N4005W 1N4006W A4 A5 A6 400 280 400 600 420 600 800 560 800 1N4007W A7 1000 700 1000 UNITS VOLTS VOLTS VOLTS I(AV) 1.0 Amp IFSM 25.0 Amps VF 1.0 Volts IR 10.0 50.0 μA J RJA TJ,TSTG 4 180 -65 to +150 pF K/W ℃ Note: 1.Averaged over any 20ms period. 2.Measured 3.Thermal at 1MHz and applied reverse voltage of 4.0V D.C. resistance from junction to ambient at 0.375” (9.5mm)lead length,P.C.B. mounted Copyright© Msksemi Incorporated www.msksemi.com 1N4001W-1N4007W ELECTRICAL CHARACTERISTICS CURVE Copyright© Msksemi Incorporated www.msksemi.com 1N4001W-1N4007W PACKAGE MECHANICAL DATA Suggested Pad Layout Note: 1.Controlling dimension:in millimeters. 2.General tolerance:±0.05mm. 3.The pad layout is for reference purposes only. REEL SPECIFICATION P/N PKG QTY 1N4001W-1N4007W SOD-123FL 3000 Copyright© Msksemi Incorporated www.msksemi.com 1N4001W-1N4007W Attention ■ Any and all MSKSEMI Semiconductor products described or contained herein do not handle applications that require extremely high levels of reliability, such as life-support have specifications that can systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you before using any MSKSEMI Semiconductor products described or contained herein in such applications. ■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein. ■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment. ■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design. ■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from theauthorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of MSKSEMI Semiconductor. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI Semiconductor productthat you intend to use. Copyright© Msksemi Incorporated www.msksemi.com
1N4007W 价格&库存
很抱歉,暂时无法提供与“1N4007W”相匹配的价格&库存,您可以联系我们找货
1N4007W
  • 100+0.02300
  • 1000+0.02100
  • 3000+0.01850
  • 9000+0.01650
  • 10000+0.01550
1N4007W
  • 100+0.02700
  • 1000+0.02160
  • 3000+0.01800
  • 9000+0.01590
  • 51000+0.01520
库存:48638
1N4007W
    • 1+0.10637
    • 200+0.03542
    • 1500+0.02211
    • 3000+0.01760
    库存:26206
