PushPull
HARTING PushPull Power
HARTING PushPull Power 2/0, type acc. to IEC 61 076-3-106 variant 4
panel feed-through and connector, 3-poles, 250 V / 16 A
Advantages
l
l
Technical characteristics
Power connectors for devices
Locking PushPull Technology
asyInstall panel feed-through for simple device
E
integration
Degree of protection
IP 65 / IP 67
Number of contacts
2 + PE
Electrical data
acc. to EN 61 984
16 A 250 V 4 kV 3
Cable diameter
4.9 ... 8.6 mm
l
Compact, space-saving design
l
Touch-proof according to IEC DIN EN 60 529
Termination Crimp
l
Polarisation with nose
Termination cross section
0.75 - 2.5 mm²
(AWG 20 - 12) stranded
l
Cable side: Male with crimp termination
Mating cycles
min. 750
l
Device side: female with crimp termination
Temperature range
-40 °C … +70 °C
Housing material
Plastic, black
l
4 different coding variants without loss of contact
Identification
Part No.
Flammability acc. to UL 94 V0
Drawing
Dimensions in mm
Panel feed-through set
incl. 3 turned crimp contacts (female) for
1.5 mm², insulation body (black), housing
bulkhead mounting EasyInstall
09 46 245 3430
incl. 3 turned contacts (female) for 1.5 mm²,
insulation body (black), housing bulkhead
mounting, with crimp termination
09 46 245 3410
Power-female with solder termination
angled
09 46 500 3400
Power-female with crimp termination
without contacts
09 46 500 3401
Connector set
incl. 3 turned crimp contacts (male)
for 1.5 mm², insulation body (black),
housing, cable gland
09 46 145 3410
Connector set
without contacts
09 46 145 3411
Coding pin set
to avoid accidental incorrect mating
a coding system is required.
This coding pins are inserted without
loss of contact.
Crimp contacts see page 02.26
Panel cut outs see page 02.04
09 46 840 0000
02
27
PushPull
HARTING PushPull Power 4/0, type acc. to IEC 61 076-3-106 variant 4
connector 4-poles 48 V / 12 A
Advantages
l
l
l
l
l
l
l
E
integration
IP 65 / IP 67
Number of contacts
4
Electrical data
acc. to EN 61 984
12 A 48 V 1.5 kV 3
Cable diameter
4.9 ... 8.6 mm
Termination
Crimp
0.75 - 2.5 mm²
Mating cycles
min. 750
Temperature range
-40 °C … +70 °C
Housing material
Plastic, black
Identification
Part No.
Connector set
incl. 4 turned crimp contacts (male)
for 1.5 mm², insulation body, housing,
cable gland
Connector set
without contacts
09 46 145 4401
Accessories – crimp contacts male
0.75 mm² (AWG 20 - 18)
09 46 500 0403
1.0 mm² (AWG 18)
09 46 500 0407
1.5 mm² (AWG 16 - 14)
09 46 500 0401
2.5 mm² (AWG 12)
09 46 500 0405
Accessories – crimp contacts female
09 46 500 0404
1.0 mm² (AWG 18)
09 46 500 0408
09 46 500 0402
2.5 mm² (AWG 12)
09 46 500 0406
Accessories – Coding pin set
09 46 840 0000
loss of contact.
02
26
1)
09 46 145 4400
09 46 195 44001)
Metal version (without contacts)
Drawing
Dimensions in mm
PushPull
Identification
Tooling
Part No.
8-indent crimping tool incl. positioner
09 46 800 0000
Locator HARTING PushPull Power
contacts for Buchanan crimping tool
(09 99 000 0001)
09 46 800 0010
Insertion tool
09 46 800 0099
Extraction tool
09 46 800 0098
Crimp connection
A perfect crimp connection is gastight, therefore corrosion free
and amounts to a cold weld of the parts being connected. For
reason, major features in achieving high quality crimp
this
connections are the design of the contact crimping parts and
of course the crimping tool itself. Wires to be connected must
atched with the correct size of crimp contacts. If
be carefully m
requirements are met, users will be assured of
these basic
highly reliable connections with low contact resistance and high
resistance to corrosive attack.
The economic and technical advantages are:
● Constant contact resistance as a result of precisely repeated
crimp connection quality
● Corrosion free connections as a result of cold weld action
● Pre-preparation of cable forms with crimp contacts fitted
● Optimum cost cable connection
Requirements for crimp connectors are laid down in DIN IEC
60 352-2, Amend. 2, as illustrated in the table.
Pull out force of stranded wire
The main criterion to judge the quality of a crimp connection is
the retention force achieved by the wire conductor in the terminal
section of the contact. DIN IEC 60 352, part 2, defines the
extraction force in relation to the cross-section of the c onductor.
When fitted using HARTING crimping tools and subject to their
utilization in an approved manner, our crimp connectors comply
with the required extraction forces.
For wire gauges
0.08 … 4.0 mm²
(AWG 28 … 12).
For an easy insertion and
extraction of the male and
female crimp contacts into /
out of the insulator body.
Tensile strength of crimped connections
Conductor cross-section
mm²
AWG
0.08
28
0.12
26
0.14
0.22
24
0.25
0.32
22
0.50
0.82
18
1.00
1.30 16
1.50
2.10 14
2.50
3.30 12
4.00
Extract from DIN IEC 60 352-2, Amend. 2, Table IV
Crimping tools
Crimping tools (hand operated or automatic) are carefully
designed to produce with high pressure forming parts a
symmetrical connection of the crimping part of the contact and
the wire being connected with the minimum increase in size at
the
connection point. The positioner automatically locates the
crimp and wire at the correct point in the tool.
A ratchet in the tool performs 2 functions:
➀ It prevents insertion of the crimp into the tool for crimping
before the jaws are fully open
➁ It prevents the tool being opened before the crimping action is
completed
02
28
Identical, perfectly formed, connections can be produced using
this crimping system.
Tensile strength
Crimp-cross section
HARTING crimp profile
N
11
15
18
28
32
40
60
85
90
108
135
150
200
230
275
310
很抱歉,暂时无法提供与“09 46 500 0405”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 85+5.45598
- 250+5.23439
- 900+5.01279
- 国内价格 香港价格
- 95+11.3838795+1.47281
- 国内价格 香港价格
- 95+11.1887295+1.44756
