IDC
0.8mm
SUR CONNECTOR
Emboss Tape
Disconnectable Insulation displacement connectors
(.031") pitch
Features –––––––––––––––––––––––
• 3-point grip construction
The 3-point insulation grip feature and the strain relief ensure a
firm grip on terminated wires and protection of the insulation
displacement connection from possible damage.
• Super fine wires are applicable
Applicable wire is of AWG #32 with only 0.38mm (.015") O.D.
With this super fine wire, routing of wires is easy."
• Shrouded header
The header is fully shrouded, but remains thin.
• Twin U-slot insulation displacement section
The insulation displacement section connected to each wire
consists of two tin-plated slots (twin U-slots), which ensures
reliable connection.
The world's first 0.8mm (.031") pitch wireto-board insulation displacement
connector. Only 3.9mm (.154") depth and
1.75mm (.069") height after mounting on
the PC board. Compared to the
conventional 1.0mm (.039") pitch SSR
connector, occupation space on the board
is reduced by 34%.
Specifications –––––––––––––––––––
• Current rating: 0.5A AC, DC (AWG #32)
• Voltage rating: 30V DC
• Temperature range: -25˚C to +85˚C(including temperature rise
in applying electrical current)
• Contact resistance: Initial value/20m Ω max.
After environmental testing/40m Ω max.
• Insulation resistance:
100M Ω min.
• Withstanding voltage: 200V AC/minute
• Applicable wire: AWG #32
Conductor/7 strands,
tin-coated copper alloy
Insulation O.D./0.38mm (.015")
* Contact JST for details.
176
SUR
CONNECTOR
Receptacle–––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––
Circuits
2
4
8
Circuit No.1
H JST 5
1.7(.067)
2.9(.114)
0.8
(.031) 0.8
(.031)
A
B
1.25(.049)
1.45(.057)
1.65(.065)
14
15
16
17
Model No.
02SUR-32S
04SUR-32S
08SUR-32S
14SUR-32S
15SUR-32S
16SUR-32S
17SUR-32S
20SUR-32S
Dimensions mm(in.)
A
B
Q'ty / box
0.8(.031)
2.4(.094)
2,000
2.4(.094)
4.0(.157)
2,000
5.6(.220)
7.2(.283)
2,000
10.4(.409)
12.0(.472)
2,000
11.2(.441)
12.8(.504)
2,000
12.0(.472)
13.6(.535)
2,000
12.8(.504)
14.4(.567)
2,000
15.2(.598)
16.8(.661)
2,000
Material and Finish
Contact: Copper alloy, tin-plated
Housing: Polyamide, UL94V-0, natural (ivory)
Shrouded header –––––––––––––––––––––––––––––––––––––––––––––––––––––––––
Circuits
2
4
8
Circuit No.1
B
A
14
15
2.7(.106)
0.8
(.031)
16
1.75(.069)
17
1.0
(.039)
0.2(.008)
Model No.
SM02B-SURS-TF
SM04B-SURS-TF
SM08B-SURS-TF
SM14B-SURS-TF
SM15B-SURS-TF
SM16B-SURS-TF
SM17B-SURS-TF
SM20B-SURS-TF
A
Dimensions mm(in.)
B
Q'ty / reel
0.8(.031)
3.8(.150)
3,500
2.4(.094)
5.4(.213)
3,500
5.6(.220)
8.6(.339)
3,500
10.4(.409)
13.4(.528)
3,500
11.2(.441)
14.2(.559)
3,500
12.0(.472)
15.0(.591)
3,500
12.8(.504)
15.8(.622)
3,500
15.2(.598)
18.2(.717)
3,500
Material and Finish
0.45(.018)
1.0
(.039)
Contact: Copper alloy, copper-undercoated, tin/lead plated
Wafer: Polyamide, UL94V-0, natural (ivory)
Solder tab: Brass, copper-undercoated, tin/lead plated
Note: The products listed above are supplied on embossed-tape.
PC board layout (viewed from component side) and Assembly layout ––––––––––––––––––
0.8 ± 0.1(.031 ± .004)
0.5 ± 0.1(.020 ± .004)
Header outline
0.7 ± 0.1
(.028 ± .004)
1.2 ± 0.1
(.047 ± .004)
1.75(.069)
2.3 ± 0.1 1.0 ± 0.1
(.091 ± .004) (.039 ± .004)
0.35 ± 0.1
(.014 ± .004)
1.7 ± 0.1(.067 ± .004)
3.9(.154)
Note: 1. Tolerances are non-cumulative: ±0.05mm(±.002" ) for all centers.
2. Dimensions above should serve as a guideline. Contact JST for details.
177
SUR
CONNECTOR
Taping specifications ––––––––––––––––––––––––––––––––––––––––––––––––––––––
Feeding direction
Feeding direction
[80(3.150)dia.]
330 ± 2.0 (12.992 ± .079)dia.
Carrier tape
[13.0(.512)dia.]
2.5
W1-+ 1.0
(W1-+ .098
.039 )
Connector
loaded area
Lead tape
20 vacancies min.
400(15.748)min.
Tail tape
40(1.575)min.
2.0 ± 0.5 (0.79 ± .020)
2.0 ± 0.1
4.0 ± 0.1
1.55 ± 0.05
(.061 ± .002)dia. (.157 ± .004) (.079 ± .004)
F ± 0.1(.004)
F ± 0.1(.004)
W ± 0.3(.012)
8.0 ± 0.1
(.315 ± .004)
Carrier tape
0.3 ± 0.05
(.012 ± .002)
Cover tape
S ± 0.1(.004)
W ± 0.3(.012)
0.3 ± 0.05
(.012 ± .002)
Cover tape
1.75 ± 0.1
(.069 ± .004)
(20 circuits)
1.75 ± 0.1
(.069 ± .004)
(2 to 17 circuits)
2.0 ± 0.1
4.0 ± 0.1
1.55 ± 0.05
Cover tape leader area
8.0 ± 0.1
(.315 ± .004)
Circuits
F
Taping dimensions mm(in.)
S
2,4
5.5(.217)
8
7.5(.295)
14 to 17
Carrier tape
W
Reel dimensions mm(in.)
W1
Q'ty / reel
12( .472)
13.5( .531)
3,500
16( .630)
17.5( .689)
3,500
11.5(.453)
24( .945)
25.5(1.004)
3,500
14.2(.559)
28.4(1.118)
32(1.260)
33.5(1.319)
3,500
Note:
1. Specifications conform to JIS C 0806. The tape width, connector recess hole dimensions, etc. are determined by the number of circuits and external shape of
the connector to be loaded.
2. Specifications are subject to change without prior notice.
178
很抱歉,暂时无法提供与“08SUR08SUR32W150”相匹配的价格&库存,您可以联系我们找货
